Hello all. I’m trying to build GROMACS with GPU/CUDA support and ran into an error. After a little investigation, it looks like the problem is with CUDA and/or GCC as the error comes from within an nvcc call.
/usr/include/c++/12.1.0/bits/stl_map.h: In member function ‘std::pair<typename std::_Rb_tree<_Key, std::pair<const _Key, _Tp>, std::_Select1st<std::pair<const _Key, _Tp> >, _Compare, typename __gnu_cxx::__alloc_traits<_Allocator>::rebind<std::pair<const _Key, _Tp> >::other>::iterator, bool> std::map<_Key, _Tp, _Compare, _Alloc>::emplace(_Args&& ...)’:
/usr/include/c++/12.1.0/bits/stl_map.h:593:29: error: parameter packs not expanded with ‘...’:
593 | if constexpr (__usable_key<decltype(__a)>)
It looks very similar to the error report titled "CUDA 11.6.0 with gcc 11.2.1 fails to process system headers included by " (search that, the forum wont let me post the direct link), but I’m already using the version of CUDA where the problem was said to be “fixed” (at least for Ubuntu.)
Also found a similar error “error: parameter packs not expanded with ‘…’” (github nccl issue #650) from a Debian user
Another “error: parameter packs not expanded with ‘…’” error (github instant-ngp issue #119) on Ubuntu.
My system is up-to-date, here are the CUDA & GCC versions though
nvcc: NVIDIA (R) Cuda compiler driver
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Tue_Mar__8_18:18:20_PST_2022
Cuda compilation tools, release 11.6, V11.6.124
Build cuda_11.6.r11.6/compiler.31057947_0
gcc (GCC) 12.1.0
Copyright (C) 2022 Free Software Foundation, Inc.
If anyone could shed some light on why this is happening, it would be greatly appreciated
