[DEEPIN] Disable Wayland
(As of 11-07-2019) Does Manjaro Linux Deepin uses Wayland?
If yes, I would like to disable it. (and use X.Org only)
Manjaro deepin already uses X.Org
More than that, as far as i know Deepin is not compatible with wayland (at least yet).
Deepin is not compatible with X.Org :rofl: :joy: :crazy_face:
...sorry, couldn't stop myself.
when I do:
$ sudo pacman -Qs wayland
local/lib32-wayland 1.17.0-1
    A computer display server protocol
local/libva 2.5.0-1
    Video Acceleration (VA) API for Linux
local/wayland 1.17.0-1
local/wayland-protocols 1.17-1
    Specifications of extended Wayland protocols
this lead me to believe that wayland may be in use (on Deepin).
How can I be sure that wayland is not used on my system? Which one of these packages (or others) may I uninstall to make sure that my DE doesn't use Wayland?
Thanks
Having those packages doesn't mean you use it, it's dependencies for a lot of essential stuff:
-gtk3
-mesa
You can see Required By section of:
pacman -Qi wayland
To run wayland you would actually need to do some additional work and Deepin wouldn't even boot, i'm pretty sure you don't run it :slight_smile:
But you can run:
inxi -Gz
To check server value, should be X.Org
I suppose you meant pacman -Qi wayland .
Thank you for the reply. Yes, I ain't using Wayland as my display server.
I wonder, why would some packages have wayland as dependency, such as gst-plugins-bad , gtk3, etc. ??
Yep, sorry typo :slight_smile:
No idea, most likely in relatively near future wayland will replace X so everyone preparing it as required dependency :slight_smile:
Good software (such as X.Org) shouldn't be replaced.
I suspect of the motives that lead to create Wayland. X.Org just works. I can see some distros ship Wayland in the future and I also can see a lot of bugs coming from using Wayland (in the future).
The Wayland display server will be the first thing to break on the system, or make it vulnerable.
Naaaah...First will be Deepin :rofl:
Then the rest :slight_smile:
you can always ask whats running by type this to a terminal (not tty)
echo $XDG_SESSION_TYPE
Thank you @Fabish
