.desktop file not working
I'm really liking st and have installed st-luke-git. It works from the terminal if I write st but I just cannot get the .desktop file to work. Neither can I get it to launch using ctrl+alt+t as the default terminal. The .desktop file is located at /usr/share/applications/st.desktop with the contents:
[Desktop Entry]
Name=Suckless Terminal
#GenericName=Terminal
Comment=suckless terminal emulator for the X window system
Exec=st
Terminal=false
Type=Application
Icon=st-color_48x48
Categories=System;TerminalEmulator;
Keywords=shell;prompt;command;commandline;cmd;
What should I do now?
Try ~/.local/share/applications/
Doesn't work. Exact same file works if I replace Exec=st with Exec=konsole for example.
Work
$ st-luke
or st-luke-git?
Try putting the whole path in the Exec= line.
No. They don't work.
Tried putting Exec=/usr/bin/st but didn't help.
which st
What advantages does st-luke-git have over the sterminal community package?
One thing to notice though. If I put st-luke or st-luke-git, an error pops up but in the case of only st or the full address, there's no such thing.
There's transparency, solarized theme, infinite scroll etc. added.
which st =?
name in /usr/bin/ is "st" ?
Can not install
[ st-manjaro]
I don't understand what you're saying.
I can't install it on me because of dependencies. But ask here for it https://github.com/LukeSmithxyz/st
Okay. I'll try asking there. Do you know of any other fork of st with at least transparency and scrolling patched in?
This works for me:
[Desktop Entry]
Version=1.0
Name=stluke
Exec=st
Icon=utilities-terminal
Terminal=false
Type=Application
Proof:
It appears for me too. But doesn't launch the program.
Actually, st-luke is not a bad find @Chrysostomus might be interested in it.
Better configured out of the box than stmanjaro, but it would take me a lot of persuasion to dump sakura.
Well that is bizarre, works fine here.
Is it possible to launch a .desktop file from terminal? Maybe it's throwing some error? Or maybe it's permissions or something?
No, desktop files do not launch from a terminal, they are descriptive files for a gui launcher.
Did you try my version?
