Hey everyone!
I’m coming from windows, used ubuntu just a little and my knowledge about linux is very limited.
But I discovered manjaro and really liked it. But after two installations, downgrading kernel and following some tutorials I haven’t solved the audio problem on my PC… So, can you guys give me a hand?
inxi -Fazy output:
Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=56558fa3-6467-4b7f-ab63-41d0f9a75d2b rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Positivo Tecnologia SA product: N1250 v: N/A
Mobo: Positivo Tecnologia SA model: N14DP7-V2 v: 11175018
serial: <superuser required> UEFI: N/A v: 1.14.X date: 08/24/2021
ID-1: BAT0 charge: 22.2 Wh (60.0%) condition: 37.0/37.0 Wh (100.0%)
volts: 7.6 min: N/A model: WB SR 1 WB Lion Battery type: Li-ion
serial: <filter> status: Discharging
Info: model: Intel Celeron N4020 bits: 64 type: MCP arch: Goldmont Plus
family: 6 model-id: 0x7A (122) stepping: 8 microcode: 0x1C
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2120 high: 2577 min/max: 800/2800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2577 2: 1663
bogomips: 4378
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3185
class-ID: 0300
Device-2: SunplusIT MTD camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-8:4 chip-ID: 735f:2223 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 model: Chi Mei Innolux built: 2016 res: 1366x768 hz: 60
dpi: 112 gamma: 1.2 size: 309x173mm (12.2x6.8") diag: 354mm (13.9")
ratio: 16:9 modes: 1366x768
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: sof-audio-pci-intel-apl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_apl bus-ID: 00:0e.0
chip-ID: 8086:3198 class-ID: 0401
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: no
Message: No device data found.
IF-ID-1: wlp0s21f0u7i2 state: up mac: <filter>
Device-1: Realtek RTL8723BU 802.11b/g/n WLAN Adapter type: USB
driver: btusb,rtl8xxxu bus-ID: 1-7:3 chip-ID: 0bda:b720 class-ID: e001
serial: <filter>
Local Storage: total: 126.57 GiB used: 8.55 GiB (6.8%)
ID-1: /dev/sda maj-min: 8:0 model: SATA CVB-CD128 size: 119.24 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 901 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston
model: DataTraveler 2.0 size: 7.32 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 118.95 GiB size: 116.52 GiB (97.96%) used: 8.55 GiB (7.3%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 173 Uptime: 11m wakeups: 1 Memory: 3.65 GiB
used: 1.66 GiB (45.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1074 lib: 316 flatpak: 0
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.13System:
bogomips: 4378
class-ID: 0300
screens: 1
serial: <filter>
