Davinci Resolve Crash on start
Hello.
I have an isse with Davinci Resolve. It crash on start. It start to crash after reinstallation of my OS. Before that it worked.
~ >>> /opt/resolve/bin/resolve
ActCCMessage Already in Table: Code= c005, Mode= 13, Level=  1, CmdKey= -1, Option= 0
ActCCMessage Already in Table: Code= c006, Mode= 13, Level=  1, CmdKey= -1, Option= 0
ActCCMessage Already in Table: Code= c007, Mode= 13, Level=  1, CmdKey= -1, Option= 0
ActCCMessage Already in Table: Code= 2282, Mode=  0, Level=  0, CmdKey= 8, Option= 0
PnlMsgActionStringAdapter Already in Table: Code= 615e, Mode=  0, Level=  0, CmdKey= -1, Option= 0
log4cxx: No appender could be found for logger (BtCommon).
log4cxx: Please initialize the log4cxx system properly.
16.2.8 (#005) Linux/Clang
Main thread starts: 008085C0
[0x7f5e008085c0] | Undefined            | INFO  | 2021-02-02 19:20:08,172 | --------------------------------------------------------------------------------
[0x7f5e008085c0] | Undefined            | INFO  | 2021-02-02 19:20:08,173 | Loaded log config from /home/biuro/.local/share/DaVinciResolve/configs/log-conf.xml
[0x7f5e008085c0] | Undefined            | INFO  | 2021-02-02 19:20:08,173 | --------------------------------------------------------------------------------
Discard all samples (playback) or generate zero samples (capture)
Rate Converter Plugin Using Samplerate Library
Rate Converter Plugin Using Speex Resampler
JACK Audio Connection Kit
Open Sound System
PipeWire Sound Server
PulseAudio Sound Server
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
Plugin for channel upmix (4,6,8)
Plugin for channel downmix (stereo) with a simple spacialization
Default ALSA Output (currently PulseAudio Sound Server)
HDA Intel PCH, 92HD73E1X5 AnalogDefault Audio Device
HDA Intel PCH, 92HD73E1X5 AnalogFront output / input
HDA Intel PCH, 92HD73E1X5 Analog2.1 Surround output to Front and Subwoofer speakers
HDA Intel PCH, 92HD73E1X5 Analog4.0 Surround output to Front and Rear speakers
HDA Intel PCH, 92HD73E1X5 Analog4.1 Surround output to Front, Rear and Subwoofer speakers
HDA Intel PCH, 92HD73E1X5 Analog5.0 Surround output to Front, Center and Rear speakers
HDA Intel PCH, 92HD73E1X5 Analog5.1 Surround output to Front, Center, Rear and Subwoofer speakers
HDA Intel PCH, 92HD73E1X5 Analog7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
HDA Intel PCHUSB Stream Output
HDA NVidia, HDMI 0HDMI Audio Output
HDA NVidia, HDMI 1HDMI Audio Output
HDA NVidia, HDMI 2HDMI Audio Output
HDA NVidia, HDMI 3HDMI Audio Output
HDA NVidia, HDMI 4HDMI Audio Output
HDA NVidiaUSB Stream Output
Plantronics C320-M, USB AudioDefault Audio Device
Plantronics C320-M, USB AudioFront output / input
Plantronics C320-M, USB Audio2.1 Surround output to Front and Subwoofer speakers
Plantronics C320-M, USB Audio4.0 Surround output to Front and Rear speakers
Plantronics C320-M, USB Audio4.1 Surround output to Front, Rear and Subwoofer speakers
Plantronics C320-M, USB Audio5.0 Surround output to Front, Center and Rear speakers
Plantronics C320-M, USB Audio5.1 Surround output to Front, Center, Rear and Subwoofer speakers
Plantronics C320-M, USB Audio7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
Plantronics C320-M, USB AudioIEC958 (S/PDIF) Digital Audio Output
Plantronics C320-MUSB Stream Output
Open Sound System
Open Sound System
OK i solved it. Downgrade curl and now it works…
