After update my external monitor screen stays black. Laptop screen is ok.
usb-c cable is used to connect Dell XPS to monitor.
inxi -Fxxxz
System: Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: GNOME 3.38.2 tk: GTK 3.24.24
wm: gnome-shell dm: GDM 3.38.2 Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: XPS 15 9570 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Dell model: 07GHH0 v: A00 serial: <filter> UEFI: Dell v: 1.16.2 da…
inxi -Fxxxz
Mobo: Dell model: 07GHH0 v: A00 serial: <filter> UEFI: Dell v: 1.16.2 date: 04/21/2020
Battery: ID-1: BAT0 charge: 75.8 Wh condition: 75.8/97.0 Wh (78%) volts: 12.6/11.4 model: SMP DELL GPM0365 type: Li-ion
serial: <filter> status: Full
CPU: Info: 6-Core model: Intel Core i9-8950HK bits: 64 type: MT MCP arch: Kaby Lake note: check rev: A L2 cache: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 69629
Speed: 800 MHz min/max: 800/4800 MHz Core speeds (MHz): 1: 800 2: 801 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
9: 800 10: 800 11: 800 12: 801
Graphics: Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] driver: nvidia v: 450.80.02 bus ID: 01:00.0 chip ID: 10de:1c8c
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 1-12:5 chip ID: 0c45:671d
Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver: intel resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.1 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:a348
Sound Server: ALSA v: k5.9.16-1-MANJARO
Network: Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Bigfoot Networks driver: ath10k_pci
v: kernel port: 3000 bus ID: 3b:00.0 chip ID: 168c:003e
IF: wlp59s0 state: up mac: <filter>
Device-2: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb bus ID: 1-4:3 chip ID: 0cf3:e300
IF-ID-1: docker0 state: down mac: <filter>
Drives: Local Storage: total: 953.87 GiB used: 122.89 GiB (12.9%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: KXG50ZNV1T02 NVMe 1024GB size: 953.87 GiB speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: AADA4105 temp: 28.9 C
Partition: ID-1: / size: 937.6 GiB used: 122.89 GiB (13.1%) fs: ext4 dev: /dev/dm-0
mapped: luks-c8a7d716-b5e6-4dfa-a804-3273dc7b8c77
ID-2: /boot/efi size: 299.4 MiB used: 440 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 42.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2501 fan-2: 2496
Info: Processes: 331 Uptime: 1h 23m wakeups: 21 Memory: 30.99 GiB used: 6.44 GiB (20.8%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: 1359 pacman: 1345 flatpak: 14 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.2.01
mhwd --listinstalled
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
Edit.
phush0
31 December 2020 11:35
2
there is no nvidia driver installed on your system: sudo mhwd -a pci nonfree 0300
Yeah, did not install nvidia driver as I have been able to get by with Intel gpu as I want to have longer battery life. This setup has worked before.
(troubleshooting continues next year…)
Latest update fixed this issue. Now my external monitor shows picture.
Kernel was changed from Kernel: 5.9.16-1-MANJARO to Kernel: 5.10.2-2-MANJARO
Or maybe it was something else?
System: Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: GNOME 3.38.2
tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1 Distro: Manjaro Linux
serial: <filter>
Battery: ID-1: BAT0 charge: 67.6 Wh condition: 75.8/97.0 Wh (78%) volts: 12.8/11.4
model: SMP DELL GPM0365 type: Li-ion serial: <filter> status: Charging
Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming Mouse
serial: <filter> charge: 100% (should be ignored) rechargeable: yes status: Discharging
Speed: 800 MHz min/max: 800/4800 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800
6: 801 7: 800 8: 800 9: 799 10: 800 11: 800 12: 800
chip ID: 8086:3e9b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell driver: N/A
chip ID: 0c45:671d
Display: wayland server: X.org 1.20.10 compositor: gnome-shell driver: intel
direct render: Yes
bus ID: 00:1f.3 chip ID: 8086:a348
Sound Server: ALSA v: k5.10.2-2-MANJARO
vendor: Bigfoot Networks driver: ath10k_pci v: kernel port: 3000 bus ID: 3b:00.0
chip ID: 168c:003e
chip ID: 0cf3:e300
Drives: Local Storage: total: 953.87 GiB used: 122.22 GiB (12.8%)
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: AADA4105 temp: 25.9 C
Partition: ID-1: / size: 937.6 GiB used: 122.22 GiB (13.0%) fs: ext4 dev: /dev/dm-0
Sensors: System Temperatures: cpu: 59.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2487 fan-2: 2531
Info: Processes: 309 Uptime: 12m wakeups: 10 Memory: 30.99 GiB used: 4.02 GiB (13.0%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: 1360 pacman: 1346 flatpak: 14
Still did not install Nvidia driver.
system
Closed
19 January 2021 06:45
5
