Hello everyone!
I have a problem with witch one i have been fighting already 1.5 y
Sometime during simple (not gaming ) work my laptop deadly lagging and only hard reset can help.
As first lags picture, after lags sound and laptop just stack and don’t response for anything…
By the way when i gaming it never happens!
A will be very happy if someone help determinate problem source or (this would be fantastic) fix it.
There is some info about my set-up:
$ inxi -Fxz
Kernel: 5.15.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
Desktop: KDE Plasma v: 5.24.5 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec0xxx v: N/A
serial: <superuser required>
Mobo: HP model: 86D5 v: 96.16 serial: <superuser required> UEFI: AMI
v: F.02 date: 09/20/2019
ID-1: BAT0 charge: 41.4 Wh (100.0%) condition: 41.4/41.4 Wh (100.0%)
volts: 12.8 min: 11.6 model: Hewlett-Packard Primary status: full
Device-1: hidpp_battery_0
model: Logitech G305 Lightspeed Wireless Gaming Mouse
charge: 100% (should be ignored) status: discharging
Info: quad core model: AMD Ryzen 7 3750H with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 384 KiB
L2: 2 MiB L3: 4 MiB
Speed (MHz): avg: 1775 high: 2659 min/max: 1400/2300 boost: enabled
cores: 1: 1320 2: 1857 3: 2602 4: 2659 5: 1386 6: 1177 7: 1198 8: 2003
bogomips: 36751
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 470.129.06 arch: Turing
bus-ID: 01:00.0
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 05:00.0
Device-3: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 3-1:2
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.1 driver: X:
loaded: modesetting,nvidia gpu: amdgpu resolution: 1920x1080~144Hz
OpenGL: renderer: AMD Radeon Vega 10 Graphics (raven LLVM 13.0.1 DRM 3.42
5.15.41-1-MANJARO)
v: 4.6 Mesa 22.0.4 direct render: Yes
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 01:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_pci_acp3x v: kernel bus-ID: 05:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 05:00.6
Sound Server-1: ALSA v: k5.15.41-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A port: e000
bus-ID: 03:00.0
vendor: Hewlett-Packard driver: r8169 v: kernel port: d000 bus-ID: 04:00.0
IF-ID-1: br-3634ee032338 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: br-5068a96795ba state: down mac: <filter>
IF-ID-3: br-5622e6b193cb state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-4: br-5c6318df5ff7 state: up speed: -1 duplex: unknown
mac: <filter>
IF-ID-5: br-6c9e65059b26 state: down mac: <filter>
IF-ID-6: br-7f061b51a658 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-7: br-898979e2f3d8 state: down mac: <filter>
IF-ID-8: br-8dc12c0da993 state: down mac: <filter>
IF-ID-9: br-bb0600e32459 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-10: br-d2d5c76b49a6 state: down mac: <filter>
IF-ID-11: br-e4a5e44f3a8c state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-12: br-e5001acb692c state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-13: br-e55b7d566fbe state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-14: docker0 state: down mac: <filter>
IF-ID-15: veth1f5dbe9 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-16: veth3af50c4 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-17: veth7cdb7ef state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-18: veth8759a05 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-19: veth9c0b6eb state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-20: vetha013069 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-21: vethd51fdc4 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-4:3
Local Storage: total: 476.94 GiB used: 314.87 GiB (66.0%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8H size: 476.94 GiB
temp: 34.9 C
ID-1: / size: 468.09 GiB used: 314.87 GiB (67.3%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 68.0 C mobo: N/A gpu: amdgpu temp: 72.0 C
Processes: 385 Uptime: 28m Memory: 13.64 GiB used: 8.73 GiB (64.1%)
Init: systemd Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1811
Shell: Zsh v: 5.9 inxi: 3.3.16
SOLVE:
For every one who will have same problem what i done to solve it:
- Create Swap file (when you will read topic in manjaro site scroll little bit more to topic about file, cause i was confused about swap partition)
- Clear docker
cause i’m a web developer i had a lot of containers, i’m just killed all of them and cleared cache. You can do this with two simple commands:
docker kill $(docker ps -q)
docker system prune -a
- Clean PC fans. I had high temperature. After removing dust temperature had normilized!
P.S: (I’m so sorry for my english, it’s not my native language and i can make a lot of dummy mistakes :D)
