Debugging xpad driver
I’m trying to run and debug xpad as I have a controller that it is not recognising and want it to work.
I downloaded and follw the instructions here:
sudo dkms remove -m xpad -v 0.4 --all
sudo dkms install -m xpad -v 0.4
the output from these two commands are here:
I assume this uninstalls and compiles then installs the new driver.
the problem is I have added into the xpad.c file:
and so I would expect that to show up in the dmesg log. I have in a separate console:
dmesg --level=debug --follow
but nothing appears to be displaying.
