Desktop effects: Invert?
Can I do it in a window like KMAG put stuff in a window?
If you activate Invert in System Settings → Window Management → Desktop Effects, then Meta+Ctrl+U will toggle the invert effect on individual windows.
To toggle invert for the entire desktop, use Meta+Ctrl+I.
Thanks, can I jusr do a sexrion of the screen? Like how KMAG shows a area under the curser?
