Installed fresh Minimal Manjaro KDE.
I can’t see output device in settings, there’s only dummy output.
Output of inxi -Fazy
Kernel: 5.15.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=b5cbdd18-aac7-44bd-8879-8223bb5b381f rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: MSI model: H61M-P31 (G3) (MS-7788) v: 1.0
serial: <superuser required> BIOS: American Megatrends v: 2.7
date: 01/10/2013
Info: model: Intel Core i5-2500 bits: 64 type: MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 2517 high: 2645 min/max: 1600/3700 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2417 2: 2645 3: 2562
4: 2446 bogomips: 26350
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
disabled
prctl and seccomp
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Micro-Star MSI driver: i915 v: kernel arch: Gen-6
process: Intel 32nm built: 2011 ports: active: VGA-1 empty: DP-1,HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:0102 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: VGA-1 model: Philips 196VL serial: <filter> built: 2012
res: 1366x768 hz: 60 dpi: 85 gamma: 1.2 size: 409x230mm (16.1x9.06")
diag: 469mm (18.5") ratio: 16:9 modes: max: 1366x768 min: 720x400
OpenGL: renderer: Mesa Intel HD Graphics 2000 (SNB GT1) v: 3.3 Mesa 22.1.7
direct render: Yes
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.15.65-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.1 running: no
Sound Server-4: PipeWire v: 0.3.57 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: TP-Link TL-WN822N Version 4 RTL8192EU type: USB driver: rtl8xxxu
bus-ID: 2-1.5:5 chip-ID: 2357:0108 class-ID: 0000 serial: <filter>
IF: wlp0s29u1u5 state: down mac: <filter>
IF-ID-1: enp0s29u1u3 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Samsung GT-I9070 (network tethering USB debugging enabled)
type: USB driver: rndis_host v: kernel bus-ID: 2-1.3:7 chip-ID: 04e8:6864
class-ID: 0a00 serial: <filter>
Device-2: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB
driver: btusb v: 0.8 bus-ID: 2-1.6:6 chip-ID: 0a12:0001 class-ID: e001
Report: ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 703.77 GiB used: 8.13 GiB (1.2%)
ID-1: /dev/sda maj-min: 8:0 type: USB model: USB Flash Memory
size: 14.43 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: PMAP scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500DM002-1BD142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: KC48 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WDS240G2G0A-00JH30 size: 223.58 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter> rev: 0000
scheme: MBR
ID-1: / raw-size: 223.58 GiB size: 219.01 GiB (97.96%) used: 8.13 GiB (3.7%)
fs: ext4 dev: /dev/sdc1 maj-min: 8:33
System Temperatures: cpu: 33.0 C mobo: N/A
Processes: 170 Uptime: 13m wakeups: 0 Memory: 7.47 GiB used: 2.03 GiB
(27.2%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1090 libs: 306
tools: pamac Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.21
I installed sof-firmware
and manjaro-pipewire
Any questions, suggestions, solutions?
