Hey there!
Yesterday I have installed a couple of update packages through the pamac-manager. Unfortunately, the manager does not start anymore. The window opens for like 100ms and then directly closed. When I tried to open it through the terminal, I found the following error:
I know. It is just to see if it starts.
Had the same yesterday. Re-applied the “light” stock theme and after a reboot switched back to dark theme and pamac manager opened again normally.
btw. I also still get the same error in terminal:
pamac-manager
This error also comes, when I start it with sudo (where it does work), so it can not really be the purpose. I think the main error is zsh: segmentation fault (core dumped) pamac-manager --updates
Yeah, it did not work. I think one package from kde or manjaro is a little bugged. Or another guess: The kernel has an error → I am using the newest version 5.l5.7-1
Ah thank you After running the command and restarting, it did work again. It did said something like updated config /var/lib/mhwd/local/pci/video-nvidia this could have been the problem.
pamac-manager is a GUI application …
The errors about set_cursor are more or less cosmetic and probably afflicts everyone … one sec … yup I have it too, next to a kio-mimeapps one.
IDK … I dont use pamac.
PS - pamac is the cli version … such as pamac update
well, I wasn’t bothered by the error message anyway. GUI works and system updates I usually apply via terminal. Just in this support case when pamac does not start an error message usually indicates something is not right.
anyways, Simax’s problem is solved, luckily. thanks.
