Hello,
I’ve made a clean install of Manjaro GNOME on a Dell G3-3590-A20P.
Initially, there was no sound support at all (Dummy output and no mic), also jack wouldn’t work either.
Browsing the web and Arch Linux forums, I’ve found that modprobe options snd_hda_intel dmic_detect=0
would enable internal speaker and jack input/output at the cost of disabling internal mic.
Now I’ve done more research and updated to Kernel 5.9, removed the hackish modprobe, and installed sof-firmware
. After tinkering a bit with alsamixer volume levels, I’ve got the internal speaker/mic and jack input/output working as expected.
The remaining problem is that my bluetooth headphones (JBL Live 300TWS) have about 1s output delay and I can’t get the mic (audio input) to work.
Looking at journalctl -b -p err
, I see this error after connecting to bluetooth headphones at startup:
Nov 11 11:48:38 ult-g33590 bluetoothd[462]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
Nov 11 11:48:38 ult-g33590 bluetoothd[462]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset unit: rfcomm_bind: Address already in use (98)
And I see this error after disconnecting and connecting the bluetooth headphones again:
Nov 11 11:50:21 ult-g33590 bluetoothd[462]: src/service.c:btd_service_connect() a2dp-source profile connect failed for B4:9A:95:EE:66:10: Device or resource busy
From the “address already in use” error, I would assume I have to stop a service or kill the process that is already using the address/port, but I’ve had no luck debugging this so far.
Here’s my system info:
▶ inxi -Fzx
System: Kernel: 5.9.3-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: GNOME 3.38.1 Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: G3 3590 v: N/A serial: <filter>
Mobo: Dell model: 0GDFK2 v: A00 serial: <filter> UEFI: Dell v: 1.7.1 date: 08/28/2019
Battery: ID-1: BAT0 charge: 51.0 Wh condition: 51.0/51.0 Wh (100%) model: BYD DELL M4GWP9A status: Full
CPU: Info: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38408
Speed: 2100 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 2100 2: 2100 3: 2100 4: 2100 5: 2100 6: 2100 7: 2100
8: 2100
Graphics: Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Dell driver: nvidia v: 450.80.02 bus ID: 01:00.0
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 1-5:3
Display: server: X.org 1.20.9 driver: modesetting,nvidia resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.2.1 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: sof-audio-pci bus ID: 00:1f.3
Sound Server: ALSA v: k5.9.3-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8169 v: kernel port: 3000
bus ID: 03:00.0
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Dell driver: ath10k_pci v: kernel
port: 3000 bus ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 1-14:4
Drives: Local Storage: total: 1.03 TiB used: 32.32 GiB (3.1%)
ID-1: /dev/nvme0n1 model: PC SN520 NVMe WDC 128GB size: 119.24 GiB
ID-2: /dev/sda vendor: Western Digital model: WD10SPZX-75Z10T3 size: 931.51 GiB
Partition: ID-1: / size: 107.92 GiB used: 32.32 GiB (29.9%) fs: ext4 dev: /dev/nvme0n1p2
Swap: ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 61.0 C mobo: N/A
Info: Processes: 304 Uptime: 1h 10m Memory: 15.49 GiB used: 5.36 GiB (34.6%) Init: systemd Compilers: gcc: 10.2.0
Packages: 1209 Shell: fish v: 3.1.2 inxi: 3.1.08
▶ hwdetect --show-modules
AGP : agpgart intel-gtt
ACPI : ac acpi_tad battery
BLOCK : uvcvideo xhci-hcd xhci-pci
BLUETOOTH: btbcm btintel btrtl btusb bluetooth
CPUFREQ : acpi-cpufreq pcc-cpufreq
CRYPTO : aesni-intel crc32c-intel crc32-pclmul crct10dif-pclmul ghash-clmulni-intel glue_helper cryptd crypto_simd ecc ecdh_generic libarc4
DRM : drm_kms_helper drm i915
HWMON : coretemp
I2C : i2c-algo-bit i2c-i801 i2c-smbus
INPUT : evdev input-leds joydev atkbd mousedev psmouse i8042 libps2 serio serio_raw sparse-keymap hid-generic hid hid-multitouch i2c-hid usbhid
KVM : kvm-intel kvm
MEDIA : cec videobuf2-common videobuf2-memops videobuf2-v4l2 videobuf2-vmalloc mc rc-core uvcvideo videodev
NET : r8169 fjes fixed_phy libphy mdio_devres ath10k_core ath10k_pci ath bluetooth mac80211 rfkill cfg80211
SOUND : pcspkr ac97_bus snd-compress snd-hwdep snd snd-pcm-dmaengine snd-pcm snd-timer snd-hda-ext-core snd-hda-core snd-intel-dspcfg snd-hda-codec snd-hda-intel snd-soc-dmic snd-soc-hdac-hda snd-soc-hdac-hdmi snd-soc-skl_hda_dsp snd-soc-acpi-intel-match snd-soc-sst-dsp snd-soc-sst-ipc snd-soc-skl snd-soc-acpi snd-soc-core snd-sof-intel-byt snd-sof-intel-hda-common snd-sof-intel-hda snd-sof-intel-ipc snd-sof snd-sof-pci snd-sof-xtensa-dsp soundcore
TPM : tpm_crb tpm tpm_tis_core tpm_tis
WATCHDOG : iTCO_vendor_support iTCO_wdt
OTHER : nvidia-drm nvidia nvidia-modeset intel-cstate intel-uncore rapl rng-core idma64 ledtrig-audio mac_hid intel-lpss intel-lpss-pci intel_pmc_bxt ee1004 mei_hdcp mei of_mdio alienware-wmi dcdbas dell-laptop dell-smbios dell-wmi-descriptor dell-wmi intel-hid mxm-wmi wmi-bmof wmi intel_rapl_common intel_rapl_msr acpi_thermal_rel int3400_thermal int3402_thermal int3403_thermal int340x_thermal_zone processor_thermal_device intel_pch_thermal intel_powerclamp intel_soc_dts_iosf x86_pkg_temp_thermal fb_sys_fops syscopyarea sysfillrect sysimgblt crc16 irqbypass
Just to recap, I would like to get the bluetooth mic working and fix the output delay if possible.
I have virtually no experience with Linux firmware, let me know if there’s any other useful info I can post. Any pointers are appreciated.
