I see in the folder /var/cache/pacman/pkg there are a lot of files with extensions pkg.tar.zst. Is it safe to delete these as they taking up a fair chunk of space?
Those are the packages that were downloaded during an upgrade. pacman
─ or pamac
if that’s what you’re using ─ downloads all the packages first, and then it starts upgrading the individual packages. That way, the risk of an upgrade going wrong is split between the phase of downloading the packages and the actual phase of upgrading your system.
If the network goes down while downloading the packages, you can always resume the download later.
If something goes wrong while upgrading your system, then you at least have all the packages on your system already, and then it’s easier to pick up from there.
It is generally advised to keep at least the packages from the last upgrade, but if you want to get rid of all of them, then just issue the following command…
sudo paccache -rvk0
As an example from my own machine just now…
[nx-74205:/dev/pts/1][/home/aragorn]
[13:00:00][aragorn] > sudo paccache -rvk0
[sudo] password for root:
removed '/var/cache/pacman/pkg/tree-1.8.0-2-x86_64.pkg.tar.zst'
==> finished: 1 packages removed (disk space saved: 33.39 KiB)
[13:57:10][aragorn] >
Note: On my machine, sudo
requires the password of the target user ─ in this case, the root account ─ rather than my own password. This is by choice.
The Wiki would have told you that too.
It is done automatically for the user.
Check…
pamac-manager > Preferences > Cache:
Number of versions of each package to keep in the cache:
Updates /etc/pamac.conf.
Notice the systemd service, pamac-cleancache:
systemctl list-timers
