Deleted the swap partition by mistake
I accidently deleted the swap partition through Windows’ disk management and when booting into Manjaro, I encountered a grub error (unknown filesystem). I need to get back to my linux environment.
Boot a live ISO and recreate the missing swap partition with GParted or any other partitioning tool. Then readout the UUID of the swap partition, mount your / partition and set the correct UUID in your /etc/fstab file.
More details are here:
https://wiki.manjaro.org/index.php?title=Swap
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
