Dependency issues when performing an update
I get this error when running sudo pacman -Syyu. I searched this issue
Installing nvidia-utils (570.133.07-1) breaks dependency 'nvidia-utils=550.144.03' required by linux612-nvidia
Mod edit:- Please avoid pasting long and unwieldly error messages as a topic title. The message has now been inserted immediately above and the topic title changed.
and found previous topics here, here, and here but they all were using EOL kernels, whereas I am using the newest LTS 6.12 kernel. Here is the output of inxi -F:
  Kernel: 6.12.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=7d66d280-12dc-4ccd-a43d-3f2eaafe3ab5 rw quiet splash
    resume=UUID=f0d8855b-ef18-40e4-bf50-9eda255ef382 udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.11.0
  Type: Desktop System: Gigabyte product: B550M AORUS ELITE v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: B550M AORUS ELITE v: x.x
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: FB date: 11/14/2022
  System RAM: total: 32 GiB available: 31.27 GiB used: 7.44 GiB (23.8%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
    part-no: F4-3200C16-16GIS serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 5 5600 bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
    desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3593 min/max: 550/4468 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3593 2: 3593 3: 3593
    4: 3593 5: 3593 6: 3593 7: 3593 8: 3593 9: 3593 10: 3593 11: 3593 12: 3593
    bogomips: 83878
    stibp succor svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
    v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
    wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    xtopology
    affected
  Device-1: NVIDIA GA102 [GeForce RTX 3080] vendor: ASUSTeK driver: nvidia
    v: 550.144.03 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
    status: current (as of 2025-01; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 05:00.0 chip-ID: 10de:2206 class-ID: 0300
  Device-2: Logitech Webcam C310 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 046d:081b
    class-ID: 0102 serial: <filter>
  Device-3: Microdia Dual Mode Camera (8006 VGA) driver: hid-generic,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2
    chip-ID: 0c45:8006 class-ID: 0301
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia gpu: nvidia
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4480x1440 s-dpi: 92 s-size: 1237x402mm (48.70x15.83")
    s-diag: 1301mm (51.21") monitors: <missing: xrandr>
  Monitor-1: Unknown-1 size-res: N/A modes: 1024x768
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
    drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia v: 550.144.03 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
    memory: 9.77 GiB
  API: Vulkan v: 1.4.304 layers: 5 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 3080 driver: N/A device-ID: 10de:2206
    surfaces: xcb,xlib
    wl: wayland-info x11: xdpyinfo,xprop
  Device-1: NVIDIA GA102 High Definition Audio vendor: ASUSTeK
    bus-ID: 05:00.1 chip-ID: 10de:1aef class-ID: 0403
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 07:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: HP HyperX Cloud III driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2
    chip-ID: 03f0:089d class-ID: 0300 serial: <filter>
  Device-4: Logitech Webcam C310 driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k6.12.19-1-MANJARO status: kernel-api with: aoss
  Server-1: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
    lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IP v6: <filter> scope: link
  IF-ID-1: docker0 state: down mac: <filter>
  Local Storage: total: 931.51 GiB used: 679.52 GiB (72.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G
    lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02103 temp: 37.9 C
    scheme: GPT
  ID-1: / raw-size: 896.82 GiB size: 881.67 GiB (98.31%)
    used: 679.45 GiB (77.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 7d66d280-12dc-4ccd-a43d-3f2eaafe3ab5
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 71D8-2AA1
  ID-1: swap-1 type: partition size: 34.39 GiB used: 71 MiB (0.2%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: f0d8855b-ef18-40e4-bf50-9eda255ef382
  Device-1: 1-4:2 info: HP HyperX Cloud III type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
  Device-2: 1-6:3 info: Logitech Webcam C310 type: video,audio
    chip-ID: 046d:081b class-ID: 0102 serial: <filter>
  Device-3: 1-10:4 info: Integrated Express RGB LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-1: 3-1:2 info: Microdia Dual Mode Camera (8006 VGA)
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
  Device-2: 3-2:3 info: SteelSeries ApS Rival 5 type: HID,mouse
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 200mA chip-ID: 1038:183c class-ID: 0300
  System Temperatures: cpu: 44.8 C mobo: 34.0 C gpu: nvidia temp: 42 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 53%
  Packages: 1949 pm: pacman pkgs: 1892 libs: 442 tools: pamac,yay pm: flatpak
    pkgs: 30 pm: snap pkgs: 27
    1: https://manjaro.kurdy.org/stable/$repo/$arch
    2: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    3: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    4: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    5: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    6: https://manjaro.ynh.ovh/stable/$repo/$arch
    7: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    8: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    9: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    10: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    11: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    12: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    13: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    14: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    15: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    16: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    17: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    18: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    19: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    20: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    21: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    22: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    23: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    24: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    25: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    26: https://mirror.init7.net/manjaro/stable/$repo/$arch
    27: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    28: https://mirror.23m.com/manjaro/stable/$repo/$arch
    29: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    30: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    31: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    32: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    33: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    34: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    35: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    36: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    37: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    38: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    39: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    40: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    41: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    42: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    43: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    44: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    45: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    46: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    47: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    48: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    49: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    50: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    51: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    52: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 343
  1: cpu: 25.3% command: firefox pid: 1777 mem: 803.3 MiB (2.5%)
  2: cpu: 18.2% command: baloo_file pid: 1398 mem: 54.3 MiB (0.1%)
  3: cpu: 14.6% command: Discord pid: 2727 mem: 408.2 MiB (1.2%)
  4: cpu: 13.4% command: electron pid: 3698 mem: 1005.6 MiB (3.1%)
  5: cpu: 12.5% command: slack pid: 3751 mem: 406.5 MiB (1.2%)
  Memory top: 5 of 343
  1: mem: 1005.6 MiB (3.1%) command: electron pid: 3698 cpu: 13.4%
  2: mem: 803.3 MiB (2.5%) command: firefox pid: 1777 cpu: 25.3%
  3: mem: 437.9 MiB (1.3%) command: plasmashell pid: 1466 cpu: 3.3%
  4: mem: 411.0 MiB (1.2%) command: firefox pid: 3437 cpu: 5.5%
  5: mem: 408.2 MiB (1.2%) command: Discord pid: 2727 cpu: 14.6%
  Processes: 343 Power: uptime: 2m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 13 Shell: Zsh v: 5.9
    default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
This issue occurred after I had removed the community repo from pacman.conf as according to https://archlinux.org/news/cleaning-up-old-repositories/ and tried updating my system. I initially also got the error installing nvidia-utils (570.133.07-1) breaks dependency 'nvidia-utils=550.144.03' required by linux66-nvidia which went away after I ran sudo pacman -R linux66-nvidia but did not want to do the same to the linux612-nvidia package in case it broke something important. Any advice on how to handle this?
sudo mhwd-kernel --listinstalled gives
   * linux612
   * linux66
The command to perform a sync/update is;
sudo pacman -Syu
(note the single “y”).
Only use another variation of the command if you are instructed to, or if you understand the ramifications of using it.
Your system information is incomplete. :eyes:
Please edit your post above and paste the full inxi output as described (below).
I’m sure someone will offer assistance when they are able.
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Required reading
Resources
Try refreshing your mirrors:
sudo pacman-mirrors --continent
Then see if you can update:
sudo pacman -Syu
Version 570.133.07-3 of linux612-nvidia is definitely in the Stable repo, as well as version 570.133.07-2 of nvidia-utils:
mbn info linux612-nvidia -q | grep -Ev 'Name|Repository|Packager'
Branch         : unstable
Version        : 570.133.07-4
Build Date     : Sat 29 Mar 2025 19:09:32
Branch         : testing
Branch         : stable
Version        : 570.133.07-3
Build Date     : Mon 24 Mar 2025 19:37:03
mbn info nvidia-utils -q | grep -Ev 'Name|Repository|Packager'
Branch         : archlinux
Version        : 570.133.07-1
Build Date     : Fri 21 Mar 2025 06:53:17
Branch         : unstable
Version        : 570.133.07-2
Build Date     : Thu 20 Mar 2025 03:37:45
Branch         : testing
Branch         : stable
mbn can be found in the manjaro-check-repos package
Because Nvidia is now 570 - the nvidia 550xx has moved to AUR.
This will cause problems with a kernel depending on nvidia 550
Use mhwd-kernel to remove linux66 before updating
mhwd-kernel -r linux66
I cannot say if this is enough …
Thank you, I have now updated the original post’s command output with the full output from inxi -zv8.
I removed the kernel as instructed, rebooted, and tried to run sudo pacman -Syu. I still get the same error. (I have updated the original post with a more complete inxi output).
I refreshed mirrors as instructed and tried to run the update command. I still get the same issue.
Please run sudo pacman -Syu again and post the complete output, from start to finish, here.
Here you go:
:: Synchronising package databases...
 core is up to date
 extra is up to date
 multilib is up to date
warning: base: local (3-3) is newer than core (3-2)
warning: base-devel: local (1-3) is newer than core (1-2)
warning: filesystem: local (2024.11.25-2) is newer than core (2024.11.21-1)
warning: mkinitcpio: local (39.2-4) is newer than core (39.2-3)
warning: pacman: local (7.0.0.r10.ga2d0293-1) is newer than core (7.0.0.r6.gc685ae6-2)
resolving dependencies...
:: installing nvidia-utils (570.133.07-1) breaks dependency 'nvidia-utils=550.144.03' required by linux612-nvidia
That is unusual. Are you somehow using Arch repos instead of Manjaro’s? Because it is saying that the versions on the mirror are older than the installed versions, and Arch is behind Manjaro on base, base-devel, filesystem, mkinitcpio & pacman:
mbn info base -q | grep -Ev 'Name|Repository|Packager'
Branch         : archlinux
Version        : 3-2
Build Date     : Sun 08 Oct 2023 12:15:41
Branch         : unstable
Version        : 3-3
Build Date     : Fri 14 Jun 2024 01:48:03
Branch         : testing
Version        : 3-3
Branch         : stable
Version        : 3-3
mbn info base-devel -q | grep -Ev 'Name|Repository|Packager'
Branch         : archlinux
Version        : 1-2
Build Date     : Sat 07 Sep 2024 05:08:35
Branch         : unstable
Version        : 1-3
Build Date     : Fri 14 Jun 2024 01:49:35
Branch         : testing
Version        : 1-3
Branch         : stable
Version        : 1-3
mbn info filesystem -q | grep -Ev 'Name|Repository|Packager'
Branch         : archlinux
Version        : 2024.11.21-1
Build Date     : Thu 21 Nov 2024 19:56:21
Branch         : unstable
Version        : 2024.11.25-2
Build Date     : Tue 03 Dec 2024 09:33:51
Branch         : testing
Branch         : stable
mbn info mkinitcpio -q | grep -Ev 'Name|Repository|Packager'
Branch         : archlinux
Version        : 39.2-3
Build Date     : Thu 19 Dec 2024 07:54:45
Branch         : unstable
Version        : 39.2-4
Build Date     : Thu 19 Dec 2024 09:07:39
Branch         : testing
Version        : 39.2-4
Branch         : stable
Version        : 39.2-4
mbn info pacman -q | grep -Ev 'Name|Repository|Packager'
Branch         : archlinux
Version        : 7.0.0.r6.gc685ae6-2
Build Date     : Sat 22 Feb 2025 04:02:11
Branch         : unstable
Version        : 7.0.0.r10.ga2d0293-1
Build Date     : Sun 27 Oct 2024 17:15:28
Branch         : testing
Branch         : stable
Edit: I see in your inxi output that your mirrors all do seem to be correct. Maybe you need to wipe the databases & re-download them. So, this time, try updating with the extra “y” to force a refresh:
sudo pacman -Syyu
If that doesn’t work, then manually remove the databases:
sudo rm /var/lib/pacman/sync/*
and then run
sudo pacman -Syu
Thank you, manually removing the databases and then updating solved the issue! Still not sure what happened…
