Somehow pamac is able to install from AUR.
Is it possible, to do this from terminal without installing yaourt/yay etc?
it is the pamac build
command, while for repo package is pamac install
Ty. Can I check for AUR updates from terminal with pamac? Like “-Syu”
While this is true, I’ve found that pamac install
searches the AUR if there as nothing found in the repositories.
Edit:
From the help:
$ pamac checkupdates -h
Safely check for updates without modifiying the databases
(Exit code is 100 if updates are available)
pamac checkupdates [options]
options:
--builddir <dir> : build directory (use with --devel), if no directory is given the one specified in pamac.conf file is used
--aur, -a : also check updates in AUR
--no-aur : do not check updates in AUR
--quiet, -q : only print one line per update
--devel : also check development packages updates (use with --aur)
--no-devel : do not check development packages updates
pamac upgrade -a
updates all packages from repo and AUR.
man pamac
is a good place for information
run pamac -h
or pamac "command" -h
for detail (as pamac build -h
we have also man pamac
I don’t use pamac so can’t reply further
Unlikely, except you enable AUR in “Add/Remove Software” aka pamac in GUI.
$ pamac install viber
Error: target not found: viber
$ pamac build viber
Preparing...
Cloning viber build files...
Checking viber dependencies...
Resolving dependencies...
Checking inter-conflicts...
To build (1):
viber 13.3.1.22-1 AUR
Aah, yes. That would explain it, thanks!
