On several machines running current manjaro/thunderbird, thunderbird has abruptly become slow to load. It seems to hang on:
[Pop3ModuleLoader] Using Pop3Service.jsm
Below, the first output is made with my .thunderbird directory:
[jake@P3 ~]$ thunderbird
(thunderbird:8173): Gtk-WARNING **: 10:23:30.748: Theme parsing error: gtk.css:1669:23: '' is not a valid color name
(thunderbird:8173): Gtk-WARNING **: 10:23:30.750: Theme parsing error: gtk.css:2168:17: Not using units is deprecated. Assuming 'px'.
(thunderbird:8173): Gtk-WARNING **: 10:23:30.750: Theme parsing error: gtk.css:2168:19: Not using units is deprecated. Assuming 'px'.
(thunderbird:8173): Gtk-WARNING **: 10:23:30.750: Theme parsing error: gtk.css:2168:25: Not using units is deprecated. Assuming 'px'.
[ImapModuleLoader] Using nsImapService.cpp
[NntpModuleLoader] Using NntpService.jsm
(thunderbird:8173): Gtk-WARNING **: 10:23:56.176: Theme parsing error: gtk.css:1669:23: '' is not a valid color name
(thunderbird:8173): Gtk-WARNING **: 10:23:56.182: Theme parsing error: gtk.css:2168:17: Not using units is deprecated. Assuming 'px'.
(thunderbird:8173): Gtk-WARNING **: 10:23:56.182: Theme parsing error: gtk.css:2168:19: Not using units is deprecated. Assuming 'px'.
(thunderbird:8173): Gtk-WARNING **: 10:23:56.182: Theme parsing error: gtk.css:2168:25: Not using units is deprecated. Assuming 'px'.
(thunderbird:8173): Gtk-WARNING **: 10:23:56.291: Theme parsing error: gtk.css:1669:23: '' is not a valid color name
(thunderbird:8173): Gtk-WARNING **: 10:23:56.293: Theme parsing error: gtk.css:2168:17: Not using units is deprecated. Assuming 'px'.
(thunderbird:8173): Gtk-WARNING **: 10:23:56.293: Theme parsing error: gtk.css:2168:19: Not using units is deprecated. Assuming 'px'.
(thunderbird:8173): Gtk-WARNING **: 10:23:56.294: Theme parsing error: gtk.css:2168:25: Not using units is deprecated. Assuming 'px'.
(thunderbird:8173): Gtk-WARNING **: 10:23:56.320: Theme parsing error: gtk.css:1669:23: '' is not a valid color name
(thunderbird:8173): Gtk-WARNING **: 10:23:56.322: Theme parsing error: gtk.css:2168:17: Not using units is deprecated. Assuming 'px'.
(thunderbird:8173): Gtk-WARNING **: 10:23:56.322: Theme parsing error: gtk.css:2168:19: Not using units is deprecated. Assuming 'px'.
(thunderbird:8173): Gtk-WARNING **: 10:23:56.322: Theme parsing error: gtk.css:2168:25: Not using units is deprecated. Assuming 'px'.
ATTENTION: default value of option mesa_glthread overridden by environment.
[calBackendLoader] Using Thunderbird's ical.js backend
console.debug: "Found 0 public keys and 0 secret keys (0 protected, 0 unprotected)"
console.warn: services.settings: Failed to load last_modified.json: TypeError: NetworkError when attempting to fetch resource.
console.debug: "Trying to load /usr/lib/thunderbird/libotr.so"
console.debug: "Trying to load libotr.so from system's standard library locations"
console.debug: "Trying to load libotr.so.5 from system's standard library locations"
console.log: (new Error("Cannot load required OTR library", "resource:///modules/OTRLib.jsm", 109))
console.debug: WebExtensions:
Compact Headers loaded
1687271039584 tbsortfolders.folderPane DEBUG Init
1687271039592 tbsortfolders.folderPane DEBUG Accounts: account1,account2,account4
1687271039592 tbsortfolders.folderPane DEBUG Add observer
1687271039593 tbsortfolders.folderPane DEBUG startup folder: mailbox://jakfish%40earthlink.net@pop.earthlink.net/Inbox
1687271039617 tbsortfolders.folderPane DEBUG Refreshing the pane and selecting folder: Success
1687271039618 tbsortfolders.folderPane DEBUG Init done
Below is output with a fresh .thunderbird directory. Both outputs reflect the same slow loading speed:
(thunderbird:16472): Gtk-WARNING **: 10:38:04.842: Theme parsing error: gtk.css:1669:23: '' is not a valid color name
(thunderbird:16472): Gtk-WARNING **: 10:38:04.844: Theme parsing error: gtk.css:2168:17: Not using units is deprecated. Assuming 'px'.
(thunderbird:16472): Gtk-WARNING **: 10:38:04.844: Theme parsing error: gtk.css:2168:19: Not using units is deprecated. Assuming 'px'.
(thunderbird:16472): Gtk-WARNING **: 10:38:04.844: Theme parsing error: gtk.css:2168:25: Not using units is deprecated. Assuming 'px'.
(thunderbird:16472): Gtk-WARNING **: 10:38:30.210: Theme parsing error: gtk.css:1669:23: '' is not a valid color name
(thunderbird:16472): Gtk-WARNING **: 10:38:30.212: Theme parsing error: gtk.css:2168:17: Not using units is deprecated. Assuming 'px'.
(thunderbird:16472): Gtk-WARNING **: 10:38:30.212: Theme parsing error: gtk.css:2168:19: Not using units is deprecated. Assuming 'px'.
(thunderbird:16472): Gtk-WARNING **: 10:38:30.212: Theme parsing error: gtk.css:2168:25: Not using units is deprecated. Assuming 'px'.
(thunderbird:16472): Gtk-WARNING **: 10:38:30.284: Theme parsing error: gtk.css:1669:23: '' is not a valid color name
(thunderbird:16472): Gtk-WARNING **: 10:38:30.286: Theme parsing error: gtk.css:2168:17: Not using units is deprecated. Assuming 'px'.
(thunderbird:16472): Gtk-WARNING **: 10:38:30.286: Theme parsing error: gtk.css:2168:19: Not using units is deprecated. Assuming 'px'.
(thunderbird:16472): Gtk-WARNING **: 10:38:30.286: Theme parsing error: gtk.css:2168:25: Not using units is deprecated. Assuming 'px'.
(thunderbird:16472): Gtk-WARNING **: 10:38:30.307: Theme parsing error: gtk.css:1669:23: '' is not a valid color name
(thunderbird:16472): Gtk-WARNING **: 10:38:30.309: Theme parsing error: gtk.css:2168:17: Not using units is deprecated. Assuming 'px'.
(thunderbird:16472): Gtk-WARNING **: 10:38:30.309: Theme parsing error: gtk.css:2168:19: Not using units is deprecated. Assuming 'px'.
(thunderbird:16472): Gtk-WARNING **: 10:38:30.309: Theme parsing error: gtk.css:2168:25: Not using units is deprecated. Assuming 'px'.
