Why am I asked to set my timezone during installation, when immediately after installation, I have to go in and manually change the time to my timezone? If I gave you my timezone, does it not make sense that I might want the time to be accurate for that timezone automatically? Perhaps, if you want me to set it manually, you should not ask for it during installation? Or the reverse, ask me for it, then actually use the data I provided?
Just curious what the justification for this is.
