Dell Inspiron 5559 TouchPad problems
xfce
touchpad
#1
Hello Everyone.
I have a Dell Inspiron 5559 with some random touchpad problems. I’m using Manjaro 18 Xfce with all the latest updates.
Problem #1: The touchpad on occasion only right clicks, no matter which side of the touchpad I click. A reboot fixes the problem, until it happens again.
Problem #2: The touchpad stops working and I can only navigate via keyboard only. A reboot fixes the problem, until it happens again.
What are my options here, if any?
If one of my options is using an external mouse, which brand and model do you recommend?
Thanks.
inxi -Fxxxz:
System:    Host: darthknight Kernel: 4.19.20-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1
           Desktop: Xfce 4.13.2git-UNKNOWN tk: Gtk 3.24.3 info: xfce4-panel wm: xfwm4 dm: LightDM 1.28.0
           Distro: Manjaro Linux
Machine:   Type: Laptop System: Dell product: Inspiron 5559 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
           Mobo: Dell model: 052K07 v: A00 serial: <filter> UEFI: Dell v: 1.5.2 date: 07/18/2018
Battery:   ID-1: BAT0 charge: 33.8 Wh condition: 33.8/37.3 Wh (91%) volts: 16.7/14.8 model: Panasonic DELL 78V9D63
           type: Li-ion serial: <filter> status: Full
CPU:       Topology: Dual Core model: Intel Core i7-6500U bits: 64 type: MT MCP arch: Skylake rev: 3 L2 cache: 4096 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20744
           Speed: 800 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 802
Graphics:  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
           chip ID: 8086:1916
           Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / R7 M520] vendor: Dell driver: radeon
           v: kernel bus ID: 01:00.0 chip ID: 1002:6660
           Display: x11 server: X.Org 1.20.3 driver: ati,intel,radeon unloaded: modesetting alternate: fbdev,vesa
           compositor: compton resolution: 1920x1080~60Hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 520 (Skylake GT2) v: 4.5 Mesa 18.3.2 compat-v: 3.0
           direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           chip ID: 8086:9d70
           Sound Server: ALSA v: k4.19.20-1-MANJARO
Network:   Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel port: e000 bus ID: 02:00.0 chip ID: 8086:08b3
           Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel port: d000
           bus ID: 03:00.0 chip ID: 10ec:8136
Drives:    Local Storage: total: 931.51 GiB used: 15.19 GiB (1.6%)
           ID-1: /dev/sda vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB speed: 6.0 Gb/s rotation: 5400 rpm
           serial: <filter> rev: 3D scheme: GPT
Partition: ID-1: / size: 19.56 GiB used: 10.37 GiB (53.0%) fs: ext4 dev: /dev/sda5
           ID-2: /home size: 414.86 GiB used: 4.34 GiB (1.0%) fs: ext4 dev: /dev/sda8
           ID-3: swap-1 size: 8.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda6
Sensors:   System Temperatures: cpu: 39.0 C mobo: 35.0 C sodimm: 32.0 C gpu: radeon temp: 37 C
           Fan Speeds (RPM): cpu: 0
Info:      Processes: 186 Uptime: 2h 41m Memory: 15.56 GiB used: 2.32 GiB (14.9%) Init: systemd v: 239 Compilers:
           gcc: 8.2.1 Shell: bash v: 5.0.0 running in: xfce4-terminal inxi: 3.0.30
journalctl -b0 -p4:
-- Logs begin at Mon 2019-02-04 21:40:41 AST, end at Sun 2019-02-10 17:07:49 AST. --
Feb 10 14:28:07 darthknight kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Feb 10 14:28:07 darthknight kernel: ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
Feb 10 14:28:07 darthknight kernel: i8042: Warning: Keylock active
Feb 10 14:28:16 darthknight kernel: i2c_hid i2c-DLLC6B2:00: i2c-DLLC6B2:00 supply vdd not found, using dummy regulator
Feb 10 14:28:16 darthknight kernel: i2c_hid i2c-DLLC6B2:00: i2c-DLLC6B2:00 supply vddl not found, using dummy regulator
Feb 10 14:28:16 darthknight kernel: wmi_bus wmi_bus-PNP0C14:00: WQBC data block query control method not found
Feb 10 14:28:16 darthknight kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
Feb 10 14:28:16 darthknight kernel: ATPX version 1, functions 0x00000033
Feb 10 14:28:16 darthknight kernel: ATPX Hybrid Graphics
Feb 10 14:28:17 darthknight kernel: kauditd_printk_skb: 74 callbacks suppressed
Feb 10 14:28:17 darthknight kernel: ATPX version 1, functions 0x00000033
Feb 10 14:28:17 darthknight kernel: ATPX Hybrid Graphics
Feb 10 14:28:14 darthknight systemd-udevd[313]: Process '/usr/bin/set-wireless-regdom' failed with exit code 1.
Feb 10 14:28:15 darthknight systemd-udevd[317]: Process '/usr/bin/tlp auto' failed with exit code 4.
Feb 10 14:28:17 darthknight systemd-udevd[317]: Process '/usr/bin/alsactl restore 0' failed with exit code 99.
Feb 10 14:28:24 darthknight kernel: kauditd_printk_skb: 8 callbacks suppressed
Feb 10 14:28:25 darthknight colord[630]: failed to get session [pid 600]: No data available
Feb 10 14:29:40 darthknight kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=2c:6e:85:e6:12:f7:48:f8:b3:58:5f:7c:08:00 SRC=74.120.8.23 DST=192.168.1.130 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=51931 DF PROTO=TCP SPT=443 DPT=58394 WINDOW=33 RES=0x00 ACK URGP=0
Feb 10 14:30:40 darthknight kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=2c:6e:85:e6:12:f7:48:f8:b3:58:5f:7c:08:00 SRC=74.120.8.23 DST=192.168.1.130 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=51932 DF PROTO=TCP SPT=443 DPT=58394 WINDOW=33 RES=0x00 ACK URGP=0
Feb 10 14:31:40 darthknight kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=2c:6e:85:e6:12:f7:48:f8:b3:58:5f:7c:08:00 SRC=74.120.8.23 DST=192.168.1.130 LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=51933 DF PROTO=TCP SPT=443 DPT=58394 WINDOW=33 RES=0x00 ACK URGP=0
Feb 10 14:33:13 darthknight kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=2c:6e:85:e6:12:f7:a4:8d:3b:f4:17:8f:08:00 SRC=192.168.1.112 DST=192.168.1.130 LEN=498 TOS=0x00 PREC=0x00 TTL=64 ID=1695 DF PROTO=UDP SPT=51551 DPT=46889 LEN=478
Feb 10 14:33:14 darthknight kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=2c:6e:85:e6:12:f7:a4:8d:3b:f4:17:8f:08:00 SRC=192.168.1.112 DST=192.168.1.130 LEN=291 TOS=0x00 PREC=0x00 TTL=64 ID=1733 DF PROTO=UDP SPT=57084 DPT=46889 LEN=271
Feb 10 14:33:14 darthknight kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=2c:6e:85:e6:12:f7:a4:8d:3b:f4:17:8f:08:00 SRC=192.168.1.112 DST=192.168.1.130 LEN=289 TOS=0x00 PREC=0x00 TTL=64 ID=1756 DF PROTO=UDP SPT=47288 DPT=46889 LEN=269
Feb 10 14:53:10 darthknight kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=2c:6e:85:e6:12:f7:c4:9d:ed:03:69:89:08:00 SRC=192.168.1.113 DST=192.168.1.130 LEN=90 TOS=0x00 PREC=0x00 TTL=128 ID=17545 PROTO=UDP SPT=137 DPT=55049 LEN=70
Feb 10 14:53:13 darthknight kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=2c:6e:85:e6:12:f7:c4:9d:ed:03:69:89:08:00 SRC=192.168.1.113 DST=192.168.1.130 LEN=90 TOS=0x00 PREC=0x00 TTL=128 ID=17546 PROTO=UDP SPT=137 DPT=48205 LEN=70
Feb 10 15:01:46 darthknight systemd-coredump[2115]: Process 2095 (Xorg) of user 0 dumped core.
                                                    Stack trace of thread 2095:
                                                    #0  0x00007f708c518d7f raise (libc.so.6)
                                                    #1  0x00007f708c503672 abort (libc.so.6)
                                                    #2  0x000055dac486eaea OsAbort (Xorg)
                                                    #3  0x000055dac486555f FatalError (Xorg)
                                                    #4  0x000055dac487337e n/a (Xorg)
                                                    #5  0x00007f708c518e00 __restore_rt (libc.so.6)
                                                    #6  0x00007f708c518d7f raise (libc.so.6)
                                                    #7  0x00007f708c503672 abort (libc.so.6)
                                                    #8  0x00007f708c503548 __assert_fail_base.cold.0 (libc.so.6)
                                                    #9  0x00007f708c511396 __assert_fail (libc.so.6)
                                                    #10 0x000055dac491cf29 dixRegisterPrivateKey (Xorg)
                                                    #11 0x00007f7086b36ce9 glamor_init (libglamoregl.so)
                                                    #12 0x00007f708706ff6d n/a (modesetting_drv.so)
                                                    #13 0x000055dac493e29d AddGPUScreen (Xorg)
                                                    #14 0x000055dac483ae5c n/a (Xorg)
                                                    #15 0x000055dac481d6d6 n/a (Xorg)
                                                    #16 0x000055dac480c1f9 n/a (Xorg)
                                                    #17 0x000055dac480c9a3 config_init (Xorg)
                                                    #18 0x000055dac48530f7 InitInput (Xorg)
                                                    #19 0x000055dac47f9734 n/a (Xorg)
                                                    #20 0x00007f708c505223 __libc_start_main (libc.so.6)
                                                    #21 0x000055dac47fa30e _start (Xorg)
                                                    Stack trace of thread 2101:
                                                    #0  0x00007f708b753afc pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0)
                                                    #1  0x00007f70898f4560 n/a (intel_drv.so)
                                                    #2  0x00007f708b74da9d start_thread (libpthread.so.0)
                                                    #3  0x00007f708c5dcb23 __clone (libc.so.6)
                                                    Stack trace of thread 2102:
                                                    #1  0x00007f70886fcbe4 n/a (i965_dri.so)
                                                    #2  0x00007f70886fc908 n/a (i965_dri.so)
                                                    #3  0x00007f708b74da9d start_thread (libpthread.so.0)
                                                    #4  0x00007f708c5dcb23 __clone (libc.so.6)
                                                    Stack trace of thread 2107:
                                                    #1  0x00007f708637c704 n/a (radeonsi_dri.so)
                                                    #2  0x00007f708637c428 n/a (radeonsi_dri.so)
                                                    Stack trace of thread 2105:
                                                    Stack trace of thread 2106:
                                                    Stack trace of thread 2109:
                                                    Stack trace of thread 2108:
                                                    Stack trace of thread 2110:
                                                    Stack trace of thread 2112:
                                                    Stack trace of thread 2111:
Feb 10 15:09:26 darthknight kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=2c:6e:85:e6:12:f7:48:f8:b3:58:5f:7c:08:00 SRC=60.242.207.152 DST=192.168.1.130 LEN=131 TOS=0x00 PREC=0x00 TTL=112 ID=28423 PROTO=UDP SPT=28014 DPT=50926 LEN=111
Feb 10 15:13:54 darthknight kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=2c:6e:85:e6:12:f7:48:f8:b3:58:5f:7c:08:00 SRC=116.254.71.219 DST=192.168.1.130 LEN=129 TOS=0x00 PREC=0x00 TTL=47 ID=0 DF PROTO=UDP SPT=6889 DPT=50926 LEN=109
Feb 10 15:29:52 darthknight kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=2c:6e:85:e6:12:f7:48:f8:b3:58:5f:7c:08:00 SRC=116.254.71.219 DST=192.168.1.130 LEN=129 TOS=0x00 PREC=0x00 TTL=47 ID=0 DF PROTO=UDP SPT=6889 DPT=50926 LEN=109
Feb 10 15:33:18 darthknight kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=2c:6e:85:e6:12:f7:48:f8:b3:58:5f:7c:08:00 SRC=2.26.15.134 DST=192.168.1.130 LEN=129 TOS=0x00 PREC=0x00 TTL=47 ID=3472 DF PROTO=UDP SPT=50321 DPT=50926 LEN=109
Feb 10 15:38:27 darthknight kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=2c:6e:85:e6:12:f7:48:f8:b3:58:5f:7c:08:00 SRC=116.254.71.219 DST=192.168.1.130 LEN=129 TOS=0x00 PREC=0x00 TTL=47 ID=0 DF PROTO=UDP SPT=6889 DPT=50926 LEN=109
Feb 10 15:40:39 darthknight kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=2c:6e:85:e6:12:f7:48:f8:b3:58:5f:7c:08:00 SRC=116.254.71.219 DST=192.168.1.130 LEN=129 TOS=0x00 PREC=0x00 TTL=47 ID=0 DF PROTO=UDP SPT=6889 DPT=50926 LEN=109
Feb 10 15:45:35 darthknight kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=2c:6e:85:e6:12:f7:48:f8:b3:58:5f:7c:08:00 SRC=72.94.7.219 DST=192.168.1.130 LEN=129 TOS=0x00 PREC=0x00 TTL=45 ID=0 DF PROTO=UDP SPT=37321 DPT=50926 LEN=109
Feb 10 15:45:45 darthknight kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=2c:6e:85:e6:12:f7:48:f8:b3:58:5f:7c:08:00 SRC=72.94.7.219 DST=192.168.1.130 LEN=129 TOS=0x00 PREC=0x00 TTL=45 ID=0 DF PROTO=UDP SPT=37321 DPT=50926 LEN=109
Feb 10 16:07:03 darthknight systemd-coredump[3911]: Process 3892 (Xorg) of user 0 dumped core.
                                                    Stack trace of thread 3892:
                                                    #0  0x00007f22b1c10d7f raise (libc.so.6)
                                                    #1  0x00007f22b1bfb672 abort (libc.so.6)
                                                    #2  0x000055f4ac5a1aea OsAbort (Xorg)
                                                    #3  0x000055f4ac59855f FatalError (Xorg)
                                                    #4  0x000055f4ac5a637e n/a (Xorg)
                                                    #5  0x00007f22b1c10e00 __restore_rt (libc.so.6)
                                                    #6  0x00007f22b1c10d7f raise (libc.so.6)
                                                    #7  0x00007f22b1bfb672 abort (libc.so.6)
                                                    #8  0x00007f22b1bfb548 __assert_fail_base.cold.0 (libc.so.6)
                                                    #9  0x00007f22b1c09396 __assert_fail (libc.so.6)
                                                    #10 0x000055f4ac64ff29 dixRegisterPrivateKey (Xorg)
                                                    #11 0x00007f22ac22ece9 glamor_init (libglamoregl.so)
                                                    #12 0x00007f22ac767f6d n/a (modesetting_drv.so)
                                                    #13 0x000055f4ac67129d AddGPUScreen (Xorg)
                                                    #14 0x000055f4ac56de5c n/a (Xorg)
                                                    #15 0x000055f4ac5506d6 n/a (Xorg)
                                                    #16 0x000055f4ac53f1f9 n/a (Xorg)
                                                    #17 0x000055f4ac53f9a3 config_init (Xorg)
                                                    #18 0x000055f4ac5860f7 InitInput (Xorg)
                                                    #19 0x000055f4ac52c734 n/a (Xorg)
                                                    #20 0x00007f22b1bfd223 __libc_start_main (libc.so.6)
                                                    #21 0x000055f4ac52d30e _start (Xorg)
                                                    Stack trace of thread 3897:
                                                    #0  0x00007f22b0e4bafc pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0)
                                                    #1  0x00007f22aefec560 n/a (intel_drv.so)
                                                    #2  0x00007f22b0e45a9d start_thread (libpthread.so.0)
                                                    #3  0x00007f22b1cd4b23 __clone (libc.so.6)
                                                    Stack trace of thread 3898:
                                                    #1  0x00007f22addf4be4 n/a (i965_dri.so)
                                                    #2  0x00007f22addf4908 n/a (i965_dri.so)
                                                    #3  0x00007f22b0e45a9d start_thread (libpthread.so.0)
                                                    #4  0x00007f22b1cd4b23 __clone (libc.so.6)
                                                    Stack trace of thread 3904:
                                                    #1  0x00007f22a7999704 n/a (radeonsi_dri.so)
                                                    #2  0x00007f22a7999428 n/a (radeonsi_dri.so)
                                                    Stack trace of thread 3902:
                                                    Stack trace of thread 3901:
                                                    Stack trace of thread 3903:
                                                    Stack trace of thread 3906:
                                                    Stack trace of thread 3907:
                                                    Stack trace of thread 3908:
                                                    Stack trace of thread 3905:
Feb 10 16:07:48 darthknight kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=2c:6e:85:e6:12:f7:48:f8:b3:58:5f:7c:08:00 SRC=210.212.181.11 DST=192.168.1.130 LEN=132 TOS=0x00 PREC=0x00 TTL=43 ID=47084 PROTO=UDP SPT=1043 DPT=50926 LEN=112
Feb 10 16:13:57 darthknight kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=2c:6e:85:e6:12:f7:48:f8:b3:58:5f:7c:08:00 SRC=37.79.0.13 DST=192.168.1.130 LEN=326 TOS=0x00 PREC=0x00 TTL=109 ID=21089 PROTO=UDP SPT=1851 DPT=50926 LEN=306
Feb 10 16:16:41 darthknight xfconfd[3955]: Name org.xfce.Xfconf lost on the message dbus, exiting.
Feb 10 16:29:21 darthknight kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=2c:6e:85:e6:12:f7:48:f8:b3:58:5f:7c:08:00 SRC=116.254.71.219 DST=192.168.1.130 LEN=129 TOS=0x00 PREC=0x00 TTL=47 ID=0 DF PROTO=UDP SPT=6889 DPT=50926 LEN=109
Feb 10 16:33:49 darthknight systemd-coredump[4154]: Process 4138 (Xorg) of user 0 dumped core.
                                                    Stack trace of thread 4138:
                                                    #0  0x00007f2259d84d7f raise (libc.so.6)
                                                    #1  0x00007f2259d6f672 abort (libc.so.6)
                                                    #2  0x0000562fb33d3aea OsAbort (Xorg)
                                                    #3  0x0000562fb33ca55f FatalError (Xorg)
                                                    #4  0x0000562fb33d837e n/a (Xorg)
                                                    #5  0x00007f2259d84e00 __restore_rt (libc.so.6)
                                                    #6  0x00007f2259d84d7f raise (libc.so.6)
                                                    #7  0x00007f2259d6f672 abort (libc.so.6)
                                                    #8  0x00007f2259d6f548 __assert_fail_base.cold.0 (libc.so.6)
                                                    #9  0x00007f2259d7d396 __assert_fail (libc.so.6)
                                                    #10 0x0000562fb3481f29 dixRegisterPrivateKey (Xorg)
                                                    #11 0x00007f22543a2ce9 glamor_init (libglamoregl.so)
                                                    #12 0x00007f22548dbf6d n/a (modesetting_drv.so)
                                                    #13 0x0000562fb34a329d AddGPUScreen (Xorg)
                                                    #14 0x0000562fb339fe5c n/a (Xorg)
                                                    #15 0x0000562fb33826d6 n/a (Xorg)
                                                    #16 0x0000562fb33711f9 n/a (Xorg)
                                                    #17 0x0000562fb33719a3 config_init (Xorg)
                                                    #18 0x0000562fb33b80f7 InitInput (Xorg)
                                                    #19 0x0000562fb335e734 n/a (Xorg)
                                                    #20 0x00007f2259d71223 __libc_start_main (libc.so.6)
                                                    #21 0x0000562fb335f30e _start (Xorg)
                                                    Stack trace of thread 4149:
                                                    #0  0x00007f2258fbfafc pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0)
                                                    #1  0x00007f224f999704 n/a (radeonsi_dri.so)
                                                    #2  0x00007f224f999428 n/a (radeonsi_dri.so)
                                                    #3  0x00007f2258fb9a9d start_thread (libpthread.so.0)
                                                    #4  0x00007f2259e48b23 __clone (libc.so.6)
                                                    Stack trace of thread 4148:
                                                    Stack trace of thread 4140:
                                                    #1  0x00007f2257160560 n/a (intel_drv.so)
                                                    #2  0x00007f2258fb9a9d start_thread (libpthread.so.0)
                                                    #3  0x00007f2259e48b23 __clone (libc.so.6)
                                                    Stack trace of thread 4150:
                                                    Stack trace of thread 4147:
                                                    Stack trace of thread 4151:
                                                    Stack trace of thread 4141:
                                                    #1  0x00007f2255f68be4 n/a (i965_dri.so)
                                                    #2  0x00007f2255f68908 n/a (i965_dri.so)
                                                    Stack trace of thread 4145:
                                                    Stack trace of thread 4146:
                                                    Stack trace of thread 4144:
Feb 10 16:54:49 darthknight kernel: [UFW BLOCK] IN=wlp2s0 OUT= MAC=2c:6e:85:e6:12:f7:48:f8:b3:58:5f:7c:08:00 SRC=192.168.1.1 DST=192.168.1.130 LEN=210 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=53 DPT=44737 LEN=190
Feb 10 17:03:47 darthknight NetworkManager[581]: <warn>  [1549832627.8382] sup-iface[0x55e00db290d0,wlp2s0]: connection disconnected (reason -4)
mhwd -li:
e[1me[31m> e[mInstalled PCI configs:
           video-linux            2018.05.04                true            PCI
e[1me[31mWarning: e[mNo installed USB configs!
#2
AFAIK that should not have issues running arch, hence no issues with Manjaro. From terminal:
xinput -list
and we start from there.
#3
I run a Dell Inspiron too but later model. I’m puzzled and baffled by your issue because on my machine the only thing I had to do was edit the settings or config file to increase the speed of movement. I second what @bogdancovaciu said.
#4
Perhaps an rmmod then a modprobe of your touchpads modules would be enough to get it working properly without the need to reboot.
You could easily create an alias to execute the commands. Not a fix by any means, bit a workaround to avoid having to reboot.
#5
Agreed although I feel the need to add this is assuming OP has an external mouse to use via usb for when they run rmmod.
#6
If you concatenate the commands it should not be required.
Example:
sudo rmmod trackpad_module; sleep 2; sudo modprobe trackpad_module
The trackpads function should only be interrupted for 2 seconds by doing it that way.
#7
True assuming everything goes smoothly.
#8
A USB device is always a good thing to have when messing with your keyboard or trackpad modules. An onscreen keyboard program is a good idea as well.
#9
Thanks for your reply.
I ran the command xinput -list in terminal and it says command not found.
#10
Ran the command and got the following error:
rmmod: ERROR: Module trackpad_module is not currently loaded
modprobe: FATAL: Module trackpad_module not found in directory /lib/modules/4.19.20-1-MANJARO
#11
I don’t have any USB mice at the moment, nor any external USB devices connected.
#12
That was only meant to be an example. You need to substitute your actual module. You can find a list of your modules with the command:
lsmod
#13
ah, my bad. Thanks.
When I run lsmod, I see a psmouse and mousedev modules, but under Used by, is empty. The module libps2 and serio is Used by atkbd, psmouse:
lsmod:
Module                  Size  Used by
ccm                    20480  9
fuse                  118784  7
nls_iso8859_1          16384  1
nls_cp437              20480  1
vfat                   24576  1
fat                    81920  1 vfat
amdgpu               3424256  0
chash                  16384  1 amdgpu
gpu_sched              28672  1 amdgpu
snd_hda_codec_hdmi     57344  1
snd_hda_codec_realtek   118784  1
snd_hda_codec_generic    86016  1 snd_hda_codec_realtek
wmi_bmof               16384  0
dell_wmi               16384  0
arc4                   16384  2
sparse_keymap          16384  1 dell_wmi
rtsx_usb_ms            20480  0
iTCO_wdt               16384  0
iTCO_vendor_support    16384  1 iTCO_wdt
memstick               16384  1 rtsx_usb_ms
dell_laptop            24576  0
intel_rapl             24576  0
iwlmvm                442368  0
joydev                 24576  0
i915                 2097152  12
x86_pkg_temp_thermal    16384  0
mousedev               24576  0
dell_smbios            28672  2 dell_wmi,dell_laptop
dell_wmi_descriptor    16384  2 dell_wmi,dell_smbios
intel_powerclamp       16384  0
nf_log_ipv6            16384  5
mac80211              929792  1 iwlmvm
coretemp               16384  0
dcdbas                 16384  1 dell_smbios
kvm_intel             245760  0
kvmgt                  28672  0
dell_smm_hwmon         16384  0
crct10dif_pclmul       16384  0
snd_soc_skl           118784  0
crc32_pclmul           16384  0
ghash_clmulni_intel    16384  0
vfio_mdev              16384  0
snd_soc_skl_ipc        73728  1 snd_soc_skl
pcbc                   16384  0
mdev                   20480  2 kvmgt,vfio_mdev
vfio_iommu_type1       28672  0
snd_soc_sst_ipc        16384  1 snd_soc_skl_ipc
snd_soc_sst_dsp        36864  1 snd_soc_skl_ipc
snd_hda_ext_core       28672  1 snd_soc_skl
snd_soc_acpi_intel_match    24576  1 snd_soc_skl
snd_soc_acpi           16384  2 snd_soc_acpi_intel_match,snd_soc_skl
aesni_intel           200704  6
radeon               1634304  0
vfio                   32768  3 kvmgt,vfio_mdev,vfio_iommu_type1
aes_x86_64             20480  1 aesni_intel
kvm                   737280  2 kvmgt,kvm_intel
crypto_simd            16384  1 aesni_intel
cryptd                 28672  3 crypto_simd,ghash_clmulni_intel,aesni_intel
snd_soc_core          270336  1 snd_soc_skl
irqbypass              16384  1 kvm
ttm                   126976  2 amdgpu,radeon
glue_helper            16384  1 aesni_intel
intel_cstate           16384  0
intel_uncore          135168  0
i2c_algo_bit           16384  3 amdgpu,radeon,i915
xt_hl                  16384  22
drm_kms_helper        208896  3 amdgpu,radeon,i915
snd_compress           24576  1 snd_soc_core
ac97_bus               16384  1 snd_soc_core
snd_pcm_dmaengine      16384  1 snd_soc_core
intel_rapl_perf        16384  0
r8169                  90112  0
iwlwifi               344064  1 iwlmvm
drm                   495616  11 gpu_sched,drm_kms_helper,amdgpu,radeon,i915,ttm
mei_me                 45056  0
snd_hda_intel          45056  3
realtek                20480  0
snd_hda_codec         151552  4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
libphy                 77824  3 r8169,realtek
mei                   114688  1 mei_me
snd_hda_core           94208  7 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek,snd_soc_skl
ip6t_rt                16384  3
cfg80211              778240  3 iwlmvm,iwlwifi,mac80211
intel_gtt              24576  1 i915
agpgart                49152  3 intel_gtt,ttm,drm
syscopyarea            16384  1 drm_kms_helper
sysfillrect            16384  1 drm_kms_helper
sysimgblt              16384  1 drm_kms_helper
idma64                 20480  0
psmouse               172032  0
pcspkr                 16384  0
i2c_hid                28672  0
input_leds             16384  0
snd_hwdep              16384  1 snd_hda_codec
intel_lpss_pci         20480  0
dell_rbtn              16384  0
fb_sys_fops            16384  1 drm_kms_helper
snd_pcm               131072  8 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_soc_core,snd_soc_skl,snd_hda_core,snd_pcm_dmaengine
wmi                    28672  4 dell_wmi,wmi_bmof,dell_smbios,dell_wmi_descriptor
ip6t_REJECT            16384  3
snd_timer              36864  1 snd_pcm
tpm_crb                16384  0
tpm_tis                16384  0
tpm_tis_core           20480  1 tpm_tis
tpm                    65536  3 tpm_tis,tpm_crb,tpm_tis_core
evdev                  28672  16
rng_core               16384  1 tpm
mac_hid                16384  0
nf_reject_ipv6         16384  1 ip6t_REJECT
rfkill                 28672  6 dell_laptop,dell_rbtn,cfg80211
ac                     16384  0
snd                    98304  16 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_compress,snd_soc_core,snd_pcm
battery                24576  0
nf_log_ipv4            16384  5
intel_pch_thermal      16384  0
soundcore              16384  1 snd
i2c_i801               32768  0
pcc_cpufreq            16384  0
intel_lpss             16384  1 intel_lpss_pci
nf_log_common          16384  2 nf_log_ipv4,nf_log_ipv6
xt_LOG                 16384  10
xt_limit               16384  13
xt_addrtype            16384  4
xt_tcpudp              16384  34
xt_conntrack           16384  16
ipt_REJECT             16384  3
nf_reject_ipv4         16384  1 ipt_REJECT
ip6table_filter        16384  1
ip6_tables             32768  53 ip6table_filter
nf_conntrack_netbios_ns    16384  0
nf_conntrack_broadcast    16384  1 nf_conntrack_netbios_ns
nf_nat_ftp             16384  0
nf_nat                 36864  1 nf_nat_ftp
nf_conntrack_ftp       20480  1 nf_nat_ftp
nf_conntrack          163840  6 xt_conntrack,nf_nat,nf_nat_ftp,nf_conntrack_netbios_ns,nf_conntrack_broadcast,nf_conntrack_ftp
nf_defrag_ipv6         20480  1 nf_conntrack
nf_defrag_ipv4         16384  1 nf_conntrack
libcrc32c              16384  2 nf_conntrack,nf_nat
iptable_filter         16384  1
uinput                 20480  0
sg                     40960  0
crypto_user            16384  0
ip_tables              28672  9 iptable_filter
x_tables               45056  13 ip6table_filter,xt_conntrack,iptable_filter,xt_LOG,xt_tcpudp,xt_addrtype,ip6t_rt,ip6_tables,ipt_REJECT,ip_tables,xt_limit,xt_hl,ip6t_REJECT
ext4                  737280  2
crc32c_generic         16384  0
crc16                  16384  1 ext4
mbcache                16384  1 ext4
jbd2                  126976  1 ext4
fscrypto               32768  1 ext4
sr_mod                 28672  0
cdrom                  69632  1 sr_mod
sd_mod                 61440  5
hid_multitouch         28672  0
hid_generic            16384  0
usbhid                 57344  0
hid                   139264  4 i2c_hid,usbhid,hid_multitouch,hid_generic
rtsx_usb_sdmmc         28672  0
mmc_core              176128  1 rtsx_usb_sdmmc
rtsx_usb               20480  2 rtsx_usb_sdmmc,rtsx_usb_ms
serio_raw              16384  0
atkbd                  32768  0
libps2                 16384  2 atkbd,psmouse
ahci                   40960  4
libahci                40960  1 ahci
libata                278528  2 libahci,ahci
xhci_pci               16384  0
crc32c_intel           24576  5
xhci_hcd              266240  1 xhci_pci
scsi_mod              253952  4 sd_mod,libata,sg,sr_mod
i8042                  32768  1 dell_laptop
serio                  28672  6 serio_raw,atkbd,psmouse,i8042
#14
Then you install it:
sudo pacman -S xorg-xinput
and run xinput -list again
#15
Installed xorg-xinput and ran xinput -list.
xinput -list:
⎡ Virtual core pointer                    	id=2	[master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer              	id=4	[slave  pointer  (2)]
⎜   ↳ DLLC6B2:00 06CB:75BF Touchpad           	id=11	[slave  pointer  (2)]
⎜   ↳ Melfas LGD AIT Touch Controller         	id=10	[slave  pointer  (2)]
⎣ Virtual core keyboard                   	id=3	[master keyboard (2)]
    ↳ Virtual core XTEST keyboard             	id=5	[slave  keyboard (3)]
    ↳ Power Button                            	id=6	[slave  keyboard (3)]
    ↳ Video Bus                               	id=7	[slave  keyboard (3)]
    ↳ Power Button                            	id=8	[slave  keyboard (3)]
    ↳ Sleep Button                            	id=9	[slave  keyboard (3)]
    ↳ Dell WMI hotkeys                        	id=12	[slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard            	id=13	[slave  keyboard (3)]
    ↳ DELL Wireless hotkeys                   	id=14	[slave  keyboard (3)]
Thanks.
#16
One thing that comes to mind is to do this from terminal:
sudo echo "blacklist i2c_hid" | sudo tee -a /etc/modprobe.d/blacklist.conf
reboot.
Someone else proposed (elsewhere) a script to Enablel and Disable the Touchpad (same model AFAIK) touchpad_toggle.sh
#!/bin/bash
read TPdevice <<< $( xinput | sed -nre '/TouchPad/s/.*id=([0-9]*).*/\1/p' )
state=$( xinput list-props "$TPdevice" | grep "Device Enabled" | grep -o "[01]$" )
if [ "$state" -eq '1' ];then
    xinput --disable "$TPdevice" && notify-send -i emblem-nowrite "Touchpad" "Disabled"
else
    xinput --enable "$TPdevice" && notify-send -i input-touchpad "Touchpad" "Enabled"
fi
then
chmod +x touchpad_toggle.sh
to use it from terminal:
./touchpad_toggle.sh
You can bind key shortcuts to it so you don’t run it from terminal …
#17
Thank you.
I will try it out and report back in a couple of days.
Thanks again.
