Hi,
I have an Intel i5-4690K with integrated graphics (disabled in the BIOS, PEG mode) and an AMD R9 390 graphics card in my desktop. I would like to use the output on the dGPU exclusively without using the iGPU at all (separate cables, requires a BIOS change to use the iGPU, Windows uses the dGPU already etc, basically its a pain).
I have read about DRI_PRIME and Reverse Prime and I don’t think they quite solve my issue, however this section in the PRIME Arch wiki page does sound promising (PRIME - ArchWiki).
I created a 10-gpu.conf
file based on the wiki entry, making some educated guesses (omitting the intel
entries because the iGPU is disabled):
Section "ServerLayout"
Identifier "layout"
Screen 0 "amd"
EndSection
Section "Device"
Identifier "amd"
Driver "video-linux"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "amd"
Device "amd"
EndSection
based on the output of these commands:
> mhwd -li
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
> lspci | grep -e VGA -e 3D
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Hawaii PRO [Radeon R9 290/390] (rev 80)
I had no output at all before creating the file but I have now got as far as seeing a blank screen with the following output:
/dev/sdb2: clean, 286552/140057472 files, 28979834/324349879874 blocks
Which I understand is not an error, however my system wont boot any further. I can reach the tty
using ctrl+alt+F2
and I am comfortable using the terminal, though this is my first try with an Arch based distro (fresh install, not worried about borking). I feel like I am tantalizingly close to being up and running, can anyone advise on how I can investigate from here?
In case it helps:
> inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.32-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=23a151d6-49a2-4408-8f64-c32f0b3c1853 rw quiet apparmor=1
security=apparmor resume=UUID=52bb9e27-cf4d-4d01-93fe-14fd77c8b0f2
udev.log_priority=3
Console: tty 2 DM: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: MSI model: Z97 GAMING 5 (MS-7917) v: 1.0
serial: <filter> UEFI: American Megatrends v: 1.11 date: 05/28/2015
RAM: total: 15.58 GiB used: 430.4 MiB (2.7%)
Info: Quad Core model: Intel Core i5-4690K bits: 64 type: MCP arch: Haswell
family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache: L2: 6 MiB
bogomips: 27998
Speed: 2988 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 2988 2: 2945
3: 2804 4: 2667
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb
pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
Type: l1tf
Device-1: AMD Hawaii PRO [Radeon R9 290/390] vendor: Micro-Star MSI
driver: radeon v: kernel alternate: amdgpu bus-ID: 01:00.0
chip-ID: 1002:67b1 class-ID: 0300
Display: server: X.org 1.20.11 driver: loaded: radeon
note: n/a (using device driver) tty: 240x67
Message: Advanced graphics data unavailable in console. Try -G --display
Device-1: Intel 9 Series Family HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
class-ID: 0403
Device-2: AMD Hawaii HDMI Audio [Radeon R9 290/290X / 390/390X]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aac8 class-ID: 0403
Sound Server-1: ALSA v: k5.10.32-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.26 running: no
Device-1: Qualcomm Atheros Killer E220x Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel port: d000 bus-ID: 03:00.0
chip-ID: 1969:e091 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: d000
bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-8:2
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 700.52 GiB used: 6.25 GiB (0.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDHII480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 00RL scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 1103 scheme: GPT
ID-3: /dev/sdd maj-min: 8:48 type: USB vendor: Generic model: MicroSD M2
size: 29.81 GiB block-size: physical: 512 B logical: 512 B rotation: SSD
serial: <filter> rev: 1.08 scheme: MBR
ID-1: / raw-size: 214.47 GiB size: 210.05 GiB (97.94%) used: 6.25 GiB (3.0%)
fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 23a151d6-49a2-4408-8f64-c32f0b3c1853
used: 296 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: DC7D-9DD9
ID-3: /mnt/usb raw-size: 29.81 GiB size: 29.8 GiB (99.97%)
used: 6.1 MiB (0.0%) fs: vfat dev: /dev/sdd1 maj-min: 8:49 label: N/A
uuid: 9016-4EF8
dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: 52bb9e27-cf4d-4d01-93fe-14fd77c8b0f2
ID-1: /dev/sda1 maj-min: 8:1 size: 450 MiB fs: ntfs label: Recovery
uuid: 94C057CCC057B36A
ID-2: /dev/sda2 maj-min: 8:2 size: 99 MiB fs: vfat label: N/A
uuid: 7858-3BB7
ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sda4 maj-min: 8:4 size: 446.06 GiB fs: ntfs label: N/A
uuid: 2ACC5A59CC5A1F7F
ID-5: /dev/sda5 maj-min: 8:5 size: 527 MiB fs: ntfs label: N/A
uuid: 005A60445A603894
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel ports: 6 rev: 2.0 speed: 480 Mb/s
chip-ID: 8087:8009 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s
chip-ID: 8087:8001 class-ID: 0900
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0
Device-1: 3-8:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-6: 3-11:3 info: Microchip Massdrop Hub ports: 2 rev: 2.0 speed: 12 Mb/s
chip-ID: 04d8:eec5 class-ID: 0900
Device-1: 3-11.2:4 info: Microchip ALT Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 04d8:eed3 class-ID: 0300 serial: <filter>
Device-2: 3-13:6 info: Alcor Micro Flash Card Reader/Writer
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 058f:8468 class-ID: 0806
serial: <filter>
Hub-7: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: radeon temp: 40.0 C
Processes: 131 Uptime: 23m wakeups: 0 Init: systemd v: 247 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1057 lib: 298 flatpak: 0
Shell: Bash (login) v: 5.1.0 running-in: tty 2 inxi: 3.3.04
