Hi,
When i boot, i have to type a password, but it takes about 20 seconds to open Slot 0.
I think it has something to do with the number of iterations used when encrypting.
Is there a way to get the iters down with the live install?
Cheers.
Hi,
Cheers.
The time taken to unlock an encrypted partition is normal - and most of it is because of limitations with GRUB and LUKS encryption.
Different methods can be utilized
So i guess it can’t be done in the live-installer? Because i can’t choose systemd boot there.
My /boot/efi is unencrypted…
But will try Architect and init partitition scheme / LUKS encryption before starting the install…
Thank you
That’s not the same as a /boot partition.
