Hello. I recently got a notification letting me know I needed to log out and log back in to update my extensions. So I did. Then for an unknown reason, I no longer have a dark theme across my computer, it’s all light theme. So, I tried to go and change it back to dark theme. It doesn’t matter what dark theme I select, it’ll instantly revert to a light version of the same theme. I don’t know what the issue is.
Check the Night Theme Switcher GNOME Shell Extension settings. If it’s enabled and it’s day time, that’s exactly what would happen.
It is enabled, but it’s dark outside. If I disable it, would that return me to being always dark?
I solved it from there, thank you very much.
