GloW
13 October 2023 06:13
1
Just after applying the last updates of today, when I lock the session, a black screen appears indicating that the screen locker is broken.
usr/lib64/kscreenlocker_greet --testing
kf.kirigami: Failed to find a Kirigami platform plugin
Cannot mix incompatible Qt library (5.15.10) with this library (5.15.11)
Could you help me?
Welcome to the forum!
Have you rebooted after the update?
You may also want to read this HowTo .
The golden rule — which nobody follows, of course — when using a rolling-release distribution…:
Always apply the bundled updates by way of the command line in a tty while completely logged out of your graphical environment, so that no shared libraries will be in use that will be overwritten by the update process.
Then, there are two additional golden rules specific to all Arch-based distributions…:
Always update the packages from the official repositories first, and update the AUR stuff, t…
GloW
13 October 2023 06:18
3
Thanks Aragorn.
Yes, sure.
And I have just found the problem:
replace qt5-virtualkeyboard-bigscreen with qt5-virtualkeyboard.
PD: Thanks for the HowTo. I will read and follow it the next time.
system
Closed
15 October 2023 20:18
4
