libvirtd.service always dies within two minutes after start:
Aug 06 14:07:38 user-notebook systemd[1]: Starting Virtualization daemon...
Aug 06 14:07:38 user-notebook systemd[1]: Started Virtualization daemon.
Aug 06 14:09:38 user-notebook systemd[1]: libvirtd.service: Deactivated successfully.
Aug 06 14:12:03 user-notebook systemd[1]: Starting Virtualization daemon...
Aug 06 14:12:03 user-notebook systemd[1]: Started Virtualization daemon.
Aug 06 14:14:03 user-notebook systemd[1]: libvirtd.service: Deactivated successfully.
Aug 06 14:25:44 user-notebook systemd[1]: Starting Virtualization daemon...
Aug 06 14:25:44 user-notebook systemd[1]: Started Virtualization daemon.
Aug 06 14:27:44 user-notebook systemd[1]: libvirtd.service: Deactivated successfully.
I’ve discovered this when I was investigating issue of Android emulator being extremely slow, and what’s worse making the machine itself laggy to the point of being unusable. I suspect that these two issues might be connected.
I pretty confident that emulator was quite fast when I installed Manjaro a few years ago, but I don’t use emulator often enough to pinpoint when it has changed.
❯ lsmod | grep kvm
kvm_intel 364544 0
kvm 1089536 1 kvm_intel
irqbypass 16384 1 kvm
❯ ./emulator -accel-check
accel:
0
KVM (version 12) is installed and usable.
accel
❯ LC_ALL=C lscpu | grep Virtualization
Virtualization: VT-x
❯ inxi -Fxz
Kernel: 5.15.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
Desktop: KDE Plasma v: 5.24.6 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Inspiron 7590 v: N/A
serial:
Mobo: Dell model: 0JKGD4 v: A00 serial: UEFI: Dell
v: 1.6.0 date: 02/07/2020
ID-1: BAT0 charge: 66.5 Wh (100.0%) condition: 66.5/97.0 Wh (68.6%)
volts: 12.7 min: 11.4 model: LGC-LGC8.33 DELL 5XJ2803 status: full
Device-1: hid-c8:47:8c:0f:4f:45-battery model: ELECOM BlueLED Mouse
charge: N/A status: discharging
Info: 6-core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Coffee Lake rev: A cache: L1: 384 KiB L2: 1.5 MiB L3: 12 MiB
Speed (MHz): avg: 900 min/max: 800/4500 cores: 1: 900 2: 900 3: 900
4: 900 5: 900 6: 900 7: 900 8: 900 9: 900 10: 900 11: 900 12: 900
bogomips: 62431
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
driver: i915 v: kernel arch: Gen-9.5 bus-ID: 00:02.0
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 515.57 arch: Turing bus-ID: 01:00.0
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:2
Display: x11 server: X.Org v: 21.1.4 driver: X:
loaded: modesetting,nvidia unloaded: nouveau gpu: i915 resolution:
1: 1920x1080~60Hz 2: N/A
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa
22.1.4 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell
driver: sof-audio-pci-intel-cnl bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.15.55-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.56 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3
IF: wlo1 state: up mac:
IF-ID-1: docker0 state: down mac:
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:4
Local Storage: total: 1.38 TiB used: 695.38 GiB (49.4%)
ID-1: /dev/nvme0n1 vendor: Crucial model: CT1000P1SSD8 size: 931.51 GiB
temp: 40.9 C
ID-2: /dev/nvme1n1 vendor: Toshiba model: KBG40ZNS512G NVMe KIOXIA 512GB
size: 476.94 GiB temp: 40.9 C
ID-1: / size: 97.87 GiB used: 50.91 GiB (52.0%) fs: ext4 dev: /dev/dm-0
mapped: luks-d09ef76c-f144-4d87-bf9e-bcb2c5b3eb8b
ID-2: /boot/efi size: 511 MiB used: 456 KiB (0.1%) fs: vfat
dev: /dev/nvme1n1p5
ID-3: /home size: 239.02 GiB used: 156.47 GiB (65.5%) fs: ext4
dev: /dev/dm-1 mapped: luks-2ab4ae21-185e-45d8-a6c5-c9cfe3cbda08
ID-1: swap-1 type: file size: 10 GiB used: 2.51 GiB (25.1%) file: /swapfile
System Temperatures: cpu: 57.0 C pch: 64.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3478 fan-2: 3069
Processes: 433 Uptime: 11d 16h 34m Memory: 15.41 GiB used: 6.43 GiB (41.7%)
Init: systemd Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: 1815
Shell: Zsh v: 5.9 inxi: 3.3.20
