If i use pacdiff in console to handle *.pacnew files i get this horrible vi even if i defined installed meld:
[john1@manjaro ~]$ sudo echo $DIFFPROG
[sudo] Passwort für john1:
meld
No, i never touch this one:
Forgot this systeminfo:
meld
pacdiff is not to be used with sudo - there is the -s option for this. So what happens if you try
pacdiff -s
and
DIFFPROG=meld pacdiff -s
Continuing that thought, the right place would be ~/.profile
and then you source the profile in ~/.bash_profile
for example. In any case some profile file in your home.
the only i can remember is ~/.bashrc
export DIFFPROG=meld
That is ok too.
But that is no issue. if i do in terminal:
Passwort:
[manjaro john1]# echo $DIFFPROG
meld
And that is ok because meld is used.
A newbe will not even know how to even close vi … two times :q very intuitiv
What happens without su
? … I just added it to my ~/.bashrc
; am going to test it if I have any new pacnew files.
I would add
DIFFPROG=/usr/bin/meld
to /etc/environment
and delete
from ~/.bashrc.
Afterwards, reboot!
Then thats probably why.
~/.bashrc
is only affecting your users bash prompt.
(and assuming you use bash at all)
Thats where I would put it too. No reason for this not to be global.
PS
Maybe you want to add some others there too. Like SUDO_EDITOR=/usr/bin/micro
so you can use
sudoedit
or sudo -e
when you want to admin a file like a reasonable person.
PPS
I thought there was an environment variable intro somewhere. Had to dig deep.
deleted
pacdiff will not ask you for password, if i remember it orrect.
But test it your own:
sudo cp /etc/locale.gen /etc/locale.gen.pacnew
then uncomment one line it , remove the # at beginning of valid line
nano /etc/locale.gen.pacnew
save you changes with CTRL+o
Now you can play around with various options of pacdiff
pacdiff
doesn’t ask for a password, by default, no. Because it tuns as the user executing it and tries to perform the relevant operations as that user. However, it does have an option use sudo
/sudoedit
$ man pacdiff
-s, --sudo
Use sudo and sudoedit to merge/remove files.
…for what it’s worth.
Thanks, that works and i don’t get shocked with vim or vi
