Current input timing is not supported
Hi there after some system update my monitor no longer works with my laptop. It says “The current input timing is not supported by the monitor display. Please change your input timing to 1920x1080,60Hz or any other monitor listed timing as per the monitor specifications”. I looked at the XOrg logs, and I do see 1920x1080 in there, although I do not understand what the entire log line means. Can someone give me a pointer on this?
[  1062.264] (II) event11 - Dygma Raise: is tagged by udev as: Mouse
[  1062.264] (II) event11 - Dygma Raise: device is a pointer
[  1074.451] (II) modeset(0): EDID vendor "CMN", prod id 5362
[  1074.451] (II) modeset(0): Printing DDC gathered Modelines:
[  1074.451] (II) modeset(0): Modeline "1920x1080"x0.0  138.78  1920 1966 1996 2080  1080 1082 1086 1112 -hsync -vsync (66.7 kHz eP)
[  1075.346] (II) modeset(0): Allocate new frame buffer 640x480 stride
[  1080.688] (II) modeset(0): EDID vendor "CMN", prod id 5362
[  1080.688] (II) modeset(0): Printing DDC gathered Modelines:
[  1080.688] (II) modeset(0): Modeline "1920x1080"x0.0  138.78  1920 1966 1996 2080  1080 1082 1086 1112 -hsync -vsync (66.7 kHz eP)
[  1081.445] (II) modeset(0): Allocate new frame buffer 1920x1080 stride
nvm I solved it by pretyping xrandr --output HDMI-1 --mode 1920x1080 on command line, plugging in the HDMI cable, and then pressing Enter
Welcome to the forum! Please mark the topic as solved if you found a solution.
