Wacom tablet frequently crashes Gnome desktop
In the past year Manjaro + Gnome + Xorg + Wacom + Krita worked swimmingly, but since the 2023-11-06 update, I have not had a stable drawing experience. The culprit seems to be Gnome+Xorg, because drawing works reasonably well in KDE Plasma, less so in Wayland.
To be certain that no weird configurations were causing this, I did a fresh install of the whole OS. The problem persisted under Xorg, even with the most recent 2023-11-20 update.
Xorg: Using the tablet, if I hover over the dash or certain other places, GUI crashes to the “Oh no! :[” screen. Going to Settings > Wacom and clicking “Map buttons” reliably causes this crash after a second’s pause.
Wayland: No GUI crashes as of yet, and works fine initially, but as the session goes on and I switch between multiple windows (e.g. Krita, OBS, Firefox), the cursor will get “stuck” in resize mode or turn invisible. When stuck, I can move the cursor around freely using either the tablet or mouse, but clicks and taps have no effect in certain windows even if they’re in focus, and even if I close and reopen them. The only way to reliably fix this is to restart but the problem eventually returns with time.
Inxi is below and I can provide the crash logs if needed.
I would love to get drawing working again in EITHER Xorg or Wayland. Any help is appreciated.
Inxi data
Kernel: 6.1.62-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=99bd297e-f1cd-4842-90c0-abcc10e4fc2d rw quiet splash
resume=UUID=616042a5-bf27-4400-a874-159e6ad2a1df udev.log_priority=3
Desktop: GNOME v: 45.1 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 45.0.1
Type: Desktop System: Micro-Star product: MS-7C37 v: 3.0
serial:
Mobo: Micro-Star model: X570-A PRO (MS-7C37) v: 3.0
serial: UEFI: American Megatrends v: H.A0
date: 09/07/2020
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
serial: charge: 55% (should be ignored) rechargeable: yes
status: discharging
Device-2: wacom_battery_0 model: Wacom Intuos Pro M serial: N/A charge: 0%
status: not charging
System RAM: total: 16 GiB available: 15.54 GiB used: 3.82 GiB (24.6%)
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 2966 high: 3601 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
3: 2200 4: 3599 5: 3600 6: 3601 7: 3600 8: 3600 9: 2200 10: 3598 11: 2995
12: 2200 bogomips: 86437
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spec_rstack_overflow mitigation: safe RET
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-2,HDMI-A-1 off: DP-3 empty: DP-1 bus-ID: 2f:00.0
chip-ID: 1002:731f class-ID: 0300
Device-2: Valve 3D Camera driver: uvcvideo type: USB rev: 3.2 speed: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-3.1:3 chip-ID: 28de:2400 class-ID: 0e02
serial:
Display: wayland server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
Monitor-1: DP-2 pos: right res: 1920x1080 hz: 60 dpi: 92
size: 530x300mm (20.87x11.81") diag: 609mm (23.98") modes: N/A
Monitor-2: HDMI-1 pos: primary,left res: 1920x1080 hz: 60 dpi: 92
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5700 XT (navi10 LLVM
16.0.6 DRM 3.49 6.1.62-1-MANJARO) device-ID: 1002:731f memory: 7.81 GiB
unified: no display-ID: :0.0
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 2f:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI X570-A PRO
bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Valve VR Radio driver: cdc_acm,hid-generic,usbhid type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-3.3.2:6
chip-ID: 28de:2102 class-ID: 0a00 serial:
Device-4: Valve VR Radio & HMD Mic driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-3.3.3:7
chip-ID: 28de:2102 class-ID: 0102 serial:
Device-5: Logitech Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-4:3
chip-ID: 046d:0ab9 class-ID: 0300 serial:
API: ALSA v: k6.1.62-1-MANJARO status: kernel-api tools: N/A
Server-3: PipeWire v: 0.3.85 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
Local Storage: total: 1.14 TiB used: 182.69 GiB (15.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 500GB
tech: SSD serial: fw-rev: CB6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
tech: SSD serial: fw-rev: 1B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: fw-rev: 4B6Q scheme: GPT
ID-1: / raw-size: 223.79 GiB size: 219.22 GiB (97.96%)
used: 43.13 GiB (19.7%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: 99bd297e-f1cd-4842-90c0-abcc10e4fc2d
used: 25.5 MiB (8.5%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: N/A
uuid: EF2B-78A9
ID-3: /mnt/sda1 raw-size: 139.8 GiB size: 136.55 GiB (97.67%)
used: 27.92 GiB (20.4%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Bus
uuid: 95e35971-d640-4955-b2f9-c9591a8e4f36
ID-4: /mnt/sda2 raw-size: 325.96 GiB size: 319.78 GiB (98.10%)
used: 111.61 GiB (34.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
label: Bartimaeus uuid: abea8636-ef53-43f6-a01e-cfe47de973b4
ID-1: swap-1 type: partition size: 8.8 GiB used: 5.2 MiB (0.1%)
priority: -2 dev: /dev/sdc3 maj-min: 8:35 label: swap
uuid: 616042a5-bf27-4400-a874-159e6ad2a1df
ID-1: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs:
label: N/A uuid: N/A
ID-2: /dev/sdb2 maj-min: 8:18 size: 465.75 GiB fs: ntfs label: N/A
uuid: E27EF5C87EF5960F
Device-1: 1-1:2 info: Dell USB Wired Multimedia Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 413c:2112 class-ID: 0300
Device-2: 1-2:3 info: Wacom PTH-651 [Intuos pro (M)] type: HID,mouse
driver: usbhid,wacom interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 498mA chip-ID: 056a:0315 class-ID: 0301
Device-3: 1-5:4 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-1:2 info: PowerA Xbox Series X En Wired Controller Black Inline
type: driver: xpad interfaces: 2 rev: 2.0
chip-ID: 20d6:2001 class-ID: ff00 serial:
Device-2: 3-5:3 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c37 class-ID: 0300
serial:
Hub-4: 3-6:4 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-7: 5-3:2 info: Valve ports: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 2mA chip-ID: 28de:2613 class-ID: 0900
Hub-8: 5-3.3:4 info: Microchip (formerly SMSC) Hub ports: 5 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0424:2744
Device-1: 5-3.3.1:5 info: Valve Index HMD type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 28de:2300 class-ID: 0300
serial:
Device-2: 5-3.3.2:6 info: Valve VR Radio
type: HID,abstract (modem),CDC-data driver: cdc_acm,hid-generic,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
Device-3: 5-3.3.3:7 info: Valve VR Radio & HMD Mic type: HID,audio
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 28de:2102
Device-4: 5-3.3.5:8 info: Microchip (formerly SMSC) Hub Controller
type: Hub driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 chip-ID: 0424:2740 class-ID: 0000
Device-5: 5-4:3 info: Logitech Blue Snowball type: audio,HID
Hub-9: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-10: 6-3:2 info: Microchip (formerly SMSC) Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0424:5744
Device-1: 6-3.1:3 info: Valve 3D Camera type: video driver: uvcvideo
interfaces: 2 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
power: 800mA chip-ID: 28de:2400 class-ID: 0e02 serial:
System Temperatures: cpu: 51.5 C mobo: N/A gpu: amdgpu temp: 33.0 C
mem: 34.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 808
Processes: 317 Uptime: 7h 9m wakeups: 0 Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 16.0.6 Packages: pm: pacman pkgs: 1332 libs: 476
tools: gnome-software,pamac Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.31
Take a look here:
Is xf86-input-wacom installed and configured?
Found that thread earlier, and it was closest to what I was experiencing. I dug a little from there and tried some of the ideas prior to the fresh install.
For me on this install, xf86-input-wacom was already installed. I uninstalled, reinstalled, restarted, chose Xorg, went to settings > wacom, “Map buttons”, still crashed. Also cannot reliably draw, getting the same “stuck cursor” behavior as on Wayland.
One idea I came across and tried before doing a wipe and fresh install was renaming /usr/share/X11/xorg.conf.d/70-wacom.conf to a different number. I look in the folder and notice now it’s called 30-wacom.conf . If I understand correctly this should apply earlier than 40-libinput.conf (which is what seems to cause the errors), but tried just now and xorg crashed when I hovered tablet pen over the dock.
Edit: Also, I do not use or need the tablet buttons, but I think being able to select “map buttons” without a crash would be good indicator.
Having a look at the end of that thread, this looks promising: Fix tablets on X11 having the wrong device (!3393) · Merge requests · GNOME / mutter · GitLab
I’m not familiar with the whole ecosystem, but I’m hoping the next update fixes the problem. Nothing to do but wait around until then I suppose.
I discovered the Wayland trouble might have to do with the number of windows open at once. More windows seems to increase the likelihood of the cursor getting stuck in the way I described.
The most recent Manjaro update appears to have fixed the problem. Under Xorg, I did some drawing, hovered over the dock, and was able to open “Map Buttons” in the wacom settings, all with no issues so far.
