Hi,
I’m currently trying (and failing) to debug an XRDP issue related to Manjaro and systemd https://github.com/neutrinolabs/xrdp/issues/1684
I’m new to Manjaro, but have pretty extensive experience with RPM-based distros, and (to a lesser extent) DEB-based distros. On both of those, there are documented procedures to install some sort of debugging package which contains the debug symbols and source code for an OS-supplied package. This allows a developer to step through the OS-installed software and libraries at a source level.
I’d really like to be able to do this with the PAM libraries installed with the systemd packages on Manjaro to look at this fault, but I can’t find a description anywhere of how to achieve this. Can anyone give me any pointers?
Thanks.
