So I know that many people do NOT have a problem with this game. Game will cause entire system to freeze. All icons will change to blank icons and clicking on them will show a input/output error. I can’t do a REISUB and I end up having to do a hard reboot. I have played about 20 hours and it has crashed 8-10 times.
Here are the system specs:
Kernel: 5.15.53-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=74319724-ff9b-4abf-83e7-2fb36117167c rw quiet apparmor=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 1201
date: 09/09/2019
RAM: total: 15.54 GiB used: 2.78 GiB (17.9%)
RAM Report:
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x71 (113)
stepping: 0 microcode: 0x8701013
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2266 high: 3115 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2450 2: 2061
3: 2057 4: 2056 5: 2459 6: 2180 7: 3115 8: 2052 9: 2053 10: 2064 11: 2457
12: 2196 bogomips: 86268
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: always-on, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Gigabyte
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Pascal process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.0
chip-ID: 10de:1c02 class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: DP-0 pos: primary,right res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.78x10.55") diag: 547mm (21.54") modes: N/A
Monitor-2: DVI-D-1 pos: primary,left res: 1920x1080 hz: 60 dpi: 102
OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
v: 4.6.0 NVIDIA 515.57 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel bus-ID: 1-4:2 v: kernel pcie: chip-ID: 1038:12b3
gen: 3 class-ID: 0300 speed: 8 GT/s lanes: 16 bus-ID: 09:00.1
chip-ID: 10de:10f1 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS Arctis 1 Wireless type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.15.53-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.54 running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
IF-ID-2: virbr1 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 3-5:2 chip-ID: 8087:0025 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 3.64 TiB used: 276.59 GiB (7.4%)
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 45.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
type: SSD serial: <filter> rev: 4B6Q scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
ID-1: / raw-size: 500 GiB size: 491.09 GiB (98.22%) used: 276.59 GiB (56.3%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: main
uuid: 74319724-ff9b-4abf-83e7-2fb36117167c
ID-2: /boot/efi raw-size: 2 GiB size: 2 GiB (99.80%) used: 288 KiB (0.0%)
fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A uuid: 49C1-B1D8
ID-1: swap-1 type: partition size: 20 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2 label: swap
uuid: b08d9c55-cc76-4c14-b494-be820491b5e6
ID-1: /dev/nvme0n1p4 maj-min: 259:4 size: 984.31 GiB fs: ext4
label: timeshift-backup uuid: f670f632-e1ee-4aac-b38e-1e168f9e55af
ID-2: /dev/sda1 maj-min: 8:1 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda5 maj-min: 8:5 size: 931.51 GiB fs: ntfs label: Storage
uuid: 01D69DE7B302CE00
ID-4: /dev/sdb1 maj-min: 8:17 size: 500 MiB fs: ntfs label: N/A
uuid: 01D69DC365F336F0
ID-5: /dev/sdb2 maj-min: 8:18 size: 930.5 GiB fs: ntfs
label: Win10 BOOT DRIVE uuid: 01D69DCE82B608C0
ID-6: /dev/sdb3 maj-min: 8:19 size: 532 MiB fs: ntfs label: N/A
uuid: 02F2E5C4F2E5BBD3
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 1-4:2 info: SteelSeries ApS Arctis 1 Wireless type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 1038:12b3 class-ID: 0300
Device-2: 1-5:3 info: Corsair H100iRGBPROXT type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 1b1c:0c20 class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-5:2 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Device-2: 3-6:3 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: Razer USA BlackWidow (2019) type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:0241 class-ID: 0300
Device-2: 5-2:3 info: Razer USA RZ01-0321 Gaming Mouse [DeathAdder V2]
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 1532:0084 class-ID: 0300
Hub-6: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 56 C
Processes: 313 Uptime: 7m wakeups: 0 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: 1538
pacman: 1534 lib: 378 flatpak: 0 snap: 4 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.19
Here is the dump core log:
Subject: Process 4551 (DesktopEditors) dumped
░░ Defined-By: systemd
░░ Documentation: man:core(5)
░░ Process 4551 (DesktopEditors) crashed and dumped core.
░░ This usually indicates a programming error in the crashing program and
░░ should be reported to its vendor as a bug.
Jul 13 10:07:01 xxx anacron[6436]: Can't find sendmail at /usr/sbin/sendmail, not mailing output
Jul 13 11:53:00 xxx systemd-coredump[18098]: Process 17999 (steam) of user 1000 dumped core.
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam with build-id cd7d44d7afd7d32d4f18c4292e4e4812b8f18b72
Module /home/xxx/.local/share/Steam/ubuntu12_32/steamservice.so with build-id e4db8743ac1dd3b91a9690369b91a0ef3744608d
Module /home/xxx/.local/share/Steam/ubuntu12_32/steamclient.so with build-id d54b6f13b5744e8fcd23e9912160bcf5d2bf2f40
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libnm.so.0.1.0 with build-id 53e4f4edd53bcde71a4a9601b072ee37c11d2568
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libgudev-1.0.so.0.1.1 with build-id d1614607248fc5039e23ce2c4d6a79f386784186
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/gtk-2.0/2.10.0/engines/libmurrine.so with build-id 65156017a203112e447a7d4871d548ff7c574392
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/gtk-2.0/2.10.0/engines/libpixmap.so with build-id a7f25bf3f3136905ee762be4694b065e73136776
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libltdl.so.7.3.0 with build-id 788d0106b1ba0e40dd0d809269714bdc3133b797
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libtdb.so.1.2.9 with build-id cc199ddb3fd0ea4a209f9a89ee998ea934cb9e3e
Module /home/xxx/.local/share/Steam/ubuntu12_32/libvorbisfile.so.3 with build-id 3e3e2e762b855b4071694930b032dba5be1614ae
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libcanberra.so.0.2.5 with build-id 037c40b97ca5190d82c9ab0eb6f367521a4346ab
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libcanberra-gtk.so.0.1.8 with build-id 4a196366177ced09759cd9d1ae82bd5add496bed
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/gtk-2.0/modules/libcanberra-gtk-module.so with build-id 6c208073297de265758fd93cf5f92e7e2b839f9b
Module /home/xxx/.local/share/Steam/ubuntu12_32/chromehtml.so with build-id 13be1c68fc5261d537f957815206665dae8134a4
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libopenal.so.1.16.0 with build-id 64ea78e946ee74e28800c7e3f28d1f91592c98f1
Module /home/xxx/.local/share/Steam/ubuntu12_32/vgui2_s.so with build-id b389f1b1df1a922a21be4927e04ae914692c7697
Module /home/xxx/.local/share/Steam/ubuntu12_32/filesystem_stdio.so with build-id 1744fbcc846e5541234207cb8c634e09e07fe770
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/lib/i386-linux-gnu/libudev.so.0.13.0 with build-id cf2498d52231d623047c965a5b0ca03e2084464f
Module /home/xxx/.local/share/Steam/ubuntu12_32/libogg.so.0 with build-id 4c91d8f0dd8581b0ba6780e60808dc1db9ff5151
Module /home/xxx/.local/share/Steam/ubuntu12_32/libvorbis.so.0 with build-id cb40c3a2fd4c2e54822da9789d01113970595af6
Module /home/xxx/.local/share/Steam/ubuntu12_32/libvorbisenc.so.2 with build-id 5de455f0c9fcd36426e121b47995d9a75bfcecbf
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/lib/i386-linux-gnu/libdbus-1.so.3.5.8 with build-id bea6597c238951c70269c034fdf4097216e2c970
Module /home/xxx/.local/share/Steam/ubuntu12_32/libswscale.so.5 with build-id a1abf019236fe16d77be7783352d31fc8d8827e8
Module /home/xxx/.local/share/Steam/ubuntu12_32/libavresample.so.4 with build-id 87e2e15c5677dabd8175201a2b5bbef33920b947
Module /home/xxx/.local/share/Steam/ubuntu12_32/libavformat.so.58 with build-id 0051c6db12e51b6a0cee33a60514456476b05a74
Module /home/xxx/.local/share/Steam/ubuntu12_32/libvpx.so.6 with build-id e7262af22bb742de3a1af404c1fcc02cea202365
Module /home/xxx/.local/share/Steam/ubuntu12_32/libicuuc.so with build-id 7bca947cbb088c5ea46ae03b4e96f2ff4efc8253
Module /home/xxx/.local/share/Steam/ubuntu12_32/libicui18n.so with build-id 88bf0deef8375bf4848f1fd853b1da471cfa8b7b
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libpipewire-0.3.so.0.327.0 with build-id 7ff12561380134ade709581c97d6a945f8383a5e
Module /home/xxx/.local/share/Steam/ubuntu12_32/libSDL2-2.0.so.0 with build-id 14200f33ac8527765a844ccab6a82d45f9fcadd9
Module /home/xxx/.local/share/Steam/ubuntu12_32/libvideo.so with build-id db10fa01e39656af8d0fefa4dbe0b4d0a63e7728
Module /home/xxx/.local/share/Steam/ubuntu12_32/libavutil.so.56 with build-id d59f21ddbccebe77b345117f9f5bb2e8ecaced55
Module /home/xxx/.local/share/Steam/ubuntu12_32/libavcodec.so.58 with build-id 3170f616f3afb700e8a910077706d96e799f4a8f
Module /home/xxx/.local/share/Steam/ubuntu12_32/libv8.so with build-id c46f89eda7dcdedd846d2d6879a7d51e17ee8f64
Module /home/xxx/.local/share/Steam/ubuntu12_32/libvstdlib_s.so with build-id 6de3bf5280c8c214b1b9874db09b5d61bcd74251
Module /home/xxx/.local/share/Steam/ubuntu12_32/libtier0_s.so with build-id 8b048587ea5943f33fb14af433d4747caef29418
Module /home/xxx/.local/share/Steam/ubuntu12_32/steamui.so with build-id 74cd2f960b7425439c57f1acb8601d6f29b98495
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libpixman-1.so.0.30.2 with build-id cdcb1dac09a64fef3fd355a05fcb0cda617e6844
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libXcomposite.so.1.0.0 with build-id 1debe7c777fe8ec2d931d5be1ba1a3283af71ef9
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libtiff.so.4.3.4 with build-id 569c408eca3fd1fe1d4012f8f3694681c59ef445
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/lib/i386-linux-gnu/libpng12.so.0.46.0 with build-id 3cbbf75280dade19d7e1253db714a32ef938b24a
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libpangoft2-1.0.so.0.3000.0 with build-id aebdc291ca93c02bf0999333f650f18c1011f86d
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libcairo.so.2.11000.2 with build-id 52c3900938e1cd8c282eff1aba115d57ba041670
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libpango-1.0.so.0.3000.0 with build-id d2bfe03653a282e438fa9e8c8a998a8109487d59
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libgdk-x11-2.0.so.0.2400.10 with build-id c271cfb31b9a244ab5f02bf4c941c3aaa8489def
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libgdk_pixbuf-2.0.so.0.2600.1 with build-id 0f2887541fb65ee29666cef40a71ea204f0ce63d
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libgtk-x11-2.0.so.0.2400.10 with build-id 48830dfc7e581fa5fbb5e7a2d2956b980a1e8ccc
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libpangocairo-1.0.so.0.3000.0 with build-id 96f61792d93c98d04769c2ffb0ebdc47cd64996a
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libatk-1.0.so.0.21809.1 with build-id 9f67d84ac1e4fc9596be71a33429b5adddc1f243
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libXinerama.so.1.0.0 with build-id 2e7bfffb8bf2e5e1fab2f81a38473b6154411cee
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libdbusmenu-glib.so.4.0.13 with build-id 2d09183a661a81cdf7be0291101109ef60158d54
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libdbusmenu-gtk.so.4.0.13 with build-id 6e7466e1f39bdb6f5178c100f15cc1ebd73d0a40
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libindicator.so.7.0.0 with build-id 06ff1b352acb876abfd45e94aa9f700d308d251b
Module /home/xxx/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libappindicator.so.1.0.0 with build-id abc4065c9af4bef61512179c06d45f9487568933
Module /home/xxx/.local/share/Steam/ubuntu12_32/crashhandler.so with build-id bf5d8f1fa0278d9f0a6ed86f75e9fb5ef3dbff65
Module linux-gate.so.1 with build-id ab0f43296334f15d1c859a643aa7e137976a3223
Module libnss_resolve.so.2 with build-id 93b5173611a89a42c62a0b6546aaee51936f6e13
Module libnss_mymachines.so.2 with build-id a1f0675f9651d87a998837e0485877e8c3d25ebd
Module libunistring.so.2 with build-id bc684570618a407fd6c4a305a38a7e3dcff87de2
Module libgmp.so.10 with build-id cafef68f474308509c3feaacf0d479a30fedcace
Module libhogweed.so.6 with build-id 7ca0f7fa561819b69cc4ded18da57cc25a27f885
Module libnettle.so.8 with build-id 2d1fa470f77c5aab02372b0f8d0e1544467f9b9a
Module libtasn1.so.6 with build-id fd5b1c9c8aec387c33af00adc4c1623587c93f89
Module libidn2.so.0 with build-id 5aebdeaffb11ad3d869fd26040cb517c6d00a749
Module libbrotlienc.so.1 with build-id fa69fa6830c270de68e774719f891951658a8948
Module libp11-kit.so.0 with build-id ef48c2739d8f80ae9a27bf632210bed2f27c9af6
Module libgnutls.so.30 with build-id ea74b78e45e0a0e8ae8a62a91d0580aa568f7e84
Module libuuid.so.1 with build-id 51c27c47667d468550757c01641c7ebb0527041a
Module libICE.so.6 with build-id 5c398351eae18b0185f2b9512647e40c97f4e068
Module libSM.so.6 with build-id 1cb4b8ce8ba49d0d98da7968de9ee574ed44fe6e
Module libgpg-error.so.0 with build-id 6ecfdea2e1871208214eee924c1a309656c8913d
Module libzstd.so.1 with build-id 442775044f6163f8c14265443311007e63d5d3e0
Module liblzma.so.5 with build-id f08d32c158738d5bcd5dfab2cd522a4e940ea692
Module libgcrypt.so.20 with build-id 8ece9a72febf606ba62e6071765e3cc597a6edf0
Module libcap.so.2 with build-id d397a803349e73a6f637ed31c890a3f56d9789ac
Module libopus.so.0 with build-id e51af9f0b271bc2ba66d7b413a97df4aa21d1228
Module libFLAC.so.8 with build-id 56c326c3797e9b6e25a8cfabbbaa5e0e225cfde9
Module libasyncns.so.0 with build-id 2c3c77cfaeddfda50b66c21e3f8a86cb78933ca2
Module libsystemd.so.0 with build-id 3b8e1c42bd93b16be4c801f6382f057bbe5f1ae0
Module libsndfile.so.1 with build-id 3e89f726838072f4fa3f8a9b16bc8405876891d1
Module libpulsecommon-16.1.so with build-id d1f892a3bc37a602d769b0664e50a7acb2257e5a
Module libvdpau.so.1 with build-id d42369090aa9fdf14c505ef29ac87c80b12daeae
Module libva-x11.so.2 with build-id 5e78d4f6f34f308e85b2f0210d32b23943cb6d79
Module libva-drm.so.2 with build-id ed5d78fd076155aec1517658d99a9e5a3fdc47ee
Module libva.so.2 with build-id b0f3370a5e39b1ba885fde3bd266c61b59e85d0f
Module libpulse.so.0 with build-id 8802cdae09ed16b8f9a246a1188bcc8dd26e09f9
Module libXtst.so.6 with build-id aad4727dece53f25a0a32590357e0ff358859277
Module libbrotlicommon.so.1 with build-id 6a6095e57c732bdc9f52c5b401ccd78412b34650
Module libbrotlidec.so.1 with build-id d217b0d877303a399de12d974671e442aaf58832
Module libharfbuzz.so.0 with build-id 8558c7e12d1702454f552426d9f57a9055d7d6f8
Module libpng16.so.16 with build-id 202b8ec7361ff29d13abdcbeb691a9273494d2d9
Module libbz2.so.1.0 with build-id 3e5d97f5bb82cda221ccd14318bfae2ac77b815e
Module libblkid.so.1 with build-id 7fd65417134318ca67f587f911d50ef2db3ea280
Module libexpat.so.1 with build-id 04afefa75a726ecd0d440f6ba5c8be90d2dc79d0
Module libxcb-render.so.0 with build-id 42eaec8c69b7df78937c6b9e664a98c457e5db18
Module libxcb-shm.so.0 with build-id c478bab45d8cef998d3d744755528b23dd9c445b
Module libfreetype.so.6 with build-id ac10dea7fcb0e1dbc52d6989bfd34abbd814c1bf
Module libXdamage.so.1 with build-id 55dd5fb5193b4ee5207ecad0d19cc6e9d7af5aa9
Module libXcursor.so.1 with build-id ae3c97e2f155847562267b1707c75fb9884a2350
Module libXrandr.so.2 with build-id 3295bdef0e30b5fd9da27c99bf5d6fd1c14551aa
Module libXi.so.6 with build-id ae19d465b15227ab5e08de671bc16532450e384f
Module libXrender.so.1 with build-id 8d67a935a15bfc2f18084d0a493880189f806583
Module libjpeg.so.8 with build-id 0c11491d2d39ff5819b2ce1425b8e2375d811b31
Module libpcre.so.1 with build-id 9e8433d78efdfe75dc9ca017f477cf938d804df1
Module libffi.so.8 with build-id 2bcd779cf0cb1d8583813bcf37976575a6078f4b
Module libmount.so.1 with build-id 9602200fd4bd5b7b2dbbe472d9fd35f088ff2c15
Module libz.so.1 with build-id eef8f76603fae7a2876659fe737c1aebadb8b90b
Module libfontconfig.so.1 with build-id 8a9ac4404881ead3fa46770b2da4e946201cd827
Module libXfixes.so.3 with build-id d04e7cb05d21774a5403cdea89e8023c4e2dbd78
Module libgmodule-2.0.so.0 with build-id 0df6b28d66299d96c47fc76f629234ab99371675
Module libglib-2.0.so.0 with build-id 6cd48b6d9f35260c79f944bd1a3eb958b91fd94b
Module libgobject-2.0.so.0 with build-id 066a15490e1540b29cae244bd589f8d236fdb058
Module libgio-2.0.so.0 with build-id d3f4fbb75e8783a33162f2b2e47bada3f223f7d3
Module libdrm.so.2 with build-id 40a5e0f2b0bbddb1ca3c2dc9f5592bc9921ebc8a
Module libxcb-glx.so.0 with build-id 817fea1247bcd2ed52775646ce5e5ad22768f3cf
Module libXext.so.6 with build-id 51364f7aaaad05288c6403f4cd82dc20bd1c2975
Module libnvidia-glcore.so.515.57 with build-id 34eacdc0d5842027e9101747cfaa7a6b5416e1d9
Module libnvidia-tls.so.515.57 with build-id 5e2342e734b9e33fbd8082ba5a61b9efbe88ab01
Module libnvidia-glsi.so.515.57 with build-id b9fd9cdd5c14cd9546f19c18eddb276845b918ba
Module libGLX_nvidia.so.0 with build-id 0faf880279899ab02753d9d588cd3b9f00002740
Module libGLX.so.0 with build-id 92c5b648663ea46e00344148f13d0e4413ece785
Module libGLdispatch.so.0 with build-id deb094bd23d7b05cfe2715882db8caadfdc7a2ab
Module libGL.so.1 with build-id 7d4cc9852ee6fd480756b2bbedc10c20167ed71a
Module libXdmcp.so.6 with build-id d6d2063b49e333551fb395c4699ce68908342ca2
Module libXau.so.6 with build-id 37885701fd17e23735180bb9afefba9fd93eafce
Module libxcb.so.1 with build-id 4187de5462ea94547789043cd82a227550b36d73
Module libgcc_s.so.1 with build-id c595e9170ddd2d74814f136f8bb17df6034adbe1
Module ld-linux.so.2 with build-id fedfde2c74e726f8e8765cb79c4f7c184aad3df7
Module libc.so.6 with build-id e5708a71bf73aa086629f1404cf3e314eb82766f
Module libm.so.6 with build-id 46402c9a5dee53f66886a2ad95ac46763fdee0ca
Module libX11.so.6 with build-id 54441eb873ba14650de70b96c9724da9f6dc6eb3
Module librt.so.1 with build-id fdd68da31308a470a527c2fc12b3adba0f67235b
Module libpthread.so.0 with build-id 5dbb72a31482c3975409bb7fa47fd888a82ce685
Module libstdc++.so.6 with build-id 1826c72b6968d69e5c976e46d41c87cae23723c8
Module libdl.so.2 with build-id b813519c6d1aaed0b146662db17b1ce022023be7
Stack trace of thread 18090:
#0 0x00000000f78a78a2 getenv (libc.so.6 + 0x398a2)
#1 0x00000000eb0095bf n/a (libnss_resolve.so.2 + 0x45bf)
#2 0x00000000f78fc46a n/a (libc.so.6 + 0x8e46a)
#3 0x00000000eb015695 _nss_resolve_gethostbyname3_r (libnss_resolve.so.2 + 0x10695)
#4 0x00000000eb016147 _nss_resolve_gethostbyname2_r (libnss_resolve.so.2 + 0x11147)
#5 0x00000000f79a535a gethostbyname2_r (libc.so.6 + 0x13735a)
#6 0x00000000f796f7c4 n/a (libc.so.6 + 0x1017c4)
#7 0x00000000f79703c3 getaddrinfo (libc.so.6 + 0x1023c3)
#8 0x00000000ed10f374 n/a (/home/apw/.local/share/Steam/ubuntu12_32/steamclient.so + 0xf65374)
#9 0x00000000ed10f91e n/a (/home/apw/.local/share/Steam/ubuntu12_32/steamclient.so + 0xf6591e)
#10 0x00000000ed41dd30 n/a (/home/apw/.local/share/Steam/ubuntu12_32/steamclient.so + 0x1273d30)
#11 0x00000000ed41e29c n/a (/home/apw/.local/share/Steam/ubuntu12_32/steamclient.so + 0x127429c)
#12 0x00000000ed608f44 n/a (/home/apw/.local/share/Steam/ubuntu12_32/steamclient.so + 0x145ef44)
#13 0x00000000f23e4800 n/a (/home/apw/.local/share/Steam/ubuntu12_32/libtier0_s.so + 0x19800)
ELF object binary architecture: Intel 80386
░░ Subject: Process 17999 (steam) dumped core
░░ Process 17999 (steam) crashed and dumped core.
