Desktop destroyed
Hello, I started my laptop and see, my desktop is destroyed. I doesn’t load bg image, the windows are fixed at the corner, I can’t close windows because the program bars disappeared… I can’t click any thing cuz the mouse is just an X. Didn’t see this before. I didn’t change anything at the system and I didn’t update anything. What can I do?
Please help me. It’s urgent and I have very important data on my desktop!
Thx
Can’t post screenshot links, can’t upload. It’s so stupid sorry. So unfortunately I can’t provide pictures l.
This sounds strange if its really xfce. Could it be that you choose a different ‘Desktop Enviorment’ at your Login screen?
This sounds like a Tiling Manager (i3, Sway or Awesome). :slightly_smiling_face:
inxi -Fazy | curl -F 'file=@-' https://0x0.st
Do you still have all necessary packages installed?
pacman -Qsq xfce
Ctrl+Q should work with most applications.
You could check your drive status. If no warning shows up, your data should be fine.
Hello @Yzga and welcome :wink:
Easy and simple fix: Create a new user account.
  1. Switch to another TTY: CTRL+ALT+F3
  2. Login there
  3. Run: sudo systemctl isolate rescue and type blindly the root password + ENTER
  4. Create a new user account:
useradd -m newusername
  1. Create a new password: passwd newusername and type blindly the user password + ENTER
  2. Close the rescue mode:
exit
  1. Restart the display-manager:
sudo systemctl restart display-manager
  1. Login with the new username.
When it is running again normally. You can move your files from the other account.
If that does not help… I would rather think that the HDD or Filesystem is damaged.
Welcome to the forum! :wave:
Your topic title is not appropriate. Please edit it with something more descriptive of the problem and remove the exaggerated cry for help.
Please see:
Thx to all
Step 0 didn’t work. It doesn’t happen anything
StrG q doesn’t work.
Don’t know what’s happening here
I think my hdd is OK
Hi,
Would you please explain This command after the pipe, what it is supposed to do??
Thanks
inxi -Fazy | curl -F ‘file=@-’ https://0x0.st
title edited
