Hi,
Running Manjaro KDE fully updated on the “Testing” branch.
Running a mini PC on a 4K television.
Everything works fine, but I would like to decrease the resolution of encrypted password & login screens.
Anyone know how?
Thanks!
Jesse
Hi,
Anyone know how?
Thanks!
Jesse
So that the text, fields, and buttons all become “larger” on the lockscreen and login screen?
Yes, correct…
(the text is too small to read - it’s a 50 inch 4K TV)
I don’t think the “HiDPI” override ever worked properly for the SDDM greeter.
You can try it for yourself, as you might have better luck: SDDM - ArchWiki
Even if it works, it doesn’t address the “lock screen”.
