Deleted an orphaned package and broke my aur downloading ability
Hi! I was trying to remove the orphaned package phonon-qt5
checking dependencies...
:: removing phonon-qt5 breaks dependency 'phonon-qt5' required by phonon-qt5-gstreamer
I force removed these two hoping to manually re install them and the orphaned package was just a redundancy. (Previously these two packages also failed to update giving only and exit 4 error)
Now I cant install them at all:
sudo pacman -S phonon-qt5-gstreamer
error: target not found: phonon-qt5-gstreamer
This is what I get now when i just try to up date the who system
 core is up to date
 extra is up to date
 multilib is up to date
:: Searching AUR for updates...
:: Searching databases for updates...
 -> 1 error occurred:
        * request failed: Get "https://aur.archlinux.org/rpc?arg%5B%5D=libva-vdpau-driver&arg%5B%5D=neofetch&arg%5B%5D=reiserfsprogs&type=info&v=5": EOF
then when I try to download it I get:
-> Failed to install the following packages. Manual intervention is required:
libva-vdpau-driver - exit status 15
completely unsure how to fix this, I’d appreciate some help. This is on kernel 6.1.147-2. On kernel 6.12.41-1 every aur I try to download exits with exit status 15
That’s perfectly logical, because phonon-qt5-gstreamer is an AUR package, and pacman doesn’t have any access to the AUR.
What are you updating with? Is that from pacman or from pamac?
Anyway, the AUR currently has a problem, as you may have heard. The Arch servers and the AUR server are currently enduring an ongoing DDoS attack.
Script kiddies with big ego’s and small minds…
I’m a bit puzzled. Do you really use ReiserFS? Also this ‘libva-vdpau-driver’ - i mean wouldn’t one rather use the driver from the official Arch repository like ‘libvdpau-va-gl’?
Instead of trying to update those 3 packages, probably the better option is to just run the following command to remove them from your system:
sudo pacman -Rns libva-vdpau-driver neofetch reiserfsprogs
libva-vdpau-driver was moved to the AUR in March, 2025. You most likely don’t need it (I think that driver is now included in the mesa package).
neofetch has not been updated since 2020, and has been moved to the AUR. Instead, try using fastfetch:
sudo pacman -Syu fastfetch
ReiserFS was removed from the kernel last year:
So, unless you are running a kernel version earlier than 6.13, and have a partition formatted as ReiserFS, reiserfsprogs should not be on your system
I was a bit sleepy my bad on trying to re install with pacman, here are the are the errors installing with yay
-> error making: phonon-gstreamer-exit status 8
phonon-qt5 - exit status 15
phonon-qt5-gstreamer - exit status 8
Are you confident that you really need this package?
I am pretty confident he doesn’t :slight_smile:
As a novice user, obviously unaqquained with the way to properly update an arch system (cause you broke several of the rules below), i strongly recommend:
  • Updating the core system first with pacman and then rebuilding the aur stuff with yay
  • Never do a full update with yay, since it will pull aur stuff instead of the repo versions
  • Removing orphans decreases the number or dependencies
  • Never install critical system packages like video drivers from aur instead of the repos, aur is for stuff not found in repos
  • Do not use aur if on stable branch, since the libraries versions are different. If you need aur switch to unstable branch
  • To be honest - as a beginner, just do not use aur. It adds another level of complexity you do not need as a beginner. It might be better to use flatpaks, because you cannot break the system with them, and you can with aur
  • Oh, i forgot - read the second post of the fine announcements!
Not you can try to work your way through that points :slight_smile: If you realize you do not need qt5 packages because they are replaced with qt6 versions, it will be some start. Actually, if you have done the update with pacman it would have asked about that. It even suggest the right answer (which is wrong in this case as i wrote in the announcement FAQ).
@negativeprice
Please provide system information as described (below).
You stated that you removed phonon-qt5-gstreamer and phonon-qt5 (for whatever reason) and now you cannot install them again.
That’s perfectly understandable, as neither package exists in the official Manjaro repositories any longer. The same goes for libva-vdpau-driver.
These packages were dropped to the AUR because (being qt5-based) they are no longer required by any official packages (Note: they may still possibly be a dependency of some outdated software installed via the AUR).
There is a phonon-qt6 package which I suggest you install;
sudo pacman -S phonon-qt6
and possibly these as well, while you’re at it:
sudo pacman -S phonon-qt6-vlc vlc-plugins-all
From what I’ve managed to glean from the limited information provided, there seems to be a problem with your strategy for performing updates.
A notice similar to the following appeared in a recent Update Announcement under Known Issues and Solutions.
This hopefully spells it out a little more clearly:
Update official repo packages FIRST before the AUR
I hope this is helpful.
Mod edit:- yay commands updated.
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8c0
Highly Recommended
Technical Resources
Required Reading
Abandoned topic (30+ days)
