Hi guys,
I searched around for a solution, but I didn’t have much luck. I haven’t been able to install any AUR packages via yay on my Pinebook Pro.
Here’s the errors I get:
$ yay -S nvpy
:: There are 2 providers available for nvpy:
:: Repository AUR
1) nvpy 2) nvpy-git
Enter a number (default=1): 1
:: Checking for conflicts...
:: Checking for inner conflicts...
[Aur:2] python-simplenote-2.1.4-1 nvpy-2.1.0-2
2 python-simplenote (Build Files Exist)
1 nvpy (Build Files Exist)
==> Packages to cleanBuild?
==> [N]one [A]ll [Ab]ort [I]nstalled [No]tInstalled or (1 2 3, 1-3, ^4)
:: PKGBUILD up to date, Skipping (1/2): nvpy
:: PKGBUILD up to date, Skipping (2/2): python-simplenote
==> Diffs to show?
:: (1/2) Parsing SRCINFO: python-simplenote
:: (2/2) Parsing SRCINFO: nvpy
==> Making package: python-simplenote 2.1.4-1 (Tue 20 Jul 2021 06:05:29 PM CDT)
==> Retrieving sources...
-> Downloading python-simplenote.tar.gz...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 136 0 136 0 0 497 0 --:--:-- --:--:-- --:--:-- 500
100 16355 0 16355 0 0 24219 0 --:--:-- --:--:-- --:--:-- 24219
python-simplenote.tar.gz ... Passed
==> Making package: nvpy 2.1.0-2 (Tue 20 Jul 2021 06:05:33 PM CDT)
-> Downloading v2.1.0.tar.gz...
100 120 100 120 0 0 436 0 --:--:-- --:--:-- --:--:-- 437
100 1619k 0 1619k 0 0 1251k 0 --:--:-- 0:00:01 --:--:-- 3014k
v2.1.0.tar.gz ... Passed
==> Making package: python-simplenote 2.1.4-1 (Tue 20 Jul 2021 06:05:39 PM CDT)
-> Found python-simplenote.tar.gz
==> Extracting sources...
-> Extracting python-simplenote.tar.gz with bsdtar
==> Sources are ready.
==> ERROR: Cannot find the fakeroot binary.
error making: python-simplenote
$ yay -S nvpy
:: Repository AUR
1) nvpy 2) nvpy-git
Enter a number (default=1): 2
[Aur:2] python-simplenote-2.1.4-1 nvpy-git-r724.c1b8549-1
1 nvpy-git
:: PKGBUILD up to date, Skipping (1/2): python-simplenote
:: Downloaded PKGBUILD (2/2): nvpy-git
1 nvpy-git (Build Files Exist)
==> Diffs to show?
:: (2/2) Parsing SRCINFO: nvpy-git
==> Making package: python-simplenote 2.1.4-1 (Tue 20 Jul 2021 06:06:08 PM CDT)
==> Making package: nvpy-git r724.c1b8549-1 (Tue 20 Jul 2021 06:06:12 PM CDT)
-> Cloning nvpy git repo...
Cloning into bare repository '/home/chewie/.cache/yay/nvpy-git/nvpy'...
remote: Enumerating objects: 3213, done.
remote: Counting objects: 100% (266/266), done.
remote: Compressing objects: 100% (118/118), done.
remote: Total 3213 (delta 175), reused 227 (delta 148), pack-reused 2947
Receiving objects: 100% (3213/3213), 2.75 MiB | 7.22 MiB/s, done.
Resolving deltas: 100% (2041/2041), done.
-> Found nvpy.desktop
==> Validating source files with md5sums...
nvpy ... Skipped
nvpy.desktop ... Passed
==> Making package: python-simplenote 2.1.4-1 (Tue 20 Jul 2021 06:06:17 PM CDT)
inxi info:
System: Kernel: 5.13.0-1-MANJARO-ARM aarch64 bits: 64 compiler: gcc v: 10.2.0
parameters: initrd=/initramfs-linux.img console=tty1 console=ttyS2,1500000 root=LABEL=ROOT_MNJRO rw rootwait
bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
Desktop: i3 4.19.1 info: i3bar vt: 7 dm: LightDM 1.30.0 Distro: Manjaro ARM base: Arch Linux
Machine: Type: ARM Device System: Pine64 Pinebook Pro details: N/A serial: <filter>
Battery: ID-1: cw2015-battery charge: 22% condition: N/A volts: 3.9 min: N/A model: N/A type: Li-ion serial: N/A
status: Charging
CPU: Info: 6-Core (2-Die) model: N/A variant-1: cortex-a53 variant-2: cortex-a72 bits: 64 type: MCP MCM arch: ARMv8
family: 8 model-id: 0 stepping: 4
features: Use -f option to see features bogomips: 0
Speed: 408 MHz min/max: 408/1416:1800 MHz Core speeds (MHz): 1: 1416 2: 1416 3: 1416 4: 1416 5: 1008 6: 1008
Type: spec_store_bypass status: Not affected
Type: spectre_v1 mitigation: __user pointer sanitization
Type: spectre_v2 mitigation: Branch predictor hardening
Graphics: Device-1: display-subsystem driver: rockchip_drm v: N/A bus-ID: N/A chip-ID: rockchip:display-subsystem
class-ID: display-subsystem
Device-2: rk3399-mali driver: panfrost v: kernel bus-ID: N/A chip-ID: rockchip:ff9a0000 class-ID: gpu
Device-3: Microdia HP Integrated Webcam type: USB driver: uvcvideo bus-ID: 1-1.2:3 chip-ID: 0c45:6321
class-ID: 0e02
Display: x11 server: X.Org 1.20.11 driver: loaded: fbturbo display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3") s-diag: 583mm (23")
Monitor-1: default res: 1920x1080
Audio: Device-1: simple-audio-card driver: asoc_simple_card bus-ID: N/A chip-ID: simple-audio-card:es8316-sound
class-ID: es8316-sound
Device-2: simple-audio-card driver: N/A bus-ID: N/A chip-ID: simple-audio-card:hdmi-sound class-ID: hdmi-sound
Sound Server-1: ALSA v: k5.13.0-1-MANJARO-ARM running: yes
Network: Message: No ARM data found for this feature.
IF-ID-1: wlan0 state: up mac: <filter>
Bluetooth: Device-1: rk3399-uart driver: dw_apb_uart bus-ID: N/A chip-ID: rockchip:ff180000 class-ID: serial
Report: rfkill ID: hci1 rfk-id: 2 state: down bt-service: enabled,running rfk-block: hardware: no
software: yes address: see --recommends
Report-ID: ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: N/A
Drives: Local Storage: total: 58.24 GiB used: 18.53 GiB (31.8%)
ID-1: /dev/mmcblk2 maj-min: 179:0 vendor: SanDisk model: DA4064 size: 58.24 GiB block-size: physical: 512 B
logical: 512 B rotation: SSD serial: <filter> rev: 0x8 scheme: MBR
Partition: ID-1: / raw-size: 58 GiB size: 57.03 GiB (98.33%) used: 18.48 GiB (32.4%) fs: ext4 dev: /dev/mmcblk2p2
maj-min: 179:2
ID-2: /boot raw-size: 213.6 MiB size: 213.4 MiB (99.89%) used: 46.9 MiB (22.0%) fs: vfat dev: /dev/mmcblk2p1
maj-min: 179:1
Swap: Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: zram size: 5.66 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 50.0 C mobo: N/A
Info: Processes: 196 Uptime: 17m Memory: 3.77 GiB used: 1.02 GiB (27.1%) Init: systemd v: 248 tool: systemctl
Compilers: gcc: 10.2.0 Packages: pacman: 911 lib: 226 Shell: Bash v: 5.1.8 running-in: urxvt inxi: 3.3.04
