I have fresh installed Manjaro linux XFCE edition. The problem is when I try to update my databases it will complain
$ sudo pacman -Sy
core 167.1 KiB 105 KiB/s 00:02
[####################################################################] 100%
extra 1879.6 KiB 170 KiB/s 00:11 [####################################################################] 100%
community 7.5 MiB 83.8 KiB/s 01:32 [####################################################################] 100%
multilib 171.0 KiB 41.7 KiB/s 00:04 [####################################################################] 100%
error: failed retrieving file 'core.db' from manjaro.c3sl.ufpr.br : OpenSSL SSL_read: error:1408F119:SSL routines:ssl3_get_record:decryption failed or bad record mac, errno 0
error: failed retrieving file 'core.db' from ftp.cuhk.edu.hk : Failed to connect to ftp.cuhk.edu.hk port 80 after 5304 ms: Connection timed out
error: failed retrieving file 'extra.db' from manjaro.c3sl.ufpr.br : OpenSSL SSL_read: error:1408F119:SSL routines:ssl3_get_record:decryption failed or bad record mac, errno 0
error: failed retrieving file 'extra.db' from ftp.cuhk.edu.hk : Failed to connect to ftp.cuhk.edu.hk port 80 after 5202 ms: Connection timed out
error: failed retrieving file 'extra.db' from ftp.nluug.nl : OpenSSL SSL_read: error:1408F119:SSL routines:ssl3_get_record:decryption failed or bad record mac, errno 0
error: failed retrieving file 'community.db' from manjaro.c3sl.ufpr.br : OpenSSL SSL_read: error:1408F119:SSL routines:ssl3_get_record:decryption failed or bad record mac, errno 0
warning: too many errors from manjaro.c3sl.ufpr.br, skipping for the remainder of this transaction
error: failed retrieving file 'community.db' from ftp.cuhk.edu.hk : Failed to connect to ftp.cuhk.edu.hk port 80 after 5202 ms: Connection timed out
warning: too many errors from ftp.cuhk.edu.hk, skipping for the remainder of this transaction
error: failed retrieving file 'community.db' from ftp.nluug.nl : OpenSSL SSL_read: error:1408F119:SSL routines:ssl3_get_record:decryption failed or bad record mac, errno 0
error: failed retrieving file 'multilib.db' from ftp.nluug.nl : OpenSSL SSL_read: error:1408F119:SSL routines:ssl3_get_record:decryption failed or bad record mac, errno 0
warning: too many errors from ftp.nluug.nl, skipping for the remainder of this transaction
Not only that but even the default browser won’t correctly, it will also complain “Error reading data from TLS socket: Decryption has failed”
But the odd thing is that this works on another network not just mine, but also it works on other machines with the same network my computer is reporting an error at. Oddly enough, using the same network, by using usb tethering using my phone also works. I can’t understand what the issue is.
Here are my drivers
$ lspci -k
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
Subsystem: Lenovo Device 3814
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
Subsystem: Lenovo Device 3815
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
Subsystem: Lenovo Device 3886
Kernel driver in use: pcieport
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
Subsystem: Lenovo Device 3842
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
Subsystem: Lenovo Device 3840
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 3
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 7
01:00.0 VGA compatible controller: NVIDIA Corporation GA106M [GeForce RTX 3060 Mobile / Max-Q] (rev a1)
Subsystem: Lenovo Device 3a80
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation GA106 High Definition Audio Controller (rev a1)
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
02:00.0 Non-Volatile memory controller: SK hynix Gold P31 SSD
Subsystem: SK hynix Gold P31 SSD
Kernel driver in use: nvme
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
DeviceName: Realtek RTL8111E Ethernet LOM
Subsystem: Lenovo Device 3900
Kernel driver in use: r8169
Kernel modules: r8169
04:00.0 Network controller: MEDIATEK Corp. MT7921 802.11ax PCI Express Wireless Network Adapter
Subsystem: Lenovo Device e0bc
Kernel driver in use: mt7921e
Kernel modules: mt7921e
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cezanne (rev c6)
Kernel driver in use: amdgpu
Kernel modules: amdgpu
05:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
Subsystem: Lenovo Device 382a
Kernel driver in use: ccp
Kernel modules: ccp
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
Subsystem: Lenovo Device 3828
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
Subsystem: Lenovo Device 3829
05:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor (rev 01)
Subsystem: Lenovo Device 382c
Kernel modules: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x
05:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
Subsystem: Lenovo Device 382b
06:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
Subsystem: Lenovo Device 383f
Kernel driver in use: ahci
06:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
I am using the “5.15.60-1-MANJARO” kernel.
Thanks
