When booting up, I get a couple of black screen flashes with the title message.
sudo systemctl --failed returns
UNIT LOAD ACTIVE SUB DESCRIPTION
● dev-disk-by\x2duuid-b25981f7\x2d0a68\x2d4ca5\x2db998\x2d91e9e4290033.swap loaded failed failed /dev/disk/by-uuid/b25981f7-0a68-4ca5-b998-91e9e4290033
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
1 loaded units listed.
/etc/fstab contents
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=EEFA-C9C4 /boot/efi vfat umask=0077 0 2
UUID=324426ca-5875-4818-97b8-d4413b765086 / ext4 defaults,noatime 0 1
UUID=b25981f7-0a68-4ca5-b998-91e9e4290033 swap swap defaults,noatime 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
I’ve read the thread Failed to activate swap - On boot, but still not sure what to do for my specific issue.
Can anyone provide some input on solving this please? Tyvm.
