Cups Printing error - "universal filter failed"
I have not tested this on other desktops, but I don’t see why this would be only for Cinnamon.
If you cannot print due to a cups error “universal filter failed”, or “pdftopdf failed”, Recent updates to libcupsfilters apparently is the culprit. The only fix is to download to version 2.1.1-4. This does not apply to all printers or printer manufacturers. On one system, the Brother MFC-J5620DW was working fine, replaced it with MFC-L9570CDW and error appeared.
So, if you are not having an issue, no need to downgrade.
sudo pacman -U https://archive.archlinux.org/packages/l/libcupsfilters/libcupsfilters-2.1.1-4-x86_64.pkg.tar.zst
After downgrading libcupsfilters, go into Pamac Software, > Preferences > Advanced > Ignored Updates and add libcupsfilters to the list in order to keep from package manager automatically updating libcupsfilters.
My partner’s system had an issue with an Epson BX535WD printer that was resolved by switching to testing branch and updating libcupsfilters from 2.2.1-2 to 2.2.1.r28.gce65eb74-1
Unstable branch also has a newer version - libcupsfilters 2.2.1.r32.gd49e9284-1
I am using the brlaser driver and had to downgrade cups-filters as well to 2.0.1-2 (sudo pacman -U https://archive.archlinux.org/packages/l/libcupsfilters/cups-filters-2.0.1-2-x86_64.pkg.tar.zst). Github issue to track: [BUG] `/usr/cups/filters/universal` appears removed per upstream but used by brlaser · Issue #87 · Owl-Maintain/brlaser · GitHub
Here is some more info on this subject: libcupsfilters 2.1.2 - Stop-gap release for regressions caused by PDFio transition
I made an AUR package for the 2.1 branch, so it’s easier to use the last “good” version while developers fix the 2.2 branch
Edit: Probably my text is not clear, but the AUR version is 2.1.2 that not Arch nor Manjaro have shipped, so it’s not possible to downgrade to it by normal means.
Suggesting this as a possible workaround for another member prompted them to search a little further:
libcupsfilters on testing branch has been updated to 2.2.1.r57.g9fcc4bf4-1
and unstable branch now has 2.2.1.r80.ge1dde819
$ mbn info libcupsfilters -q
Branch         : archlinux
Version        : 2.2.1.r80.ge1dde819-1
Repository     : extra
Build Date     : Mon 09 Nov 2026 14:46:32
Packager       : Andreas Radke <andyrtr@archlinux.org>
Branch         : unstable
Repository     : extra
Branch         : testing
Version        : 2.2.1.r57.g9fcc4bf4-1
Repository     : extra
Build Date     : Sat 31 Oct 2026 20:51:38
Branch         : stable
Version        : 2.2.1.r28.gce65eb74-1
Repository     : extra
Build Date     : Tue 06 Oct 2026 15:22:25
The thing is that 2.2.X branch is problematic for the time being. In the 2.1.2 release post is mentioned that the fix could take a few months. It’s not just a single commit problem.
libcupsfilters-duplexfix 2.2.1.r32.gd49e9284-2 is available in the AUR; one user confirms that it solved the specific problem they were experiencing (see: Duplex printing on Canon TS6350 is upside down).
However, upstream are apparently dealing with multiple regressions of libcupsfilters – while r32 fixed the issue for that user, others with related issues might not be as fortunate; doubtless, this is also true for r80.
I think that @cfinnberg’s libcupsfilters2.1 (2.1.2-1) available via the AUR is likely the most versatile workaround for the time being.
