dependence of system tray using stalonetray on battery status
Hello all,
I have seen stalonetray is a recommended way to put tray icons both in the forum and default limepanel configuration.
I am using it to show the nm-applet (I need it for connect to eduroam).
Everything looks OK, but if my battery is let say less than 30% the nm-pallet icon does not appear in the limepanel.
I went through the configuration and I can not see any dependence on the Battery status. Am I right?
My distro: bspwm-minimal
Thanks!
I figured out the solution myself. Maybe it is not an elegant way but It works:
I cut two lines from if [ "$systemtray" -eq 1 ]; then block from my $HOME/.bin/mypanel file and paste it at the end of mypanel just before the wait command.
Here is the tail of the modified mypanel file now. It will show nm-applet all the time. Calling stalonetray and top_padding are those which cut from the above if block.
       | while read line; do eval "$line"; done &
    sleep 0.2 && stalonetray &
    sleep 0.3 && bspc config top_padding $((panel_height-gap)) &
    sleep 2.0 && nm-applet &
fi
wait
