Delete key not working as expected
Hi everyone.
Recently delete key is behaving a bit strange.
In the beginning I found it on Gnome Text, but it also happens in Files.
When I hit delete key to erase characters from a text, it displays some weird character instead (picture below).
I am using a Dell wireless keyboard and mouse combo.
inxi -Fz
  Kernel: 6.9.12-3-MANJARO arch: x86_64 bits: 64
  Desktop: GNOME v: 46.4 Distro: Manjaro Linux
  Type: Desktop Mobo: Gigabyte model: 990FXA-UD5 serial: N/A
    UEFI: American Megatrends v: FC date: 06/24/2015
  Info: 8-core model: AMD FX-8350 bits: 64 type: MCP cache: L2: 8 MiB
  Speed (MHz): avg: 4000 min/max: 1400/4000 cores: 1: 4000 2: 4000 3: 4000
    4: 4000 5: 4000 6: 4000 7: 4000 8: 4000
  Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] driver: nvidia v: 550.90.07
  Display: unspecified server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
    driver: X: loaded: N/A failed: nvidia gpu: nvidia resolution:
    1: 1920x1080~60Hz 2: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: kms_swrast,nvidia,swrast
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.90.07
    renderer: NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2
  Device-1: Advanced Micro Devices [AMD/ATI] SBx00 Azalia
    driver: snd_hda_intel
  Device-2: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
  API: ALSA v: k6.9.12-3-MANJARO status: kernel-api
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi
  IF: wlp4s0 state: down mac: <filter>
    driver: r8169
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel AX200 Bluetooth driver: btusb type: USB
  Local Storage: total: 689.33 GiB used: 225.41 GiB (32.7%)
  ID-1: /dev/nvme0n1 vendor: Western Digital model: WD Green SN350 500GB
    2G0C size: 465.76 GiB
  ID-2: /dev/sda vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB
  ID-1: / size: 223.27 GiB used: 62.45 GiB (28.0%) fs: btrfs dev: /dev/sda2
  ID-2: /boot/efi size: 299.4 MiB used: 584 KiB (0.2%) fs: vfat
    dev: /dev/sda1
  ID-3: /home size: 223.27 GiB used: 62.45 GiB (28.0%) fs: btrfs
    dev: /dev/sda2
  ID-4: /var/log size: 223.27 GiB used: 62.45 GiB (28.0%) fs: btrfs
    dev: /dev/sda2
  System Temperatures: cpu: 47.9 C mobo: N/A gpu: nvidia temp: 51 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
  Memory: total: 32 GiB available: 31.3 GiB used: 14.02 GiB (44.8%)
  Processes: 378 Uptime: 1h 29m Shell: Sudo inxi: 3.3.36
lsusb -v
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            9 Hub
  bDeviceSubClass         0 [unknown]
  bDeviceProtocol         0 Full speed (or root) hub
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0001 1.1 root hub
  bcdDevice            6.09
  iManufacturer           3 Linux 6.9.12-3-MANJARO ohci_hcd
  iProduct                2 OHCI PCI host controller
  iSerial                 1 0000:00:12.0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 [unknown]
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0002  1x 2 bytes
        bInterval             255
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             5
  wHubCharacteristic 0x000b
    No power switching (usb 1.0)
    Per-port overcurrent protection
  bPwrOn2PwrGood        2 * 2 milli seconds
  bHubContrCurrent      0 milli Ampere
  DeviceRemovable    0x00
  PortPwrCtrlMask    0xff
 Hub Port Status:
   Port 1: 0000.0100 power
   Port 2: 0000.0100 power
   Port 3: 0000.0100 power
   Port 4: 0000.0100 power
   Port 5: 0000.0100 power
Device Status:     0x0001
  Self Powered
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  idProduct          0x0002 2.0 root hub
  bcdDevice            6.09
  iManufacturer           3 Linux 6.9.12-3-MANJARO ehci_hcd
  iProduct                2 EHCI Host Controller
  iSerial                 1 0000:00:12.2
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             5
  wHubCharacteristic 0x000a
  bPwrOn2PwrGood       10 * 2 milli seconds
 Hub Port Status:
  Self Powered
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            6.09
  iSerial                 1 0000:00:13.2
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             5
 Hub Port Status:
  Self Powered
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            6.09
  iSerial                 1 0000:00:16.2
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             4
 Hub Port Status:
   Port 4: 0000.0503 highspeed power enable connect
  Self Powered
Bus 004 Device 002: ID 058f:6366 Alcor Micro Corp. Multi Flash Reader
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 [unknown]
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x058f Alcor Micro Corp.
  idProduct          0x6366 Multi Flash Reader
  bcdDevice            1.00
  iManufacturer           1 Generic
  iProduct                2 Mass Storage Device
  iSerial                 3 058F63666471
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0020
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass         8 Mass Storage
      bInterfaceSubClass      6 SCSI
      bInterfaceProtocol     80 Bulk-Only
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceProtocol         0
  bMaxPacketSize0        64
Device Status:     0x0000
  (Bus Powered)
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            6.09
  iSerial                 1 0000:00:13.0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval             255
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             5
 Hub Port Status:
   Port 1: 0000.0107 power suspend enable connect
   Port 3: 0000.0103 power enable connect
  Self Powered
Bus 005 Device 002: ID 8087:0029 Intel Corp. AX200 Bluetooth
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.01
  bDeviceClass          224 Wireless
  bDeviceSubClass         1 Radio Frequency
  bDeviceProtocol         1 Bluetooth
  bMaxPacketSize0        64
  idVendor           0x8087 Intel Corp.
  idProduct          0x0029 AX200 Bluetooth
  bcdDevice            0.01
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x00c8
    bNumInterfaces          2
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceClass       224 Wireless
      bInterfaceSubClass      1 Radio Frequency
      bInterfaceProtocol      1 Bluetooth
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x03  EP 3 OUT
        bmAttributes            1
          Transfer Type            Isochronous
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0000  1x 0 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0009  1x 9 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       2
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0011  1x 17 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       3
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0019  1x 25 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       4
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0021  1x 33 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       5
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0031  1x 49 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       6
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x003f  1x 63 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
Binary Object Store Descriptor:
  bLength                 5
  bDescriptorType        15
  wTotalLength       0x000c
  bNumDeviceCaps          1
  USB 2.0 Extension Device Capability:
    bLength                 7
    bDescriptorType        16
    bDevCapabilityType      2
    bmAttributes   0x0000040e
      BESL Link Power Management (LPM) Supported
    BESL value     1024 us
  Self Powered
Bus 005 Device 003: ID 413c:2514 Dell Computer Corp. Dell Universal Receiver
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceProtocol         0
  bMaxPacketSize0        32
  idVendor           0x413c Dell Computer Corp.
  idProduct          0x2514 Dell Universal Receiver
  bcdDevice            2.22
  iManufacturer           1 Dell Computer Corp
  iProduct                2 Dell Universal Receiver
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0054
    bNumInterfaces          3
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3 Human Interface Device
      bInterfaceSubClass      1 Boot Interface Subclass
      bInterfaceProtocol      1 Keyboard
      iInterface              0
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bCountryCode            0 Not supported
          bNumDescriptors         1
          bDescriptorType        34 Report
          wDescriptorLength      59
          Report Descriptors:
            ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      2 Mouse
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bNumDescriptors         1
          wDescriptorLength     127
          Report Descriptors:
            ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               2
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bNumDescriptors         1
          wDescriptorLength      47
          Report Descriptors:
            ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0020  1x 32 bytes
        bInterval               2
  (Bus Powered)
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            6.09
  iSerial                 1 0000:00:14.5
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval             255
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             2
 Hub Port Status:
  Self Powered
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            6.09
  iSerial                 1 0000:00:16.0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval             255
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             4
 Hub Port Status:
  Self Powered
Bus 008 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  bcdDevice            6.09
  iManufacturer           3 Linux 6.9.12-3-MANJARO xhci-hcd
  iProduct                2 xHCI Host Controller
  iSerial                 1 0000:01:00.2
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             2
    TT think time 8 FS bits
 Hub Port Status:
  Self Powered
Bus 009 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               3.10
  bDeviceClass            9 Hub
  bDeviceProtocol         3
  bMaxPacketSize0         9
  idProduct          0x0003 3.0 root hub
  bcdDevice            6.09
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x001f
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
        bMaxBurst               0
  bLength                 5
  bDescriptorType        15
  wTotalLength       0x002b
  bNumDeviceCaps          2
  SuperSpeed USB Device Capability:
    bLength                10
    bDescriptorType        16
    bDevCapabilityType      3
    bmAttributes         0x00
    wSpeedsSupported   0x0008
      Device can operate at SuperSpeed (5Gbps)
    bFunctionalitySupport   1
      Lowest fully-functional device speed is Full Speed (12Mbps)
    bU1DevExitLat           0 micro seconds
    bU2DevExitLat           0 micro seconds
  SuperSpeedPlus USB Device Capability:
    bLength                28
    bDescriptorType        16
    bDevCapabilityType     10
    bmAttributes         0x00000023
      Sublink Speed Attribute count 4
      Sublink Speed ID count 2
    wFunctionalitySupport   0x1104
      Min functional Speed Attribute ID: 4
      Min functional RX lanes: 1
      Min functional TX lanes: 1
    bmSublinkSpeedAttr[0]   0x00050034
      Speed Attribute ID: 4 5Gb/s Symmetric RX SuperSpeed
    bmSublinkSpeedAttr[1]   0x000500b4
      Speed Attribute ID: 4 5Gb/s Symmetric TX SuperSpeed
    bmSublinkSpeedAttr[2]   0x000a4035
      Speed Attribute ID: 5 10Gb/s Symmetric RX SuperSpeedPlus
    bmSublinkSpeedAttr[3]   0x000a40b5
      Speed Attribute ID: 5 10Gb/s Symmetric TX SuperSpeedPlus
Hub Descriptor:
  bLength              12
  bDescriptorType      42
  nNbrPorts             4
  bPwrOn2PwrGood       50 * 2 milli seconds
  bHubDecLat          0.0 micro seconds
  wHubDelay             0 nano seconds
 Hub Port Status:
   Port 1: 0000.02a0 5Gbps power Rx.Detect
   Port 2: 0000.02a0 5Gbps power Rx.Detect
   Port 3: 0000.02a0 5Gbps power Rx.Detect
   Port 4: 0000.02a0 5Gbps power Rx.Detect
  Self Powered
Bus 010 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            6.09
  iSerial                 1 0000:02:00.0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             2
  wHubCharacteristic 0x0009
    Per-port power switching
 Hub Port Status:
  Self Powered
Bus 011 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               3.00
  bDeviceClass            9 Hub
  bDeviceProtocol         3
  bMaxPacketSize0         9
  bcdDevice            6.09
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x001f
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
        bMaxBurst               0
  bLength                 5
  bDescriptorType        15
  wTotalLength       0x000f
  bNumDeviceCaps          1
    bLength                10
    bDescriptorType        16
    bmAttributes         0x00
Hub Descriptor:
  bLength              12
  bDescriptorType      42
  nNbrPorts             2
 Hub Port Status:
  Self Powered
Bus 012 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            6.09
  iSerial                 1 0000:08:00.0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             2
 Hub Port Status:
  Self Powered
Bus 013 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               3.00
  bDeviceClass            9 Hub
  bDeviceProtocol         3
  bMaxPacketSize0         9
  bcdDevice            6.09
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x001f
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
        bMaxBurst               0
  bLength                 5
  bDescriptorType        15
  wTotalLength       0x000f
  bNumDeviceCaps          1
    bLength                10
    bDescriptorType        16
    bmAttributes         0x00
Hub Descriptor:
  bLength              12
  bDescriptorType      42
  nNbrPorts             2
 Hub Port Status:
  Self Powered
Appreciate any help.
Hi @danilo-jlle,
Is the correct keyboard layout listed in the output of:
localectl
Did you perhaps did something or install something that could have changed the keyboard’s key mapping?
Edit:
Also check the correct layout is set in /etc/vconsole.conf:
cat /etc/vconsole.conf
Hi.
I think so.
Libreoffice Writer and other software work as expected.
I’ve observed this behavior only in Text Editor and Files.
Maybe something in Gnome?
locatectl
System Locale: LANG=pt_BR.UTF-8
    VC Keymap: br-abnt2
   X11 Layout: br
KEYMAP=br-abnt2
My Pamac history
[2024-09-11T13:35:24-0300] [ALPM] upgraded epson-inkjet-printer-escpr2 (1.2.15-1 -> 1.2.16-1)
[2024-09-11T13:34:47-0300] [ALPM] upgraded gnome-shell-extension-arc-menu (58-1 -> 59-1)
[2024-09-08T10:40:03-0300] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m Printing support installede[1;0m
[2024-09-08T10:40:03-0300] [ALPM] upgraded manjaro-gnome-settings (20240812-1 -> 20240907-1)
[2024-09-06T18:04:18-0300] [ALPM] upgraded manjaro-gnome-extension-settings (20240826-1 -> 20240906-1)
[2024-09-06T18:04:18-0300] [ALPM] upgraded gnome-shell-extension-dash-to-dock (95-1 -> 96-1)
[2024-09-05T16:10:11-0300] [ALPM] upgraded inxi (3.3.35.1-1 -> 3.3.36.1-1)
[2024-09-04T11:12:32-0300] [ALPM] upgraded firefox-i18n-pt-br (129.0.2-1 -> 130.0-1)
[2024-09-04T11:12:32-0300] [ALPM] upgraded firefox-i18n-en-us (129.0.2-1 -> 130.0-1)
[2024-09-04T11:12:32-0300] [ALPM] upgraded firefox (129.0.2-1 -> 130.0-1)
[2024-09-03T14:16:36-0300] [ALPM] upgraded chromium (128.0.6613.113-1 -> 128.0.6613.119-1)
[2024-09-03T08:02:43-0300] [ALPM] upgraded xdg-dbus-proxy (0.1.5-2 -> 0.1.6-1)
[2024-09-03T08:02:43-0300] [ALPM] upgraded touche (2.0.12-3 -> 2.0.14-1)
[2024-09-03T08:02:43-0300] [ALPM] upgraded systemd-sysvcompat (256.4-1 -> 256.5-1)
[2024-09-03T08:02:43-0300] [ALPM] upgraded python-protobuf (27.3-1 -> 27.3-2)
[2024-09-03T08:02:43-0300] [ALPM] upgraded python-cachetools (5.3.2-3 -> 5.3.3-1)
[2024-09-03T08:02:42-0300] [ALPM] upgraded pipewire-pulse (1:1.2.2-2 -> 1:1.2.3-1)
[2024-09-03T08:02:42-0300] [ALPM] upgraded pipewire-alsa (1:1.2.2-2 -> 1:1.2.3-1)
[2024-09-03T08:02:42-0300] [ALPM] upgraded pipewire-audio (1:1.2.2-2 -> 1:1.2.3-1)
[2024-09-03T08:02:42-0300] [ALPM] upgraded nfs-utils (2.6.4-1 -> 2.7.1-1)
[2024-09-03T08:02:42-0300] [ALPM] upgraded nfsidmap (2.6.4-1 -> 2.7.1-1)
[2024-09-03T08:02:42-0300] [ALPM] upgraded mariadb-libs (11.4.3-1 -> 11.5.2-1)
[2024-09-03T08:02:42-0300] [ALPM] upgraded manjaro-release (24.0.7-1 -> 24.0.8-1)
[2024-09-03T08:02:42-0300] [ALPM] upgraded luajit (2.1.1720049189-1 -> 2.1.1723675123-1)
[2024-09-03T08:02:42-0300] [ALPM] upgraded liburing (2.6-2 -> 2.7-1)
[2024-09-03T08:02:41-0300] [ALPM] upgraded libreoffice-still-pt-br (7.6.7-1 -> 24.2.5-1)
[2024-09-03T08:02:41-0300] [ALPM] upgraded libreoffice-still-pt (7.6.7-1 -> 24.2.5-1)
[2024-09-03T08:02:40-0300] [ALPM] upgraded libreoffice-still (7.6.7-1 -> 24.2.5-1)
[2024-09-03T08:02:37-0300] [ALPM] upgraded libpcap (1.10.4-1 -> 1.10.4-2)
[2024-09-03T08:02:37-0300] [ALPM] upgraded libjuice (1.5.1-1 -> 1.5.2-1)
[2024-09-03T08:02:37-0300] [ALPM] upgraded libimobiledevice (1.3.0-13 -> 1.3.0-14)
[2024-09-03T08:02:37-0300] [ALPM] upgraded libcacard (2.7.0-4 -> 2.8.1-1)
[2024-09-03T08:02:37-0300] [ALPM] upgraded gst-plugins-ugly (1.24.6-1 -> 1.24.7-1)
[2024-09-03T08:02:37-0300] [ALPM] upgraded gst-plugins-good (1.24.6-1 -> 1.24.7-1)
[2024-09-03T08:02:37-0300] [ALPM] upgraded taglib (2.0.1-1 -> 2.0.2-1)
[2024-09-03T08:02:37-0300] [ALPM] upgraded gst-plugins-base (1.24.6-1 -> 1.24.7-1)
[2024-09-03T08:02:37-0300] [ALPM] upgraded gst-plugins-bad (1.24.6-1 -> 1.24.7-1)
[2024-09-03T08:02:37-0300] [ALPM] upgraded gst-plugin-pipewire (1:1.2.2-2 -> 1:1.2.3-1)
[2024-09-03T08:02:37-0300] [ALPM] upgraded gst-plugin-gtk (1.24.6-1 -> 1.24.7-1)
[2024-09-03T08:02:37-0300] [ALPM] upgraded gst-libav (1.24.6-1 -> 1.24.7-1)
[2024-09-03T08:02:37-0300] [ALPM] upgraded gst-editing-services (1.24.6-1 -> 1.24.7-1)
[2024-09-03T08:02:37-0300] [ALPM] upgraded gst-python (1.24.6-1 -> 1.24.7-1)
[2024-09-03T08:02:37-0300] [ALPM] upgraded gst-devtools-libs (1.24.6-1 -> 1.24.7-1)
[2024-09-03T08:02:37-0300] [ALPM] upgraded gnome-desktop-4 (1:44.0-1 -> 1:44.1-1)
[2024-09-03T08:02:37-0300] [ALPM] upgraded gnome-desktop (1:44.0-1 -> 1:44.1-1)
[2024-09-03T08:02:37-0300] [ALPM] upgraded gnome-desktop-common (1:44.0-1 -> 1:44.1-1)
[2024-09-03T08:02:37-0300] [ALPM] upgraded fwupd (1.9.23-1 -> 1.9.24-1)
[2024-09-03T08:02:30-0300] [ALPM] upgraded protobuf (27.3-1 -> 27.3-2)
[2024-09-03T08:02:30-0300] [ALPM] upgraded fragments (3.0.1-1 -> 3.0.1-2)
[2024-09-03T08:02:30-0300] [ALPM] upgraded firefox-i18n-pt-br (129.0.1-1 -> 129.0.2-1)
[2024-09-03T08:02:30-0300] [ALPM] upgraded firefox-i18n-en-us (129.0.1-1 -> 129.0.2-1)
[2024-09-03T08:02:30-0300] [ALPM] upgraded firefox (129.0.1-2 -> 129.0.2-1)
[2024-09-03T08:02:29-0300] [ALPM] upgraded fakeroot (1.35.1-1 -> 1.36-1)
[2024-09-03T08:02:29-0300] [ALPM] upgraded easyeffects (7.1.7-1 -> 7.1.8-1)
[2024-09-03T08:02:28-0300] [ALPM] upgraded pipewire (1:1.2.2-2 -> 1:1.2.3-1)
[2024-09-03T08:02:28-0300] [ALPM] upgraded libpipewire (1:1.2.2-2 -> 1:1.2.3-1)
[2024-09-03T08:02:28-0300] [ALPM] upgraded calibre (7.16.0-1 -> 7.17.0-1)
[2024-09-03T08:02:27-0300] [ALPM] upgraded libwmf (0.2.13-2 -> 0.2.13-3)
[2024-09-03T08:02:27-0300] [ALPM] upgraded blender (17:4.2.0-5 -> 17:4.2.1-1)
[2024-09-03T08:02:26-0300] [ALPM] upgraded usd (24.08-1 -> 24.08-2)
[2024-09-03T08:02:25-0300] [ALPM] upgraded qt6-base (6.7.2-1 -> 6.7.2-2)
[2024-09-03T08:02:25-0300] [ALPM] upgraded libinput (1.26.1-1 -> 1.26.2-1)
[2024-09-03T08:02:25-0300] [ALPM] upgraded gst-plugins-bad-libs (1.24.6-1 -> 1.24.7-1)
[2024-09-03T08:02:25-0300] [ALPM] upgraded gst-plugins-base-libs (1.24.6-1 -> 1.24.7-1)
[2024-09-03T08:02:24-0300] [ALPM] upgraded gstreamer (1.24.6-1 -> 1.24.7-1)
[2024-09-03T08:02:24-0300] [ALPM] upgraded ffmpeg (2:7.0.1-2 -> 2:7.0.2-1)
[2024-09-03T08:02:24-0300] [ALPM] upgraded v4l-utils (1.26.1-1 -> 1.28.1-1)
[2024-09-03T08:02:24-0300] [ALPM] upgraded libbluray (1.3.4-1 -> 1.3.4-2)
[2024-09-03T08:02:24-0300] [ALPM] upgraded ayatana-ido (0.10.3-1 -> 0.10.4-1)
[2024-09-03T08:02:24-0300] [ALPM] upgraded python (3.12.4-1 -> 3.12.5-1)
[2024-09-03T08:02:22-0300] [ALPM] upgraded systemd (256.4-1 -> 256.5-1)
[2024-09-03T08:02:21-0300] [ALPM] upgraded kmod (33-1 -> 33-2)
[2024-09-03T08:02:21-0300] [ALPM] upgraded systemd-libs (256.4-1 -> 256.5-1)
[2024-09-03T08:02:21-0300] [ALPM] upgraded pambase (20230918-1 -> 20230918-2)
[2024-09-03T08:02:21-0300] [ALPM] upgraded libsasl (2.1.28-4 -> 2.1.28-5)
[2024-09-03T08:02:21-0300] [ALPM] upgraded lmdb (0.9.32-1 -> 0.9.33-1)
[2024-09-03T08:02:21-0300] [ALPM] upgraded alsa-card-profiles (1:1.2.2-2 -> 1:1.2.3-1)
[2024-08-30T13:13:03-0300] [ALPM] upgraded chromium (128.0.6613.84-1 -> 128.0.6613.113-1)
[2024-08-28T18:39:03-0300] [ALPM] upgraded gnome-shell-extension-dash-to-dock (94-1 -> 95-1)
[2024-08-28T13:52:23-0300] [ALPM] upgraded manjaro-printer (20240718-1 -> 20240827-1)
[2024-08-28T13:52:23-0300] [ALPM] installed foomatic-db-engine (5:20200131-1)
[2024-08-28T13:52:23-0300] [ALPM] installed perl-dbi (1.643-7)
[2024-08-28T13:52:23-0300] [ALPM] installed perl-xml-libxml (2.0210-1)
[2024-08-28T13:52:23-0300] [ALPM] installed perl-xml-sax (1.02-2)
[2024-08-28T13:52:23-0300] [ALPM] installed perl-xml-namespacesupport (1.12-6)
[2024-08-28T13:52:23-0300] [ALPM] installed perl-xml-sax-base (1.09-6)
[2024-08-28T13:52:23-0300] [ALPM] installed perl-alien-libxml2 (0.19-3)
[2024-08-28T13:52:23-0300] [ALPM] installed perl-alien-build (2.83-1)
[2024-08-28T13:52:23-0300] [ALPM] installed perl-path-tiny (0.146-1)
[2024-08-28T13:52:23-0300] [ALPM] installed perl-file-which (1.27-4)
[2024-08-28T13:52:23-0300] [ALPM] installed perl-file-chdir (0.1011-6)
[2024-08-28T13:52:23-0300] [ALPM] installed perl-ffi-checklib (0.31-4)
[2024-08-28T13:52:23-0300] [ALPM] installed perl-capture-tiny (0.48-8)
[2024-08-26T16:32:03-0300] [ALPM] upgraded epson-inkjet-printer-escpr2 (1.2.14-1 -> 1.2.15-1)
[2024-08-26T16:31:26-0300] [ALPM] upgraded manjaro-gnome-extension-settings (20231213-3 -> 20240826-1)
[2024-08-26T16:31:26-0300] [ALPM] upgraded gnome-shell-extension-dash-to-dock (93-1 -> 94-1)
[2024-08-22T15:49:36-0300] [ALPM] upgraded chromium (128.0.6613.36-1 -> 128.0.6613.84-1)
[2024-08-20T11:12:08-0300] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m Printing support installede[1;0m
[2024-08-20T11:08:35-0300] [ALPM] upgraded xmlsec (1.3.4-1 -> 1.3.5-1)
[2024-08-20T11:08:35-0300] [ALPM] upgraded webkit2gtk (2.44.2-1 -> 2.44.3-3)
[2024-08-20T11:08:34-0300] [ALPM] upgraded vte3 (0.76.3-1 -> 0.76.4-1)
[2024-08-20T11:08:34-0300] [ALPM] upgraded vte-common (0.76.3-1 -> 0.76.4-1)
[2024-08-20T11:08:34-0300] [ALPM] upgraded v86d (0.1.10-7 -> 0.1.10-8)
[2024-08-20T11:08:34-0300] [ALPM] upgraded thin-provisioning-tools (1.0.13-1 -> 1.1.0-1)
[2024-08-20T11:08:34-0300] [ALPM] upgraded syncthing (1.27.9-1 -> 1.27.10-1)
[2024-08-20T11:08:34-0300] [ALPM] upgraded suitesparse (7.7.0-2 -> 7.8.1-1)
[2024-08-20T11:08:34-0300] [ALPM] upgraded sigil (2.2.1-1 -> 2.3.0-1)
[2024-08-20T11:08:34-0300] [ALPM] upgraded samba (4.20.3-1 -> 4.20.4-1)
[2024-08-20T11:08:33-0300] [ALPM] upgraded rpcbind (1.2.6-4 -> 1.2.7-1)
[2024-08-20T11:08:33-0300] [ALPM] upgraded python-yaml (6.0.1-4 -> 6.0.2-1)
[2024-08-20T11:08:33-0300] [ALPM] upgraded python-validate-pyproject (0.18-1 -> 0.19-1)
[2024-08-20T11:08:33-0300] [ALPM] upgraded python-pyopenssl (24.1.0-1 -> 24.2.1-1)
[2024-08-20T11:08:33-0300] [ALPM] upgraded python-py7zr (0.21.1-1 -> 0.22.0-1)
[2024-08-20T11:08:33-0300] [ALPM] upgraded python-pyzstd (0.16.0-2 -> 0.16.1-1)
[2024-08-20T11:08:33-0300] [ALPM] upgraded python-markdown (3.6-3 -> 3.7-1)
[2024-08-20T11:08:33-0300] [ALPM] upgraded python-jaraco.text (3.14.0-1 -> 4.0.0-1)
[2024-08-20T11:08:33-0300] [ALPM] upgraded python-jaraco.functools (4.0.1-1 -> 4.0.2-1)
[2024-08-20T11:08:33-0300] [ALPM] upgraded python-google-api-python-client (2.123.0-2 -> 2.140.0-1)
[2024-08-20T11:08:33-0300] [ALPM] upgraded python-google-api-core (2.18.0-2 -> 2.19.1-1)
[2024-08-20T11:08:33-0300] [ALPM] upgraded python-protobuf (27.2-1 -> 27.3-1)
[2024-08-20T11:08:33-0300] [ALPM] upgraded python-cryptography (42.0.6-1 -> 42.0.7-1)
[2024-08-20T11:08:33-0300] [ALPM] upgraded python-apsw (3.46.0.1-1 -> 3.46.1.0-1)
[2024-08-20T11:08:33-0300] [ALPM] upgraded pybind11 (2.13.1-2 -> 2.13.4-1)
[2024-08-20T11:08:33-0300] [ALPM] upgraded pipewire-alsa (1:1.2.2-1 -> 1:1.2.2-2)
[2024-08-20T11:08:33-0300] [ALPM] upgraded opencv (4.10.0-3 -> 4.10.0-4)
[2024-08-20T11:08:32-0300] [ALPM] upgraded networkmanager (1.48.6-1 -> 1.48.8-1)
[2024-08-20T11:08:32-0300] [ALPM] upgraded pcsclite (2.2.3-1 -> 2.3.0-1)
[2024-08-20T11:08:32-0300] [ALPM] upgraded mariadb-libs (11.4.2-1 -> 11.4.3-1)
[2024-08-20T11:08:32-0300] [ALPM] upgraded manjaro-release (24.0.6-1 -> 24.0.7-1)
[2024-08-20T11:08:32-0300] [ALPM] upgraded manjaro-gnome-settings (20240610-1 -> 20240812-1)
[2024-08-20T11:08:32-0300] [ALPM] upgraded man-pages-pt_br (4.22.0-1 -> 4.23.1-1)
[2024-08-20T11:08:31-0300] [ALPM] upgraded linux69-headers (6.9.12-1 -> 6.9.12-3)
[2024-08-20T11:08:27-0300] [ALPM] upgraded linux69 (6.9.12-1 -> 6.9.12-3)
[2024-08-20T11:08:25-0300] [ALPM] upgraded linux-firmware (20240703.e94a2a3b-1 -> 20240809.59460076-1)
[2024-08-20T11:08:23-0300] [ALPM] upgraded linux-firmware-whence (20240703.e94a2a3b-1 -> 20240809.59460076-1)
[2024-08-20T11:08:23-0300] [ALPM] upgraded libxdp (1.4.2-1 -> 1.4.3-1)
[2024-08-20T11:08:23-0300] [ALPM] upgraded libvirt (1:10.5.0-2 -> 1:10.6.0-1)
[2024-08-20T11:08:23-0300] [ALPM] upgraded libphonenumber (1:8.13.40-1 -> 1:8.13.42-1)
[2024-08-20T11:08:23-0300] [ALPM] upgraded libheif (1.18.1-1 -> 1.18.2-1)
[2024-08-20T11:08:23-0300] [ALPM] upgraded libcamera (0.3.0-1 -> 0.3.1-2)
[2024-08-20T11:08:23-0300] [ALPM] upgraded libcamera-ipa (0.3.0-1 -> 0.3.1-2)
[2024-08-20T11:08:23-0300] [ALPM] upgraded kwindowsystem (6.4.0-1 -> 6.5.0-1)
[2024-08-20T11:08:23-0300] [ALPM] upgraded inkscape (1.3.2-8 -> 1.3.2-9)
[2024-08-20T11:08:21-0300] [ALPM] upgraded libimagequant (4.3.1-1 -> 4.3.3-1)
[2024-08-20T11:08:21-0300] [ALPM] upgraded python-soupsieve (2.5-3 -> 2.6-1)
[2024-08-20T11:08:21-0300] [ALPM] upgraded python-lxml (5.2.2-1 -> 5.3.0-1)
[2024-08-20T11:08:21-0300] [ALPM] upgraded python-coverage (7.6.0-1 -> 7.6.1-1)
[2024-08-20T11:08:21-0300] [ALPM] upgraded poppler-glib (24.06.1-1 -> 24.08.0-1)
[2024-08-20T11:08:21-0300] [ALPM] upgraded gst-plugin-pipewire (1:1.2.2-1 -> 1:1.2.2-2)
[2024-08-20T11:08:21-0300] [ALPM] upgraded gom (0.5.2-1 -> 0.5.3-1)
[2024-08-20T11:08:21-0300] [ALPM] upgraded go (2:1.22.5-1 -> 2:1.23.0-1)
[2024-08-20T11:08:19-0300] [ALPM] upgraded gnome-user-docs (46.1-1 -> 46.4-1)
[2024-08-20T11:08:15-0300] [ALPM] upgraded gnome-shell-extension-gtk4-desktop-icons-ng (1:79-1 -> 1:80-1)
[2024-08-20T11:08:15-0300] [ALPM] upgraded gnome-shell-extension-custom-accent-colors (11-1 -> 11-2)
[2024-08-20T11:08:15-0300] [ALPM] upgraded gnome-control-center (46.3-1 -> 46.4-1)
[2024-08-20T11:08:15-0300] [ALPM] upgraded libnvme (1.9-1 -> 1.10-1)
[2024-08-20T11:08:15-0300] [ALPM] upgraded gnome-keybindings (46.3-1 -> 46.4-1)
[2024-08-20T11:08:15-0300] [ALPM] upgraded smbclient (4.20.3-1 -> 4.20.4-1)
[2024-08-20T11:08:15-0300] [ALPM] upgraded libwbclient (4.20.3-1 -> 4.20.4-1)
[2024-08-20T11:08:15-0300] [ALPM] upgraded gnome-shell (1:46.3.1-1 -> 1:46.4-1)
[2024-08-20T11:08:14-0300] [ALPM] upgraded webkitgtk-6.0 (2.44.2-1 -> 2.44.3-3)
[2024-08-20T11:08:14-0300] [ALPM] upgraded mutter (46.3.1-1.1 -> 46.4-1)
[2024-08-20T11:08:14-0300] [ALPM] upgraded libtool (2.5.1-1 -> 2.5.1-2)
[2024-08-20T11:08:14-0300] [ALPM] upgraded tdb (1.4.11-1 -> 1.4.12-1)
[2024-08-20T11:08:14-0300] [ALPM] upgraded pipewire-pulse (1:1.2.2-1 -> 1:1.2.2-2)
[2024-08-20T11:08:14-0300] [ALPM] upgraded pipewire-audio (1:1.2.2-1 -> 1:1.2.2-2)
[2024-08-20T11:08:14-0300] [ALPM] upgraded xorg-xwayland (24.1.1-1 -> 24.1.2-1)
[2024-08-20T11:08:14-0300] [ALPM] upgraded libxfont2 (2.0.6-3 -> 2.0.7-1)
[2024-08-20T11:08:14-0300] [ALPM] upgraded libnm (1.48.6-1 -> 1.48.8-1)
[2024-08-20T11:08:14-0300] [ALPM] upgraded gnome-online-accounts (3.50.3-1 -> 3.50.4-1)
[2024-08-20T11:08:14-0300] [ALPM] upgraded libgoa (3.50.3-1 -> 3.50.4-1)
[2024-08-20T11:08:14-0300] [ALPM] upgraded gtk4 (1:4.14.4-2 -> 1:4.14.5-1)
[2024-08-20T11:08:13-0300] [ALPM] upgraded glibc-locales (2.40-1 -> 2.40+r16+gaa533d58ff-2)
[2024-08-20T11:08:12-0300] [ALPM] upgraded gcc (14.1.1+r309+gbb34b7eda1f-1 -> 14.2.1+r32+geccf707e5ce-1)
[2024-08-20T11:08:11-0300] [ALPM] upgraded fwupd (1.9.22-2 -> 1.9.23-1)
[2024-08-20T11:08:11-0300] [ALPM] upgraded protobuf-c (1.5.0-3 -> 1.5.0-4)
[2024-08-20T11:08:11-0300] [ALPM] upgraded protobuf (27.2-1 -> 27.3-1)
[2024-08-20T11:08:11-0300] [ALPM] upgraded freerdp (2:3.6.3-1 -> 2:3.7.0-1)
[2024-08-20T11:08:10-0300] [ALPM] upgraded webkit2gtk-4.1 (2.44.2-1 -> 2.44.3-3)
[2024-08-20T11:08:10-0300] [ALPM] upgraded fluidsynth (2.3.5-1 -> 2.3.6-1)
[2024-08-20T11:08:10-0300] [ALPM] upgraded flatpak (1:1.15.9-1 -> 1:1.15.10-1)
[2024-08-20T11:08:10-0300] [ALPM] upgraded pipewire (1:1.2.2-1 -> 1:1.2.2-2)
[2024-08-20T11:08:10-0300] [ALPM] upgraded libpipewire (1:1.2.2-1 -> 1:1.2.2-2)
[2024-08-20T11:08:10-0300] [ALPM] upgraded polkit (124-2 -> 125-1)
[2024-08-20T11:08:09-0300] [ALPM] upgraded firefox-i18n-pt-br (129.0-1 -> 129.0.1-1)
[2024-08-20T11:08:09-0300] [ALPM] upgraded firefox-i18n-en-us (129.0-1 -> 129.0.1-1)
[2024-08-20T11:08:09-0300] [ALPM] upgraded firefox (129.0-1 -> 129.0.1-2)
[2024-08-20T11:08:08-0300] [ALPM] upgraded libdovi (3.3.0-2 -> 3.3.1-1)
[2024-08-20T11:08:08-0300] [ALPM] upgraded libdeflate (1.20-2 -> 1.21-1)
[2024-08-20T11:08:08-0300] [ALPM] upgraded libssh (0.10.6-2 -> 0.11.0-2)
[2024-08-20T11:08:08-0300] [ALPM] upgraded fakeroot (1.35-1 -> 1.35.1-1)
[2024-08-20T11:08:08-0300] [ALPM] upgraded exfatprogs (1.2.4-1 -> 1.2.5-1)
[2024-08-20T11:08:08-0300] [ALPM] upgraded cups-filters (2.0.0-2 -> 2.0.1-1)
[2024-08-20T11:08:08-0300] [ALPM] upgraded poppler (24.06.1-1 -> 24.08.0-1)
[2024-08-20T11:08:08-0300] [ALPM] upgraded cracklib (2.10.1-1 -> 2.10.2-1)
[2024-08-20T11:08:08-0300] [ALPM] upgraded composefs (1.0.3-1 -> 1.0.4-1)
[2024-08-20T11:08:08-0300] [ALPM] upgraded chromium (127.0.6533.119-1 -> 128.0.6613.36-1)
[2024-08-20T11:08:07-0300] [ALPM] upgraded mpg123 (1.32.6-1 -> 1.32.7-1)
[2024-08-20T11:08:07-0300] [ALPM] upgraded mesa (1:24.1.5-1 -> 1:24.1.6-1)
[2024-08-20T11:08:07-0300] [ALPM] upgraded kmod (32-1 -> 33-1)
[2024-08-20T11:08:07-0300] [ALPM] upgraded hwdata (0.384-1 -> 0.385-1)
[2024-08-20T11:08:07-0300] [ALPM] upgraded libei (1.2.1-1 -> 1.3.0-1)
[2024-08-20T11:08:07-0300] [ALPM] upgraded libxtst (1.2.4-2 -> 1.2.5-1)
[2024-08-20T11:08:06-0300] [ALPM] upgraded gnutls (3.8.6-1 -> 3.8.7-1)
[2024-08-20T11:08:06-0300] [ALPM] upgraded gtk-update-icon-cache (1:4.14.4-2 -> 1:4.14.5-1)
[2024-08-20T11:08:06-0300] [ALPM] upgraded librsvg (2:2.58.2-1 -> 2:2.58.3-1)
[2024-08-20T11:08:06-0300] [ALPM] upgraded libx11 (1.8.9-1 -> 1.8.10-1)
[2024-08-20T11:08:06-0300] [ALPM] upgraded freetype2 (2.13.2-2 -> 2.13.3-1)
[2024-08-20T11:08:06-0300] [ALPM] upgraded nss (3.102.1-1 -> 3.103-1)
[2024-08-20T11:08:06-0300] [ALPM] upgraded bubblewrap (0.9.0-1 -> 0.10.0-1)
[2024-08-20T11:08:06-0300] [ALPM] upgraded btrfs-progs (6.10-1 -> 6.10.1-1)
[2024-08-20T11:08:06-0300] [ALPM] upgraded box2d (2.4.1-2 -> 2.4.2-1)
[2024-08-20T11:08:05-0300] [ALPM] upgraded binutils (2.42+r195+g29ae8b8ea71-1 -> 2.43+r4+g7999dae6961-1)
[2024-08-20T11:08:05-0300] [ALPM] upgraded curl (8.9.1-1 -> 8.9.1-2)
[2024-08-20T11:08:05-0300] [ALPM] upgraded ca-certificates-mozilla (3.102.1-1 -> 3.103-1)
[2024-08-20T11:08:05-0300] [ALPM] upgraded apparmor (3.1.7-2 -> 3.1.7-3)
[2024-08-20T11:08:05-0300] [ALPM] upgraded libtirpc (1.3.4-1 -> 1.3.5-1)
[2024-08-20T11:08:05-0300] [ALPM] upgraded audit (4.0.1-3 -> 4.0.2-1)
[2024-08-20T11:08:05-0300] [ALPM] upgraded sqlite (3.46.0-1 -> 3.46.1-1)
[2024-08-20T11:08:05-0300] [ALPM] upgraded bash (5.2.026-3 -> 5.2.032-1)
[2024-08-20T11:08:05-0300] [ALPM] upgraded readline (8.2.010-1 -> 8.2.013-1)
[2024-08-20T11:08:05-0300] [ALPM] upgraded amd-ucode (20240703.e94a2a3b-1 -> 20240809.59460076-1)
[2024-08-20T11:08:05-0300] [ALPM] upgraded alsa-card-profiles (1:1.2.2-1 -> 1:1.2.2-2)
[2024-08-20T11:08:05-0300] [ALPM] upgraded adw-gtk-theme (1.1-2 -> 5.3-3)
[2024-08-20T11:08:05-0300] [ALPM] upgraded abseil-cpp (20240116.2-2 -> 20240722.0-1)
[2024-08-20T11:08:04-0300] [ALPM] upgraded gtest (1.14.0-2 -> 1.15.2-1)
[2024-08-20T11:08:04-0300] [ALPM] upgraded gcc-libs (14.1.1+r309+gbb34b7eda1f-1 -> 14.2.1+r32+geccf707e5ce-1)
[2024-08-20T11:08:01-0300] [ALPM] upgraded glibc (2.40-1 -> 2.40+r16+gaa533d58ff-2)
[2024-08-20T11:08:00-0300] [ALPM] removed adw-gtk3 (5.3-1)
[2024-08-16T09:35:52-0300] [ALPM] upgraded gtksourceview-pkgbuild (5-1 -> 5-2)
[2024-08-14T11:41:05-0300] [ALPM] upgraded chromium (127.0.6533.99-1 -> 127.0.6533.119-1)
[2024-08-12T17:17:32-0300] [ALPM] upgraded iriunwebcam-bin (2.8.2-3 -> 2.8.3-1)
[2024-08-12T13:20:52-0300] [ALPM] installed easyeffects (7.1.7-1)
[2024-08-12T13:20:51-0300] [ALPM] installed zita-convolver (4.0.3-4)
[2024-08-11T17:50:12-0300] [ALPM] installed manjaro-pipewire (20231009-1)
[2024-08-11T17:50:12-0300] [ALPM] installed pipewire-pulse (1:1.2.2-1)
[2024-08-11T17:50:12-0300] [ALPM] removed pulseaudio (17.0-3)
[2024-08-11T17:49:54-0300] [ALPM] removed pulseaudio-bluetooth (17.0-3)
[2024-08-10T17:38:58-0300] [ALPM] upgraded epson-inkjet-printer-escpr2 (1.2.13-1 -> 1.2.14-1)
[2024-08-10T15:34:05-0300] [ALPM] upgraded xfsprogs (6.8.0-2 -> 6.9.0-1)
[2024-08-10T15:34:05-0300] [ALPM] upgraded xapp (2.8.4-1 -> 2.8.5-1)
[2024-08-10T15:34:05-0300] [ALPM] upgraded systemd-sysvcompat (256.2-1 -> 256.4-1)
[2024-08-10T15:34:05-0300] [ALPM] upgraded squashfs-tools (4.6.1-1 -> 4.6.1-2)
[2024-08-10T15:34:05-0300] [ALPM] upgraded samba (4.20.2-1 -> 4.20.3-1)
[2024-08-10T15:34:05-0300] [ALPM] upgraded smbclient (4.20.2-1 -> 4.20.3-1)
[2024-08-10T15:34:05-0300] [ALPM] upgraded python-pyasn1-modules (0.3.0-2 -> 0.4.0-1)
[2024-08-10T15:34:04-0300] [ALPM] upgraded python-pyasn1 (0.5.1-1 -> 0.6.0-1)
[2024-08-10T15:34:04-0300] [ALPM] upgraded python-googleapis-common-protos (1.63.0-2 -> 1.63.2-1)
[2024-08-10T15:34:04-0300] [ALPM] upgraded pipewire-alsa (1:1.2.1-1 -> 1:1.2.2-1)
[2024-08-10T15:34:04-0300] [ALPM] upgraded pipewire-audio (1:1.2.1-1 -> 1:1.2.2-1)
[2024-08-10T15:34:04-0300] [ALPM] upgraded pangomm-2.48 (2.52.0-1 -> 2.54.0-1)
[2024-08-10T15:34:04-0300] [ALPM] upgraded obs-studio (30.1.2-2 -> 30.2.1-1)
[2024-08-10T15:34:04-0300] [ALPM] installed uthash (2.3.0-2)
[2024-08-10T15:34:04-0300] [ALPM] upgraded noto-fonts-extra (1:24.7.1-1 -> 1:24.8.1-1)
[2024-08-10T15:34:03-0300] [ALPM] upgraded networkmanager (1.48.4-1 -> 1.48.6-1)
[2024-08-10T15:34:03-0300] [ALPM] upgraded wpa_supplicant (2:2.10-8 -> 2:2.11-2)
[2024-08-10T15:34:02-0300] [ALPM] upgraded mhwd-nvidia (550.100-1 -> 550.107.02-1)
[2024-08-10T15:34:02-0300] [ALPM] upgraded manjaro-release (24.0.5-1 -> 24.0.6-1)
[2024-08-10T15:34:02-0300] [ALPM] upgraded lollypop (1.4.39-1 -> 1.4.40-1)
[2024-08-10T15:34:02-0300] [ALPM] upgraded linux69-headers (6.9.10-1 -> 6.9.12-1)
[2024-08-10T15:33:58-0300] [ALPM] upgraded linux69 (6.9.10-1 -> 6.9.12-1)
[2024-08-10T15:33:56-0300] [ALPM] upgraded licenses (20240206-1 -> 20240728-1)
[2024-08-10T15:33:56-0300] [ALPM] upgraded libwbclient (4.20.2-1 -> 4.20.3-1)
[2024-08-10T15:33:56-0300] [ALPM] upgraded libvirt (1:10.5.0-1 -> 1:10.5.0-2)
[2024-08-10T15:33:56-0300] [ALPM] upgraded libtracefs (1.8.0-1 -> 1.8.1-1)
[2024-08-10T15:33:56-0300] [ALPM] upgraded libtraceevent (1:1.8.2-2 -> 1:1.8.3-1)
[2024-08-10T15:33:56-0300] [ALPM] upgraded libshumate (1.2.2-2 -> 1.2.3-1)
[2024-08-10T15:33:56-0300] [ALPM] upgraded libedataserverui4 (3.52.3-1 -> 3.52.4-1)
[2024-08-10T15:33:56-0300] [ALPM] upgraded ldb (2:2.9.1-1 -> 2:2.9.1-2)
[2024-08-10T15:33:56-0300] [ALPM] upgraded iproute2 (6.10.0-1 -> 6.10.0-2)
[2024-08-10T15:33:56-0300] [ALPM] upgraded gzip (1.13-2 -> 1.13-4)
[2024-08-10T15:33:56-0300] [ALPM] upgraded gtksourceview3 (1:3.24.11+r28+g73e57b57-1 -> 1:3.24.11+r28+g73e57b57-2)
[2024-08-10T15:33:56-0300] [ALPM] upgraded gst-plugins-ugly (1.24.5-2 -> 1.24.6-1)
[2024-08-10T15:33:56-0300] [ALPM] upgraded gst-plugins-good (1.24.5-2 -> 1.24.6-1)
[2024-08-10T15:33:56-0300] [ALPM] upgraded gst-plugins-base (1.24.5-2 -> 1.24.6-1)
[2024-08-10T15:33:56-0300] [ALPM] upgraded gst-plugins-bad (1.24.5-2 -> 1.24.6-1)
[2024-08-10T15:33:56-0300] [ALPM] upgraded imagemagick (7.1.1.35-1 -> 7.1.1.36-1)
[2024-08-10T15:33:55-0300] [ALPM] upgraded libgme (0.6.3-4 -> 0.6.3-5)
[2024-08-10T15:33:55-0300] [ALPM] upgraded gst-plugin-pipewire (1:1.2.1-1 -> 1:1.2.2-1)
[2024-08-10T15:33:55-0300] [ALPM] upgraded gst-plugin-gtk (1.24.5-2 -> 1.24.6-1)
[2024-08-10T15:33:55-0300] [ALPM] upgraded gst-libav (1.24.5-2 -> 1.24.6-1)
[2024-08-10T15:33:55-0300] [ALPM] upgraded gst-editing-services (1.24.5-2 -> 1.24.6-1)
[2024-08-10T15:33:55-0300] [ALPM] upgraded gst-python (1.24.5-2 -> 1.24.6-1)
[2024-08-10T15:33:55-0300] [ALPM] upgraded gst-devtools-libs (1.24.5-2 -> 1.24.6-1)
[2024-08-10T15:33:55-0300] [ALPM] upgraded gpm (1.20.7.r38.ge82d1a6-5 -> 1.20.7.r38.ge82d1a6-6)
[2024-08-10T15:33:55-0300] [ALPM] upgraded gnome-shell-extension-dash-to-dock (92-1 -> 93-1)
[2024-08-10T15:33:55-0300] [ALPM] upgraded mutter (46.3.1-1.0 -> 46.3.1-1.1)
[2024-08-10T15:33:55-0300] [ALPM] upgraded libnm (1.48.4-1 -> 1.48.6-1)
[2024-08-10T15:33:55-0300] [ALPM] upgraded gnome-bluetooth-3.0 (46.0-1 -> 46.1-1)
[2024-08-10T15:33:55-0300] [ALPM] upgraded glibc-locales (2.39+r52+gf8e4623421-1 -> 2.40-1)
[2024-08-10T15:33:54-0300] [ALPM] upgraded git (2.45.2-1 -> 2.46.0-1)
[2024-08-10T15:33:54-0300] [ALPM] upgraded fwupd (1.9.21-3 -> 1.9.22-2)
[2024-08-10T15:33:53-0300] [ALPM] upgraded flatpak (1:1.15.8-1 -> 1:1.15.9-1)
[2024-08-10T15:33:53-0300] [ALPM] upgraded pipewire (1:1.2.1-1 -> 1:1.2.2-1)
[2024-08-10T15:33:53-0300] [ALPM] upgraded libpipewire (1:1.2.1-1 -> 1:1.2.2-1)
[2024-08-10T15:33:53-0300] [ALPM] upgraded ostree (2024.6-1 -> 2024.7-1)
[2024-08-10T15:33:53-0300] [ALPM] upgraded flashrom (1.3.0-3 -> 1.4.0-1)
[2024-08-10T15:33:53-0300] [ALPM] upgraded f2fs-tools (1.16.0-2 -> 1.16.0-3)
[2024-08-10T15:33:53-0300] [ALPM] upgraded evolution-ews (3.52.3-1 -> 3.52.4-1)
[2024-08-10T15:33:53-0300] [ALPM] upgraded evolution (3.52.3-1 -> 3.52.4-2)
[2024-08-10T15:33:52-0300] [ALPM] upgraded evolution-data-server (3.52.3-1 -> 3.52.4-1)
[2024-08-10T15:33:52-0300] [ALPM] upgraded libavif (1.1.0-1 -> 1.1.1-1)
[2024-08-10T15:33:52-0300] [ALPM] upgraded tdb (1.4.10-3 -> 1.4.11-1)
[2024-08-10T15:33:52-0300] [ALPM] upgraded deja-dup (45.2-1 -> 46.1-1)
[2024-08-10T15:33:51-0300] [ALPM] upgraded duplicity (3.0.0-1 -> 3.0.0-2)
[2024-08-10T15:33:51-0300] [ALPM] upgraded dbus-glib (0.112-3 -> 0.112-4)
[2024-08-10T15:33:51-0300] [ALPM] upgraded cracklib (2.9.11-2 -> 2.10.1-1)
[2024-08-10T15:33:51-0300] [ALPM] upgraded cmark (0.31.0-2 -> 0.31.1-1)
[2024-08-10T15:33:51-0300] [ALPM] upgraded cdrtools (3.02a09-5 -> 3.02a09-6)
[2024-08-10T15:33:51-0300] [ALPM] upgraded calibre (7.15.0-1 -> 7.16.0-1)
[2024-08-10T15:33:50-0300] [ALPM] upgraded parted (3.6-1 -> 3.6-2)
[2024-08-10T15:33:50-0300] [ALPM] upgraded qt6-webengine (6.7.2-1 -> 6.7.2-2)
[2024-08-10T15:33:49-0300] [ALPM] upgraded noto-fonts (1:24.7.1-1 -> 1:24.8.1-1)
[2024-08-10T15:33:49-0300] [ALPM] upgraded nss (3.102-1 -> 3.102.1-1)
[2024-08-10T15:33:49-0300] [ALPM] upgraded python-zeroconf (0.63.0-2 -> 0.132.2-1)
[2024-08-10T15:33:49-0300] [ALPM] upgraded python-regex (2024.5.15-1 -> 2024.7.24-1)
[2024-08-10T15:33:49-0300] [ALPM] upgraded python-lxml-html-clean (0.1.1-2 -> 0.2.0-1)
[2024-08-10T15:33:49-0300] [ALPM] upgraded btrfs-progs (6.9.2-1 -> 6.10-1)
[2024-08-10T15:33:49-0300] [ALPM] upgraded blender (17:4.2.0-3 -> 17:4.2.0-5)
[2024-08-10T15:33:47-0300] [ALPM] upgraded libvpx (1.14.0-1 -> 1.14.1-1)
[2024-08-10T15:33:47-0300] [ALPM] upgraded svt-av1 (2.1.0-1 -> 2.1.2-1)
[2024-08-10T15:33:47-0300] [ALPM] upgraded libopenmpt (0.7.8-1 -> 0.7.9-1)
[2024-08-10T15:33:47-0300] [ALPM] upgraded usd (24.05-2 -> 24.08-1)
[2024-08-10T15:33:47-0300] [ALPM] upgraded blosc (1.21.5-2 -> 1.21.6-1)
[2024-08-10T15:33:47-0300] [ALPM] upgraded clang (18.1.8-1 -> 18.1.8-2)
[2024-08-10T15:33:46-0300] [ALPM] upgraded gcc (14.1.1+r58+gfc9fb69ad62-1 -> 14.1.1+r309+gbb34b7eda1f-1)
[2024-08-10T15:33:45-0300] [ALPM] upgraded mpfr (4.2.1-3 -> 4.2.1-4)
[2024-08-10T15:33:45-0300] [ALPM] upgraded libheif (1.18.0-1 -> 1.18.1-1)
[2024-08-10T15:33:45-0300] [ALPM] upgraded libadwaita (1:1.5.2-1 -> 1:1.5.3-1)
[2024-08-10T15:33:45-0300] [ALPM] upgraded gsettings-desktop-schemas (46.1-1 -> 46.1-2)
[2024-08-10T15:33:45-0300] [ALPM] upgraded gst-plugins-bad-libs (1.24.5-2 -> 1.24.6-1)
[2024-08-10T15:33:44-0300] [ALPM] upgraded glib-networking (1:2.80.0-2 -> 1:2.80.0-3)
[2024-08-10T15:33:44-0300] [ALPM] installed gsettings-system-schemas (46.1-2)
[2024-08-10T15:33:44-0300] [ALPM] upgraded libva (2.21.0-1 -> 2.22.0-1)
[2024-08-10T15:33:44-0300] [ALPM] upgraded gst-plugins-base-libs (1.24.5-2 -> 1.24.6-1)
[2024-08-10T15:33:43-0300] [ALPM] upgraded systemd (256.2-1 -> 256.4-1)
[2024-08-10T15:33:43-0300] [ALPM] upgraded dbus-broker-units (36-2 -> 36-4)
[2024-08-10T15:33:43-0300] [ALPM] upgraded dbus-broker (36-2 -> 36-4)
[2024-08-10T15:33:43-0300] [ALPM] upgraded cryptsetup (2.7.3-1 -> 2.7.4-1)
[2024-08-10T15:33:42-0300] [ALPM] upgraded gstreamer (1.24.5-2 -> 1.24.6-1)
[2024-08-10T15:33:42-0300] [ALPM] upgraded libsysprof-capture (46.0-3 -> 46.0-4)
[2024-08-10T15:33:42-0300] [ALPM] upgraded python-jaraco.context (4.3.0-4 -> 5.3.0-1)
[2024-08-10T15:33:42-0300] [ALPM] upgraded hwloc (2.10.0-1 -> 2.11.1-1)
[2024-08-10T15:33:42-0300] [ALPM] upgraded libtool (2.5.0+14+g9a4a0261-1 -> 2.5.1-1)
[2024-08-10T15:33:42-0300] [ALPM] upgraded sdl2 (2.30.5-2 -> 2.30.6-1)
[2024-08-10T15:33:42-0300] [ALPM] upgraded mesa (1:24.1.3-1 -> 1:24.1.5-1)
[2024-08-10T15:33:42-0300] [ALPM] upgraded hidapi (0.14.0-2 -> 0.14.0-3)
[2024-08-10T15:33:42-0300] [ALPM] upgraded python-numpy (2.0.0-1 -> 2.0.1-1)
[2024-08-10T15:33:41-0300] [ALPM] upgraded libxml2 (2.13.2-2 -> 2.13.3-1)
[2024-08-10T15:33:41-0300] [ALPM] upgraded binutils (2.42+r91+g6224493e457-1 -> 2.42+r195+g29ae8b8ea71-1)
[2024-08-10T15:33:41-0300] [ALPM] upgraded libelf (0.191-3 -> 0.191-4)
[2024-08-10T15:33:41-0300] [ALPM] upgraded curl (8.8.0-1 -> 8.9.1-1)
[2024-08-10T15:33:41-0300] [ALPM] upgraded ca-certificates-mozilla (3.102-1 -> 3.102.1-1)
[2024-08-10T15:33:41-0300] [ALPM] upgraded systemd-libs (256.2-1 -> 256.4-1)
[2024-08-10T15:33:41-0300] [ALPM] upgraded keyutils (1.6.3-2 -> 1.6.3-3)
[2024-08-10T15:33:41-0300] [ALPM] upgraded libxcrypt (4.4.36-1 -> 4.4.36-2)
[2024-08-10T15:33:41-0300] [ALPM] upgraded lz4 (1:1.9.4-3 -> 1:1.10.0-2)
[2024-08-10T15:33:41-0300] [ALPM] upgraded gcc-libs (14.1.1+r58+gfc9fb69ad62-1 -> 14.1.1+r309+gbb34b7eda1f-1)
[2024-08-10T15:33:40-0300] [ALPM] upgraded argon2 (20190702-5 -> 20190702-6)
[2024-08-10T15:33:40-0300] [ALPM] upgraded alsa-plugins (1:1.2.12-2 -> 1:1.2.12-3)
[2024-08-10T15:33:37-0300] [ALPM] upgraded glibc (2.39+r52+gf8e4623421-1 -> 2.40-1)
[2024-08-10T15:33:36-0300] [ALPM] warning: /etc/locale.gen installed as /etc/locale.gen.pacnew
[2024-08-10T15:33:36-0300] [ALPM] upgraded alsa-card-profiles (1:1.2.1-1 -> 1:1.2.2-1)
[2024-08-10T15:33:35-0300] [ALPM] removed manjaro-pulse (20221015-2)
[2024-08-07T08:37:41-0300] [ALPM] upgraded gnome-shell-extension-appindicator (1:58-1 -> 1:59-1)
[2024-08-07T08:37:41-0300] [ALPM] upgraded firefox-i18n-pt-br (128.0-1 -> 129.0-1)
[2024-08-07T08:37:41-0300] [ALPM] upgraded firefox-i18n-en-us (128.0-1 -> 129.0-1)
[2024-08-07T08:37:41-0300] [ALPM] upgraded firefox (128.0-2 -> 129.0-1)
[2024-08-07T08:37:40-0300] [ALPM] upgraded chromium (127.0.6533.88-1 -> 127.0.6533.99-1)
[2024-08-06T18:14:07-0300] [ALPM] installed onedriver (0.14.1-0)
[2024-08-06T17:42:11-0300] [ALPM] installed go (2:1.22.5-1)
[2024-08-01T16:05:08-0300] [ALPM] upgraded chromium (127.0.6533.72-1 -> 127.0.6533.88-1)
[2024-07-30T11:40:34-0300] [ALPM] installed sigil (2.2.1-1)
[2024-07-30T11:40:34-0300] [ALPM] installed qt6-5compat (6.7.2-1)
[2024-07-30T11:40:34-0300] [ALPM] installed qt6-shadertools (6.7.2-1)
[2024-07-30T11:40:34-0300] [ALPM] installed python-dulwich (0.22.1-1)
[2024-07-30T11:40:34-0300] [ALPM] installed tk (8.6.14-4)
[2024-07-29T18:04:13-0300] [ALPM] upgraded zsh-history-substring-search (1.1.0-1 -> 1.1.0-2)
[2024-07-29T18:04:13-0300] [ALPM] upgraded zsh-completions (0.35.0-1 -> 0.35.0-2)
[2024-07-29T18:04:13-0300] [ALPM] upgraded zsh-autosuggestions (0.7.0-2 -> 0.7.0-3)
[2024-07-29T18:04:13-0300] [ALPM] upgraded yelp-xsl (42.1-1 -> 42.1-2)
[2024-07-29T18:04:12-0300] [ALPM] upgraded xorg-xinit (1.4.2-1 -> 1.4.2-2)
[2024-07-29T18:04:12-0300] [ALPM] upgraded xorg-xmodmap (1.0.11-1 -> 1.0.11-2)
[2024-07-29T18:04:12-0300] [ALPM] upgraded xorg-xhost (1.0.9-1 -> 1.0.9-2)
[2024-07-29T18:04:12-0300] [ALPM] upgraded xf86-input-void (1.4.2-1 -> 1.4.2-2)
[2024-07-29T18:04:12-0300] [ALPM] upgraded xdg-user-dirs-gtk (0.11-2 -> 0.11-3)
[2024-07-29T18:04:12-0300] [ALPM] upgraded xdg-user-dirs (0.18-1 -> 0.18-2)
[2024-07-29T18:04:12-0300] [ALPM] upgraded webapp-manager (1.3.6-1 -> 1.3.7-1)
[2024-07-29T18:04:12-0300] [ALPM] upgraded virtualbox-guest-iso (7.0.18-1 -> 7.0.20-1)
[2024-07-29T18:04:12-0300] [ALPM] upgraded virtualbox (7.0.18-1 -> 7.0.20-1)
[2024-07-29T18:04:11-0300] [ALPM] upgraded virtualbox-host-dkms (7.0.18-1 -> 7.0.20-1)
[2024-07-29T18:04:11-0300] [ALPM] upgraded usb_modeswitch (2.6.1-3 -> 2.6.1-4)
[2024-07-29T18:04:11-0300] [ALPM] upgraded ttf-hack (3.003-6 -> 3.003-7)
[2024-07-29T18:04:11-0300] [ALPM] upgraded timeshift (24.06.2-1 -> 24.06.3-1)
[2024-07-29T18:04:11-0300] [ALPM] upgraded suitesparse (7.7.0-1 -> 7.7.0-2)
[2024-07-29T18:04:11-0300] [ALPM] upgraded sudo (1.9.15.p5-1 -> 1.9.15.p5-2)
[2024-07-29T18:04:11-0300] [ALPM] upgraded strongswan (5.9.13-2 -> 5.9.14-1)
[2024-07-29T18:04:10-0300] [ALPM] upgraded sstp-client (1:1.0.19-1 -> 1:1.0.19-2)
[2024-07-29T18:04:10-0300] [ALPM] upgraded sof-firmware (2024.03-1 -> 2024.06-1)
[2024-07-29T18:04:10-0300] [ALPM] upgraded sbc (2.0-1 -> 2.0-2)
[2024-07-29T18:04:10-0300] [ALPM] upgraded quadrapassel (40.2-1 -> 40.2-2)
[2024-07-29T18:04:10-0300] [ALPM] upgraded qt5-base (5.15.14+kde+r141-1 -> 5.15.14+kde+r143-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-desktop (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-vhost-user-gpu (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-ui-spice-app (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-ui-sdl (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-ui-gtk (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-ui-egl-headless (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-ui-dbus (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-ui-curses (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-hw-usb-smartcard (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-hw-usb-redirect (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-hw-usb-host (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-hw-display-virtio-vga-gl (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-hw-display-virtio-vga (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-hw-display-virtio-gpu-pci-gl (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-hw-display-virtio-gpu-pci (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-hw-display-virtio-gpu-gl (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-hw-display-virtio-gpu (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-hw-display-qxl (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-chardev-spice (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-block-ssh (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-block-nfs (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-block-dmg (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-block-curl (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-base (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded virtiofsd (1.11.0-1 -> 1.11.1-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-system-x86 (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded wolfssl (5.7.0-1 -> 5.7.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-system-x86-firmware (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-img (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-audio-spice (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-ui-spice-core (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-ui-opengl (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-audio-sdl (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-audio-pipewire (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-audio-pa (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-audio-oss (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-audio-jack (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-audio-dbus (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-audio-alsa (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded qemu-common (9.0.1-1 -> 9.0.2-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded python-google-auth (2.30.0-1 -> 2.32.0-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded python-coverage (7.5.1-1 -> 7.6.0-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded openvpn (2.6.11-1 -> 2.6.12-1)
[2024-07-29T18:04:09-0300] [ALPM] upgraded nftables (1:1.0.9-3 -> 1:1.1.0-2)
[2024-07-29T18:04:09-0300] [ALPM] upgraded ndctl (78-2 -> 79-1)
[2024-07-29T18:04:08-0300] [ALPM] upgraded manjaro-release (24.0.4-1 -> 24.0.5-1)
[2024-07-29T18:04:08-0300] [ALPM] upgraded manjaro-printer (20220924-1 -> 20240718-1)
[2024-07-29T18:04:08-0300] [ALPM] upgraded lvm2 (2.03.24-1 -> 2.03.25-2)
[2024-07-29T18:04:08-0300] [ALPM] upgraded thin-provisioning-tools (1.0.12-1 -> 1.0.13-1)
[2024-07-29T18:04:08-0300] [ALPM] upgraded logrotate (3.21.0-2 -> 3.22.0-1)
[2024-07-29T18:04:08-0300] [ALPM] upgraded linux69-headers (6.9.9-1 -> 6.9.10-1)
[2024-07-29T18:04:03-0300] [ALPM] upgraded linux69 (6.9.9-1 -> 6.9.10-1)
[2024-07-29T18:04:01-0300] [ALPM] upgraded libinstpatch (1.1.6-2 -> 1.1.6-3)
[2024-07-29T18:04:01-0300] [ALPM] upgraded libfprint (1.94.7-2 -> 1.94.7-3)
[2024-07-29T18:04:01-0300] [ALPM] upgraded less (1:643-2 -> 1:661-1)
[2024-07-29T18:04:01-0300] [ALPM] upgraded kwindowsystem (6.3.0-1 -> 6.4.0-1)
[2024-07-29T18:04:01-0300] [ALPM] upgraded qt6-wayland (6.7.2-2 -> 6.7.2-4)
[2024-07-29T18:04:01-0300] [ALPM] upgraded iproute2 (6.9.0-2 -> 6.10.0-1)
[2024-07-29T18:04:01-0300] [ALPM] upgraded libnl (3.9.0-1 -> 3.10.0-1)
[2024-07-29T18:04:01-0300] [ALPM] upgraded libnftnl (1.2.6-1 -> 1.2.7-1)
[2024-07-29T18:04:01-0300] [ALPM] upgraded imlib2 (1.12.2-2 -> 1.12.3-1)
[2024-07-29T18:04:01-0300] [ALPM] upgraded imagemagick (7.1.1.34-1 -> 7.1.1.35-1)
[2024-07-29T18:04:01-0300] [ALPM] upgraded ibus (1.5.30-2 -> 1.5.30-3)
[2024-07-29T18:04:01-0300] [ALPM] upgraded python-gobject (3.48.2-1 -> 3.48.2-2)
[2024-07-29T18:04:00-0300] [ALPM] upgraded hwinfo (23.2-1 -> 23.2-2)
[2024-07-29T18:04:00-0300] [ALPM] upgraded gnome-shell-extension-gtk4-desktop-icons-ng (1:78-1 -> 1:79-1)
[2024-07-29T18:04:00-0300] [ALPM] upgraded gnome-shell-extension-arc-menu (57-1 -> 58-1)
[2024-07-29T18:04:00-0300] [ALPM] upgraded xdg-dbus-proxy (0.1.5-1 -> 0.1.5-2)
[2024-07-29T18:04:00-0300] [ALPM] upgraded wpebackend-fdo (1.14.2-1 -> 1.14.2-2)
[2024-07-29T18:04:00-0300] [ALPM] upgraded xorg-setxkbmap (1.3.4-1 -> 1.3.4-2)
[2024-07-29T18:04:00-0300] [ALPM] upgraded libibus (1.5.30-2 -> 1.5.30-3)
[2024-07-29T18:04:00-0300] [ALPM] upgraded gnome-settings-daemon (46.0-1 -> 46.0-2)
[2024-07-29T18:04:00-0300] [ALPM] upgraded webrtc-audio-processing-1 (1.3-2 -> 1.3-3)
[2024-07-29T18:04:00-0300] [ALPM] upgraded rtkit (0.13-2 -> 0.13-3)
[2024-07-29T18:04:00-0300] [ALPM] upgraded xorg-xrdb (1.2.2-1 -> 1.2.2-2)
[2024-07-29T18:04:00-0300] [ALPM] upgraded fwupd (1.9.21-2 -> 1.9.21-3)
[2024-07-29T18:04:00-0300] [ALPM] upgraded firefox (128.0-1 -> 128.0-2)
[2024-07-29T18:03:59-0300] [ALPM] upgraded evince (46.3-1 -> 46.3.1-1)
[2024-07-29T18:03:58-0300] [ALPM] upgraded cpupower (6.9-2 -> 6.10-1)
[2024-07-29T18:03:58-0300] [ALPM] upgraded calibre (7.14.0-1 -> 7.15.0-1)
[2024-07-29T18:03:57-0300] [ALPM] upgraded gpgme (1.23.2-4 -> 1.23.2-6)
[2024-07-29T18:03:57-0300] [ALPM] upgraded gnupg (2.4.5-1 -> 2.4.5-4)
[2024-07-29T18:03:57-0300] [ALPM] upgraded pinentry (1.3.1-2 -> 1.3.1-5)
[2024-07-29T18:03:57-0300] [ALPM] upgraded libassuan (2.5.7-2 -> 3.0.0-1)
[2024-07-29T18:03:57-0300] [ALPM] upgraded uchardet (0.0.8-2 -> 0.0.8-3)
[2024-07-29T18:03:57-0300] [ALPM] upgraded python-pyqt6 (6.7.0-4 -> 6.7.1-1)
[2024-07-29T18:03:57-0300] [ALPM] upgraded python-pyqt6-sip (13.6.0-2 -> 13.8.0-1)
[2024-07-29T18:03:57-0300] [ALPM] upgraded python-apsw (3.45.2.0-2 -> 3.46.0.1-1)
[2024-07-29T18:03:57-0300] [ALPM] upgraded blender (17:4.1.1-11 -> 17:4.2.0-3)
[2024-07-29T18:03:55-0300] [ALPM] upgraded python-urllib3 (1.26.18-3 -> 1.26.19-1)
[2024-07-29T18:03:55-0300] [ALPM] upgraded portaudio (1:19.7.0-2 -> 1:19.7.0-3)
[2024-07-29T18:03:55-0300] [ALPM] upgraded xvidcore (1.3.7-2 -> 1.3.7-3)
[2024-07-29T18:03:55-0300] [ALPM] upgraded vid.stab (1.1.1-1 -> 1.1.1-2)
[2024-07-29T18:03:55-0300] [ALPM] upgraded srt (1.5.3-1 -> 1.5.3-2)
[2024-07-29T18:03:55-0300] [ALPM] upgraded speex (1.2.1-1 -> 1.2.1-2)
[2024-07-29T18:03:55-0300] [ALPM] upgraded speexdsp (1.2.1-1 -> 1.2.1-2)
[2024-07-29T18:03:55-0300] [ALPM] upgraded rubberband (3.3.0-1 -> 3.3.0-2)
[2024-07-29T18:03:55-0300] [ALPM] upgraded usd (24.05-1 -> 24.05-2)
[2024-07-29T18:03:54-0300] [ALPM] upgraded llvm (18.1.8-3 -> 18.1.8-4)
[2024-07-29T18:03:53-0300] [ALPM] upgraded xorg-xset (1.2.5-1 -> 1.2.5-2)
[2024-07-29T18:03:53-0300] [ALPM] upgraded xorg-xrandr (1.5.2-1 -> 1.5.2-2)
[2024-07-29T18:03:53-0300] [ALPM] upgraded glib-networking (1:2.80.0-1 -> 1:2.80.0-2)
[2024-07-29T18:03:53-0300] [ALPM] upgraded libproxy (0.5.7-1 -> 0.5.8-1)
[2024-07-29T18:03:53-0300] [ALPM] upgraded orc (0.4.38-1 -> 0.4.39-1)
[2024-07-29T18:03:53-0300] [ALPM] upgraded device-mapper (2.03.24-1 -> 2.03.25-2)
[2024-07-29T18:03:53-0300] [ALPM] upgraded gsettings-desktop-schemas (46.0-2 -> 46.1-1)
[2024-07-29T18:03:53-0300] [ALPM] upgraded python-trove-classifiers (2024.5.22-1 -> 2024.7.2-1)
[2024-07-29T18:03:53-0300] [ALPM] upgraded python-jaraco.text (3.12.1-1 -> 3.14.0-1)
[2024-07-29T18:03:53-0300] [ALPM] upgraded sdl2 (2.30.5-1 -> 2.30.5-2)
[2024-07-29T18:03:53-0300] [ALPM] upgraded openshadinglanguage (1.13.9.0-2 -> 1.13.10.0-1)
[2024-07-29T18:03:53-0300] [ALPM] upgraded openimageio (2.5.13.0-1 -> 2.5.13.1-1)
[2024-07-29T18:03:53-0300] [ALPM] upgraded tinyxml (2.6.2-10 -> 2.6.2-11)
[2024-07-29T18:03:53-0300] [ALPM] upgraded yaml-cpp (0.8.0-1 -> 0.8.0-2)
[2024-07-29T18:03:53-0300] [ALPM] upgraded pystring (1.1.4-1 -> 1.1.4-2)
[2024-07-29T18:03:53-0300] [ALPM] upgraded pybind11 (2.13.1-1 -> 2.13.1-2)
[2024-07-29T18:03:53-0300] [ALPM] upgraded llvm-libs (18.1.8-3 -> 18.1.8-4)
[2024-07-29T18:03:52-0300] [ALPM] upgraded libxml2 (2.13.2-1 -> 2.13.2-2)
[2024-07-29T18:03:52-0300] [ALPM] upgraded embree (4.3.2-1 -> 4.3.3-1)
[2024-07-29T18:03:52-0300] [ALPM] upgraded automake (1.16.5-2 -> 1.17-1)
[2024-07-29T18:03:52-0300] [ALPM] upgraded perl (5.38.2-1 -> 5.38.2-2)
[2024-07-29T18:03:51-0300] [ALPM] upgraded apache (2.4.61-1 -> 2.4.62-1)
[2024-07-29T18:03:51-0300] [ALPM] upgraded linux-api-headers (6.8-1 -> 6.10-1)
[2024-07-24T16:54:31-0300] [ALPM] upgraded epson-inkjet-printer-escpr2 (1.2.12-1 -> 1.2.13-1)
[2024-07-24T16:53:47-0300] [ALPM] upgraded mhwd-nvidia-390xx (390.157-13 -> 390.157-14)
[2024-07-24T16:53:47-0300] [ALPM] upgraded mhwd-nvidia-470xx (470.256.02-3 -> 470.256.02-4)
[2024-07-24T16:53:47-0300] [ALPM] upgraded chromium (126.0.6478.182-1 -> 127.0.6533.72-1)
[2024-07-18T15:16:06-0300] [ALPM] reinstalled networkmanager-strongswan (1.6.0-2)
[2024-07-18T15:16:06-0300] [ALPM] reinstalled strongswan (5.9.13-2)
[2024-07-17T08:04:13-0300] [ALPM] upgraded chromium (126.0.6478.126-1 -> 126.0.6478.182-1)
[2024-07-16T08:43:15-0300] [ALPM] upgraded xf86-input-libinput (1.4.0-1 -> 1.4.0-2)
[2024-07-16T08:43:15-0300] [ALPM] upgraded wireless-regdb (2024.05.08-1 -> 2024.07.04-1)
[2024-07-16T08:43:15-0300] [ALPM] upgraded wget (1.24.5-2 -> 1.24.5-3)
[2024-07-16T08:43:15-0300] [ALPM] upgraded unixodbc (2.3.12-1 -> 2.3.12-2)
[2024-07-16T08:43:15-0300] [ALPM] upgraded ttf-indic-otf (0.2-11 -> 0.2-12)
[2024-07-16T08:43:15-0300] [ALPM] upgraded transmission-cli (4.0.6-1 -> 4.0.6-2)
[2024-07-16T08:43:15-0300] [ALPM] upgraded touchegg (2.0.17-1 -> 2.0.17-2)
[2024-07-16T08:43:15-0300] [ALPM] upgraded totem-pl-parser (3.26.6-2 -> 3.26.6+r30+g51b8439-1)
[2024-07-16T08:43:14-0300] [ALPM] upgraded timeshift (24.06.1-1 -> 24.06.2-1)
[2024-07-16T08:43:14-0300] [ALPM] upgraded xapp (2.8.3-1 -> 2.8.4-1)
[2024-07-16T08:43:14-0300] [ALPM] upgraded systemd-sysvcompat (256.1-1 -> 256.2-1)
[2024-07-16T08:43:14-0300] [ALPM] upgraded sysfsutils (2.1.1-1 -> 2.1.1-2)
[2024-07-16T08:43:14-0300] [ALPM] upgraded syncthing (1.27.8-1 -> 1.27.9-1)
[2024-07-16T08:43:14-0300] [ALPM] upgraded spice-gtk (0.42-3 -> 0.42-4)
[2024-07-16T08:43:14-0300] [ALPM] upgraded spice-protocol (0.14.4-1 -> 0.14.4-2)
[2024-07-16T08:43:14-0300] [ALPM] upgraded shotcut (24.04-1 -> 24.06-1)
[2024-07-16T08:43:14-0300] [ALPM] upgraded sdl12-compat (1.2.68-1 -> 1.2.68-2)
[2024-07-16T08:43:13-0300] [ALPM] upgraded samba (4.20.1-2 -> 4.20.2-1)
[2024-07-16T08:43:13-0300] [ALPM] upgraded reiserfsprogs (3.6.27-4 -> 3.6.27-5)
[2024-07-16T08:43:13-0300] [ALPM] upgraded qt6ct (0.9-8 -> 0.9-9)
[2024-07-16T08:43:13-0300] [ALPM] upgraded qt6-wayland (6.7.1-1 -> 6.7.2-2)
[2024-07-16T08:43:13-0300] [ALPM] upgraded qt6-multimedia (6.7.1-2 -> 6.7.2-1)
[2024-07-16T08:43:13-0300] [ALPM] upgraded qt6-multimedia-ffmpeg (6.7.1-2 -> 6.7.2-1)
[2024-07-16T08:43:13-0300] [ALPM] upgraded qt6-charts (6.7.1-1 -> 6.7.2-1)
[2024-07-16T08:43:13-0300] [ALPM] upgraded qt5ct (1.8-1 -> 1.8-2)
[2024-07-16T08:43:13-0300] [ALPM] upgraded qt5-tools (5.15.14+kde+r4-1 -> 5.15.14+kde+r4-2)
[2024-07-16T08:43:13-0300] [ALPM] upgraded python-yaml (6.0.1-3 -> 6.0.1-4)
[2024-07-16T08:43:13-0300] [ALPM] upgraded python-protobuf (25.3-4 -> 27.2-1)
[2024-07-16T08:43:13-0300] [ALPM] upgraded pipewire-alsa (1:1.0.7-2 -> 1:1.2.1-1)
[2024-07-16T08:43:13-0300] [ALPM] upgraded pipewire-audio (1:1.0.7-2 -> 1:1.2.1-1)
[2024-07-16T08:43:13-0300] [ALPM] upgraded phodav (3.0-2 -> 3.0-3)
[2024-07-16T08:43:13-0300] [ALPM] upgraded perl-mailtools (2.21-7 -> 2.21-8)
[2024-07-16T08:43:13-0300] [ALPM] upgraded perl-error (0.17029-5 -> 0.17029-6)
[2024-07-16T08:43:13-0300] [ALPM] upgraded obs-studio (30.1.2-1 -> 30.1.2-2)
[2024-07-16T08:43:12-0300] [ALPM] upgraded nss-mdns (0.15.1-1 -> 0.15.1-2)
[2024-07-16T08:43:12-0300] [ALPM] upgraded noto-fonts-extra (1:24.6.1-1 -> 1:24.7.1-1)
[2024-07-16T08:43:11-0300] [ALPM] upgraded networkmanager-vpnc (1.2.8-3 -> 1.2.8-4)
[2024-07-16T08:43:11-0300] [ALPM] upgraded networkmanager-strongswan (1.6.0-1.0 -> 1.6.0-2)
[2024-07-16T08:43:11-0300] [ALPM] upgraded networkmanager-openvpn (1.10.4-1 -> 1.12.0-1)
[2024-07-16T08:43:11-0300] [ALPM] upgraded openvpn (2.6.10-1 -> 2.6.11-1)
[2024-07-16T08:43:11-0300] [ALPM] upgraded networkmanager-openconnect (1.2.10-1 -> 1.2.10-2)
[2024-07-16T08:43:11-0300] [ALPM] upgraded openconnect (1:9.12-1 -> 1:9.12-2)
[2024-07-16T08:43:11-0300] [ALPM] upgraded networkmanager (1.48.0-1 -> 1.48.4-1)
[2024-07-16T08:43:11-0300] [ALPM] upgraded nano (8.0-1 -> 8.1-1)
[2024-07-16T08:43:11-0300] [ALPM] upgraded movit (1.7.1-1 -> 1.7.1-2)
[2024-07-16T08:43:11-0300] [ALPM] upgraded mlt (7.24.0-1 -> 7.24.0-3)
[2024-07-16T08:43:10-0300] [ALPM] upgraded miniupnpc (2.2.7-2 -> 2.2.8-1)
[2024-07-16T08:43:10-0300] [ALPM] upgraded mhwd-nvidia (550.90.07-7 -> 550.100-1)
[2024-07-16T08:43:10-0300] [ALPM] upgraded pacman-mirrors (4.26.1-1 -> 4.27-1)
[2024-07-16T08:43:10-0300] [ALPM] upgraded perl-xml-writer (0.900-2 -> 0.900-3)
[2024-07-16T08:43:10-0300] [ALPM] upgraded perl-xml-parser (2.46-5 -> 2.47-1)
[2024-07-16T08:43:10-0300] [ALPM] upgraded perl-libwww (6.72-1 -> 6.77-1)
[2024-07-16T08:43:10-0300] [ALPM] upgraded perl-www-robotrules (6.02-12 -> 6.02-13)
[2024-07-16T08:43:10-0300] [ALPM] upgraded perl-try-tiny (0.31-3 -> 0.31-4)
[2024-07-16T08:43:10-0300] [ALPM] upgraded perl-net-http (6.23-2 -> 6.23-3)
[2024-07-16T08:43:10-0300] [ALPM] upgraded perl-http-negotiate (6.01-12 -> 6.01-13)
[2024-07-16T08:43:10-0300] [ALPM] upgraded perl-http-daemon (6.16-2 -> 6.16-3)
[2024-07-16T08:43:10-0300] [ALPM] upgraded perl-http-message (6.45-1 -> 6.46-1)
[2024-07-16T08:43:10-0300] [ALPM] upgraded perl-uri (5.21-1 -> 5.28-1)
[2024-07-16T08:43:10-0300] [ALPM] upgraded perl-lwp-mediatypes (6.04-4 -> 6.04-5)
[2024-07-16T08:43:10-0300] [ALPM] upgraded perl-io-html (1.004-4 -> 1.004-5)
[2024-07-16T08:43:10-0300] [ALPM] upgraded perl-clone (0.46-2 -> 0.46-3)
[2024-07-16T08:43:10-0300] [ALPM] upgraded perl-http-cookiejar (0.014-1 -> 0.014-2)
[2024-07-16T08:43:10-0300] [ALPM] upgraded perl-file-listing (6.16-2 -> 6.16-3)
[2024-07-16T08:43:10-0300] [ALPM] upgraded perl-http-date (6.06-1 -> 6.06-2)
[2024-07-16T08:43:10-0300] [ALPM] upgraded perl-timedate (2.33-5 -> 2.33-6)
[2024-07-16T08:43:10-0300] [ALPM] upgraded perl-encode-locale (1.05-11 -> 1.05-12)
[2024-07-16T08:43:10-0300] [ALPM] upgraded mbedtls (3.5.2-1 -> 3.6.0-1)
[2024-07-16T08:43:10-0300] [ALPM] upgraded manjaro-release (24.0.3-1 -> 24.0.4-1)
[2024-07-16T08:43:10-0300] [ALPM] upgraded manjaro-base-skel (20171029-3 -> 20171029-4)
[2024-07-16T08:43:10-0300] [ALPM] upgraded mailcap (2.1.54-1 -> 2.1.54-2)
[2024-07-16T08:43:10-0300] [ALPM] upgraded lrzip (0.651-2 -> 0.651-3)
[2024-07-16T08:43:10-0300] [ALPM] upgraded lpsolve (5.5.2.11-2 -> 5.5.2.11-3)
[2024-07-16T08:43:10-0300] [ALPM] upgraded linux69-headers (6.9.5-1 -> 6.9.9-1)
[2024-07-16T08:43:06-0300] [ALPM] upgraded pahole (1:1.27-1 -> 1:1.27-2)
[2024-07-16T08:43:06-0300] [ALPM] upgraded linux69 (6.9.5-1 -> 6.9.9-1)
[2024-07-16T08:43:05-0300] [ALPM] upgraded linux-firmware (20240610.9c10a208-1 -> 20240703.e94a2a3b-1)
[2024-07-16T08:43:02-0300] [ALPM] upgraded linux-firmware-whence (20240610.9c10a208-1 -> 20240703.e94a2a3b-1)
[2024-07-16T08:43:02-0300] [ALPM] upgraded libxss (1.2.4-1 -> 1.2.4-2)
[2024-07-16T08:43:02-0300] [ALPM] upgraded libx86emu (3.5-3 -> 3.5-4)
[2024-07-16T08:43:02-0300] [ALPM] upgraded libwps (0.4.14-1 -> 0.4.14-2)
[2024-07-16T08:43:02-0300] [ALPM] upgraded libvirt (1:10.4.0-1 -> 1:10.5.0-1)
[2024-07-16T08:43:00-0300] [ALPM] upgraded liburcu (0.14.0-1 -> 0.14.0-2)
[2024-07-16T08:43:00-0300] [ALPM] upgraded libteam (1.32-1 -> 1.32-2)
[2024-07-16T08:43:00-0300] [ALPM] upgraded libstaroffice (0.0.7-2 -> 0.0.7-3)
[2024-07-16T08:43:00-0300] [ALPM] upgraded libspectre (0.2.12-1 -> 0.2.12-2)
[2024-07-16T08:43:00-0300] [ALPM] upgraded libsodium (1.0.19-3 -> 1.0.20-1)
[2024-07-16T08:43:00-0300] [ALPM] upgraded libshumate (1.2.2-1 -> 1.2.2-2)
[2024-07-16T08:43:00-0300] [ALPM] upgraded librsync (1:2.3.4-1 -> 1:2.3.4-2)
[2024-07-16T08:43:00-0300] [ALPM] upgraded libportal-gtk4 (0.7.1-2 -> 0.7.1-3)
[2024-07-16T08:43:00-0300] [ALPM] upgraded libportal-gtk3 (0.7.1-2 -> 0.7.1-3)
[2024-07-16T08:43:00-0300] [ALPM] upgraded libportal (0.7.1-2 -> 0.7.1-3)
[2024-07-16T08:43:00-0300] [ALPM] upgraded libpagemaker (0.0.4-3 -> 0.0.4-4)
[2024-07-16T08:43:00-0300] [ALPM] upgraded libosinfo (1.11.0-2 -> 1.11.0-3)
[2024-07-16T08:43:00-0300] [ALPM] upgraded osinfo-db (20240523-1 -> 20240701-1)
[2024-07-16T08:43:00-0300] [ALPM] upgraded libodfgen (0.1.8-2 -> 0.1.8-3)
[2024-07-16T08:43:00-0300] [ALPM] upgraded liboauth (1:1.0.3+r16+gc26f038-1 -> 1:1.0.3+r16+gc26f038-2)
[2024-07-16T08:43:00-0300] [ALPM] upgraded libnumbertext (1.0.11-1 -> 1.0.11-2)
[2024-07-16T08:43:00-0300] [ALPM] upgraded libndp (1.8-2 -> 1.9-1)
[2024-07-16T08:43:00-0300] [ALPM] upgraded libnatpmp (20230423-2 -> 20230423-3)
[2024-07-16T08:43:00-0300] [ALPM] upgraded libmwaw (0.3.22-1 -> 0.3.22-3)
[2024-07-16T08:43:00-0300] [ALPM] upgraded libmediaart (1.9.6-2 -> 1.9.6-3)
[2024-07-16T08:43:00-0300] [ALPM] upgraded liblzf (3.6-4 -> 3.6-5)
[2024-07-16T08:43:00-0300] [ALPM] upgraded libgxps (0.3.2-4 -> 0.3.2-5)
[2024-07-16T08:43:00-0300] [ALPM] upgraded libfreehand (0.1.2-4 -> 0.1.2-5)
[2024-07-16T08:43:00-0300] [ALPM] upgraded libetonyek (0.1.10-3 -> 0.1.10-4)
[2024-07-16T08:42:59-0300] [ALPM] upgraded libepubgen (0.1.1-4 -> 0.1.1-5)
[2024-07-16T08:42:59-0300] [ALPM] upgraded libedataserverui4 (3.52.2-1 -> 3.52.3-1)
[2024-07-16T08:42:59-0300] [ALPM] upgraded libebur128 (1.2.6-1 -> 1.2.6-2)
[2024-07-16T08:42:59-0300] [ALPM] upgraded libdvdcss (1.4.3-1 -> 1.4.3-2)
[2024-07-16T08:42:59-0300] [ALPM] upgraded libdatachannel (0.21.1-1 -> 0.21.2-1)
[2024-07-16T08:42:59-0300] [ALPM] upgraded libjuice (1.4.2-1 -> 1.5.1-1)
[2024-07-16T08:42:59-0300] [ALPM] upgraded libcacard (2.7.0-3 -> 2.7.0-4)
[2024-07-16T08:42:59-0300] [ALPM] upgraded libb64 (1.2.1-4 -> 1.2.1-5)
[2024-07-16T08:42:59-0300] [ALPM] upgraded libabw (0.1.3-3 -> 0.1.3-4)
[2024-07-16T08:42:59-0300] [ALPM] upgraded ld-lsb (3-8 -> 3-9)
[2024-07-16T08:42:59-0300] [ALPM] upgraded ladspa (1.17-4 -> 1.17-5)
[2024-07-16T08:42:59-0300] [ALPM] upgraded iproute2 (6.9.0-1 -> 6.9.0-2)
[2024-07-16T08:42:59-0300] [ALPM] upgraded libbpf (1.4.2-1 -> 1.4.3-1)
[2024-07-16T08:42:59-0300] [ALPM] upgraded iptables (1:1.8.10-1 -> 1:1.8.10-2)
[2024-07-16T08:42:59-0300] [ALPM] upgraded inkscape (1.3.2-7 -> 1.3.2-8)
[2024-07-16T08:42:58-0300] [ALPM] upgraded python-certifi (2024.06.02-1 -> 2024.07.04-1)
[2024-07-16T08:42:58-0300] [ALPM] upgraded python-cairo (1.26.0-2 -> 1.26.1-1)
[2024-07-16T08:42:58-0300] [ALPM] upgraded libwpg (0.3.4-1 -> 0.3.4-2)
[2024-07-16T08:42:58-0300] [ALPM] upgraded libwpd (0.10.3-4 -> 0.10.3-5)
[2024-07-16T08:42:58-0300] [ALPM] upgraded librevenge (0.0.5-2 -> 0.0.5-3)
[2024-07-16T08:42:58-0300] [ALPM] upgraded imagescan (3.65.0-10 -> 3.65.0-11)
[2024-07-16T08:42:58-0300] [ALPM] upgraded ibus (1.5.30-1 -> 1.5.30-2)
[2024-07-16T08:42:58-0300] [ALPM] upgraded iagno (3.38.1+r57+gd147e1a-1 -> 3.38.1+r57+gd147e1a-2)
[2024-07-16T08:42:58-0300] [ALPM] upgraded hyphen-en (2.8.8-5 -> 2.8.8-6)
[2024-07-16T08:42:58-0300] [ALPM] upgraded gvfs-smb (1.54.1-1 -> 1.54.2-1)
[2024-07-16T08:42:57-0300] [ALPM] upgraded gvfs-nfs (1.54.1-1 -> 1.54.2-1)
[2024-07-16T08:42:57-0300] [ALPM] upgraded gvfs-mtp (1.54.1-1 -> 1.54.2-1)
[2024-07-16T08:42:57-0300] [ALPM] upgraded gvfs-gphoto2 (1.54.1-1 -> 1.54.2-1)
[2024-07-16T08:42:57-0300] [ALPM] upgraded libgphoto2 (2.5.31-1 -> 2.5.31-2)
[2024-07-16T08:42:57-0300] [ALPM] upgraded gvfs-google (1.54.1-1 -> 1.54.2-1)
[2024-07-16T08:42:57-0300] [ALPM] upgraded gvfs-goa (1.54.1-1 -> 1.54.2-1)
[2024-07-16T08:42:57-0300] [ALPM] upgraded gvfs-afc (1.54.1-1 -> 1.54.2-1)
[2024-07-16T08:42:57-0300] [ALPM] upgraded usbmuxd (1.1.1-3 -> 1.1.1-4)
[2024-07-16T08:42:57-0300] [ALPM] upgraded gvfs (1.54.1-1 -> 1.54.2-1)
[2024-07-16T08:42:57-0300] [ALPM] upgraded gupnp-dlna (0.12.0-2 -> 0.12.0-3)
[2024-07-16T08:42:57-0300] [ALPM] upgraded guile (3.0.9-1 -> 3.0.10-1)
[2024-07-16T08:42:57-0300] [ALPM] upgraded gtkmm (1:2.24.5-4 -> 1:2.24.5-5)
[2024-07-16T08:42:57-0300] [ALPM] upgraded gst-plugins-ugly (1.24.3-1 -> 1.24.5-2)
[2024-07-16T08:42:57-0300] [ALPM] upgraded libcdio (2.1.0-3 -> 2.1.0-4)
[2024-07-16T08:42:57-0300] [ALPM] upgraded gst-plugins-good (1.24.3-1 -> 1.24.5-2)
[2024-07-16T08:42:57-0300] [ALPM] upgraded twolame (0.4.0-3 -> 0.4.0-4)
[2024-07-16T08:42:57-0300] [ALPM] upgraded libshout (1:2.4.6-2 -> 1:2.4.6-3)
[2024-07-16T08:42:57-0300] [ALPM] upgraded gst-plugins-bad (1.24.3-1 -> 1.24.5-2)
[2024-07-16T08:42:57-0300] [ALPM] upgraded imagemagick (7.1.1.33-1 -> 7.1.1.34-1)
[2024-07-16T08:42:57-0300] [ALPM] upgraded liblqr (0.4.2-3 -> 0.4.2-4)
[2024-07-16T08:42:57-0300] [ALPM] upgraded qrencode (4.1.1-2 -> 4.1.1-3)
[2024-07-16T08:42:57-0300] [ALPM] upgraded libmpcdec (1:0.1+r475-5 -> 1:0.1+r475-6)
[2024-07-16T08:42:57-0300] [ALPM] upgraded libmicrodns (0.2.0-1 -> 0.2.0-2)
[2024-07-16T08:42:57-0300] [ALPM] upgraded libltc (1.3.2-1 -> 1.3.2-2)
[2024-07-16T08:42:57-0300] [ALPM] upgraded liblrdf (0.6.1-4 -> 0.6.1-5)
[2024-07-16T08:42:57-0300] [ALPM] upgraded libldac (2.0.2.3-1 -> 2.0.2.3-2)
[2024-07-16T08:42:57-0300] [ALPM] upgraded libfreeaptx (0.1.1-1 -> 0.1.1-2)
[2024-07-16T08:42:57-0300] [ALPM] upgraded libavtp (0.2.0-2 -> 0.2.0-3)
[2024-07-16T08:42:57-0300] [ALPM] upgraded gst-plugin-pipewire (1:1.0.7-2 -> 1:1.2.1-1)
[2024-07-16T08:42:56-0300] [ALPM] upgraded wireplumber (0.5.3-1 -> 0.5.5-1)
[2024-07-16T08:42:56-0300] [ALPM] upgraded libwireplumber (0.5.3-1 -> 0.5.5-1)
[2024-07-16T08:42:56-0300] [ALPM] upgraded gst-plugin-gtk (1.24.3-1 -> 1.24.5-2)
[2024-07-16T08:42:56-0300] [ALPM] upgraded gst-libav (1.24.3-1 -> 1.24.5-2)
[2024-07-16T08:42:56-0300] [ALPM] upgraded gst-editing-services (1.24.3-1 -> 1.24.5-2)
[2024-07-16T08:42:56-0300] [ALPM] upgraded gst-python (1.24.3-1 -> 1.24.5-2)
[2024-07-16T08:42:56-0300] [ALPM] upgraded gst-devtools-libs (1.24.3-1 -> 1.24.5-2)
[2024-07-16T08:42:56-0300] [ALPM] upgraded gom (0.5.1-1 -> 0.5.2-1)
[2024-07-16T08:42:56-0300] [ALPM] upgraded gnome-user-share (43.0-1 -> 43.0-2)
[2024-07-16T08:42:56-0300] [ALPM] upgraded gnome-themes-extra (3.28+r6+g45b1d457-1 -> 3.28+r6+g45b1d457-2)
[2024-07-16T08:42:56-0300] [ALPM] upgraded gnome-text-editor (46.3-1 -> 46.3-2)
[2024-07-16T08:42:56-0300] [ALPM] upgraded gnome-system-monitor (46.0-1 -> 46.0-2)
[2024-07-16T08:42:56-0300] [ALPM] upgraded gnome-shell-extension-dash-to-panel (62-2 -> 62-3)
[2024-07-16T08:42:56-0300] [ALPM] upgraded gnome-mines (40.1-1 -> 40.1-2)
[2024-07-16T08:42:56-0300] [ALPM] upgraded libgee (0.20.6-1 -> 0.20.6-2)
[2024-07-16T08:42:56-0300] [ALPM] upgraded gnome-menus (3.36.0-2 -> 3.36.0-3)
[2024-07-16T08:42:56-0300] [ALPM] upgraded gnome-control-center (46.2-2 -> 46.3-1)
[2024-07-16T08:42:55-0300] [ALPM] upgraded gnome-keybindings (46.2-2 -> 46.3-1)
[2024-07-16T08:42:55-0300] [ALPM] upgraded smbclient (4.20.1-2 -> 4.20.2-1)
[2024-07-16T08:42:55-0300] [ALPM] upgraded ldb (2:2.9.0-3 -> 2:2.9.1-1)
[2024-07-16T08:42:55-0300] [ALPM] upgraded gnome-shell (1:46.2-1 -> 1:46.3.1-1)
[2024-07-16T08:42:55-0300] [ALPM] upgraded xdg-desktop-portal-gnome (46.2-1 -> 46.2-2)
[2024-07-16T08:42:55-0300] [ALPM] upgraded gnome-keyring (1:46.1-2 -> 1:46.2-1)
[2024-07-16T08:42:55-0300] [ALPM] upgraded mutter (46.2-1.3 -> 46.3.1-1.0)
[2024-07-16T08:42:55-0300] [ALPM] upgraded xorg-xwayland (24.1.0-1 -> 24.1.1-1)
[2024-07-16T08:42:55-0300] [ALPM] upgraded libxcvt (0.1.2-1 -> 0.1.2-2)
[2024-07-16T08:42:55-0300] [ALPM] upgraded libxfont2 (2.0.6-2 -> 2.0.6-3)
[2024-07-16T08:42:55-0300] [ALPM] upgraded pipewire (1:1.0.7-2 -> 1:1.2.1-1)
[2024-07-16T08:42:55-0300] [ALPM] upgraded libdisplay-info (0.1.1-3 -> 0.2.0-1)
[2024-07-16T08:42:55-0300] [ALPM] upgraded libpipewire (1:1.0.7-2 -> 1:1.2.1-1)
[2024-07-16T08:42:54-0300] [ALPM] upgraded libnma-gtk4 (1.10.6-2 -> 1.10.6-3)
[2024-07-16T08:42:54-0300] [ALPM] upgraded libnma-common (1.10.6-2 -> 1.10.6-3)
[2024-07-16T08:42:54-0300] [ALPM] upgraded libnm (1.48.0-1 -> 1.48.4-1)
[2024-07-16T08:42:54-0300] [ALPM] upgraded libibus (1.5.30-1 -> 1.5.30-2)
[2024-07-16T08:42:54-0300] [ALPM] upgraded gnome-online-accounts (3.50.2-1 -> 3.50.3-1)
[2024-07-16T08:42:54-0300] [ALPM] upgraded gnome-characters (46.0-1 -> 46.0-2)
[2024-07-16T08:42:54-0300] [ALPM] upgraded js115 (115.12.0-1 -> 115.13.0-1)
[2024-07-16T08:42:54-0300] [ALPM] upgraded glib2-devel (2.80.3-2 -> 2.80.4-1)
[2024-07-16T08:42:54-0300] [ALPM] upgraded gimp-plugin-gmic (3.4.0-1 -> 3.4.0-2)
[2024-07-16T08:42:54-0300] [ALPM] upgraded slang (2.3.3-2 -> 2.3.3-3)
[2024-07-16T08:42:54-0300] [ALPM] upgraded mypaint-brushes1 (1.3.1-1 -> 1.3.1-2)
[2024-07-16T08:42:53-0300] [ALPM] upgraded libmypaint (1.6.1-1 -> 1.6.1-2)
[2024-07-16T08:42:53-0300] [ALPM] upgraded libgexiv2 (0.14.2-2 -> 0.14.3-1)
[2024-07-16T08:42:53-0300] [ALPM] upgraded gtk2 (2.24.33-3 -> 2.24.33-4)
[2024-07-16T08:42:53-0300] [ALPM] upgraded gmic (3.4.0-1 -> 3.4.0-2)
[2024-07-16T08:42:53-0300] [ALPM] upgraded opencv (4.9.0-8 -> 4.10.0-3)
[2024-07-16T08:42:53-0300] [ALPM] upgraded gst-plugins-base (1.24.3-1 -> 1.24.5-2)
[2024-07-16T08:42:53-0300] [ALPM] upgraded gegl (0.4.48-3 -> 0.4.48-4)
[2024-07-16T08:42:52-0300] [ALPM] upgraded luajit (2.1.1716656478-1 -> 2.1.1720049189-1)
[2024-07-16T08:42:52-0300] [ALPM] upgraded libspiro (1:20221101-2 -> 1:20221101-3)
[2024-07-16T08:42:52-0300] [ALPM] upgraded gd (2.3.3-7 -> 2.3.3-8)
[2024-07-16T08:42:52-0300] [ALPM] upgraded libxpm (3.5.17-1 -> 3.5.17-2)
[2024-07-16T08:42:52-0300] [ALPM] upgraded fwupd (1.9.21-1 -> 1.9.21-2)
[2024-07-16T08:42:52-0300] [ALPM] upgraded libqrtr-glib (1.2.2-2 -> 1.2.2-3)
[2024-07-16T08:42:51-0300] [ALPM] upgraded protobuf-c (1.5.0-2 -> 1.5.0-3)
[2024-07-16T08:42:51-0300] [ALPM] upgraded fuse2 (2.9.9-4 -> 2.9.9-5)
[2024-07-16T08:42:51-0300] [ALPM] upgraded frei0r-plugins (2.3.3-1 -> 2.3.3-2)
[2024-07-16T08:42:51-0300] [ALPM] upgraded freerdp (2:3.5.1-2 -> 2:3.6.3-1)
[2024-07-16T08:42:51-0300] [ALPM] upgraded ffmpegthumbnailer (2.2.2-5 -> 2.2.2-6)
[2024-07-16T08:42:51-0300] [ALPM] upgraded faac (1.30-4 -> 1.30-5)
[2024-07-16T08:42:51-0300] [ALPM] upgraded exiv2 (0.28.2-4 -> 0.28.3-1)
[2024-07-16T08:42:51-0300] [ALPM] upgraded evolution-ews (3.52.2-1 -> 3.52.3-1)
[2024-07-16T08:42:51-0300] [ALPM] upgraded evolution (3.52.2-1 -> 3.52.3-1)
[2024-07-16T08:42:50-0300] [ALPM] upgraded libytnef (1:2.1.2-1 -> 1:2.1.2-2)
[2024-07-16T08:42:50-0300] [ALPM] upgraded libpst (0.6.76-9 -> 0.6.76-10)
[2024-07-16T08:42:50-0300] [ALPM] upgraded evolution-data-server (3.52.2-1 -> 3.52.3-1)
[2024-07-16T08:42:50-0300] [ALPM] upgraded harfbuzz-icu (8.5.0-1 -> 9.0.0-1)
[2024-07-16T08:42:50-0300] [ALPM] upgraded libavif (1.0.4-3 -> 1.1.0-1)
[2024-07-16T08:42:50-0300] [ALPM] upgraded libphonenumber (1:8.13.36-1 -> 1:8.13.40-1)
[2024-07-16T08:42:50-0300] [ALPM] upgraded protobuf (25.3-4 -> 27.2-1)
[2024-07-16T08:42:50-0300] [ALPM] upgraded gtest (1.14.0-1 -> 1.14.0-2)
[2024-07-16T08:42:50-0300] [ALPM] upgraded libgoa (3.50.2-1 -> 3.50.3-1)
[2024-07-16T08:42:50-0300] [ALPM] upgraded libcanberra (1:0.30+r2+gc0620e4-3 -> 1:0.30+r2+gc0620e4-4)
[2024-07-16T08:42:50-0300] [ALPM] upgraded sound-theme-freedesktop (0.8-5 -> 0.8-6)
[2024-07-16T08:42:50-0300] [ALPM] upgraded dosfstools (4.2-3 -> 4.2-4)
[2024-07-16T08:42:49-0300] [ALPM] upgraded dmraid (1.0.0.rc16.3-14 -> 1.0.0.rc16.3-15)
[2024-07-16T08:42:49-0300] [ALPM] upgraded dmidecode (3.5-1 -> 3.6-1)
[2024-07-16T08:42:49-0300] [ALPM] upgraded cups-pk-helper (0.2.7-1 -> 0.2.7-2)
[2024-07-16T08:42:49-0300] [ALPM] upgraded cups-pdf (3.0.1-7 -> 3.0.1-8)
[2024-07-16T08:42:49-0300] [ALPM] upgraded poppler-data (0.4.12-1 -> 0.4.12-2)
[2024-07-16T08:42:49-0300] [ALPM] upgraded cups-filters (2.0.0-1 -> 2.0.0-2)
[2024-07-16T08:42:49-0300] [ALPM] upgraded libppd (2.0.0-1 -> 2.0.0-2)
[2024-07-16T08:42:49-0300] [ALPM] upgraded libexif (0.6.24-2 -> 0.6.24-3)
[2024-07-16T08:42:49-0300] [ALPM] upgraded cracklib (2.9.11-1 -> 2.9.11-2)
[2024-07-16T08:42:49-0300] [ALPM] upgraded cpupower (6.9-1 -> 6.9-2)
[2024-07-16T08:42:49-0300] [ALPM] upgraded colord-gtk4 (0.3.0-2 -> 0.3.1-1)
[2024-07-16T08:42:49-0300] [ALPM] upgraded colord-gtk-common (0.3.0-2 -> 0.3.1-1)
[2024-07-16T08:42:49-0300] [ALPM] upgraded collision (3.8.0-1 -> 3.8.1-1)
[2024-07-16T08:42:49-0300] [ALPM] upgraded clutter-gtk (1.8.4-3 -> 1.8.4-4)
[2024-07-16T08:42:49-0300] [ALPM] upgraded clucene (2.3.3.4-14 -> 2.3.3.4-15)
[2024-07-16T08:42:49-0300] [ALPM] upgraded cifs-utils (7.0-3 -> 7.0-4)
[2024-07-16T08:42:49-0300] [ALPM] upgraded libwbclient (4.20.1-2 -> 4.20.2-1)
[2024-07-16T08:42:49-0300] [ALPM] upgraded libmd (1.1.0-1 -> 1.1.0-2)
[2024-07-16T08:42:49-0300] [ALPM] upgraded chromaprint (1.5.1-7 -> 1.5.1-8)
[2024-07-16T08:42:49-0300] [ALPM] upgraded calibre (7.12.0-1 -> 7.14.0-1)
[2024-07-16T08:42:48-0300] [ALPM] upgraded pinentry (1.3.0-1 -> 1.3.1-2)
[2024-07-16T08:42:48-0300] [ALPM] upgraded libksba (1.6.6-1 -> 1.6.7-1)
[2024-07-16T08:42:48-0300] [ALPM] upgraded lua (5.4.6-3 -> 5.4.7-1)
[2024-07-16T08:42:48-0300] [ALPM] upgraded qt6-webengine (6.7.1-1 -> 6.7.2-1)
[2024-07-16T08:42:47-0300] [ALPM] upgraded ttf-liberation (2.1.5-1 -> 2.1.5-2)
[2024-07-16T08:42:47-0300] [ALPM] upgraded noto-fonts (1:24.6.1-1 -> 1:24.7.1-1)
[2024-07-16T08:42:46-0300] [ALPM] upgraded qt6-webchannel (6.7.1-1 -> 6.7.2-1)
[2024-07-16T08:42:46-0300] [ALPM] upgraded qt6-positioning (6.7.1-1 -> 6.7.2-1)
[2024-07-16T08:42:46-0300] [ALPM] upgraded nss (3.101-1 -> 3.102-1)
[2024-07-16T08:42:46-0300] [ALPM] upgraded qt6-svg (6.7.1-1 -> 6.7.2-1)
[2024-07-16T08:42:46-0300] [ALPM] upgraded qt6-imageformats (6.7.1-1 -> 6.7.2-1)
[2024-07-16T08:42:46-0300] [ALPM] upgraded libmng (2.0.3-3 -> 2.0.3-4)
[2024-07-16T08:42:46-0300] [ALPM] upgraded python-pyqt6 (6.7.0-3 -> 6.7.0-4)
[2024-07-16T08:42:46-0300] [ALPM] upgraded python-pygments (2.17.2-3 -> 2.18.0-1)
[2024-07-16T08:42:46-0300] [ALPM] upgraded python-py7zr (0.21.0-2 -> 0.21.1-1)
[2024-07-16T08:42:46-0300] [ALPM] upgraded python-psutil (5.9.8-4 -> 6.0.0-1)
[2024-07-16T08:42:46-0300] [ALPM] upgraded python-pillow (10.3.0-2 -> 10.4.0-1)
[2024-07-16T08:42:46-0300] [ALPM] upgraded libraqm (0.10.1-1 -> 0.10.1-2)
[2024-07-16T08:42:46-0300] [ALPM] upgraded python-html2text (2020.1.16-10 -> 2024.2.26-1)
[2024-07-16T08:42:46-0300] [ALPM] upgraded mathjax (3.2.2-1 -> 3.2.2-2)
[2024-07-16T08:42:46-0300] [ALPM] upgraded libwmf (0.2.13-1 -> 0.2.13-2)
[2024-07-16T08:42:46-0300] [ALPM] upgraded gsfonts (20200910-3 -> 20200910-4)
[2024-07-16T08:42:46-0300] [ALPM] upgraded libmtp (1.1.21-1 -> 1.1.21-2)
[2024-07-16T08:42:46-0300] [ALPM] upgraded hyphen (2.8.8-5 -> 2.8.8-6)
[2024-07-16T08:42:46-0300] [ALPM] upgraded hunspell (1.7.2-1 -> 1.7.2-2)
[2024-07-16T08:42:46-0300] [ALPM] upgraded btrfsmaintenance (1:0.5.1-1 -> 1:0.5.2-1)
[2024-07-16T08:42:45-0300] [ALPM] upgraded btrfs-progs (6.9-1 -> 6.9.2-1)
[2024-07-16T08:42:45-0300] [ALPM] upgraded bluez-libs (5.76-1 -> 5.77-1)
[2024-07-16T08:42:45-0300] [ALPM] upgraded bluez (5.76-1 -> 5.77-1)
[2024-07-16T08:42:45-0300] [ALPM] upgraded blender (17:4.1.1-8 -> 17:4.1.1-11)
[2024-07-16T08:42:43-0300] [ALPM] upgraded pyside6 (6.7.1-1 -> 6.7.2-3)
[2024-07-16T08:42:43-0300] [ALPM] upgraded shiboken6 (6.7.1-1 -> 6.7.2-3)
[2024-07-16T08:42:43-0300] [ALPM] upgraded llvm (17.0.6-5 -> 18.1.8-3)
[2024-07-16T08:42:42-0300] [ALPM] upgraded libxslt (1.1.40-2 -> 1.1.42-1)
[2024-07-16T08:42:42-0300] [ALPM] upgraded qt6-declarative (6.7.1-1 -> 6.7.2-1)
[2024-07-16T08:42:41-0300] [ALPM] upgraded qt6-base (6.7.1-4 -> 6.7.2-1)
[2024-07-16T08:42:40-0300] [ALPM] upgraded qt6-translations (6.7.1-1 -> 6.7.2-1)
[2024-07-16T08:42:40-0300] [ALPM] upgraded xcb-util-wm (0.4.2-1 -> 0.4.2-2)
[2024-07-16T08:42:40-0300] [ALPM] upgraded xcb-util-renderutil (0.3.10-1 -> 0.3.10-2)
[2024-07-16T08:42:40-0300] [ALPM] upgraded xcb-util-keysyms (0.4.1-4 -> 0.4.1-5)
[2024-07-16T08:42:40-0300] [ALPM] upgraded xcb-util-image (0.4.1-2 -> 0.4.1-3)
[2024-07-16T08:42:40-0300] [ALPM] upgraded xcb-util (0.4.1-1 -> 0.4.1-2)
[2024-07-16T08:42:40-0300] [ALPM] upgraded libinput (1.26.0-1 -> 1.26.1-1)
[2024-07-16T08:42:40-0300] [ALPM] upgraded libwacom (2.12.1-1 -> 2.12.2-1)
[2024-07-16T08:42:40-0300] [ALPM] upgraded libb2 (0.98.1-2 -> 0.98.1-3)
[2024-07-16T08:42:40-0300] [ALPM] upgraded double-conversion (3.3.0-1 -> 3.3.0-2)
[2024-07-16T08:42:40-0300] [ALPM] upgraded mtdev (1.1.6-2 -> 1.1.7-1)
[2024-07-16T08:42:40-0300] [ALPM] upgraded python-idna (3.6-2 -> 3.7-1)
[2024-07-16T08:42:40-0300] [ALPM] upgraded zenity (4.0.1-1 -> 4.0.2-1)
[2024-07-16T08:42:40-0300] [ALPM] upgraded libadwaita (1:1.5.1-1 -> 1:1.5.2-1)
[2024-07-16T08:42:40-0300] [ALPM] upgraded libyaml (0.2.5-2 -> 0.2.5-3)
[2024-07-16T08:42:40-0300] [ALPM] upgraded gtk4 (1:4.14.4-1 -> 1:4.14.4-2)
[2024-07-16T08:42:40-0300] [ALPM] upgraded gst-plugins-bad-libs (1.24.3-1 -> 1.24.5-2)
[2024-07-16T08:42:40-0300] [ALPM] upgraded gst-plugins-base-libs (1.24.3-1 -> 1.24.5-2)
[2024-07-16T08:42:39-0300] [ALPM] upgraded gstreamer (1.24.3-1 -> 1.24.5-2)
[2024-07-16T08:42:39-0300] [ALPM] upgraded python-setuptools (1:69.0.3-6 -> 1:69.5.1-1)
[2024-07-16T08:42:39-0300] [ALPM] upgraded python-inflect (7.2.1-2 -> 7.3.1-1)
[2024-07-16T08:42:39-0300] [ALPM] upgraded python-validate-pyproject (0.16-1 -> 0.18-1)
[2024-07-16T08:42:39-0300] [ALPM] upgraded python-platformdirs (4.2.0-3 -> 4.2.2-1)
[2024-07-16T08:42:39-0300] [ALPM] upgraded python-more-itertools (10.2.0-2 -> 10.3.0-1)
[2024-07-16T08:42:39-0300] [ALPM] upgraded python-packaging (24.0-1 -> 24.1-1)
[2024-07-16T08:42:39-0300] [ALPM] upgraded libxt (1.3.0-1 -> 1.3.0-2)
[2024-07-16T08:42:39-0300] [ALPM] upgraded libsm (1.2.4-1 -> 1.2.4-2)
[2024-07-16T08:42:39-0300] [ALPM] upgraded libice (1.1.1-2 -> 1.1.1-3)
[2024-07-16T08:42:39-0300] [ALPM] upgraded python-numpy (1.26.4-2 -> 2.0.0-1)
[2024-07-16T08:42:39-0300] [ALPM] upgraded openxr (1.1.36-1 -> 1.1.38-1)
[2024-07-16T08:42:39-0300] [ALPM] upgraded jsoncpp (1.9.5-2 -> 1.9.5-3)
[2024-07-16T08:42:39-0300] [ALPM] upgraded openvdb (11.0.0-2 -> 11.0.0-4)
[2024-07-16T08:42:36-0300] [ALPM] upgraded log4cplus (2.1.0-1 -> 2.1.0-2)
[2024-07-16T08:42:36-0300] [ALPM] upgraded blosc (1.21.5-1 -> 1.21.5-2)
[2024-07-16T08:42:36-0300] [ALPM] upgraded openshadinglanguage (1.13.9.0-1 -> 1.13.9.0-2)
[2024-07-16T08:42:36-0300] [ALPM] upgraded clang (17.0.6-2 -> 18.1.8-1)
[2024-07-16T08:42:35-0300] [ALPM] upgraded libmpc (1.3.1-1 -> 1.3.1-2)
[2024-07-16T08:42:35-0300] [ALPM] upgraded compiler-rt (17.0.6-2 -> 18.1.8-1)
[2024-07-16T08:42:35-0300] [ALPM] upgraded openimageio (2.5.10.1-1 -> 2.5.13.0-1)
[2024-07-16T08:42:35-0300] [ALPM] upgraded libheif (1.17.6-5 -> 1.18.0-1)
[2024-07-16T08:42:35-0300] [ALPM] upgraded libde265 (1.0.15-1 -> 1.0.15-2)
[2024-07-16T08:42:35-0300] [ALPM] upgraded pybind11 (2.12.0-4 -> 2.13.1-1)
[2024-07-16T08:42:35-0300] [ALPM] upgraded opencolorio (2.3.2-2 -> 2.3.2-3)
[2024-07-16T08:42:35-0300] [ALPM] upgraded openal (1.23.1-1 -> 1.23.1-2)
[2024-07-16T08:42:35-0300] [ALPM] upgraded onetbb (2021.12.0-2 -> 2021.13.0-1)
[2024-07-16T08:42:35-0300] [ALPM] upgraded libtool (2.5.0+1+g38c166c8-1 -> 2.5.0+14+g9a4a0261-1)
[2024-07-16T08:42:35-0300] [ALPM] upgraded libspnav (1.1-1 -> 1.1-2)
[2024-07-16T08:42:35-0300] [ALPM] upgraded level-zero-loader (1.16.15-1 -> 1.17.6-1)
[2024-07-16T08:42:35-0300] [ALPM] installed spdlog (1.14.1-1)
[2024-07-16T08:42:35-0300] [ALPM] installed fmt (10.2.0-1)
[2024-07-16T08:42:35-0300] [ALPM] upgraded glew (2.2.0-6 -> 2.2.0-7)
[2024-07-16T08:42:35-0300] [ALPM] upgraded glu (9.0.3-1 -> 9.0.3-2)
[2024-07-16T08:42:35-0300] [ALPM] upgraded ffmpeg (2:6.1.1-7 -> 2:7.0.1-2)
[2024-07-16T08:42:35-0300] [ALPM] upgraded l-smash (2.14.5-3 -> 2.14.5-4)
[2024-07-16T08:42:35-0300] [ALPM] upgraded libasyncns (1:0.8+r3+g68cd5af-2 -> 1:0.8+r3+g68cd5af-3)
[2024-07-16T08:42:35-0300] [ALPM] upgraded libsamplerate (0.2.2-2 -> 0.2.2-3)
[2024-07-16T08:42:35-0300] [ALPM] upgraded x265 (3.5-3 -> 3.6-1)
[2024-07-16T08:42:35-0300] [ALPM] upgraded vapoursynth (R68-1 -> R69-1)
[2024-07-16T08:42:35-0300] [ALPM] upgraded sdl2 (2.30.3-1 -> 2.30.5-1)
[2024-07-16T08:42:35-0300] [ALPM] upgraded opencore-amr (0.1.6-1 -> 0.1.6-2)
[2024-07-16T08:42:35-0300] [ALPM] upgraded libvpl (2.11.0-1 -> 2.12.0-1)
[2024-07-16T08:42:35-0300] [ALPM] upgraded ocl-icd (2.3.2-1 -> 2.3.2-2)
[2024-07-16T08:42:35-0300] [ALPM] installed mbedtls2 (2.28.8-3)
[2024-07-16T08:42:35-0300] [ALPM] upgraded libxv (1.0.12-1 -> 1.0.12-2)
[2024-07-16T08:42:35-0300] [ALPM] upgraded libvdpau (1.5-2 -> 1.5-3)
[2024-07-16T08:42:35-0300] [ALPM] upgraded libsoxr (0.1.3-3 -> 0.1.3-4)
[2024-07-16T08:42:34-0300] [ALPM] upgraded libplacebo (6.338.2-7 -> 7.349.0-1)
[2024-07-16T08:42:34-0300] [ALPM] upgraded libmodplug (0.8.9.0-5 -> 0.8.9.0-6)
[2024-07-16T08:42:34-0300] [ALPM] upgraded libjxl (0.10.2-1 -> 0.10.3-1)
[2024-07-16T08:42:34-0300] [ALPM] upgraded libiec61883 (1.2.0-7 -> 1.2.0-8)
[2024-07-16T08:42:34-0300] [ALPM] upgraded libraw1394 (2.1.2-3 -> 2.1.2-4)
[2024-07-16T08:42:34-0300] [ALPM] upgraded libbs2b (3.1.0-8 -> 3.1.0-9)
[2024-07-16T08:42:34-0300] [ALPM] upgraded flac (1.4.3-1 -> 1.4.3-2)
[2024-07-16T08:42:34-0300] [ALPM] upgraded libass (0.17.2-1 -> 0.17.3-1)
[2024-07-16T08:42:34-0300] [ALPM] upgraded lame (3.100-4 -> 3.100-5)
[2024-07-16T08:42:34-0300] [ALPM] upgraded gsm (1.0.22-1 -> 1.0.22-2)
[2024-07-16T08:42:34-0300] [ALPM] upgraded dav1d (1.4.2-1 -> 1.4.3-1)
[2024-07-16T08:42:34-0300] [ALPM] upgraded draco (1.5.6-2 -> 1.5.6-3)
[2024-07-16T08:42:34-0300] [ALPM] upgraded boost-libs (1.83.0-8 -> 1.83.0-9)
[2024-07-16T08:42:34-0300] [ALPM] upgraded b43-fwcutter (019-4 -> 019-5)
[2024-07-16T08:42:34-0300] [ALPM] upgraded ayatana-ido (0.10.2-1 -> 0.10.3-1)
[2024-07-16T08:42:34-0300] [ALPM] upgraded gtk3 (1:3.24.42-1 -> 1:3.24.43-1)
[2024-07-16T08:42:34-0300] [ALPM] upgraded duktape (2.7.0-6 -> 2.7.0-7)
[2024-07-16T08:42:34-0300] [ALPM] upgraded json-glib (1.8.0-1 -> 1.8.0-2)
[2024-07-16T08:42:34-0300] [ALPM] upgraded libdaemon (0.14-5 -> 0.14-6)
[2024-07-16T08:42:34-0300] [ALPM] upgraded gnutls (3.8.5-1 -> 3.8.6-1)
[2024-07-16T08:42:34-0300] [ALPM] upgraded gsettings-desktop-schemas (46.0-1 -> 46.0-2)
[2024-07-16T08:42:34-0300] [ALPM] upgraded libxtst (1.2.4-1 -> 1.2.4-2)
[2024-07-16T08:42:32-0300] [ALPM] upgraded systemd (256.1-1 -> 256.2-1)
[2024-07-16T08:42:32-0300] [ALPM] upgraded json-c (0.17-1 -> 0.17-2)
[2024-07-16T08:42:32-0300] [ALPM] upgraded hwdata (0.383-1 -> 0.384-1)
[2024-07-16T08:42:32-0300] [ALPM] upgraded gtk-update-icon-cache (1:4.14.4-1 -> 1:4.14.4-2)
[2024-07-16T08:42:32-0300] [ALPM] upgraded libxinerama (1.1.5-1 -> 1.1.5-2)
[2024-07-16T08:42:32-0300] [ALPM] upgraded libxi (1.8.1-1 -> 1.8.1-2)
[2024-07-16T08:42:32-0300] [ALPM] upgraded libxdamage (1.1.6-1 -> 1.1.6-2)
[2024-07-16T08:42:32-0300] [ALPM] upgraded libxcomposite (0.4.6-1 -> 0.4.6-2)
[2024-07-16T08:42:32-0300] [ALPM] upgraded librsvg (2:2.58.1-1 -> 2:2.58.2-1)
[2024-07-16T08:42:32-0300] [ALPM] upgraded libxft (2.3.8-1 -> 2.3.8-2)
[2024-07-16T08:42:32-0300] [ALPM] upgraded libxrender (0.9.11-1 -> 0.9.11-2)
[2024-07-16T08:42:32-0300] [ALPM] upgraded libepoxy (1.5.10-2 -> 1.5.10-3)
[2024-07-16T08:42:32-0300] [ALPM] upgraded mesa (1:24.1.1-1 -> 1:24.1.3-1)
[2024-07-16T08:42:31-0300] [ALPM] upgraded ca-certificates (20220905-1 -> 20240618-1)
[2024-07-16T08:42:31-0300] [ALPM] upgraded ca-certificates-mozilla (3.101-1 -> 3.102-1)
[2024-07-16T08:42:31-0300] [ALPM] upgraded ca-certificates-utils (20220905-1 -> 20240618-1)
[2024-07-16T08:42:31-0300] [ALPM] upgraded p11-kit (0.25.3-1 -> 0.25.5-1)
[2024-07-16T08:42:31-0300] [ALPM] upgraded libp11-kit (0.25.3-1 -> 0.25.5-1)
[2024-07-16T08:42:31-0300] [ALPM] upgraded libtasn1 (4.19.0-1 -> 4.19.0-2)
[2024-07-16T08:42:31-0300] [ALPM] upgraded default-cursors (2-1 -> 2-2)
[2024-07-16T08:42:31-0300] [ALPM] upgraded libomxil-bellagio (0.9.3-4 -> 0.9.3-5)
[2024-07-16T08:42:31-0300] [ALPM] upgraded lm_sensors (1:3.6.0.r41.g31d1f125-2 -> 1:3.6.0.r41.g31d1f125-3)
[2024-07-16T08:42:31-0300] [ALPM] upgraded libxshmfence (1.3.2-1 -> 1.3.2-2)
[2024-07-16T08:42:31-0300] [ALPM] upgraded llvm-libs (17.0.6-5 -> 18.1.8-3)
[2024-07-16T08:42:31-0300] [ALPM] upgraded libxml2 (2.13.0-4 -> 2.13.2-1)
[2024-07-16T08:42:31-0300] [ALPM] upgraded libxxf86vm (1.1.5-1 -> 1.1.5-2)
[2024-07-16T08:42:31-0300] [ALPM] upgraded libdrm (2.4.121-1 -> 2.4.122-1)
[2024-07-16T08:42:31-0300] [ALPM] upgraded libxfixes (6.0.1-1 -> 6.0.1-2)
[2024-07-16T08:42:31-0300] [ALPM] upgraded libxau (1.0.11-2 -> 1.0.11-3)
[2024-07-16T08:42:31-0300] [ALPM] upgraded harfbuzz (8.5.0-1 -> 9.0.0-1)
[2024-07-16T08:42:31-0300] [ALPM] upgraded graphite (1:1.3.14-3 -> 1:1.3.14-4)
[2024-07-16T08:42:31-0300] [ALPM] upgraded freetype2 (2.13.2-1 -> 2.13.2-2)
[2024-07-16T08:42:30-0300] [ALPM] upgraded dconf (0.40.0-2 -> 0.40.0-3)
[2024-07-16T08:42:30-0300] [ALPM] upgraded cantarell-fonts (1:0.303.1-1 -> 1:0.303.1-2)
[2024-07-16T08:42:30-0300] [ALPM] upgraded glib2 (2.80.3-2 -> 2.80.4-1)
[2024-07-16T08:42:30-0300] [ALPM] upgraded apache (2.4.59-1 -> 2.4.61-1)
[2024-07-16T08:42:30-0300] [ALPM] upgraded util-linux (2.40.1-1 -> 2.40.2-1)
[2024-07-16T08:42:30-0300] [ALPM] upgraded shadow (4.15.1-2 -> 4.16.0-1)
[2024-07-16T08:42:30-0300] [ALPM] upgraded systemd-libs (256.1-1 -> 256.2-1)
[2024-07-16T08:42:30-0300] [ALPM] upgraded krb5 (1.21.2-2 -> 1.21.3-1)
[2024-07-16T08:42:30-0300] [ALPM] upgraded libldap (2.6.7-2 -> 2.6.8-1)
[2024-07-16T08:42:30-0300] [ALPM] upgraded gdbm (1.23-2 -> 1.24-1)
[2024-07-16T08:42:30-0300] [ALPM] upgraded libgcrypt (1.10.3-1 -> 1.11.0-2)
[2024-07-16T08:42:30-0300] [ALPM] upgraded libgpg-error (1.49-1 -> 1.50-1)
[2024-07-16T08:42:30-0300] [ALPM] upgraded util-linux-libs (2.40.1-1 -> 2.40.2-1)
[2024-07-16T08:42:30-0300] [ALPM] upgraded amd-ucode (20240610.9c10a208-1 -> 20240703.e94a2a3b-1)
[2024-07-16T08:42:30-0300] [ALPM] upgraded alsa-plugins (1:1.2.12-1 -> 1:1.2.12-2)
[2024-07-16T08:42:30-0300] [ALPM] upgraded alsa-oss (1.1.8-5 -> 1.1.8-6)
[2024-07-16T08:42:30-0300] [ALPM] upgraded alsa-topology-conf (1.2.5.1-3 -> 1.2.5.1-4)
[2024-07-16T08:42:30-0300] [ALPM] upgraded alsa-firmware (1.2.4-3 -> 1.2.4-4)
[2024-07-16T08:42:30-0300] [ALPM] upgraded alsa-card-profiles (1:1.0.7-2 -> 1:1.2.1-1)
[2024-07-16T08:42:30-0300] [ALPM] upgraded alembic (1.8.6-2 -> 1.8.6-3)
[2024-07-16T08:42:30-0300] [ALPM] upgraded hdf5 (1.14.4.2-6 -> 1.14.4.3-1)
[2024-07-16T08:42:30-0300] [ALPM] upgraded adobe-source-code-pro-fonts (2.042u+1.062i+1.026vf-1 -> 2.042u+1.062i+1.026vf-2)
[2024-07-16T08:42:30-0300] [ALPM] upgraded acpid (2.0.34-1 -> 2.0.34-2)
[2024-07-16T08:42:29-0300] [ALPM] upgraded bash (5.2.026-2 -> 5.2.026-3)
[2024-07-16T08:42:29-0300] [ALPM] upgraded acpi (1.7-3 -> 1.7-4)
[2024-07-16T08:42:29-0300] [ALPM] upgraded iana-etc (20240412-1 -> 20240612-1)
[2024-07-16T08:39:02-0300] [ALPM] upgraded archlinux-keyring (20240609-1 -> 20240709-1)
[2024-07-12T09:06:42-0300] [ALPM] upgraded firefox-i18n-pt-br (127.0.1-1 -> 128.0-1)
[2024-07-12T09:06:42-0300] [ALPM] upgraded firefox-i18n-en-us (127.0.1-1 -> 128.0-1)
[2024-07-12T09:06:42-0300] [ALPM] upgraded firefox (127.0.1-1 -> 128.0-1)
[2024-07-08T11:19:34-0300] [ALPM] upgraded epson-inkjet-printer-escpr2 (1.2.11-1 -> 1.2.12-1)
[2024-07-05T10:06:10-0300] [ALPM] upgraded gnome-shell-extension-gtk4-desktop-icons-ng (1:77-1 -> 1:78-1)
[2024-07-01T17:18:58-0300] [ALPM] upgraded webapp-manager (1.3.4-2 -> 1.3.6-1)
[2024-07-01T17:18:58-0300] [ALPM] upgraded vpnc (1:0.5.3.r526.r213-1 -> 1:0.5.3.r539.r239-1)
[2024-07-01T17:18:58-0300] [ALPM] upgraded usd (24.03-7 -> 24.05-1)
[2024-07-01T17:18:58-0300] [ALPM] upgraded touche (2.0.12-2 -> 2.0.12-3)
[2024-07-01T17:18:58-0300] [ALPM] upgraded timeshift (24.01.1-1 -> 24.06.1-1)
[2024-07-01T17:18:58-0300] [ALPM] upgraded xapp (2.8.2-2 -> 2.8.3-1)
[2024-07-01T17:18:57-0300] [ALPM] upgraded syncthing (1.27.7-1 -> 1.27.8-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded seahorse (1:43.0-2 -> 1:43.0-3)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-desktop (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-vhost-user-gpu (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-ui-spice-app (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-ui-sdl (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-ui-gtk (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded vte3 (0.76.2-1 -> 0.76.3-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded vte-common (0.76.2-1 -> 0.76.3-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-ui-egl-headless (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-ui-dbus (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-ui-curses (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-hw-usb-smartcard (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-hw-usb-redirect (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-hw-usb-host (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-hw-display-virtio-vga-gl (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-hw-display-virtio-vga (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-hw-display-virtio-gpu-pci-gl (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-hw-display-virtio-gpu-pci (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-hw-display-virtio-gpu-gl (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-hw-display-virtio-gpu (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-hw-display-qxl (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-chardev-spice (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-block-ssh (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-block-nfs (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-block-dmg (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-block-curl (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-base (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded virtiofsd (1.10.1-1 -> 1.11.0-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-system-x86 (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-system-x86-firmware (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-img (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-audio-spice (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-ui-spice-core (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-ui-opengl (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-audio-sdl (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-audio-pipewire (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-audio-pa (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-audio-oss (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-audio-jack (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-audio-dbus (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-audio-alsa (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded qemu-common (9.0.0-1 -> 9.0.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded python-jaraco.text (3.12.0-3 -> 3.12.1-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded python-typeguard (4.2.1-2 -> 4.3.0-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded python-typing_extensions (4.12.0-1 -> 4.12.2-1)
[2024-07-01T17:18:56-0300] [ALPM] upgraded python-google-auth (2.29.0-2 -> 2.30.0-1)
[2024-07-01T17:18:54-0300] [ALPM] upgraded python-fastjsonschema (2.19.1-3 -> 2.20.0-1)
[2024-07-01T17:18:54-0300] [ALPM] upgraded ptex (2.4.2-2 -> 2.4.3-1)
[2024-07-01T17:18:54-0300] [ALPM] upgraded noto-fonts-cjk (20230817-1 -> 20230817-2)
[2024-07-01T17:18:53-0300] [ALPM] upgraded networkmanager (1.46.0-2 -> 1.48.0-1)
[2024-07-01T17:18:53-0300] [ALPM] upgraded nautilus (46.2-1 -> 46.2-2)
[2024-07-01T17:18:53-0300] [ALPM] upgraded mkinitcpio-openswap (0.1.0-3 -> 0.1.0-4)
[2024-07-01T17:18:53-0300] [ALPM] upgraded minizip-ng (4.0.6-1 -> 4.0.7-1)
[2024-07-01T17:18:53-0300] [ALPM] upgraded mhwd-nvidia (550.90.07-3 -> 550.90.07-7)
[2024-07-01T17:18:53-0300] [ALPM] upgraded mhwd-nvidia-470xx (470.256.02-1 -> 470.256.02-3)
[2024-07-01T17:18:53-0300] [ALPM] upgraded mhwd-nvidia-390xx (390.157-11 -> 390.157-13)
[2024-07-01T17:18:53-0300] [ALPM] upgraded perl-html-tagset (3.20-14 -> 3.24-1)
[2024-07-01T17:18:53-0300] [ALPM] upgraded mariadb-libs (11.3.2-2 -> 11.4.2-1)
[2024-07-01T17:18:52-0300] [ALPM] upgraded manjaro-release (24.0.2-1 -> 24.0.3-1)
[2024-07-01T17:18:52-0300] [ALPM] upgraded man-pages (6.8-1 -> 6.9.1-1)
[2024-07-01T17:18:52-0300] [ALPM] upgraded linux69-headers (6.9.3-3 -> 6.9.5-1)
[2024-07-01T17:18:47-0300] [ALPM] upgraded pahole (1:1.26-2 -> 1:1.27-1)
[2024-07-01T17:18:47-0300] [ALPM] upgraded linux69 (6.9.3-3 -> 6.9.5-1)
[2024-07-01T17:18:40-0300] [ALPM] upgraded linux-firmware (20240510.b9d2bf23-1 -> 20240610.9c10a208-1)
[2024-07-01T17:18:38-0300] [ALPM] upgraded linux-firmware-whence (20240510.b9d2bf23-1 -> 20240610.9c10a208-1)
[2024-07-01T17:18:38-0300] [ALPM] upgraded libvirt (1:10.3.0-1 -> 1:10.4.0-1)
[2024-07-01T17:18:37-0300] [ALPM] upgraded libndp (1.8-1 -> 1.8-2)
[2024-07-01T17:18:37-0300] [ALPM] upgraded libnautilus-extension (46.2-1 -> 46.2-2)
[2024-07-01T17:18:37-0300] [ALPM] upgraded kwindowsystem (6.2.0-1 -> 6.3.0-1)
[2024-07-01T17:18:37-0300] [ALPM] upgraded inkscape (1.3.2-5 -> 1.3.2-7)
[2024-07-01T17:18:37-0300] [ALPM] upgraded python-certifi (2024.02.02-2 -> 2024.06.02-1)
[2024-07-01T17:18:37-0300] [ALPM] upgraded lib2geom (1.3-1 -> 1.3-2)
[2024-07-01T17:18:37-0300] [ALPM] upgraded iniparser (4.2.2-1 -> 4.2.4-1)
[2024-07-01T17:18:37-0300] [ALPM] upgraded gsl (2.7.1-3 -> 2.8-1)
[2024-07-01T17:18:36-0300] [ALPM] upgraded gnome-font-viewer (46.0-1 -> 46.0-2)
[2024-07-01T17:18:36-0300] [ALPM] upgraded gnome-control-center (46.2-1 -> 46.2-2)
[2024-07-01T17:18:36-0300] [ALPM] upgraded talloc (2.4.2-2 -> 2.4.2-3)
[2024-07-01T17:18:36-0300] [ALPM] upgraded gnome-keybindings (46.2-1 -> 46.2-2)
[2024-07-01T17:18:36-0300] [ALPM] upgraded git (2.45.1-1 -> 2.45.2-1)
[2024-07-01T17:18:35-0300] [ALPM] upgraded gimp-plugin-gmic (3.3.6-1 -> 3.4.0-1)
[2024-07-01T17:18:35-0300] [ALPM] upgraded poppler-glib (24.05.0-1 -> 24.06.1-1)
[2024-07-01T17:18:35-0300] [ALPM] upgraded qt5-base (5.15.14+kde+r140-1 -> 5.15.14+kde+r141-1)
[2024-07-01T17:18:34-0300] [ALPM] upgraded gmic (3.3.6-1 -> 3.4.0-1)
[2024-07-01T17:18:34-0300] [ALPM] upgraded gdm (46.2-2 -> 46.2-3)
[2024-07-01T17:18:34-0300] [ALPM] upgraded woff2 (1.0.2-4 -> 1.0.2-5)
[2024-07-01T17:18:34-0300] [ALPM] upgraded libxslt (1.1.39-2 -> 1.1.40-2)
[2024-07-01T17:18:34-0300] [ALPM] upgraded js115 (115.11.0-1 -> 115.12.0-1)
[2024-07-01T17:18:33-0300] [ALPM] upgraded unzip (6.0-20 -> 6.0-21)
[2024-07-01T17:18:33-0300] [ALPM] upgraded mutter (46.2-1.0 -> 46.2-1.3)
[2024-07-01T17:18:33-0300] [ALPM] upgraded libimobiledevice-glue (1.2.0-1 -> 1.3.0-1)
[2024-07-01T17:18:33-0300] [ALPM] upgraded libinput (1.25.0-1 -> 1.26.0-1)
[2024-07-01T17:18:33-0300] [ALPM] upgraded libwacom (2.11.0-1 -> 2.12.1-1)
[2024-07-01T17:18:33-0300] [ALPM] upgraded libnm (1.46.0-2 -> 1.48.0-1)
[2024-07-01T17:18:33-0300] [ALPM] upgraded libgdm (46.2-2 -> 46.2-3)
[2024-07-01T17:18:33-0300] [ALPM] upgraded gcr-4 (4.2.1-2 -> 4.3.0-1)
[2024-07-01T17:18:33-0300] [ALPM] upgraded gcr (3.41.2-1 -> 3.41.2-2)
[2024-07-01T17:18:33-0300] [ALPM] upgraded openssh (9.7p1-2 -> 9.8p1-1)
[2024-07-01T17:18:33-0300] [ALPM] upgraded fwupd (1.9.20-1 -> 1.9.21-1)
[2024-07-01T17:18:33-0300] [ALPM] upgraded frei0r-plugins (2.3.2-2 -> 2.3.3-1)
[2024-07-01T17:18:33-0300] [ALPM] upgraded freeglut (3.4.0-1 -> 3.6.0-1)
[2024-07-01T17:18:33-0300] [ALPM] upgraded fragments (3.0.0-1 -> 3.0.1-1)
[2024-07-01T17:18:33-0300] [ALPM] upgraded transmission-cli (4.0.5-1 -> 4.0.6-1)
[2024-07-01T17:18:33-0300] [ALPM] upgraded firefox-i18n-pt-br (127.0-1 -> 127.0.1-1)
[2024-07-01T17:18:33-0300] [ALPM] upgraded firefox-i18n-en-us (127.0-1 -> 127.0.1-1)
[2024-07-01T17:18:33-0300] [ALPM] upgraded firefox (127.0-1 -> 127.0.1-1)
[2024-07-01T17:18:32-0300] [ALPM] upgraded x264 (3:0.164.r3108.31e19f9-1 -> 3:0.164.r3108.31e19f9-2)
[2024-07-01T17:18:32-0300] [ALPM] upgraded libplacebo (6.338.2-6 -> 6.338.2-7)
[2024-07-01T17:18:32-0300] [ALPM] upgraded shaderc (2024.0-1 -> 2024.1-1)
[2024-07-01T17:18:32-0300] [ALPM] upgraded glslang (14.1.0-1 -> 14.2.0-1)
[2024-07-01T17:18:32-0300] [ALPM] upgraded spirv-tools (2024.1-1 -> 2024.2-1)
[2024-07-01T17:18:32-0300] [ALPM] upgraded libopenmpt (0.7.7-1 -> 0.7.8-1)
[2024-07-01T17:18:32-0300] [ALPM] upgraded libogg (1.3.5-1 -> 1.3.5-2)
[2024-07-01T17:18:32-0300] [ALPM] upgraded exfatprogs (1.2.3-1 -> 1.2.4-1)
[2024-07-01T17:18:32-0300] [ALPM] upgraded enchant (2.7.3-2 -> 2.8.0-1)
[2024-07-01T17:18:32-0300] [ALPM] upgraded embree (4.3.1-1 -> 4.3.2-1)
[2024-07-01T17:18:32-0300] [ALPM] upgraded editorconfig-core-c (0.12.7-1 -> 0.12.9-1)
[2024-07-01T17:18:32-0300] [ALPM] upgraded dynamic-wallpaper (0.1.0-2 -> 0.1.0-3)
[2024-07-01T17:18:32-0300] [ALPM] upgraded duplicity (2.2.3-1 -> 3.0.0-1)
[2024-07-01T17:18:32-0300] [ALPM] upgraded python-bcrypt (4.1.2-2 -> 4.1.3-1)
[2024-07-01T17:18:31-0300] [ALPM] upgraded cups (2:2.4.8-1 -> 2:2.4.10-1)
[2024-07-01T17:18:31-0300] [ALPM] upgraded qpdf (11.9.0-1 -> 11.9.1-1)
[2024-07-01T17:18:31-0300] [ALPM] upgraded poppler (24.05.0-1 -> 24.06.1-1)
[2024-07-01T17:18:31-0300] [ALPM] upgraded nss (3.100-1 -> 3.101-1)
[2024-07-01T17:18:31-0300] [ALPM] upgraded nspr (4.35-2 -> 4.35-3)
[2024-07-01T17:18:31-0300] [ALPM] upgraded btrfs-progs (6.8.1-1 -> 6.9-1)
[2024-07-01T17:18:31-0300] [ALPM] upgraded bolt (0.9.7-2 -> 0.9.8-1)
[2024-07-01T17:18:31-0300] [ALPM] upgraded base-devel (1-2 -> 1-3)
[2024-07-01T17:18:31-0300] [ALPM] upgraded groff (1.23.0-5 -> 1.23.0-6)
[2024-07-01T17:18:30-0300] [ALPM] upgraded fakeroot (1.34-1 -> 1.35-1)
[2024-07-01T17:18:30-0300] [ALPM] upgraded base (3-2 -> 3-3)
[2024-07-01T17:18:30-0300] [ALPM] upgraded systemd-sysvcompat (255.7-1 -> 256.1-1)
[2024-07-01T17:18:29-0300] [ALPM] upgraded manjaro-keyring (20230719-2 -> 20230719-3)
[2024-07-01T17:18:29-0300] [ALPM] upgraded pacman-mirrors (4.24.1-2 -> 4.26.1-1)
[2024-07-01T17:18:29-0300] [ALPM] warning: /etc/pacman-mirrors.conf installed as /etc/pacman-mirrors.conf.pacnew
[2024-07-01T17:18:29-0300] [ALPM] upgraded aom (3.9.0-1 -> 3.9.1-1)
[2024-07-01T17:18:29-0300] [ALPM] upgraded amd-ucode (20240510.b9d2bf23-1 -> 20240610.9c10a208-1)
[2024-07-01T17:18:29-0300] [ALPM] upgraded alsa-utils (1.2.11-1 -> 1.2.12-1)
[2024-07-01T17:18:29-0300] [ALPM] upgraded pciutils (3.12.0-1 -> 3.13.0-1)
[2024-07-01T17:18:29-0300] [ALPM] upgraded alsa-plugins (1:1.2.7.1-2 -> 1:1.2.12-1)
[2024-07-01T17:18:29-0300] [ALPM] upgraded alsa-lib (1.2.11-1 -> 1.2.12-1)
[2024-07-01T17:18:29-0300] [ALPM] upgraded alsa-ucm-conf (1.2.11-1 -> 1.2.12-1)
[2024-07-01T17:18:28-0300] [ALPM] upgraded adw-gtk-theme (1.1-1 -> 1.1-2)
[2024-07-01T17:18:28-0300] [ALPM] upgraded libproxy (0.5.6-1 -> 0.5.7-1)
[2024-07-01T17:18:28-0300] [ALPM] upgraded xkeyboard-config (2.41-1 -> 2.42-1)
[2024-07-01T17:18:27-0300] [ALPM] upgraded systemd (255.7-1 -> 256.1-1)
[2024-07-01T17:18:27-0300] [ALPM] upgraded cryptsetup (2.7.2-1 -> 2.7.3-1)
[2024-07-01T17:18:27-0300] [ALPM] upgraded hwdata (0.382-1 -> 0.383-1)
[2024-07-01T17:18:27-0300] [ALPM] upgraded mesa (1:24.0.9-1 -> 1:24.1.1-1)
[2024-07-01T17:18:26-0300] [ALPM] upgraded libdrm (2.4.120-1 -> 2.4.121-1)
[2024-07-01T17:18:26-0300] [ALPM] upgraded libxml2 (2.12.7-1 -> 2.13.0-4)
[2024-07-01T17:18:26-0300] [ALPM] upgraded libcups (2:2.4.8-1 -> 2:2.4.10-1)
[2024-07-01T17:18:26-0300] [ALPM] upgraded nettle (3.9.1-1 -> 3.10-1)
[2024-07-01T17:18:26-0300] [ALPM] upgraded pango (1:1.52.2-1 -> 1:1.54.0-1)
[2024-07-01T17:18:26-0300] [ALPM] upgraded fribidi (1.0.14-1 -> 1.0.15-1)
[2024-07-01T17:18:26-0300] [ALPM] installed glib2-devel (2.80.3-2)
[2024-07-01T17:18:26-0300] [ALPM] upgraded ca-certificates-mozilla (3.100-1 -> 3.101-1)
[2024-07-01T17:18:26-0300] [ALPM] upgraded systemd-libs (255.7-1 -> 256.1-1)
[2024-07-01T17:18:26-0300] [ALPM] upgraded findutils (4.9.0-3 -> 4.10.0-1)
[2024-07-01T17:18:26-0300] [ALPM] upgraded libnghttp3 (1.3.0-1 -> 1.4.0-1)
[2024-07-01T17:18:26-0300] [ALPM] upgraded xz (5.6.1-3 -> 5.6.2-1)
[2024-07-01T17:18:26-0300] [ALPM] upgraded python (3.12.3-1 -> 3.12.4-1)
[2024-07-01T17:18:26-0300] [ALPM] upgraded openssl (3.3.0-1 -> 3.3.1-1)
[2024-07-01T17:18:25-0300] [ALPM] upgraded glib2 (2.80.2-2 -> 2.80.3-2)
[2024-07-01T17:18:25-0300] [ALPM] upgraded pcre2 (10.43-4 -> 10.44-1)
[2024-06-25T16:14:08-0300] [ALPM] upgraded chromium (126.0.6478.114-1 -> 126.0.6478.126-1)
[2024-06-23T09:08:01-0300] [ALPM] upgraded epson-inkjet-printer-escpr2 (1.2.10-1 -> 1.2.11-1)
[2024-06-23T09:07:18-0300] [ALPM] upgraded gnome-shell-extension-forge (80-1 -> 83-1)
[2024-06-21T10:47:38-0300] [ALPM] removed libvncserver (0.9.14-2)
[2024-06-21T10:47:38-0300] [ALPM] removed gnome-remote-desktop (46.2-1)
[2024-06-21T10:27:36-0300] [ALPM] installed manjaro-pulse (20221015-2)
[2024-06-21T10:27:18-0300] [ALPM] installed pulseaudio-bluetooth (17.0-3)
[2024-06-21T10:26:38-0300] [ALPM] installed pulseaudio (17.0-3)
[2024-06-21T10:26:38-0300] [ALPM] removed pipewire-pulse (1:1.0.7-2)
[2024-06-21T10:24:57-0300] [ALPM] removed manjaro-pipewire (20231009-1)
[2024-06-21T10:21:16-0300] [ALPM] removed fmt (10.2.0-1)
[2024-06-21T10:21:16-0300] [ALPM] removed zita-convolver (4.0.3-3)
[2024-06-21T10:21:16-0300] [ALPM] removed easyeffects (7.1.6-1)
[2024-06-21T10:15:24-0300] [ALPM] removed pipewire-session-manager (1:1.0.7-2)
[2024-06-20T08:28:23-0300] [ALPM] upgraded chromium (126.0.6478.61-1 -> 126.0.6478.114-1)
[2024-06-19T08:52:24-0300] [ALPM] upgraded inxi (3.3.34.1-1 -> 3.3.35.1-1)
[2024-06-18T15:34:30-0300] [ALPM] upgraded gnome-shell-extension-gtk4-desktop-icons-ng (1:76-1 -> 1:77-1)
[2024-06-18T15:34:29-0300] [ALPM] upgraded bibata-cursor-theme (2.0.6-2 -> 2.0.7-1)
[2024-06-18T15:34:16-0300] [ALPM] upgraded archlinux-keyring (20240520-1 -> 20240609-1)
[2024-06-16T20:57:02-0300] [ALPM] upgraded gnome-shell-extension-arc-menu (56-1 -> 57-1)
[2024-06-14T16:22:45-0300] [ALPM] upgraded chromium (126.0.6478.55-1 -> 126.0.6478.61-1)
[2024-06-13T11:29:04-0300] [ALPM] installed gparted (1.6.0-1)
[2024-06-13T11:29:04-0300] [ALPM] installed gpart (0.3-5)
[2024-06-13T11:29:04-0300] [ALPM] upgraded chromium (125.0.6422.141-1 -> 126.0.6478.55-1)
[2024-06-12T13:25:01-0300] [ALPM] installed hunspell-pt-br (3.2.15-1)
[2024-06-12T13:23:02-0300] [ALPM] installed gimp-help-pt (2.10.34-1)
[2024-06-12T13:23:02-0300] [ALPM] installed gimp-help-pt_br (2.10.34-1)
[2024-06-12T13:23:01-0300] [ALPM] installed gimp-help-en (2.10.34-1)
[2024-06-12T10:12:17-0300] [ALPM] upgraded firefox-i18n-pt-br (126.0.1-1 -> 127.0-1)
[2024-06-12T10:12:17-0300] [ALPM] upgraded firefox-i18n-en-us (126.0.1-1 -> 127.0-1)
[2024-06-12T10:12:17-0300] [ALPM] upgraded firefox (126.0.1-1 -> 127.0-1)
[2024-06-11T08:37:17-0300] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m Printing support installede[1;0m
[2024-06-11T08:37:13-0300] [ALPM] upgraded mhwd-nvidia (550.90.07-2 -> 550.90.07-3)
[2024-06-11T08:37:13-0300] [ALPM] upgraded manjaro-gnome-settings (20240510-1 -> 20240610-1)
[2024-06-11T08:37:13-0300] [ALPM] upgraded gdm (46.2-1 -> 46.2-2)
[2024-06-11T08:37:13-0300] [ALPM] upgraded libgdm (46.2-1 -> 46.2-2)
[2024-06-11T08:37:13-0300] [ALPM] removed manjaro-gdm-branding (20221120-1)
[2024-06-10T18:20:22-0300] [ALPM] upgraded linux69-headers (6.9.3-2 -> 6.9.3-3)
[2024-06-10T18:20:19-0300] [ALPM] upgraded linux69 (6.9.3-2 -> 6.9.3-3)
[2024-06-10T10:58:14-0300] [ALPM] upgraded virglrenderer (1.0.1-1 -> 1.0.1-2)
[2024-06-10T10:58:14-0300] [ALPM] upgraded v4l2loopback-dkms (0.13.1-1 -> 0.13.2-1)
[2024-06-10T10:58:14-0300] [ALPM] upgraded systemd-sysvcompat (255.6-4 -> 255.7-1)
[2024-06-10T10:58:14-0300] [ALPM] upgraded qt5-tools (5.15.13+kde+r4-1 -> 5.15.14+kde+r4-1)
[2024-06-10T10:58:14-0300] [ALPM] upgraded python-pyopenssl (24.0.0-2 -> 24.1.0-1)
[2024-06-10T10:58:14-0300] [ALPM] upgraded python-jinja (1:3.1.3-2 -> 1:3.1.4-1)
[2024-06-10T10:58:14-0300] [ALPM] upgraded osinfo-db (20240510-1 -> 20240523-1)
[2024-06-10T10:58:14-0300] [ALPM] upgraded noto-fonts-extra (1:24.5.1-1 -> 1:24.6.1-1)
[2024-06-10T10:58:12-0300] [ALPM] upgraded mtools (1:4.0.43-1 -> 1:4.0.44-1)
[2024-06-10T10:58:12-0300] [ALPM] upgraded minizip-ng (4.0.5-1 -> 4.0.6-1)
[2024-06-10T10:58:12-0300] [ALPM] upgraded mhwd-nvidia (550.78-1 -> 550.90.07-2)
[2024-06-10T10:58:12-0300] [ALPM] upgraded python-requests (2.32.2-1 -> 2.32.3-1)
[2024-06-10T10:58:12-0300] [ALPM] upgraded mhwd-nvidia-470xx (470.239.06-3 -> 470.256.02-1)
[2024-06-10T10:58:12-0300] [ALPM] upgraded manjaro-release (24.0.1-1 -> 24.0.2-1)
[2024-06-10T10:58:12-0300] [ALPM] upgraded luajit (2.1.1713773202-1 -> 2.1.1716656478-1)
[2024-06-10T10:58:12-0300] [ALPM] upgraded linux69-headers (6.9.2-1 -> 6.9.3-2)
[2024-06-10T10:58:07-0300] [ALPM] upgraded linux69 (6.9.2-1 -> 6.9.3-2)
[2024-06-10T10:58:06-0300] [ALPM] upgraded mkinitcpio (39.1-2 -> 39.2-2)
[2024-06-10T10:58:06-0300] [ALPM] upgraded libnbd (1.20.0-2 -> 1.20.0-3)
[2024-06-10T10:58:06-0300] [ALPM] upgraded libbpf (1.3.0-1 -> 1.4.2-1)
[2024-06-10T10:58:06-0300] [ALPM] upgraded kvantum-qt5 (1.1.1-1 -> 1.1.2-1)
[2024-06-10T10:58:06-0300] [ALPM] upgraded qt5-x11extras (5.15.13-1 -> 5.15.14-1)
[2024-06-10T10:58:06-0300] [ALPM] upgraded qt5-svg (5.15.13+kde+r6-1 -> 5.15.14+kde+r5-1)
[2024-06-10T10:58:06-0300] [ALPM] upgraded qt5-base (5.15.13+kde+r147-1 -> 5.15.14+kde+r140-1)
[2024-06-10T10:58:05-0300] [ALPM] upgraded qt5-translations (5.15.13-1 -> 5.15.14-1)
[2024-06-10T10:58:05-0300] [ALPM] upgraded kvantum (1.1.1-1 -> 1.1.2-1)
[2024-06-10T10:58:05-0300] [ALPM] upgraded gtksourceview5 (5.12.0-1 -> 5.12.1-1)
[2024-06-10T10:58:04-0300] [ALPM] upgraded grub-btrfs (4.13-1 -> 4.13-2)
[2024-06-10T10:58:04-0300] [ALPM] upgraded gdm (46.0-1 -> 46.2-1)
[2024-06-10T10:58:04-0300] [ALPM] upgraded wireplumber (0.5.2-2 -> 0.5.3-1)
[2024-06-10T10:58:04-0300] [ALPM] upgraded libwireplumber (0.5.2-2 -> 0.5.3-1)
[2024-06-10T10:58:04-0300] [ALPM] upgraded libgdm (46.0-1 -> 46.2-1)
[2024-06-10T10:58:04-0300] [ALPM] upgraded ckbcomp (1.215-1 -> 1.227-1)
[2024-06-10T10:58:04-0300] [ALPM] upgraded calibre (7.11.0-1 -> 7.12.0-1)
[2024-06-10T10:58:03-0300] [ALPM] upgraded highway (1.1.0-1 -> 1.2.0-1)
[2024-06-10T10:58:03-0300] [ALPM] upgraded noto-fonts (1:24.5.1-1 -> 1:24.6.1-1)
[2024-06-10T10:58:03-0300] [ALPM] upgraded qt6-base (6.7.1-2 -> 6.7.1-4)
[2024-06-10T10:58:02-0300] [ALPM] upgraded libevdev (1.13.1-1 -> 1.13.2-1)
[2024-06-10T10:58:00-0300] [ALPM] upgraded systemd (255.6-4 -> 255.7-1)
[2024-06-10T10:58:00-0300] [ALPM] upgraded mesa (1:24.0.8-1 -> 1:24.0.9-1)
[2024-06-10T10:58:00-0300] [ALPM] upgraded libedit (20230828_3.1-1 -> 20240517_3.1-1)
[2024-06-10T10:58:00-0300] [ALPM] upgraded wayland (1.22.0-1 -> 1.23.0-1)
[2024-06-10T10:58:00-0300] [ALPM] upgraded systemd-libs (255.6-4 -> 255.7-1)
[2024-06-09T20:36:29-0300] [ALPM] installed calibre (7.11.0-1)
[2024-06-09T20:36:28-0300] [ALPM] installed uchardet (0.0.8-2)
[2024-06-09T20:36:28-0300] [ALPM] installed python-zeroconf (0.63.0-2)
[2024-06-09T20:36:28-0300] [ALPM] installed python-ifaddr (0.2.0-5)
[2024-06-09T20:36:28-0300] [ALPM] installed python-xxhash (3.4.1-3)
[2024-06-09T20:36:28-0300] [ALPM] installed python-unrardll (0.1.7-2)
[2024-06-09T20:36:28-0300] [ALPM] installed libunrar (1:7.0.9-1)
[2024-06-09T20:36:28-0300] [ALPM] installed python-regex (2024.5.15-1)
[2024-06-09T20:36:28-0300] [ALPM] installed python-pygments (2.17.2-3)
[2024-06-09T20:36:28-0300] [ALPM] installed python-pycryptodome (3.20.0-2)
[2024-06-09T20:36:28-0300] [ALPM] installed python-py7zr (0.21.0-2)
[2024-06-09T20:36:28-0300] [ALPM] installed python-texttable (1.7.0-2)
[2024-06-09T20:36:28-0300] [ALPM] installed python-pyzstd (0.16.0-2)
[2024-06-09T20:36:28-0300] [ALPM] installed python-pyppmd (1.1.0-2)
[2024-06-09T20:36:28-0300] [ALPM] installed python-pycryptodomex (3.20.0-1)
[2024-06-09T20:36:28-0300] [ALPM] installed python-multivolumefile (0.2.3-7)
[2024-06-09T20:36:28-0300] [ALPM] installed python-brotlicffi (1.1.0.0-2)
[2024-06-09T20:36:28-0300] [ALPM] installed python-brotli (1.1.0-2)
[2024-06-09T20:36:28-0300] [ALPM] installed python-pdftotext (2.2.2-6)
[2024-06-09T20:36:28-0300] [ALPM] installed python-mechanize (1:0.4.10-1)
[2024-06-09T20:36:28-0300] [ALPM] installed python-markdown (3.6-3)
[2024-06-09T20:36:28-0300] [ALPM] installed python-lxml-html-clean (0.1.1-2)
[2024-06-09T20:36:28-0300] [ALPM] installed python-jeepney (0.8.0-3)
[2024-06-09T20:36:28-0300] [ALPM] installed python-feedparser (6.0.11-2)
[2024-06-09T20:36:28-0300] [ALPM] installed python-sgmllib3k (1.0.0-6)
[2024-06-09T20:36:28-0300] [ALPM] installed python-dnspython (1:2.6.1-1)
[2024-06-09T20:36:28-0300] [ALPM] installed python-dateutil (2.9.0-5)
[2024-06-09T20:36:28-0300] [ALPM] installed python-css-parser (1.0.10-2)
[2024-06-09T20:36:27-0300] [ALPM] installed python-apsw (3.45.2.0-2)
[2024-06-09T20:36:27-0300] [ALPM] installed optipng (0.7.8-1)
[2024-06-09T20:36:27-0300] [ALPM] installed mathjax (3.2.2-1)
[2024-06-09T20:36:27-0300] [ALPM] installed python-inflate64 (1.0.0-2)
[2024-06-09T20:36:27-0300] [ALPM] installed python-async-timeout (4.0.3-4)
[2024-06-09T20:36:27-0300] [ALPM] installed python-netifaces (0.11.0-5)
[2024-06-09T20:36:27-0300] [ALPM] installed python-pychm (0.8.6-8)
[2024-06-09T20:36:27-0300] [ALPM] installed chmlib (0.40-7)
[2024-06-09T20:36:27-0300] [ALPM] installed python-html5-parser (0.4.12-2)
[2024-06-09T20:36:27-0300] [ALPM] installed python-pybcj (1.0.2-2)
[2024-06-09T20:36:27-0300] [ALPM] installed python-psutil (5.9.8-4)
[2024-06-09T20:36:27-0300] [ALPM] installed podofo (0.10.3-1)
[2024-06-09T20:36:27-0300] [ALPM] installed python-html2text (2020.1.16-10)
[2024-06-09T20:36:27-0300] [ALPM] installed jxrlib (0.2.4-2)
[2024-06-09T20:36:27-0300] [ALPM] installed python-html5lib (1.1-14)
[2024-06-09T20:36:27-0300] [ALPM] installed python-webencodings (0.5.1-11)
[2024-06-09T20:36:27-0300] [ALPM] installed python-pyqt6-webengine (6.7.0-2)
[2024-06-09T20:36:27-0300] [ALPM] installed qt6-webengine (6.7.1-1)
[2024-06-09T20:36:26-0300] [ALPM] installed qt6-webchannel (6.7.1-1)
[2024-06-09T20:36:26-0300] [ALPM] installed qt6-positioning (6.7.1-1)
[2024-06-09T20:36:26-0300] [ALPM] installed python-pyqt6 (6.7.0-3)
[2024-06-09T20:36:26-0300] [ALPM] installed python-pyqt6-sip (13.6.0-2)
[2024-06-09T20:36:26-0300] [ALPM] installed python-faust-cchardet (2.1.19-2)
[2024-06-09T20:24:20-0300] [ALPM] removed zeroc-ice (3.7.10-1)
[2024-06-09T20:24:20-0300] [ALPM] removed mumble-server (1.5.634-1)
[2024-06-09T20:24:20-0300] [ALPM] removed poco (1.13.3-1)
[2024-06-09T20:24:20-0300] [ALPM] removed libspeechd (0.11.5-2)
[2024-06-09T20:24:20-0300] [ALPM] removed mumble (1.5.634-1)
[2024-06-09T19:04:03-0300] [ALPM] installed mumble (1.5.634-1)
[2024-06-09T19:04:03-0300] [ALPM] installed poco (1.13.3-1)
[2024-06-09T19:04:03-0300] [ALPM] installed libspeechd (0.11.5-2)
[2024-06-09T19:02:22-0300] [ALPM] installed mumble-server (1.5.634-1)
[2024-06-09T19:02:22-0300] [ALPM] installed zeroc-ice (3.7.10-1)
[2024-06-09T19:02:21-0300] [ALPM] installed mcpp (2.7.2-8)
[2024-06-09T19:01:43-0300] [ALPM] removed poco (1.13.3-1)
[2024-06-09T19:01:43-0300] [ALPM] removed libspeechd (0.11.5-2)
[2024-06-09T19:01:43-0300] [ALPM] removed mumble (1.5.634-1)
[2024-06-09T19:00:50-0300] [ALPM] installed mumble (1.5.634-1)
[2024-06-09T19:00:50-0300] [ALPM] installed libspeechd (0.11.5-2)
[2024-06-09T19:00:50-0300] [ALPM] installed poco (1.13.3-1)
[2024-06-09T19:00:49-0300] [ALPM] installed unixodbc (2.3.12-1)
[2024-06-09T19:00:49-0300] [ALPM] installed mariadb-libs (11.3.2-2)
[2024-06-09T18:14:40-0300] [ALPM] installed shotcut (24.04-1)
[2024-06-09T18:14:40-0300] [ALPM] installed frei0r-plugins (2.3.2-2)
[2024-06-09T18:14:40-0300] [ALPM] installed movit (1.7.1-1)
[2024-06-09T18:14:40-0300] [ALPM] installed mlt (7.24.0-1)
[2024-06-09T18:14:40-0300] [ALPM] installed qt6-imageformats (6.7.1-1)
[2024-06-09T18:14:40-0300] [ALPM] installed qt6-charts (6.7.1-1)
[2024-06-09T18:14:40-0300] [ALPM] installed qt6-multimedia (6.7.1-2)
[2024-06-09T18:14:40-0300] [ALPM] installed qt6-multimedia-ffmpeg (6.7.1-2)
[2024-06-09T16:41:41-0300] [ALPM] installed imagescan-plugin-networkscan (1.1.4-0)
[2024-06-09T16:41:26-0300] [ALPM] installed imagescan (3.65.0-10)
[2024-06-09T16:41:26-0300] [ALPM] installed gtkmm (1:2.24.5-4)
[2024-06-09T15:30:25-0300] [ALPM] installed easyeffects (7.1.6-1)
[2024-06-09T15:30:25-0300] [ALPM] installed zita-convolver (4.0.3-3)
[2024-06-09T15:30:25-0300] [ALPM] installed ladspa (1.17-4)
[2024-06-09T15:30:25-0300] [ALPM] installed libebur128 (1.2.6-1)
[2024-06-09T15:30:25-0300] [ALPM] installed fmt (10.2.0-1)
[2024-06-09T15:12:50-0300] [ALPM] installed virtualbox (7.0.18-1)
[2024-06-09T15:12:49-0300] [ALPM] installed libtpms (0.9.6-1)
[2024-06-09T15:12:49-0300] [ALPM] installed sdl12-compat (1.2.68-1)
[2024-06-09T15:12:49-0300] [ALPM] installed virtualbox-host-dkms (7.0.18-1)
[2024-06-09T15:12:49-0300] [ALPM] installed virtualbox-guest-iso (7.0.18-1)
[2024-06-09T15:12:49-0300] [ALPM] installed liblzf (3.6-4)
[2024-06-09T15:12:49-0300] [ALPM] installed qt5-tools (5.15.13+kde+r4-1)
[2024-06-09T15:00:04-0300] [ALPM] installed epson-printer-utility (1.1.3-1)
[2024-06-09T14:59:52-0300] [ALPM] installed ld-lsb (3-8)
[2024-06-09T14:58:01-0300] [ALPM] installed epson-inkjet-printer-escpr2 (1.2.10-1)
[2024-06-09T14:50:56-0300] [ALPM] reinstalled v4l2loopback-dkms (0.13.1-1)
[2024-06-09T14:42:51-0300] [ALPM] installed iriunwebcam-bin (2.8.2-3)
[2024-06-09T14:42:33-0300] [ALPM] installed base-devel (1-2)
[2024-06-09T14:42:33-0300] [ALPM] installed fakeroot (1.34-1)
[2024-06-09T14:42:33-0300] [ALPM] installed bison (3.8.2-6)
[2024-06-09T14:42:33-0300] [ALPM] installed automake (1.16.5-2)
[2024-06-09T14:42:33-0300] [ALPM] installed debugedit (5.0-6)
[2024-06-09T14:42:33-0300] [ALPM] installed autoconf (2.72-1)
[2024-06-09T14:42:33-0300] [ALPM] installed pkgconf (2.1.1-1)
[2024-06-09T14:42:33-0300] [ALPM] installed flex (2.6.4-5)
[2024-06-09T14:42:33-0300] [ALPM] installed m4 (1.4.19-3)
[2024-06-09T14:19:58-0300] [ALPM] installed linux69-headers (6.9.2-1)
[2024-06-09T14:19:56-0300] [ALPM] installed pahole (1:1.26-2)
[2024-06-09T14:09:15-0300] [ALPM] installed evolution-ews (3.52.2-1)
[2024-06-09T14:09:15-0300] [ALPM] installed libmspack (1:1.11-1)
[2024-06-09T14:05:52-0300] [ALPM] installed evolution (3.52.2-1)
[2024-06-09T14:05:51-0300] [ALPM] installed libytnef (1:2.1.2-1)
[2024-06-09T14:05:51-0300] [ALPM] installed libpst (0.6.76-9)
[2024-06-09T14:05:51-0300] [ALPM] installed cmark (0.31.0-2)
[2024-06-09T14:05:51-0300] [ALPM] removed botan2 (2.19.3-2)
[2024-06-09T14:05:51-0300] [ALPM] removed thunderbird (115.11.0-4)
[2024-06-09T14:05:51-0300] [ALPM] removed thunderbird-i18n-en-us (115.11.0-4)
[2024-06-09T14:05:51-0300] [ALPM] removed thunderbird-i18n-pt-br (115.11.0-4)
[2024-06-09T13:58:19-0300] [ALPM] installed syncthing (1.27.7-1)
[2024-06-09T13:31:16-0300] [ALPM] installed v4l2loopback-dkms (0.13.1-1)
[2024-06-09T13:31:16-0300] [ALPM] installed dkms (3.0.12-1)
[2024-06-09T13:31:16-0300] [ALPM] installed inkscape (1.3.2-5)
[2024-06-09T13:31:16-0300] [ALPM] installed scour (0.38.2-4)
[2024-06-09T13:31:16-0300] [ALPM] installed python-zstandard (0.22.0-2)
[2024-06-09T13:31:16-0300] [ALPM] installed python-pyserial (3.5-6)
[2024-06-09T13:31:16-0300] [ALPM] installed python-appdirs (1.4.4-10)
[2024-06-09T13:31:16-0300] [ALPM] installed libwpg (0.3.4-1)
[2024-06-09T13:31:16-0300] [ALPM] installed lib2geom (1.3-1)
[2024-06-09T13:31:16-0300] [ALPM] installed gtkmm3 (3.24.9-1)
[2024-06-09T13:31:16-0300] [ALPM] installed pangomm (2.46.4-1)
[2024-06-09T13:31:16-0300] [ALPM] installed gsl (2.7.1-3)
[2024-06-09T13:31:15-0300] [ALPM] installed cairomm (1.14.5-1)
[2024-06-09T13:31:15-0300] [ALPM] installed python-cssselect (1.2.0-6)
[2024-06-09T13:31:15-0300] [ALPM] installed make (4.4.1-2)
[2024-06-09T13:31:15-0300] [ALPM] installed guile (3.0.9-1)
[2024-06-09T13:31:15-0300] [ALPM] installed atkmm (2.28.4-1)
[2024-06-09T13:31:15-0300] [ALPM] installed glibmm (2.66.7-1)
[2024-06-09T13:31:15-0300] [ALPM] installed libsigc++ (2.12.1-1)
[2024-06-09T13:31:15-0300] [ALPM] installed blender (17:4.1.1-8)
[2024-06-09T13:31:13-0300] [ALPM] installed usd (24.03-7)
[2024-06-09T13:31:12-0300] [ALPM] installed python-jinja (1:3.1.3-2)
[2024-06-09T13:31:12-0300] [ALPM] installed ninja (1.12.1-1)
[2024-06-09T13:31:12-0300] [ALPM] installed python-numpy (1.26.4-2)
[2024-06-09T13:31:12-0300] [ALPM] installed potrace (1.16-3)
[2024-06-09T13:31:12-0300] [ALPM] installed openvdb (11.0.0-2)
[2024-06-09T13:31:12-0300] [ALPM] installed log4cplus (2.1.0-1)
[2024-06-09T13:31:12-0300] [ALPM] installed blosc (1.21.5-1)
[2024-06-09T13:31:12-0300] [ALPM] installed opensubdiv (3.6.0-1)
[2024-06-09T13:31:11-0300] [ALPM] installed openshadinglanguage (1.13.9.0-1)
[2024-06-09T13:31:11-0300] [ALPM] installed materialx (1.38.10-4)
[2024-06-09T13:31:11-0300] [ALPM] installed zenity (4.0.1-1)
[2024-06-09T13:31:11-0300] [ALPM] installed dos2unix (7.5.2-2)
[2024-06-09T13:31:11-0300] [ALPM] installed python-setuptools (1:69.0.3-6)
[2024-06-09T13:31:10-0300] [ALPM] installed python-validate-pyproject (0.16-1)
[2024-06-09T13:31:10-0300] [ALPM] installed python-trove-classifiers (2024.5.22-1)
[2024-06-09T13:31:10-0300] [ALPM] installed python-fastjsonschema (2.19.1-3)
[2024-06-09T13:31:10-0300] [ALPM] installed python-tomli (2.0.1-4)
[2024-06-09T13:31:10-0300] [ALPM] installed python-platformdirs (4.2.0-3)
[2024-06-09T13:31:10-0300] [ALPM] installed python-jaraco.text (3.12.0-3)
[2024-06-09T13:31:10-0300] [ALPM] installed glfw (3.4-2)
[2024-06-09T13:31:10-0300] [ALPM] installed embree (4.3.1-1)
[2024-06-09T13:31:10-0300] [ALPM] installed draco (1.5.6-2)
[2024-06-09T13:31:10-0300] [ALPM] installed alembic (1.8.6-2)
[2024-06-09T13:31:10-0300] [ALPM] installed libspnav (1.1-1)
[2024-06-09T13:31:10-0300] [ALPM] installed opencollada (1:1.6.68-3)
[2024-06-09T13:31:10-0300] [ALPM] installed xorg-xrandr (1.5.2-1)
[2024-06-09T13:31:10-0300] [ALPM] installed python-inflect (7.2.1-2)
[2024-06-09T13:31:10-0300] [ALPM] installed python-lxml (5.2.2-1)
[2024-06-09T13:31:10-0300] [ALPM] installed python-markupsafe (2.1.5-2)
[2024-06-09T13:31:10-0300] [ALPM] installed openpgl (0.6.0-1)
[2024-06-09T13:31:10-0300] [ALPM] installed jemalloc (1:5.3.0-4)
[2024-06-09T13:31:10-0300] [ALPM] installed libharu (2.4.4-1)
[2024-06-09T13:31:10-0300] [ALPM] installed python-chardet (5.2.0-2)
[2024-06-09T13:31:10-0300] [ALPM] installed python-cachecontrol (1:0.14.0-3)
[2024-06-09T13:31:10-0300] [ALPM] installed python-msgpack (1.0.5-2)
[2024-06-09T13:31:10-0300] [ALPM] installed ptex (2.4.2-2)
[2024-06-09T13:31:10-0300] [ALPM] installed patch (2.7.6-10)
[2024-06-09T13:31:10-0300] [ALPM] installed python-jaraco.context (4.3.0-4)
[2024-06-09T13:31:10-0300] [ALPM] installed openxr (1.1.36-1)
[2024-06-09T13:31:10-0300] [ALPM] installed jsoncpp (1.9.5-2)
[2024-06-09T13:31:10-0300] [ALPM] installed openimagedenoise (2.2.2-1)
[2024-06-09T13:31:09-0300] [ALPM] installed python-autocommand (2.2.2-6)
[2024-06-09T13:31:03-0300] [ALPM] installed python-opengl (3.1.7-1)
[2024-06-09T13:30:41-0300] [ALPM] installed python-lockfile (0.12.2-13)
[2024-06-09T13:30:41-0300] [ALPM] installed gimp-plugin-gmic (3.3.6-1)
[2024-06-09T13:30:41-0300] [ALPM] installed gmic (3.3.6-1)
[2024-06-09T13:30:41-0300] [ALPM] installed opencv (4.9.0-8)
[2024-06-09T13:30:40-0300] [ALPM] installed onetbb (2021.12.0-2)
[2024-06-09T13:30:40-0300] [ALPM] installed verdict (1.4.2-1)
[2024-06-09T13:30:40-0300] [ALPM] installed cblas (3.12.0-5)
[2024-06-09T13:30:40-0300] [ALPM] installed graphicsmagick (1.3.43-1)
[2024-06-09T13:30:40-0300] [ALPM] installed gimp (2.10.38-1)
[2024-06-09T13:30:39-0300] [ALPM] installed libwmf (0.2.13-1)
[2024-06-09T13:30:39-0300] [ALPM] installed libmng (2.0.3-3)
[2024-06-09T13:30:39-0300] [ALPM] installed mypaint-brushes1 (1.3.1-1)
[2024-06-09T13:30:39-0300] [ALPM] installed libmypaint (1.6.1-1)
[2024-06-09T13:30:39-0300] [ALPM] installed gtk2 (2.24.33-3)
[2024-06-09T13:30:39-0300] [ALPM] installed gegl (0.4.48-3)
[2024-06-09T13:30:39-0300] [ALPM] installed luajit (2.1.1713773202-1)
[2024-06-09T13:30:39-0300] [ALPM] installed lensfun (1:0.3.4-4)
[2024-06-09T13:30:39-0300] [ALPM] installed babl (0.1.108-1)
[2024-06-09T13:30:39-0300] [ALPM] installed pyside6 (6.7.1-1)
[2024-06-09T13:30:39-0300] [ALPM] installed shiboken6 (6.7.1-1)
[2024-06-09T13:30:39-0300] [ALPM] installed llvm (17.0.6-5)
[2024-06-09T13:30:38-0300] [ALPM] installed clang (17.0.6-2)
[2024-06-09T13:30:37-0300] [ALPM] installed compiler-rt (17.0.6-2)
[2024-06-09T13:30:37-0300] [ALPM] installed gcc (14.1.1+r58+gfc9fb69ad62-1)
[2024-06-09T13:30:36-0300] [ALPM] installed libisl (0.26-2)
[2024-06-09T13:30:36-0300] [ALPM] installed python-ordered-set (4.1.0-5)
[2024-06-09T13:30:36-0300] [ALPM] installed python-jaraco.functools (4.0.1-1)
[2024-06-09T13:30:36-0300] [ALPM] installed python-more-itertools (10.2.0-2)
[2024-06-09T13:30:36-0300] [ALPM] installed libspiro (1:20221101-2)
[2024-06-09T13:30:36-0300] [ALPM] installed obs-studio (30.1.2-1)
[2024-06-09T13:30:36-0300] [ALPM] installed libdatachannel (0.21.1-1)
[2024-06-09T13:30:36-0300] [ALPM] installed libjuice (1.4.2-1)
[2024-06-09T13:30:36-0300] [ALPM] installed rnnoise (1:0.2-1)
[2024-06-09T13:30:36-0300] [ALPM] installed ragel (6.10-3)
[2024-06-09T13:30:36-0300] [ALPM] installed python-typeguard (4.2.1-2)
[2024-06-09T13:30:36-0300] [ALPM] installed python-typing_extensions (4.12.0-1)
[2024-06-09T13:30:36-0300] [ALPM] installed intel-oneapi-compiler-dpcpp-cpp-runtime-libs (2024.1.0-1)
[2024-06-09T13:30:36-0300] [ALPM] installed intel-oneapi-tbb (2021.12.0-1)
[2024-06-09T13:30:36-0300] [ALPM] installed intel-oneapi-compiler-shared-runtime-libs (2024.1.0-1)
[2024-06-09T13:30:36-0300] [ALPM] installed intel-oneapi-openmp (2024.1.0-1)
[2024-06-09T13:30:35-0300] [ALPM] installed level-zero-loader (1.16.15-1)
[2024-06-09T13:30:35-0300] [ALPM] installed intel-oneapi-tcm (1.0.1-1)
[2024-06-09T13:30:35-0300] [ALPM] installed hwloc (2.10.0-1)
[2024-06-09T13:30:35-0300] [ALPM] installed intel-oneapi-common (2024.1.0-1)
[2024-06-09T13:30:35-0300] [ALPM] installed mbedtls (3.5.2-1)
[2024-06-09T13:30:35-0300] [ALPM] installed openimageio (2.5.10.1-1)
[2024-06-09T13:30:35-0300] [ALPM] installed hdf5 (1.14.4.2-6)
[2024-06-09T13:30:35-0300] [ALPM] installed libaec (1.1.3-1)
[2024-06-09T13:30:35-0300] [ALPM] installed pybind11 (2.12.0-4)
[2024-06-09T13:30:35-0300] [ALPM] installed libraw (0.21.2-1)
[2024-06-09T13:30:35-0300] [ALPM] installed jasper (4.2.4-1)
[2024-06-09T13:30:35-0300] [ALPM] installed opencolorio (2.3.2-2)
[2024-06-09T13:30:35-0300] [ALPM] installed minizip-ng (4.0.5-1)
[2024-06-09T13:30:35-0300] [ALPM] installed pystring (1.1.4-1)
[2024-06-09T13:30:35-0300] [ALPM] installed yaml-cpp (0.8.0-1)
[2024-06-09T13:30:35-0300] [ALPM] installed tinyxml (2.6.2-10)
[2024-06-09T13:30:35-0300] [ALPM] installed glew (2.2.0-6)
[2024-06-09T13:30:35-0300] [ALPM] installed suitesparse (7.7.0-1)
[2024-06-09T13:30:35-0300] [ALPM] installed lapack (3.12.0-5)
[2024-06-09T13:30:35-0300] [ALPM] installed blas (3.12.0-5)
[2024-06-09T13:30:35-0300] [ALPM] installed python-coverage (7.5.1-1)
[2024-06-09T13:30:35-0300] [ALPM] installed chromium (125.0.6422.141-1)
[2024-06-09T13:30:33-0300] [ALPM] installed minizip (1:1.3.1-2)
[2024-06-09T13:30:33-0300] [ALPM] installed ttf-liberation (2.1.5-1)
[2024-06-09T13:25:07-0300] [ALPM] installed man-pages-pt_br (4.22.0-1)
[2024-06-09T13:25:07-0300] [ALPM] installed libreoffice-still-pt (7.6.7-1)
[2024-06-09T13:25:07-0300] [ALPM] installed libreoffice-still-pt-br (7.6.7-1)
[2024-06-09T13:25:07-0300] [ALPM] installed thunderbird-i18n-pt-br (115.11.0-4)
[2024-06-09T13:25:07-0300] [ALPM] installed firefox-i18n-pt-br (126.0.1-1)
[2024-06-09T13:25:07-0300] [ALPM] installed hyphen-en (2.8.8-5)
[2024-06-09T13:25:07-0300] [ALPM] installed hunspell-en_us (2020.12.07-5)
[2024-06-09T13:25:07-0300] [ALPM] installed thunderbird-i18n-en-us (115.11.0-4)
[2024-06-09T13:25:07-0300] [ALPM] installed firefox-i18n-en-us (126.0.1-1)
[2024-06-09T13:20:54-0300] [ALPM] upgraded firefox (126.0-1 -> 126.0.1-1)
[2024-06-09T13:14:55-0300] [ALPM] installed libreoffice-still (7.6.7-1)
[2024-06-09T13:14:53-0300] [ALPM] installed box2d (2.4.1-2)
[2024-06-09T13:14:53-0300] [ALPM] installed libqxp (0.0.2-12)
[2024-06-09T13:14:53-0300] [ALPM] installed libepubgen (0.1.1-4)
[2024-06-09T13:14:53-0300] [ALPM] installed libstaroffice (0.0.7-2)
[2024-06-09T13:14:53-0300] [ALPM] installed libfreehand (0.1.2-4)
[2024-06-09T13:14:53-0300] [ALPM] installed libnumbertext (1.0.11-1)
[2024-06-09T13:14:53-0300] [ALPM] installed libatomic_ops (7.8.2-1)
[2024-06-09T13:14:53-0300] [ALPM] installed libzmf (0.0.2-16)
[2024-06-09T13:14:53-0300] [ALPM] installed libtommath (1.3.0-1)
[2024-06-09T13:14:53-0300] [ALPM] installed libcmis (0.6.2-1)
[2024-06-09T13:14:53-0300] [ALPM] installed liborcus (0.19.2-2)
[2024-06-09T13:14:53-0300] [ALPM] installed libixion (0.19.0-2)
[2024-06-09T13:14:53-0300] [ALPM] installed boost-libs (1.83.0-8)
[2024-06-09T13:14:53-0300] [ALPM] installed libexttextcat (3.4.7-1)
[2024-06-09T13:14:53-0300] [ALPM] installed libe-book (0.1.3-16)
[2024-06-09T13:14:52-0300] [ALPM] installed libmwaw (0.3.22-1)
[2024-06-09T13:14:52-0300] [ALPM] installed libabw (0.1.3-3)
[2024-06-09T13:14:52-0300] [ALPM] installed libpagemaker (0.0.4-3)
[2024-06-09T13:14:52-0300] [ALPM] installed clucene (2.3.3.4-14)
[2024-06-09T13:14:52-0300] [ALPM] installed libmspub (0.1.4-16)
[2024-06-09T13:14:52-0300] [ALPM] installed libcdr (0.1.7-8)
[2024-06-09T13:14:52-0300] [ALPM] installed libodfgen (0.1.8-2)
[2024-06-09T13:14:52-0300] [ALPM] installed libetonyek (0.1.10-3)
[2024-06-09T13:14:52-0300] [ALPM] installed liblangtag (0.6.7-1)
[2024-06-09T13:14:52-0300] [ALPM] installed libvisio (0.1.7-11)
[2024-06-09T13:14:52-0300] [ALPM] installed lpsolve (5.5.2.11-2)
[2024-06-09T13:14:52-0300] [ALPM] installed redland (1:1.0.17-9)
[2024-06-09T13:14:52-0300] [ALPM] installed rasqal (1:0.9.33-7)
[2024-06-09T13:14:52-0300] [ALPM] installed libwps (0.4.14-1)
[2024-06-09T13:14:52-0300] [ALPM] installed libwpd (0.10.3-4)
[2024-06-09T13:14:52-0300] [ALPM] installed librevenge (0.0.5-2)
[2024-06-09T13:14:05-0300] [ALPM] removed intel-ucode (20240514-1)
I think so. Sounds that way, anyhow.
Check the following for key mappings:
It can be found as “System Settings” in the menu or accessed on the command line using “gnome-control-center”. The key bindings are in the “Keyboard” section under a “Shortcuts” tab
And the following for keyboard layouts in Gnome, specifically:
  1. Open the Activities overview and start typing Settings.
  2. Click on Settings.
  3. Click Region & Language in the sidebar to open the panel.
  4. Click the + button in the Input Sources section, select the language which is associated with the layout, then select a layout and press Add.
More here: Keyboard
Else, all I can think of is hardware. Have you tested with a different keyboard?
It won’t be hardware, the scancode is being sent to the computer. If it’s only in certain software then it’s presumably the software. It may be using a different layout, or has something hard-coded to the key in question. Probably just a weird bug.
Settings look fine.
I did a “reset” in keyboard shortcuts.
I’ve added a second keyboard layout (en-US) and that also not helped.
I don’t think it is hardware because it works in other software.
I’ll try to get a second keyboard to test, anyway.
Thanks for assist.
Maybe switching to a supported Kernel could help?
You can choose a supported Kernel like 6.6 LTS or 6.10 which are supported.
Additional question, is the del key working when you want to delete a file?
That’s why it was my first suggestion.
Did you maintained .pacnew files?
For example locale.conf.pacnew could be just one of them around your system. There are some new config files coming up and the older config files needs some adjustments and required to be merged from time to time.
Hi.
I’m on kernel 6.6 now, and the issue remains.
Del key is working to move files to trash and within other software (LibreOffice Writer for instance).
I’ll investigate further.
Update:
I’ve tried to reset Gnome:
dconf reset -f /org/gnome/
It didn’t work.
I confirm this issue on 3 devices (desktop with wireless keyboard, Lenovo laptop and Dell laptop with their keyboards). Apparently, this issue is not related to a specific keyboard.
One interesting thing is that the Dell laptop still has Gedit as default text editor and the delete key works nicely in it. Conversely, in Files it didn’t work.
Att.
Hi there.
This issue is solved with the last update.
inxi -Fz
  Kernel: 6.6.63-1-MANJARO arch: x86_64 bits: 64
  Desktop: GNOME v: 47.2 Distro: Manjaro Linux
  Type: Desktop Mobo: Gigabyte model: 990FXA-UD5 serial: N/A
    UEFI: American Megatrends v: FC date: 06/24/2015
  Info: 8-core model: AMD FX-8350 bits: 64 type: MT MCP cache: L2: 8 MiB
  Speed (MHz): avg: 1400 min/max: 1400/4000 cores: 1: 1400 2: 1400 3: 1400
    4: 1400 5: 1400 6: 1400 7: 1400 8: 1400
  Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] driver: nvidia v: 550.90.07
  Display: unspecified server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    driver: X: loaded: nvidia gpu: nvidia resolution: 1: 1920x1080~60Hz
    2: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: kms_swrast,nvidia,swrast
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.90.07
    renderer: NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2
  Device-1: Advanced Micro Devices [AMD/ATI] SBx00 Azalia
    driver: snd_hda_intel
  Device-2: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
  API: ALSA v: k6.6.63-1-MANJARO status: kernel-api
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi
  IF: wlp4s0 state: up mac: <filter>
    driver: r8169
  IF: enp7s0 state: down mac: <filter>
  Device-1: Intel AX200 Bluetooth driver: btusb type: USB
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 689.33 GiB used: 344.7 GiB (50.0%)
  ID-1: /dev/nvme0n1 vendor: Western Digital model: WD Green SN350 500GB
    2G0C size: 465.76 GiB
  ID-2: /dev/sda vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB
  ID-1: / size: 223.27 GiB used: 69.39 GiB (31.1%) fs: btrfs dev: /dev/sda2
  ID-2: /boot/efi size: 299.4 MiB used: 584 KiB (0.2%) fs: vfat
    dev: /dev/sda1
  ID-3: /home size: 223.27 GiB used: 69.39 GiB (31.1%) fs: btrfs
    dev: /dev/sda2
  ID-4: /var/log size: 223.27 GiB used: 69.39 GiB (31.1%) fs: btrfs
    dev: /dev/sda2
  System Temperatures: cpu: 33.2 C mobo: N/A gpu: nvidia temp: 48 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
  Memory: total: 32 GiB available: 31.3 GiB used: 4.47 GiB (14.3%)
  Processes: 355 Uptime: 12m Shell: Sudo inxi: 3.3.36
locatectl
System Locale: LANG=pt_BR.UTF-8
    VC Keymap: br-abnt2
   X11 Layout: br
