Dell Inspiron 15 5585 not waking from suspend
My Dell laptop won't wake when suspended. If I close the lid and let it suspend, it doesn't respond to anything. I have to turn it off by holding the power button for a while. I was wondering if anyone had a solution.
Some background: This laptop has had some issues running linux in the past. There was a bug that didn't allow it to boot due to weird ACPI tables, and it caused kernel panic on boot. The solution I found was to go into the BIOS and set the sleep mode to "Force S3".
Since then, the system has been able to boot and function fine, but I cannot get it to wake from suspend! If someone could offer some insight, that would be greatly appreciated.
Hardware info
Bugzilla thread on ACPI tables
I'm running GNOME 3.32.2 as my DE
Have a look through this, see if anything fixes your model, 10.2 might help with your problem.
https://wiki.archlinux.org/index.php/Dell_Inspiron_15_(7590)
That worked, thanks!
your welcome & good job working it out :wink:
would be great if you can briefly explain what you did, in case a noob is looking into the same problem...
In order to fix the issue, I added these kernel parameters to my bootloader:
acpi_rev_override=1 acpi_osi=Linux mem_sleep_default=deep
Depending on which bootloader you're using, you can find out how to add kernel parameters here:
https://wiki.archlinux.org/index.php/kernel_parameters
