there was more:
cost / benefit ratio - remember?
Manjaro is a bit different - they just take the packages from their parent distro (Arch), then delay them, hold them back.
It’s supposed to provide a more stable result.
It’s also creating some issues precisely because of that.
(it’s why I don’t actually use it - but that is my personal choice and opinion and a separate matter)
They would need to invest time and effort to keep and provide the original debug symbols, which, let’s be honest, almost no one is going to use.
Yes, they do - but the similarity in branch name does not translate directly to what Manjaro does.
as I said:
you may advocate for it - or may put the work in yourself to make it happen
It’s not going to happen just because you
(as in: a member of a quite small minority of users of the stable branch)
would find it convenient.
You can always put in some work and recompile and end up with having the debug info you want.
and:
no one is going to act on it, because a different version, a newer version, is already available - where the issue might be solved already
There is a reason why Arch doesn’t accept complaints or bug reports from Manjaro users (stable in particular).
Essentially: it’s just old news to them …
for the current version at any one time - not for every version in the past
… I’d guess - or do you know better?
ps:
I just saw by clicking your avatar picture, that you state that you are using unstable.
You should have no problem at all with this - you are essentially using a slightly modified Arch
and for you, the available debug info is current and usable.
