Hi folks,
I set up a used pc with a minimal KDE installation and now I have problems getting CUPS to work. I installed cups and manjaro-printer but I can’t reach localhost 631. Terminal outputs, that cupsd.service does not exist. Tried reinstalling CUPS, but no change.
I am kinda lost now. Can you help?
Best regards!
Hi!
Have you enabled the cups service as mentioned in the ArchWiki?
https://wiki.archlinux.org/title/CUPS
Then enable and start
cups.service
or alternatively use socket activation to only start CUPS when a program wants to use the service.
sudo systemctl enable cups.service
sudo systemctl start cups.service
Thanx, that was the problem!
