Deja Dup crashes when opening preferences in Plasma on Wayland
I tried using Deja Dup. I have tried using this software many years ago, so there must still be some configuration files in my home directory with a backup location saved, but I haven’t used it in many years. When I open Deja Dup now, it sometimes starts with a warning that the current backup directory is no longer available.
When I try to access the “Preferences” in Deja Dup, the program immediately crashes. Here is the terminal output on crashing:
(org.gnome.DejaDup:10763): GLib-GIO-ERROR **: 17:03:36.971: The schema default value for key 'backend' in schema 'org.gnome.DejaDup' was rejected by the binding mapping function.
Trace/breakpoint trap (core dumped)
Hi @Electric-Gecko,
That might be because it was installed from the AUR. If it’s not that, well then I won’t be of help. But you can check with:
pamac search --installed deja
