Hello everyone, I once did it successfully, but now I can’t understand how. I want the file to be edited in Kate on the server when FileZilla is connected, for this I prescribed using the following editor
/usr/share/applications/org.kde.kate.desktop
The default file associations are empty, I didn’t touch anything, I tried to write something like this
For file extensions in general for KDE. System Settings > Applications > File Associations
Search for *.txt and make sure Kate is added and as first choice.
Thanks to yours, and my next digging, this is what I did, launched Filezilla again, and went into the default editor settings and saw where it got Libreoffice from, installed Kate in the same way
/usr/bin/kate
It automatically installed this in the associations, I believe it will continue to register as files are opened
log /usr/bin/kate
Everything worked out! Thank you!
I’m deleting the photo due to the load on the forum, this is how I wrote my article, and if anyone gets lost it will be really useful
An easier way to change associations is to right click the file, select properties and then change the Open with applications, you can reorder them or add new associations.
Perhaps they are best kept with your personal notes. I doubt they will be allowed to remain in this thread for very long. Images are generally discouraged as they can become a drain on site resources after a time. Cheers.
