arch
24
yeah it worked
but still that --save-position-on-quite
isnt working like the video is always starting from the start
does it worked for you?
btw it should be mpv;--save-position-on-quit
in Custom External Player Arguments
FreeTube is running this command to play the video in mpv
mpv --save-position-on-quit --speed=1 ytdl://QBcUr7DlY3c
I tried this command on terminal and there also the --save-position-on-quit
didn’t worked
So ig save position doesnt worked with ytdl urls
Use Shift+q instead of -save-position-on-quit
arch
26
Shift+q is quiting the player
but video is playing from start only
Edit : I was having no-resume-playback
line in mpv.conf which was preventing it to start from the position where i left
I removed that line and now its working fine
Thanks @ishaanbhimwal for the help
system
Closed
27
