Dropouts with bluetooth earphones
Hi again from Bluetooth noob-land. This may indicate my lack of Bluetooth experience, but I don’t think so.
I am using i12 Bluetooth headphones. In recent months, using the stable updates only, I am having audio dropout problems with playing videos, sometimes one or the other ear, or both ears.
I have tried kernels 5.12 and 5.10 LTS, same problems. Playing the video files over HDMI audio shows the problem is not with the videos themselves.
My info:
  Kernel: 5.12.1-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
  root=UUID=c8e669d6-890c-431a-9083-a5bee720d372 rw quiet apparmor=1
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
  Type: Mini-pc System: IP3 Tech product: TX95 v: N/A serial: <filter>
  Mobo: IP3 model: AB1A serial: <filter> UEFI: American Megatrends v: 0.02
  date: 06/30/2020
  RAM: total: 7.62 GiB used: 1.68 GiB (22.1%)
  Info: Quad Core model: Intel Celeron N3450 bits: 64 type: MCP arch: Goldmont
  family: 6 model-id: 5C (92) stepping: 9 microcode: 40 cache: L2: 1024 KiB
  bogomips: 8756
  Speed: 796 MHz min/max: 800/2200 MHz Core speeds (MHz): 1: 796 2: 1741
  3: 988 4: 808
  Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
  arch_perfmon art bts cat_l2 clflush clflushopt cmov constant_tsc cpuid
  cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
  flexpriority fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt lahf_lm lm mca mce
  md_clear mmx movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pclmulqdq
  pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdt_a
  rdtscp rep_good sdbg sep sha_ni smap smep ss sse sse2 sse4_1 sse4_2 ssse3
  stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
  tsc_known_freq tsc_reliable vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
  xsaveopt xsaves xtopology xtpr
  Type: spec_store_bypass status: Not affected
  Device-1: Intel HD Graphics 500 driver: i915 v: kernel bus-ID: 00:02.0
  chip-ID: 8086:5a85 class-ID: 0300
  Display: x11 server: X.Org 1.20.11 driver: loaded: intel
  unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: HDMI1 res: 1920x1080 hz: 60
  OpenGL: renderer: Mesa Intel HD Graphics 500 (APL 2) v: 4.6 Mesa 21.0.3
  direct render: Yes
  Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_apl
  bus-ID: 00:0e.0 chip-ID: 8086:5a98 class-ID: 0403
  Sound Server-1: ALSA v: k5.12.1-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.26 running: no
  driver: r8169 v: kernel port: e000 bus-ID: 01:00.0 chip-ID: 10ec:8168
  class-ID: 0200
  IF: enp1s0 state: down mac: <filter>
  Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000
  bus-ID: 02:00.0 chip-ID: 8086:3165 class-ID: 0280
  IF-ID-1: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
  IP v4: <filter> scope: global
  bus-ID: 1-7:3 chip-ID: 8087:0a2a class-ID: e001
  Local Storage: total: 235.56 GiB used: 109.94 GiB (46.7%)
  ID-1: /dev/mmcblk1 maj-min: 179:0 vendor: HP model: DF4128 size: 116.48 GiB
  block-size: physical: 512 B logical: 512 B rotation: SSD serial: <filter>
  rev: 0x8 scheme: GPT
  ID-2: /dev/sdc maj-min: 8:32 type: USB model: Genesys SD USB3 Reader
  size: 119.08 GiB block-size: physical: 512 B logical: 512 B serial: <filter>
  rev: 1206 scheme: GPT
  ID-1: / raw-size: 118.79 GiB size: 116.87 GiB (98.39%)
  used: 53.16 GiB (45.5%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
  uuid: c8e669d6-890c-431a-9083-a5bee720d372
  used: 312 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: N/A
  uuid: 6EF9-53C7
  ID-3: /mnt raw-size: 115.32 GiB size: 115.32 GiB (100.00%)
  used: 56.79 GiB (49.2%) fs: ntfs dev: /dev/mmcblk1p3 maj-min: 179:3
  label: OS uuid: 7802BE5802BE1AD8
  ID-1: /dev/mmcblk1p1 maj-min: 179:1 size: 100 MiB fs: vfat label: SYSTEM
  uuid: C2B5-68AC
  ID-2: /dev/mmcblk1p2 maj-min: 179:2 size: 128 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-3: /dev/mmcblk1p4 maj-min: 179:4 size: 957 MiB fs: ntfs label: Recovery
  uuid: 08B2BED7B2BEC888
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 8 rev: 2.0
  Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 1-2.1:4
  info: Holtek Wired Keyboard (78/79 key) [RPI Wired Keyboard 5]
  type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
  speed: 1.5 Mb/s power: 100mA chip-ID: 04d9:0006 class-ID: 0300
  Device-2: 1-2.3:5 info: Microdia USB Device type: Keyboard,Mouse
  driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s
  power: 100mA chip-ID: 0c45:8101 class-ID: 0301
  Device-3: 1-2.4:6 info: Logitech Keyboard K120 type: Keyboard,HID
  power: 90mA chip-ID: 046d:c31c class-ID: 0300
  Device-4: 1-7:3 info: Intel Bluetooth wireless interface type: Bluetooth
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 7 rev: 3.0 speed: 5 Gb/s
  Device-1: 2-3:2 info: Genesys Logic All-in-One Cardreader type: Mass Storage
  driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
  chip-ID: 05e3:0748 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 74.0 C mobo: N/A
  Processes: 197 Uptime: 21h 45m wakeups: 6 Init: systemd v: 247
  tool: systemctl Compilers: gcc: 10.2.0 Packages: 1295 pacman: 1290 lib: 403
  flatpak: 5 Shell: Bash v: 5.1.4 running-in: xfce4-terminal inxi: 3.3.04
Unfortunately, I don’t remember exactly at which update this started. I’ve had (and continue to have) other problems with Bluetooth headphones freezing out my keyboard, and that was more my focus.
Has Pulse audio been updated recently?
Thanks for any ideas on this.
R
The latest update for PulseAudio (v14.2-2 to v14.2-3) was included in [Stable Update] 2021-04-09
If PulseAudio is not working after an update, clearing old user settings might get audio working again
Delete Pulseaudio user settings databases and cookie, then reboot system so new user files are created
rm ~/.config/pulse/*.tdb ~/.config/pulse/cookie && reboot
Thanks for this suggestion! I tried it, but unfortunately, the dropouts persist. I’m now wondering how to try pipewire instead of pulseaudio, since it is supposed to address bluetooth issues when playing video. I’ll check the forum for pipewire info.
Pipewire didn’t seem to help, but the most recent stable update (16 jun 2021) fixed the dropouts!
THANKS to whichever layer was improved, and to the Manjaro team in any case!
R
