cubocore woes
I have installed Cubocore on my Lenovo T450s. So far, so good. I did the first update and suddenly the laptop would only boot as far as showing
Loading initial ramdisk
I could still boot the machine using one of the backup images. Today I updated one of those images and now nothing boots.
So, what do I do? The easy way out is to re-install but what do I learn from that? Nothing!! I'd like to try and sort out why the initial update borked it so that I can fix it. Problem is - I have no way of posting anything much in the way of output/logs etc from the machine.
@Librewish made the iso, maybe he knows whats going on.
if you want to get into your currently installed setup you can boot the live usb, connect to internet, open a terminal and sudo manjaro-chroot -a
if the only option is zero (0), enter 1 anyway. this should drop you to a root shell on your installed manjaro.
inxi -Fxxxza
journalctl -b -1 -p3
tail -300 /var/log/pacman.log
post as preformatted text </> so it's formatted properly.
then run the update again just in case something went wrong with the last one.
sudo pacman-mirrors -f5
sudo pacman -Syyu
did anything get updated? errors?
i would say
boot into the snapshot from grub menu.
and open timeshift and click restore.
then reboot.
when you update
make sure to install another kernel.
its kernel update that must have caused issue.
i suggest you to install kernel 4.19.
this does not work.
as the btrfs is default fs.
use this
assuming /dev/sda2 is root partition
sudo mount /dev/sda2 /mnt
sudo manjaro-chroot /mnt/@
@dglt
Inxi gives the following
grub-probe: error: cannot find a GRUB drive for /dev/sdb1.  Check your device.map.
==> Detected systems:
 --> 0) Cubocore:linux:btrfs:UUID=dd9331a7-c09b-4a64-9ca0-7a9b225037ff
 --> 1) Parrot
==> Select system to mount [0-1] :
0
==> ERROR: You can't mount 0!
this bug has been there for a while, try hitting enter without entering a number.
if not, you can use mhwd-chroot
sudo pacman -S mhwd-chroot
sudo mhwd-chroot
sudo pacman -S mhwd-chroot                                                             [255]
warning: database file for 'core' does not exist (use '-Sy' to download)
warning: database file for 'extra' does not exist (use '-Sy' to download)
warning: database file for 'community' does not exist (use '-Sy' to download)
warning: database file for 'multilib' does not exist (use '-Sy' to download)
warning: database file for 'chaotic-aur' does not exist (use '-Sy' to download)
error: target not found: mhwd-chroot
WTF!!
it's because your on the live environment and database has not yet been updated
sudo pacman -Syy mhwd-chroot
OK. I think we are getting somewhere
inxi -Fxxxza
System:    Host: cubocore Kernel: 5.3.0-0-MANJARO x86_64 bits: 64 compiler: gcc v: 9.1.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
           driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 misobasedir=manjaro
           misolabel=MJROROLL quiet systemd.show_status=1
           Desktop: LXQt tk: Qt 5.13.1 info: plank wm: kwin_x11 dm: SDDM
           Distro: CubocoreLinux Rolling by_Librewish
Machine:   Type: Laptop System: LENOVO product: 20BWS0XS0C v: ThinkPad T450s serial: <filter>
           Chassis: type: 10 serial: <filter>
           Mobo: LENOVO model: 20BWS0XS0C v: SDK0E50510 WIN serial: <filter>
           UEFI [Legacy]: LENOVO v: JBET46WW (1.11 ) date: 03/02/2015
Battery:   ID-1: BAT0 charge: 20.2 Wh condition: 20.2/23.2 Wh (87%) volts: 12.3/11.1
           model: SONY 45N1111 type: Li-poly serial: <filter> status: Full
           ID-2: BAT1 charge: 12.8 Wh condition: 12.8/23.2 Wh (55%) volts: 12.3/11.1
           model: SANYO 45N1775 type: Li-ion serial: <filter> status: Unknown
CPU:       Topology: Dual Core model: Intel Core i5-5300U bits: 64 type: MT MCP arch: Broadwell
           family: 6 model-id: 3D (61) stepping: 4 microcode: 2D L2 cache: 3072 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18366
           Speed: 2296 MHz min/max: 500/2900 MHz Core speeds (MHz): 1: 2295 2: 2295 3: 2295
           4: 2295
           Vulnerabilities: Type: l1tf mitigation: PTE Inversion
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
Graphics:  Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
           bus ID: 00:02.0 chip ID: 8086:1616
           Display: x11 server: X.org 1.20.5 driver: modesetting alternate: fbdev,intel,vesa
           compositor: kwin_x11 resolution: <xdpyinfo missing>
           OpenGL: renderer: Mesa DRI Intel HD Graphics 5500 (Broadwell GT2) v: 4.5 Mesa 19.1.6
           compat-v: 3.0 direct render: Yes
Audio:     Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel v: kernel
           bus ID: 00:03.0 chip ID: 8086:160c
           Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
           driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:9ca0
           Sound Server: ALSA v: k5.3.0-0-MANJARO
Network:   Device-1: Intel Ethernet I218-LM vendor: Lenovo driver: e1000e v: 3.2.6-k port: 3080
           bus ID: 00:19.0 chip ID: 8086:15a2
           IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
           Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: efa0 bus ID: 03:00.0
           chip ID: 8086:095b
           IF: wlan0 state: down mac: <filter>
Drives:    Local Storage: total: 245.93 GiB used: 15.14 GiB (6.2%)
           ID-1: /dev/sda vendor: Samsung model: SSD 840 PRO Series size: 238.47 GiB
           block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
           rev: 3B0Q scheme: MBR
           ID-2: /dev/sdb type: USB vendor: SanDisk model: Cruzer Force size: 7.45 GiB
           block size: physical: 512 B logical: 512 B serial: <filter> rev: 1.26 scheme: MBR
Partition: ID-1: / raw size: N/A size: 5.61 GiB used: 111.3 MiB (1.9%) fs: overlay
           source: ERR-102
Sensors:   System Temperatures: cpu: 42.5 C mobo: 0.0 C
           Fan Speeds (RPM): cpu: 0
Info:      Processes: 189 Uptime: 9h 13m Memory: 7.48 GiB used: 1.43 GiB (19.1%) Init: systemd
           v: 242 Compilers: gcc: 9.1.0 Shell: zsh v: 5.7.1 running in: coreterminal
           inxi: 3.0.36
Maybe cancel my last:disappointed:
[2019-10-18 16:00] [PACMAN] Running 'pacman -S mhwd-chroot'
[2019-10-18 16:22] [PACMAN] Running 'pacman -Syy mhwd-chroot'
[2019-10-18 16:22] [PACMAN] synchronizing package lists
[2019-10-18 16:22] [ALPM] running '00-timeshift-autosnap.hook'...
[2019-10-18 16:22] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap because system is booted in Live CD mode...
[2019-10-18 16:22] [ALPM] transaction started
[2019-10-18 16:22] [ALPM] upgraded archlinux-keyring (20190827-1 -> 20191007-1)
[2019-10-18 16:22] [ALPM-SCRIPTLET] ==> Appending keys from archlinux.gpg...
[2019-10-18 16:22] [ALPM-SCRIPTLET] ==> Locally signing trusted keys in keyring...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Locally signing key D8AFDDA07A5B6EDFA7D8CCDAD6D055F927843F1C...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Locally signing key DDB867B92AA789C165EEFA799B729B06A680C281...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Locally signing key 684148BB25B49E986A4944C55184252D824B18E8...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Locally signing key 91FFE0700E80619CEB73235CA88E23E377514E00...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Locally signing key 0E8B644079F599DFC1DDC3973348882F6AC6A4C2...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Locally signing key AB19265E5D7D20687D303246BA1DFB64FFF979E7...
[2019-10-18 16:22] [ALPM-SCRIPTLET] ==> Importing owner trust values...
[2019-10-18 16:22] [ALPM-SCRIPTLET] ==> Disabling revoked keys in keyring...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 8F76BEEA0289F9E1D3E229C05F946DED983D4366...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 63F395DE2D6398BBE458F281F2DBB4931985A992...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 50F33E2E5B0C3D900424ABE89BDCF497A4BBCC7F...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 27FFC4769E19F096D41D9265A04F9397CDFD6BB0...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 39F880E50E49A4D11341E8F939E4F17F295AFBF4...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 8840BD07FC24CB7CE394A07CCF7037A4F27FB7DA...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 5559BC1A32B8F76B3FCCD9555FA5E5544F010D48...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 0B20CA1931F5DA3A70D0F8D2EA6836E1AB441196...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 07DFD3A0BC213FA12EDC217559B3122E2FA915EC...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 4FCF887689C41B09506BE8D5F3E1D5C5D30DB0AD...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 5A2257D19FF7E1E0E415968CE62F853100F0D0F0...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 7FA647CD89891DEDC060287BB9113D1ED21E1A55...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key BC1FBE4D2826A0B51E47ED62E2539214C6C11350...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 4A8B17E20B88ACA61860009B5CED81B7C2E5C0D2...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 5696C003B0854206450C8E5BE613C09CB4440678...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 8CF934E339CAD8ABF342E822E711306E3C4F88BC...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key F5A361A3A13554B85E57DDDAAF7EF7873CFD4BB6...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 5E7585ADFF106BFFBBA319DC654B877A0864983E...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 65EEFE022108E2B708CBFCF7F9E712E59AF5F22A...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 40440DC037C05620984379A6761FAD69BA06C6A9...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 34C5D94FE7E7913E86DC427E7FB1A3800C84C0A5...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 81D7F8241DB38BC759C80FCE3A726C6170E80477...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key E7210A59715F6940CF9A4E36A001876699AD6E84...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 5357F3B111688D88C1D88119FCF2CB179205AC90...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key FB871F0131FEA4FB5A9192B4C8880A6406361833...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 66BD74A036D522F51DD70A3C7F2A16726521E06D...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key B1F2C889CB2CCB2ADA36D963097D629E437520BD...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 9515D8A8EAB88E49BB65EDBCE6B456CAF15447D5...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 40776A5221EF5AD468A4906D42A1DB15EC133BAD...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key D4DE5ABDE2A7287644EAC7E36D1A9E70E19DAA50...
[2019-10-18 16:22] [ALPM-SCRIPTLET]   -> Disabling key 44D4A033AC140143927397D47EFD567D4C7EA887...
[2019-10-18 16:22] [ALPM-SCRIPTLET] ==> Updating trust database...
[2019-10-18 16:22] [ALPM-SCRIPTLET] gpg: next trustdb check due at 2019-12-30
[2019-10-18 16:23] [ALPM] transaction completed
[2019-10-18 16:23] [ALPM] running 'systemd-update.hook'...
[2019-10-18 16:23] [ALPM] transaction started
[2019-10-18 16:23] [ALPM] installed mhwd-chroot (20180408-1)
[2019-10-18 16:23] [ALPM] running 'update-desktop-database.hook'...
[2019-10-18 16:23] [PACMAN] Running 'pacman -S mhwd-chroot'
[2019-10-18 16:23] [ALPM] running '00-timeshift-autosnap.hook'...
[2019-10-18 16:23] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap because system is booted in Live CD mode...
[2019-10-18 16:23] [ALPM] reinstalled mhwd-chroot (20180408-1)
[2019-10-18 16:26] [PACMAN] Running 'pacman -Syy mhwd-chroot'
[2019-10-18 16:26] [PACMAN] synchronizing package lists
[2019-10-18 16:26] [ALPM] running '00-timeshift-autosnap.hook'...
[2019-10-18 16:26] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap because system is booted in Live CD mode...
[2019-10-18 16:26] [ALPM] transaction started
[2019-10-18 16:26] [ALPM] reinstalled mhwd-chroot (20180408-1)
[2019-10-18 16:26] [ALPM] transaction completed
[2019-10-18 16:26] [ALPM] running 'systemd-update.hook'...
[2019-10-18 16:26] [ALPM] running 'update-desktop-database.hook'...
i think i mixed up threads, @Librewish already posted that the manjaro chroot tools wont work with btrfs i guess?
Deleted last post as I hadn't included all of the log
-- Logs begin at Mon 2019-10-14 18:05:28 BST, end at Sat 2019-10-19 07:52:47 BST. --
Oct 17 18:09:18 delta kernel: ACPI Error: Needed type [Reference], found [Integer] 00000000e6f22008 (20190703/exresop-66)
Oct 17 18:09:18 delta kernel: ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [Store] (20190703/dswexec-424)
Oct 17 18:09:18 delta kernel: ACPI Error: Aborting method \_PR.CPU0._PDC due to previous error (AE_AML_OPERAND_TYPE) (20190703/psparse-529)
Oct 17 18:09:18 delta systemd[1]: connman.service: Two services allocated for the same bus name net.connman, refusing operation.
Oct 17 18:09:20 delta kernel: kvm: disabled by bios
Oct 17 18:09:20 delta connmand[1075]: Aborting (signal 11) [/usr/bin/connmand]
Oct 17 18:09:20 delta connmand[1075]: ++++++++ backtrace ++++++++
Oct 17 18:09:20 delta connmand[1075]: #0  0x7f8b1689bfb0 in /usr/lib/libc.so.6
Oct 17 18:09:20 delta connmand[1075]: #1  0x55857389dba4 in /usr/bin/connmand
Oct 17 18:09:20 delta connmand[1075]: #2  0x5585738852e9 in /usr/bin/connmand
Oct 17 18:09:20 delta connmand[1075]: #3  0x5585738f2995 in /usr/bin/connmand
Oct 17 18:09:20 delta connmand[1075]: #4  0x5585738f2b92 in /usr/bin/connmand
Oct 17 18:09:20 delta connmand[1075]: #5  0x5585738f2edd in /usr/bin/connmand
Oct 17 18:09:20 delta connmand[1075]: #6  0x5585738f4427 in /usr/bin/connmand
Oct 17 18:09:20 delta connmand[1075]: #7  0x7f8b16c3c9df in /usr/lib/libdbus-1.so.3
Oct 17 18:09:20 delta connmand[1075]: #8  0x7f8b16c3f6ba in /usr/lib/libdbus-1.so.3
Oct 17 18:09:20 delta connmand[1075]: #9  0x5585738eddb1 in /usr/bin/connmand
Oct 17 18:09:20 delta connmand[1075]: #10 0x7f8b16cde2cf in /usr/lib/libglib-2.0.so.0
Oct 17 18:09:20 delta connmand[1075]: #11 0x7f8b16ce0211 in /usr/lib/libglib-2.0.so.0
Oct 17 18:09:20 delta connmand[1075]: #12 0x7f8b16ce1123 in /usr/lib/libglib-2.0.so.0
Oct 17 18:09:20 delta connmand[1075]: #13 0x55857386437b in /usr/bin/connmand
Oct 17 18:09:20 delta connmand[1075]: #14 0x7f8b16887153 in /usr/lib/libc.so.6
Oct 17 18:09:20 delta connmand[1075]: +++++++++++++++++++++++++++
Oct 17 18:09:20 delta connmand[1425]: Failed to set domainname to Home
Oct 17 18:09:21 delta systemd[1]: connman.service: Two services allocated for the same bus name net.connman, refusing operation.
Oct 17 18:09:21 delta sddm[1393]: Failed to read display number from pipe
Oct 17 18:09:21 delta sddm[1393]: Display server failed to start. Exiting
Oct 17 18:09:21 delta systemd-coredump[1462]: Process 1393 (sddm) of user 0 dumped core.
                                              Stack trace of thread 1393:
                                              #0  0x00007ff4b40fcf25 raise (libc.so.6)
                                              #1  0x00007ff4b40e6897 abort (libc.so.6)
                                              #2  0x00007ff4b45158f8 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5)
                                              #3  0x0000561bc798c0f5 n/a (sddm)
                                              #4  0x0000561bc79d0ebe _ZN4SDDM4Seat13createDisplayEi (sddm)
                                              #5  0x0000561bc79d1102 _ZN4SDDM4SeatC2ERK7QStringP7QObject (sddm)
                                              #6  0x0000561bc79d30c1 _ZN4SDDM11SeatManager10createSeatERK7QString (sddm)
                                              #7  0x0000561bc79d3ee2 n/a (sddm)
                                              #8  0x00007ff4b474ab70 _ZN11QMetaObject8activateEP7QObjectiiPPv (libQt5Core.so.5)
                                              #9  0x0000561bc79d2130 _ZN4SDDM10LogindSeat19canGraphicalChangedEb (sddm)
                                              #10 0x0000561bc79d2443 n/a (sddm)
                                              #11 0x00007ff4b474ab70 _ZN11QMetaObject8activateEP7QObjectiiPPv (libQt5Core.so.5)
                                              #12 0x00007ff4b5151d00 _ZN23QDBusPendingCallWatcher8finishedEPS_ (libQt5DBus.so.5)
                                              #13 0x00007ff4b5151e01 n/a (libQt5DBus.so.5)
                                              #14 0x00007ff4b474b44a _ZN7QObject5eventEP6QEvent (libQt5Core.so.5)
                                              #15 0x00007ff4b471e9a0 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5)
                                              #16 0x00007ff4b4721739 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt5Core.so.5)
                                              #17 0x00007ff4b4777404 n/a (libQt5Core.so.5)
                                              #18 0x00007ff4b2f523fe g_main_context_dispatch (libglib-2.0.so.0)
                                              #19 0x00007ff4b2f54211 n/a (libglib-2.0.so.0)
                                              #20 0x00007ff4b2f54251 g_main_context_iteration (libglib-2.0.so.0)
                                              #21 0x00007ff4b4776a03 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #22 0x00007ff4b471d4ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #23 0x00007ff4b4725326 _ZN16QCoreApplication4execEv (libQt5Core.so.5)
                                              #24 0x0000561bc798f8da main (sddm)
                                              #25 0x00007ff4b40e8153 __libc_start_main (libc.so.6)
                                              #26 0x0000561bc798fbde _start (sddm)
                                              Stack trace of thread 1406:
                                              #0  0x00007ff4b41b59ef __poll (libc.so.6)
                                              #1  0x00007ff4b2f54180 n/a (libglib-2.0.so.0)
                                              #2  0x00007ff4b2f54251 g_main_context_iteration (libglib-2.0.so.0)
                                              #3  0x00007ff4b4776a03 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #4  0x00007ff4b471d4ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #5  0x00007ff4b454f385 _ZN7QThread4execEv (libQt5Core.so.5)
                                              #6  0x00007ff4b50edb37 n/a (libQt5DBus.so.5)
                                              #7  0x00007ff4b45505b0 n/a (libQt5Core.so.5)
                                              #8  0x00007ff4b40a84cf start_thread (libpthread.so.0)
                                              #9  0x00007ff4b41c02d3 __clone (libc.so.6)
Oct 17 18:09:21 delta sddm[1489]: Failed to read display number from pipe
Oct 17 18:09:21 delta sddm[1489]: Display server failed to start. Exiting
Oct 17 18:09:22 delta systemd-coredump[1495]: Process 1489 (sddm) of user 0 dumped core.
                                              Stack trace of thread 1489:
                                              #0  0x00007f460fc4cf25 raise (libc.so.6)
                                              #1  0x00007f460fc36897 abort (libc.so.6)
                                              #2  0x00007f46100658f8 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5)
                                              #3  0x00005654e19a20f5 n/a (sddm)
                                              #4  0x00005654e19e6ebe _ZN4SDDM4Seat13createDisplayEi (sddm)
                                              #5  0x00005654e19e7102 _ZN4SDDM4SeatC2ERK7QStringP7QObject (sddm)
                                              #6  0x00005654e19e90c1 _ZN4SDDM11SeatManager10createSeatERK7QString (sddm)
                                              #7  0x00005654e19e9ee2 n/a (sddm)
                                              #8  0x00007f461029ab70 _ZN11QMetaObject8activateEP7QObjectiiPPv (libQt5Core.so.5)
                                              #9  0x00005654e19e8130 _ZN4SDDM10LogindSeat19canGraphicalChangedEb (sddm)
                                              #10 0x00005654e19e8443 n/a (sddm)
                                              #11 0x00007f461029ab70 _ZN11QMetaObject8activateEP7QObjectiiPPv (libQt5Core.so.5)
                                              #12 0x00007f4610ca1d00 _ZN23QDBusPendingCallWatcher8finishedEPS_ (libQt5DBus.so.5)
                                              #13 0x00007f4610ca1e01 n/a (libQt5DBus.so.5)
                                              #14 0x00007f461029b44a _ZN7QObject5eventEP6QEvent (libQt5Core.so.5)
                                              #15 0x00007f461026e9a0 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5)
                                              #16 0x00007f4610271739 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt5Core.so.5)
                                              #17 0x00007f46102c7404 n/a (libQt5Core.so.5)
                                              #18 0x00007f460eaa23fe g_main_context_dispatch (libglib-2.0.so.0)
                                              #19 0x00007f460eaa4211 n/a (libglib-2.0.so.0)
                                              #20 0x00007f460eaa4251 g_main_context_iteration (libglib-2.0.so.0)
                                              #21 0x00007f46102c6a03 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #22 0x00007f461026d4ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #23 0x00007f4610275326 _ZN16QCoreApplication4execEv (libQt5Core.so.5)
                                              #24 0x00005654e19a58da main (sddm)
                                              #25 0x00007f460fc38153 __libc_start_main (libc.so.6)
                                              #26 0x00005654e19a5bde _start (sddm)
                                              Stack trace of thread 1490:
                                              #0  0x00007f460fd059ef __poll (libc.so.6)
                                              #1  0x00007f460eaa4180 n/a (libglib-2.0.so.0)
                                              #2  0x00007f460eaa4251 g_main_context_iteration (libglib-2.0.so.0)
                                              #3  0x00007f46102c6a03 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #4  0x00007f461026d4ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #5  0x00007f461009f385 _ZN7QThread4execEv (libQt5Core.so.5)
                                              #6  0x00007f4610c3db37 n/a (libQt5DBus.so.5)
                                              #7  0x00007f46100a05b0 n/a (libQt5Core.so.5)
                                              #8  0x00007f460fbf84cf start_thread (libpthread.so.0)
                                              #9  0x00007f460fd102d3 __clone (libc.so.6)
Oct 17 18:09:22 delta sddm[1509]: Failed to read display number from pipe
Oct 17 18:09:22 delta sddm[1509]: Display server failed to start. Exiting
Oct 17 18:09:22 delta systemd-coredump[1514]: Process 1509 (sddm) of user 0 dumped core.
                                              Stack trace of thread 1509:
                                              #0  0x00007ff9c5f59f25 raise (libc.so.6)
                                              #1  0x00007ff9c5f43897 abort (libc.so.6)
                                              #2  0x00007ff9c63728f8 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5)
                                              #3  0x0000564c149590f5 n/a (sddm)
                                              #4  0x0000564c1499debe _ZN4SDDM4Seat13createDisplayEi (sddm)
                                              #5  0x0000564c1499e102 _ZN4SDDM4SeatC2ERK7QStringP7QObject (sddm)
                                              #6  0x0000564c149a00c1 _ZN4SDDM11SeatManager10createSeatERK7QString (sddm)
                                              #7  0x0000564c149a0ee2 n/a (sddm)
                                              #8  0x00007ff9c65a7b70 _ZN11QMetaObject8activateEP7QObjectiiPPv (libQt5Core.so.5)
                                              #9  0x0000564c1499f130 _ZN4SDDM10LogindSeat19canGraphicalChangedEb (sddm)
                                              #10 0x0000564c1499f443 n/a (sddm)
                                              #11 0x00007ff9c65a7b70 _ZN11QMetaObject8activateEP7QObjectiiPPv (libQt5Core.so.5)
                                              #12 0x00007ff9c6faed00 _ZN23QDBusPendingCallWatcher8finishedEPS_ (libQt5DBus.so.5)
                                              #13 0x00007ff9c6faee01 n/a (libQt5DBus.so.5)
                                              #14 0x00007ff9c65a844a _ZN7QObject5eventEP6QEvent (libQt5Core.so.5)
                                              #15 0x00007ff9c657b9a0 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5)
                                              #16 0x00007ff9c657e739 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt5Core.so.5)
                                              #17 0x00007ff9c65d4404 n/a (libQt5Core.so.5)
                                              #18 0x00007ff9c4daf3fe g_main_context_dispatch (libglib-2.0.so.0)
                                              #19 0x00007ff9c4db1211 n/a (libglib-2.0.so.0)
                                              #20 0x00007ff9c4db1251 g_main_context_iteration (libglib-2.0.so.0)
                                              #21 0x00007ff9c65d3a03 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #22 0x00007ff9c657a4ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #23 0x00007ff9c6582326 _ZN16QCoreApplication4execEv (libQt5Core.so.5)
                                              #24 0x0000564c1495c8da main (sddm)
                                              #25 0x00007ff9c5f45153 __libc_start_main (libc.so.6)
                                              #26 0x0000564c1495cbde _start (sddm)
                                              Stack trace of thread 1510:
                                              #0  0x00007ff9c60129ef __poll (libc.so.6)
                                              #1  0x00007ff9c4db1180 n/a (libglib-2.0.so.0)
                                              #2  0x00007ff9c4db1251 g_main_context_iteration (libglib-2.0.so.0)
                                              #3  0x00007ff9c65d3a03 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #4  0x00007ff9c657a4ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #5  0x00007ff9c63ac385 _ZN7QThread4execEv (libQt5Core.so.5)
                                              #6  0x00007ff9c6f4ab37 n/a (libQt5DBus.so.5)
                                              #7  0x00007ff9c63ad5b0 n/a (libQt5Core.so.5)
                                              #8  0x00007ff9c5f054cf start_thread (libpthread.so.0)
                                              #9  0x00007ff9c601d2d3 __clone (libc.so.6)
Oct 17 18:09:23 delta sddm[1520]: Failed to read display number from pipe
Oct 17 18:09:23 delta sddm[1520]: Display server failed to start. Exiting
Oct 17 18:09:23 delta systemd-coredump[1525]: Process 1520 (sddm) of user 0 dumped core.
                                              Stack trace of thread 1520:
                                              #0  0x00007fefcd8def25 raise (libc.so.6)
                                              #1  0x00007fefcd8c8897 abort (libc.so.6)
                                              #2  0x00007fefcdcf78f8 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5)
                                              #3  0x0000555ec92670f5 n/a (sddm)
                                              #4  0x0000555ec92abebe _ZN4SDDM4Seat13createDisplayEi (sddm)
                                              #5  0x0000555ec92ac102 _ZN4SDDM4SeatC2ERK7QStringP7QObject (sddm)
                                              #6  0x0000555ec92ae0c1 _ZN4SDDM11SeatManager10createSeatERK7QString (sddm)
                                              #7  0x0000555ec92aeee2 n/a (sddm)
                                              #8  0x00007fefcdf2cb70 _ZN11QMetaObject8activateEP7QObjectiiPPv (libQt5Core.so.5)
                                              #9  0x0000555ec92ad130 _ZN4SDDM10LogindSeat19canGraphicalChangedEb (sddm)
                                              #10 0x0000555ec92ad443 n/a (sddm)
                                              #11 0x00007fefcdf2cb70 _ZN11QMetaObject8activateEP7QObjectiiPPv (libQt5Core.so.5)
                                              #12 0x00007fefce933d00 _ZN23QDBusPendingCallWatcher8finishedEPS_ (libQt5DBus.so.5)
                                              #13 0x00007fefce933e01 n/a (libQt5DBus.so.5)
                                              #14 0x00007fefcdf2d44a _ZN7QObject5eventEP6QEvent (libQt5Core.so.5)
                                              #15 0x00007fefcdf009a0 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5)
                                              #16 0x00007fefcdf03739 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt5Core.so.5)
                                              #17 0x00007fefcdf59404 n/a (libQt5Core.so.5)
                                              #18 0x00007fefcc7343fe g_main_context_dispatch (libglib-2.0.so.0)
                                              #19 0x00007fefcc736211 n/a (libglib-2.0.so.0)
                                              #20 0x00007fefcc736251 g_main_context_iteration (libglib-2.0.so.0)
                                              #21 0x00007fefcdf58a03 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #22 0x00007fefcdeff4ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #23 0x00007fefcdf07326 _ZN16QCoreApplication4execEv (libQt5Core.so.5)
                                              #24 0x0000555ec926a8da main (sddm)
                                              #25 0x00007fefcd8ca153 __libc_start_main (libc.so.6)
                                              #26 0x0000555ec926abde _start (sddm)
                                              Stack trace of thread 1521:
                                              #0  0x00007fefcd9979ef __poll (libc.so.6)
                                              #1  0x00007fefcc736180 n/a (libglib-2.0.so.0)
                                              #2  0x00007fefcc736251 g_main_context_iteration (libglib-2.0.so.0)
                                              #3  0x00007fefcdf58a03 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #4  0x00007fefcdeff4ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #5  0x00007fefcdd31385 _ZN7QThread4execEv (libQt5Core.so.5)
                                              #6  0x00007fefce8cfb37 n/a (libQt5DBus.so.5)
                                              #7  0x00007fefcdd325b0 n/a (libQt5Core.so.5)
                                              #8  0x00007fefcd88a4cf start_thread (libpthread.so.0)
                                              #9  0x00007fefcd9a22d3 __clone (libc.so.6)
Oct 17 18:09:23 delta sddm[1539]: Failed to read display number from pipe
Oct 17 18:09:23 delta sddm[1539]: Display server failed to start. Exiting
Oct 17 18:09:23 delta systemd-coredump[1544]: Process 1539 (sddm) of user 0 dumped core.
                                              Stack trace of thread 1539:
                                              #0  0x00007efc779b3f25 raise (libc.so.6)
                                              #1  0x00007efc7799d897 abort (libc.so.6)
                                              #2  0x00007efc77dcc8f8 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5)
                                              #3  0x0000556a68cfe0f5 n/a (sddm)
                                              #4  0x0000556a68d42ebe _ZN4SDDM4Seat13createDisplayEi (sddm)
                                              #5  0x0000556a68d43102 _ZN4SDDM4SeatC2ERK7QStringP7QObject (sddm)
                                              #6  0x0000556a68d450c1 _ZN4SDDM11SeatManager10createSeatERK7QString (sddm)
                                              #7  0x0000556a68d45ee2 n/a (sddm)
                                              #8  0x00007efc78001b70 _ZN11QMetaObject8activateEP7QObjectiiPPv (libQt5Core.so.5)
                                              #9  0x0000556a68d44130 _ZN4SDDM10LogindSeat19canGraphicalChangedEb (sddm)
                                              #10 0x0000556a68d44443 n/a (sddm)
                                              #11 0x00007efc78001b70 _ZN11QMetaObject8activateEP7QObjectiiPPv (libQt5Core.so.5)
                                              #12 0x00007efc78a08d00 _ZN23QDBusPendingCallWatcher8finishedEPS_ (libQt5DBus.so.5)
                                              #13 0x00007efc78a08e01 n/a (libQt5DBus.so.5)
                                              #14 0x00007efc7800244a _ZN7QObject5eventEP6QEvent (libQt5Core.so.5)
                                              #15 0x00007efc77fd59a0 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5)
                                              #16 0x00007efc77fd8739 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt5Core.so.5)
                                              #17 0x00007efc7802e404 n/a (libQt5Core.so.5)
                                              #18 0x00007efc768093fe g_main_context_dispatch (libglib-2.0.so.0)
                                              #19 0x00007efc7680b211 n/a (libglib-2.0.so.0)
                                              #20 0x00007efc7680b251 g_main_context_iteration (libglib-2.0.so.0)
                                              #21 0x00007efc7802da03 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #22 0x00007efc77fd44ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #23 0x00007efc77fdc326 _ZN16QCoreApplication4execEv (libQt5Core.so.5)
                                              #24 0x0000556a68d018da main (sddm)
                                              #25 0x00007efc7799f153 __libc_start_main (libc.so.6)
                                              #26 0x0000556a68d01bde _start (sddm)
                                              Stack trace of thread 1540:
                                              #0  0x00007efc77a6c9ef __poll (libc.so.6)
                                              #1  0x00007efc7680b180 n/a (libglib-2.0.so.0)
                                              #2  0x00007efc7680b251 g_main_context_iteration (libglib-2.0.so.0)
                                              #3  0x00007efc7802da03 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #4  0x00007efc77fd44ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #5  0x00007efc77e06385 _ZN7QThread4execEv (libQt5Core.so.5)
                                              #6  0x00007efc789a4b37 n/a (libQt5DBus.so.5)
                                              #7  0x00007efc77e075b0 n/a (libQt5Core.so.5)
                                              #8  0x00007efc7795f4cf start_thread (libpthread.so.0)
                                              #9  0x00007efc77a772d3 __clone (libc.so.6)
Oct 17 18:09:24 delta sddm[1558]: Failed to read display number from pipe
Oct 17 18:09:24 delta sddm[1558]: Display server failed to start. Exiting
Oct 17 18:09:24 delta systemd-coredump[1563]: Process 1558 (sddm) of user 0 dumped core.
                                              Stack trace of thread 1558:
                                              #0  0x00007fc3a31eef25 raise (libc.so.6)
                                              #1  0x00007fc3a31d8897 abort (libc.so.6)
                                              #2  0x00007fc3a36078f8 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5)
                                              #3  0x00005613c26410f5 n/a (sddm)
                                              #4  0x00005613c2685ebe _ZN4SDDM4Seat13createDisplayEi (sddm)
                                              #5  0x00005613c2686102 _ZN4SDDM4SeatC2ERK7QStringP7QObject (sddm)
                                              #6  0x00005613c26880c1 _ZN4SDDM11SeatManager10createSeatERK7QString (sddm)
                                              #7  0x00005613c2688ee2 n/a (sddm)
                                              #8  0x00007fc3a383cb70 _ZN11QMetaObject8activateEP7QObjectiiPPv (libQt5Core.so.5)
                                              #9  0x00005613c2687130 _ZN4SDDM10LogindSeat19canGraphicalChangedEb (sddm)
                                              #10 0x00005613c2687443 n/a (sddm)
                                              #11 0x00007fc3a383cb70 _ZN11QMetaObject8activateEP7QObjectiiPPv (libQt5Core.so.5)
                                              #12 0x00007fc3a4243d00 _ZN23QDBusPendingCallWatcher8finishedEPS_ (libQt5DBus.so.5)
                                              #13 0x00007fc3a4243e01 n/a (libQt5DBus.so.5)
                                              #14 0x00007fc3a383d44a _ZN7QObject5eventEP6QEvent (libQt5Core.so.5)
                                              #15 0x00007fc3a38109a0 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5)
                                              #16 0x00007fc3a3813739 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt5Core.so.5)
                                              #17 0x00007fc3a3869404 n/a (libQt5Core.so.5)
                                              #18 0x00007fc3a20443fe g_main_context_dispatch (libglib-2.0.so.0)
                                              #19 0x00007fc3a2046211 n/a (libglib-2.0.so.0)
                                              #20 0x00007fc3a2046251 g_main_context_iteration (libglib-2.0.so.0)
                                              #21 0x00007fc3a3868a03 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #22 0x00007fc3a380f4ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #23 0x00007fc3a3817326 _ZN16QCoreApplication4execEv (libQt5Core.so.5)
                                              #24 0x00005613c26448da main (sddm)
                                              #25 0x00007fc3a31da153 __libc_start_main (libc.so.6)
                                              #26 0x00005613c2644bde _start (sddm)
                                              Stack trace of thread 1559:
                                              #0  0x00007fc3a32a79ef __poll (libc.so.6)
                                              #1  0x00007fc3a2046180 n/a (libglib-2.0.so.0)
                                              #2  0x00007fc3a2046251 g_main_context_iteration (libglib-2.0.so.0)
                                              #3  0x00007fc3a3868a03 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #4  0x00007fc3a380f4ec _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5)
                                              #5  0x00007fc3a3641385 _ZN7QThread4execEv (libQt5Core.so.5)
                                              #6  0x00007fc3a41dfb37 n/a (libQt5DBus.so.5)
                                              #7  0x00007fc3a36425b0 n/a (libQt5Core.so.5)
                                              #8  0x00007fc3a319a4cf start_thread (libpthread.so.0)
                                              #9  0x00007fc3a32b22d3 __clone (libc.so.6)
Oct 17 18:09:24 delta systemd[1]: Failed to start Simple Desktop Display Manager.
Oct 19 07:41:53 delta kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
Oct 19 07:42:02 delta connmand[1425]: Failed to find URL:http://ipv6.connman.net/online/status.html
Oct 19 07:42:04 delta connmand[1425]: Failed to find URL:http://ipv6.connman.net/online/status.html
And now the pacman log
sh-5.0# tail -300 /var/log/pacman.log
[2019-10-14 20:29] [ALPM] upgraded at-spi2-atk (2.34.0-1 -> 2.34.1-1)
[2019-10-14 20:29] [ALPM] upgraded librsvg (2:2.46.0-1 -> 2:2.46.1-1)
[2019-10-14 20:29] [ALPM] upgraded libelf (0.176-1 -> 0.177-1)
[2019-10-14 20:29] [ALPM] upgraded llvm-libs (8.0.1-3 -> 9.0.0-3)
[2019-10-14 20:29] [ALPM] upgraded libglvnd (1.1.1-1 -> 1.2.0-2)
[2019-10-14 20:29] [ALPM] upgraded mesa (19.1.6-2 -> 19.2.1-1)
[2019-10-14 20:29] [ALPM] upgraded sqlite (3.29.0-1 -> 3.30.1-1)
[2019-10-14 20:29] [ALPM] upgraded kbd (2.2.0-3 -> 2.2.0-4)
[2019-10-14 20:29] [ALPM] upgraded libnl (3.4.0-1 -> 3.5.0-1)
[2019-10-14 20:29] [ALPM] upgraded libpcap (1.9.0-1 -> 1.9.1-1)
[2019-10-14 20:29] [ALPM] upgraded coreutils (8.31-1 -> 8.31-2)
[2019-10-14 20:29] [ALPM] upgraded systemd (242.108-1 -> 242.135-1)
[2019-10-14 20:29] [ALPM] upgraded colord (1.4.4-2 -> 1.4.4+9+g1ce26da-1)
[2019-10-14 20:29] [ALPM] upgraded gtk-update-icon-cache (1:3.24.11-1 -> 1:3.24.12-1)
[2019-10-14 20:29] [ALPM] upgraded tar (1.32-1 -> 1.32-2)
[2019-10-14 20:29] [ALPM] upgraded libtool (2.4.6+42+gb88cebd5-5 -> 2.4.6+42+gb88cebd5-6)
[2019-10-14 20:29] [ALPM] upgraded libtasn1 (4.14-1 -> 4.14-2)
[2019-10-14 20:29] [ALPM] upgraded p11-kit (0.23.17-2 -> 0.23.18.1-1)
[2019-10-14 20:29] [ALPM] upgraded gnutls (3.6.9-1 -> 3.6.10-1)
[2019-10-14 20:29] [ALPM] upgraded glib-networking (2.62.0-1 -> 2.62.1-1)
[2019-10-14 20:29] [ALPM] upgraded libsoup (2.68.1-1 -> 2.68.2-1)
[2019-10-14 20:29] [ALPM] upgraded gtk3 (1:3.24.11-1 -> 1:3.24.12-1)
[2019-10-14 20:29] [ALPM] upgraded gcab (1.2-1 -> 1.3-1)
[2019-10-14 20:29] [ALPM] upgraded libssh2 (1.8.2-1 -> 1.9.0-1)
[2019-10-14 20:29] [ALPM] upgraded ca-certificates-mozilla (3.46-1 -> 3.46.1-1)
[2019-10-14 20:29] [ALPM] upgraded python (3.7.4-1 -> 3.7.4-2)
[2019-10-14 20:29] [ALPM] upgraded appstream-glib (0.7.15-1 -> 0.7.16-1)
[2019-10-14 20:29] [ALPM] upgraded archlinux-appstream-data (20190825-1 -> 20190925-1)
[2019-10-14 20:29] [ALPM] upgraded binutils (2.32-2 -> 2.32-3)
[2019-10-14 20:29] [ALPM] upgraded libical (3.0.5-1 -> 3.0.6-1)
[2019-10-14 20:29] [ALPM] upgraded bluez (5.50-7 -> 5.51-2)
[2019-10-14 20:29] [ALPM] upgraded nss (3.46-1 -> 3.46.1-1)
[2019-10-14 20:29] [ALPM] upgraded poppler (0.80.0-1 -> 0.80.0-2)
[2019-10-14 20:29] [ALPM] upgraded qpdf (9.0.0-1 -> 9.0.1-1)
[2019-10-14 20:29] [ALPM] upgraded imagemagick (7.0.8.64-1 -> 7.0.8.68-1)
[2019-10-14 20:29] [ALPM] upgraded liblouis (3.10.0-1 -> 3.11.0-1)
[2019-10-14 20:29] [ALPM] upgraded cups-filters (1.25.5-1 -> 1.25.11-1)
[2019-10-14 20:29] [ALPM] upgraded bluez-cups (5.50-7 -> 5.51-2)
[2019-10-14 20:29] [ALPM] upgraded bluez-libs (5.50-7 -> 5.51-2)
[2019-10-14 20:29] [ALPM] upgraded boost-libs (1.69.0-2 -> 1.71.0-2)
[2019-10-14 20:29] [ALPM] upgraded boost (1.69.0-2 -> 1.71.0-2)
[2019-10-14 20:29] [ALPM] upgraded btrfs-progs (5.2.1-1 -> 5.2.2-1)
[2019-10-14 20:29] [ALPM] upgraded libuv (1.31.0-1 -> 1.32.0-1)
[2019-10-14 20:29] [ALPM] upgraded cmake (3.15.3-2 -> 3.15.4-1)
[2019-10-14 20:29] [ALPM] upgraded colord-sane (1.4.4-2 -> 1.4.4+9+g1ce26da-1)
[2019-10-14 20:29] [ALPM] upgraded diffutils (3.7-1 -> 3.7-2)
[2019-10-14 20:29] [ALPM] upgraded glibmm (2.60.0-1 -> 2.62.0-1)
[2019-10-14 20:29] [ALPM] upgraded libwacom (1.0-1 -> 1.1-1)
[2019-10-14 20:29] [ALPM] upgraded easystroke (0.6.0-20 -> 0.6.0-21)
[2019-10-14 20:29] [ALPM] upgraded elfutils (0.176-1 -> 0.177-1)
[2019-10-14 20:29] [ALPM] upgraded enchant (2.2.6-1 -> 2.2.7-1)
[2019-10-14 20:29] [ALPM] upgraded f2fs-tools (1.12.0-2 -> 1.13.0-1)
[2019-10-14 20:29] [ALPM] upgraded zita-alsa-pcmi (0.3.2-1 -> 0.3.2-2)
[2019-10-14 20:29] [ALPM] upgraded zita-resampler (1.6.2-1 -> 1.6.2-2)
[2019-10-14 20:29] [ALPM] upgraded jack (0.125.0-7 -> 0.125.0-8)
[2019-10-14 20:29] [ALPM] upgraded vulkan-icd-loader (1.1.121-1 -> 1.1.123-1)
[2019-10-14 20:29] [ALPM] upgraded ffmpeg (1:4.2.1-1 -> 1:4.2.1-2)
[2019-10-14 20:29] [ALPM] upgraded file (5.37-2 -> 5.37-3)
[2019-10-14 20:29] [ALPM] upgraded gstreamer (1.16.0-2 -> 1.16.1-1)
[2019-10-14 20:29] [ALPM] upgraded gst-plugins-base-libs (1.16.0-3 -> 1.16.1-1)
[2019-10-14 20:29] [ALPM] upgraded gst-plugins-base (1.16.0-3 -> 1.16.1-1)
[2019-10-14 20:29] [ALPM] upgraded xfsprogs (4.20.0-2 -> 5.2.1-1)
[2019-10-14 20:29] [ALPM] upgraded filelight (19.08.1-1 -> 19.08.2-1)
[2019-10-14 20:29] [ALPM] upgraded noto-fonts (20190111-2 -> 20190926-2)
[2019-10-14 20:29] [ALPM] upgraded firefox (69.0.1-0.1 -> 69.0.3-1)
[2019-10-14 20:29] [ALPM] upgraded firefox-extension-privacybadger (2019.7.1.1-1 -> 2019.9.23-1)
[2019-10-14 20:29] [ALPM] upgraded firefox-ublock-origin (1.22.2-1 -> 1.22.4-1)
[2019-10-14 20:29] [ALPM] upgraded flashplugin (32.0.0.255-1 -> 32.0.0.270-1)
[2019-10-14 20:29] [ALPM] upgraded freeglut (3.0.0-2 -> 3.2.1-1)
[2019-10-14 20:29] [ALPM] upgraded fuse-common (3.6.2-1 -> 3.7.0-1)
[2019-10-14 20:29] [ALPM] upgraded fuse2 (2.9.9-1 -> 2.9.9-3)
[2019-10-14 20:29] [ALPM] upgraded fuse3 (3.6.2-1 -> 3.7.0-1)
[2019-10-14 20:29] [ALPM] upgraded gc (7.6.8-1 -> 8.0.4-2)
[2019-10-14 20:29] [ALPM] upgraded gcc (9.1.0-2 -> 9.2.0-2)
[2019-10-14 20:29] [ALPM] upgraded geoclue (2.5.3-2 -> 2.5.5-2)
[2019-10-14 20:29] [ALPM] upgraded grep (3.3-1 -> 3.3-2)
[2019-10-14 20:29] [ALPM] upgraded gst-libav (1.16.0-1 -> 1.16.1-1)
[2019-10-14 20:29] [ALPM] upgraded libfdk-aac (2.0.0-1 -> 2.0.1-1)
[2019-10-14 20:29] [ALPM] upgraded twolame (0.3.13-8 -> 0.3.13-9)
[2019-10-14 20:29] [ALPM] upgraded gst-plugins-good (1.16.0-1 -> 1.16.1-1)
[2019-10-14 20:29] [ALPM] upgraded sdl (1.2.15-10 -> 1.2.15-13)
[2019-10-14 20:29] [ALPM] upgraded gst-plugins-bad (1.16.0-5 -> 1.16.1-1)
[2019-10-14 20:29] [ALPM] upgraded gst-plugins-espeak (0.5.0-1 -> 0.5.0-2)
[2019-10-14 20:29] [ALPM] upgraded gst-plugins-ugly (1.16.0-1 -> 1.16.1-1)
[2019-10-14 20:29] [ALPM] upgraded python-msgpack (0.6.1-1 -> 0.6.2-1)
[2019-10-14 20:29] [ALPM] upgraded python-packaging (19.1-2 -> 19.2-2)
[2019-10-14 20:29] [ALPM] upgraded python-urllib3 (1.25.3-1 -> 1.25.5-1)
[2019-10-14 20:29] [ALPM] upgraded python-importlib-metadata (0.22-1 -> 0.23-1)
[2019-10-14 20:29] [ALPM] upgraded python-pip (19.2.3-1.2 -> 19.2.3-1.5)
[2019-10-14 20:29] [ALPM] upgraded guiscrcpy-git (v1.10.2.r6.6bad4f6-1 -> 1:nightly.r5.b48a7e7-1)
[2019-10-14 20:29] [ALPM] upgraded less (551-1 -> 551-2)
[2019-10-14 20:29] [ALPM] upgraded gzip (1.10-1 -> 1.10-2)
[2019-10-14 20:29] [ALPM] upgraded harfbuzz-icu (2.6.1-1 -> 2.6.2-1)
[2019-10-14 20:29] [ALPM] upgraded haveged (1.9.6-3 -> 1.9.8-1)
[2019-10-14 20:29] [ALPM] upgraded intel-ucode (20190618-1 -> 20190918-1)
[2019-10-14 20:29] [ALPM] upgraded iproute2 (5.2.0-1 -> 5.3.0-1)
[2019-10-14 20:29] [ALPM] upgraded iputils (20180629.f6aac8d-4 -> 20190709-1)
[2019-10-14 20:29] [ALPM] upgraded iwd (0.20-3 -> 0.21-1)
[2019-10-14 20:29] [ALPM] upgraded jre-openjdk-headless (12.0.2.u10-1 -> 13.u33-1)
[2019-10-14 20:29] [ALPM] upgraded jre-openjdk (12.0.2.u10-1 -> 13.u33-1)
[2019-10-14 20:29] [ALPM] upgraded jdk-openjdk (12.0.2.u10-1 -> 13.u33-1)
[2019-10-14 20:29] [ALPM] upgraded kio-extras (19.08.1-1 -> 19.08.2-1)
[2019-10-14 20:29] [ALPM] upgraded phonon-qt5 (4.11.0-1 -> 4.11.1-1)
[2019-10-14 20:29] [ALPM] upgraded krdc (19.08.1-1 -> 19.08.2-1)
[2019-10-14 20:29] [ALPM] upgraded pipewire (0.2.6+1+g37613b67-1 -> 0.2.7-1)
[2019-10-14 20:29] [ALPM] upgraded krfb (19.08.1-1 -> 19.08.2-1)
[2019-10-14 20:29] [ALPM] upgraded kvantum-qt5 (0.11.2-1 -> 0.12.1-1)
[2019-10-14 20:29] [ALPM] upgraded kwin-decoration-sierra-breeze-enhanced-git (r65.60ba57d-1 -> r70.aeacd33-1)
[2019-10-14 20:29] [ALPM] upgraded lib32-glibc (2.29-4 -> 2.30-1)
[2019-10-14 20:29] [ALPM] upgraded lib32-gcc-libs (9.1.0-2 -> 9.2.0-2)
[2019-10-14 20:29] [ALPM] upgraded lib32-libvorbis (1.3.6-1 -> 1.3.6-1.1)
[2019-10-14 20:29] [ALPM] upgraded lib32-libx11 (1.6.8-1 -> 1.6.9-1)
[2019-10-14 20:29] [ALPM] upgraded lib32-systemd (242.108-1 -> 242.135-1)
[2019-10-14 20:29] [ALPM] upgraded libcmis (0.5.2-2 -> 0.5.2-3)
[2019-10-14 20:29] [ALPM] upgraded libixion (0.14.1-2 -> 0.14.1-3)
[2019-10-14 20:29] [ALPM] upgraded libksane (19.08.1-1 -> 19.08.2-1)
[2019-10-14 20:29] [ALPM] upgraded liblangtag (0.6.2-2 -> 0.6.3-1)
[2019-10-14 20:29] [ALPM] upgraded libmediainfo (19.07-1 -> 19.09-1)
[2019-10-14 20:29] [ALPM] upgraded liborcus (0.14.1-2 -> 0.14.1-3)
[2019-10-14 20:29] [ALPM] upgraded libqmi (1.22.6-1 -> 1.24.0-1)
[2019-10-14 20:30] [ALPM] upgraded libreoffice-fresh (6.3.1-1 -> 6.3.2-2)
[2019-10-14 20:30] [ALPM] upgraded libtorrent-rasterbar (1:1.1.13-1 -> 1:1.1.13-2)
[2019-10-14 20:30] [ALPM] upgraded libwpe (1.3.91-1 -> 1.4.0-1)
[2019-10-14 20:30] [ALPM] upgraded linux-firmware (20190815.07b925b-1 -> 20190926.c0590d8-1)
[2019-10-14 20:30] [ALPM] upgraded mkinitcpio (25-2 -> 26-1)
[2019-10-14 20:30] [ALPM] upgraded linux53 (5.3.0-0 -> 5.3.6-1)
[2019-10-14 20:30] [ALPM] upgraded linux53-headers (5.3.0-0 -> 5.3.6-1)
[2019-10-14 20:30] [ALPM] upgraded lxqt-globalkeys (0.14.1-1 -> 0.14.2-1)
[2019-10-14 20:30] [ALPM] upgraded man-pages (5.02-1 -> 5.03-1)
[2019-10-14 20:30] [ALPM] upgraded qps-git (r266.5b392e9-1 -> r312.6fa69e9-1)
[2019-10-14 20:30] [ALPM] upgraded mojave-gtk-theme-git (240.6d12906-1 -> 245.84222c0-1)
[2019-10-14 20:30] [ALPM] upgraded nohang-git (0.1.r477.g286ed84-1 -> 0.1.r499.g2a3209c-1)
[2019-10-14 20:30] [ALPM] upgraded sddm-theme-sugar-candy-git (r30.9cbdbc2-1 -> r31.e1a1b42-1)
[2019-10-14 20:30] [ALPM] upgraded manjarowish-lxqt-kwin-dark-coreapps-settings (0.1-2 -> 0.1-4)
[2019-10-14 20:30] [ALPM-SCRIPTLET] Created symlink /etc/systemd/system/multi-user.target.wants/grub-btrfs.path → /usr/lib/systemd/system/grub-btrfs.path.
[2019-10-14 20:30] [ALPM-SCRIPTLET] Created symlink /etc/systemd/system/timers.target.wants/fstrim.timer → /usr/lib/systemd/system/fstrim.timer.
[2019-10-14 20:30] [ALPM-SCRIPTLET] ==> services enabled.
[2019-10-14 20:30] [ALPM] upgraded mesa-demos (8.4.0-1 -> 8.4.0-2)
[2019-10-14 20:30] [ALPM] installed mujs (1.0.6-1)
[2019-10-14 20:30] [ALPM] upgraded mpv (1:0.29.1-8 -> 1:0.29.1-11)
[2019-10-14 20:30] [ALPM] upgraded nano (4.4-1 -> 4.5-1)
[2019-10-14 20:30] [ALPM] upgraded noto-fonts-emoji (20180810-2 -> 20190810-1)
[2019-10-14 20:30] [ALPM] upgraded openresolv (3.9.1-1 -> 3.9.2-1)
[2019-10-14 20:30] [ALPM] upgraded openssh (8.0p1-2 -> 8.1p1-1)
[2019-10-14 20:30] [ALPM] upgraded vte-common (0.58.0-1 -> 0.58.2-1)
[2019-10-14 20:30] [ALPM] upgraded vte3 (0.58.0-1 -> 0.58.2-1)
[2019-10-14 20:30] [ALPM] upgraded pamac-common (8.0.4-7 -> 9.0.0-3)
[2019-10-14 20:30] [ALPM] upgraded pamac-cli (8.0.4-7 -> 9.0.0-3)
[2019-10-14 20:30] [ALPM] upgraded pamac-gtk (8.0.4-7 -> 9.0.0-3)
[2019-10-14 20:30] [ALPM] upgraded perl-alien-build (1.86-1 -> 1.89-1)
[2019-10-14 20:30] [ALPM] upgraded poppler-qt5 (0.80.0-1 -> 0.80.0-2)
[2019-10-14 20:30] [ALPM] upgraded python-attrs (19.1.0-1 -> 19.2.0-1)
[2019-10-14 20:30] [ALPM] upgraded sed (4.7-1 -> 4.7-2)
[2019-10-14 20:30] [ALPM] upgraded system-config-printer (1.5.11-4 -> 1.5.12-1)
[2019-10-14 20:30] [ALPM] upgraded systemd-sysvcompat (242.108-1 -> 242.135-1)
[2019-10-14 20:30] [ALPM] upgraded thunderbird (68.1.0-1 -> 68.1.2-0)
[2019-10-14 20:30] [ALPM] upgraded timeshift (19.08.1-2 -> 19.08.1-3)
[2019-10-14 20:30] [ALPM-SCRIPTLET] ==> Attempting to enable Cronie services...
[2019-10-14 20:30] [ALPM] upgraded wpebackend-fdo (1.3.91-1 -> 1.4.0-1)
[2019-10-14 20:30] [ALPM] upgraded xdg-dbus-proxy (0.1.1-1 -> 0.1.2-1)
[2019-10-14 20:30] [ALPM] upgraded webkit2gtk (2.26.0-1 -> 2.26.1-1.1)
[2019-10-14 20:30] [ALPM] upgraded which (2.21-3 -> 2.21-4)
[2019-10-14 20:30] [ALPM] upgraded wireless-regdb (2019.03.01-1 -> 2019.06.03-1)
[2019-10-14 20:30] [ALPM] upgraded youtube-dl (2019.09.12.1-1 -> 2019.09.28-1)
[2019-10-14 20:30] [ALPM] transaction completed
[2019-10-14 20:30] [ALPM] running '20-systemd-sysusers.hook'...
[2019-10-14 20:30] [ALPM] running '60-linux53.hook'...
[2019-10-14 20:30] [ALPM] running '90-linux53.hook'...
[2019-10-14 20:30] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux53.preset: 'default'
[2019-10-14 20:30] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-5.3-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.3-x86_64.img
[2019-10-14 20:30] [ALPM-SCRIPTLET] ==> Starting build: 5.3.6-1-MANJARO
[2019-10-14 20:30] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2019-10-14 20:30] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2019-10-14 20:30] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2019-10-14 20:30] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2019-10-14 20:30] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2019-10-14 20:30] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2019-10-14 20:30] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2019-10-14 20:30] [ALPM-SCRIPTLET]   -> Running build hook: [resume]
[2019-10-14 20:30] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2019-10-14 20:30] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2019-10-14 20:30] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.3-x86_64.img
[2019-10-14 20:30] [ALPM-SCRIPTLET] ==> Image generation successful
[2019-10-14 20:30] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux53.preset: 'fallback'
[2019-10-14 20:30] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-5.3-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.3-x86_64-fallback.img -S autodetect
[2019-10-14 20:30] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.3-x86_64-fallback.img
[2019-10-14 20:30] [ALPM] running '99-grub.hook'...
[2019-10-14 20:30] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2019-10-14 20:30] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2019-10-14 20:30] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.3-x86_64
[2019-10-14 20:30] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.3-x86_64.img
[2019-10-14 20:30] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.3-x86_64-fallback.img
[2019-10-14 20:31] [ALPM-SCRIPTLET] Found Parrot 4.5 (4.5) on /dev/sda2
[2019-10-14 20:31] [ALPM-SCRIPTLET] ###### - Grub-btrfs: Snapshot detection started - ######
[2019-10-14 20:31] [ALPM-SCRIPTLET] # Info: Separate boot partition not detected
[2019-10-14 20:31] [ALPM-SCRIPTLET] # Found snapshot: 2019-10-14 20:28:39 | timeshift-btrfs/snapshots/2019-10-14_20-28-39/@
[2019-10-14 20:31] [ALPM-SCRIPTLET] # Found snapshot: 2019-10-14 20:12:30 | timeshift-btrfs/snapshots/2019-10-14_20-12-30/@
[2019-10-14 20:31] [ALPM-SCRIPTLET] # Found snapshot: 2019-10-14 20:08:39 | timeshift-btrfs/snapshots/2019-10-14_20-08-39/@
[2019-10-14 20:31] [ALPM-SCRIPTLET] # Found 3 snapshot(s)
[2019-10-14 20:31] [ALPM-SCRIPTLET] ###### - Grub-btrfs: Snapshot detection ended   - ######
[2019-10-14 20:31] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2019-10-14 20:31] [ALPM-SCRIPTLET] done
[2019-10-14 20:31] [ALPM] running 'dbus-reload.hook'...
[2019-10-14 20:31] [ALPM] running 'detect-old-perl-modules.hook'...
[2019-10-14 20:31] [ALPM] running 'fontconfig.hook'...
[2019-10-14 20:31] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2019-10-14 20:31] [ALPM] running 'gio-querymodules.hook'...
[2019-10-14 20:31] [ALPM] running 'glib-compile-schemas.hook'...
[2019-10-14 20:31] [ALPM] running 'gtk-query-immodules-3.0.hook'...
[2019-10-14 20:31] [ALPM] running 'gtk-update-icon-cache.hook'...
[2019-10-14 20:31] [ALPM] running 'kernel-alive-post.hook'...
[2019-10-14 20:31] [ALPM-SCRIPTLET] ==> Warning:
[2019-10-14 20:31] [ALPM-SCRIPTLET]      -> Kernel has been updated. Modules of the current kernel
[2019-10-14 20:31] [ALPM-SCRIPTLET]      -> have been backed up so you can continue to use your
[2019-10-14 20:31] [ALPM-SCRIPTLET]      -> computer. However, the new kernel will only work
[2019-10-14 20:31] [ALPM-SCRIPTLET]      -> at next boot.
[2019-10-14 20:31] [ALPM] running 'systemd-catalog.hook'...
[2019-10-14 20:31] [ALPM] running 'systemd-daemon-reload.hook'...
[2019-10-14 20:31] [ALPM] running 'systemd-hwdb.hook'...
[2019-10-14 20:31] [ALPM] running 'systemd-sysctl.hook'...
[2019-10-14 20:31] [ALPM] running 'systemd-tmpfiles.hook'...
[2019-10-14 20:31] [ALPM] running 'systemd-udev-reload.hook'...
[2019-10-14 20:31] [ALPM] running 'systemd-update.hook'...
[2019-10-14 20:31] [ALPM] running 'texinfo-install.hook'...
[2019-10-14 20:31] [ALPM] running 'update-ca-trust.hook'...
[2019-10-14 20:31] [ALPM] running 'update-desktop-database.hook'...
[2019-10-14 20:31] [ALPM] running 'update-mime-database.hook'...
[2019-10-14 20:31] [ALPM] running 'xorg-mkfontscale.hook'...
[2019-10-16 17:21] [PACMAN] Running 'pacman -Syyu'
[2019-10-16 17:21] [PACMAN] synchronizing package lists
[2019-10-16 17:21] [PACMAN] starting full system upgrade
[2019-10-16 17:21] [ALPM] running '00-timeshift-autosnap.hook'...
[2019-10-16 17:21] [ALPM-SCRIPTLET] First run mode (config file not found)
[2019-10-16 17:21] [ALPM-SCRIPTLET] Selected default snapshot type: BTRFS
[2019-10-16 17:21] [ALPM-SCRIPTLET] Using system disk as snapshot device for creating snapshots in BTRFS mode
[2019-10-16 17:21] [ALPM-SCRIPTLET] Mounted '/dev/sda1' at '/mnt/timeshift/backup'
[2019-10-16 17:21] [ALPM-SCRIPTLET] Creating new backup...(BTRFS)
[2019-10-16 17:21] [ALPM-SCRIPTLET] Saving to device: /dev/sda1, mounted at path: /mnt/timeshift/backup
[2019-10-16 17:21] [ALPM-SCRIPTLET] Created directory: /mnt/timeshift/backup/timeshift-btrfs/snapshots/2019-10-16_17-21-26
[2019-10-16 17:21] [ALPM-SCRIPTLET] Created subvolume snapshot: /mnt/timeshift/backup/timeshift-btrfs/snapshots/2019-10-16_17-21-26/@
[2019-10-16 17:21] [ALPM-SCRIPTLET] Created control file: /mnt/timeshift/backup/timeshift-btrfs/snapshots/2019-10-16_17-21-26/info.json
[2019-10-16 17:21] [ALPM-SCRIPTLET] BTRFS Snapshot saved successfully (0s)
[2019-10-16 17:21] [ALPM-SCRIPTLET] Tagged snapshot '2019-10-16_17-21-26': ondemand
[2019-10-16 17:21] [ALPM-SCRIPTLET] ------------------------------------------------------------------------------
[2019-10-16 17:21] [ALPM-SCRIPTLET] /dev/sda1 is mounted at: /mnt/timeshift/backup, options: rw,relatime,compress=zstd:3,ssd_spread,space_cache,autodefrag,subvolid=5,subvol=/
[2019-10-16 17:21] [ALPM-SCRIPTLET] Selected default snapshot device: /dev/sda1
[2019-10-16 17:21] [ALPM-SCRIPTLET] Removing snapshot: 2019-10-14_20-08-39
[2019-10-16 17:21] [ALPM-SCRIPTLET] Deleting subvolume: @ (Id:266)
[2019-10-16 17:21] [ALPM-SCRIPTLET] Deleted subvolume: @ (Id:266)
[2019-10-16 17:21] [ALPM-SCRIPTLET] Destroying qgroup: 0/266
[2019-10-16 17:21] [ALPM-SCRIPTLET] Destroyed qgroup: 0/266
[2019-10-16 17:21] [ALPM-SCRIPTLET] Deleted directory: /mnt/timeshift/backup/timeshift-btrfs/snapshots/2019-10-14_20-08-39
[2019-10-16 17:21] [ALPM-SCRIPTLET] Removed snapshot: 2019-10-14_20-08-39
[2019-10-16 17:21] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2019-10-16 17:21] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2019-10-16 17:21] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.3-x86_64
[2019-10-16 17:21] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.3-x86_64.img
[2019-10-16 17:21] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.3-x86_64-fallback.img
[2019-10-16 17:21] [ALPM-SCRIPTLET] Found Parrot 4.5 (4.5) on /dev/sda2
[2019-10-16 17:21] [ALPM-SCRIPTLET] ###### - Grub-btrfs: Snapshot detection started - ######
[2019-10-16 17:21] [ALPM-SCRIPTLET] # Info: Separate boot partition not detected
[2019-10-16 17:21] [ALPM-SCRIPTLET] # Found snapshot: 2019-10-16 17:21:26 | timeshift-btrfs/snapshots/2019-10-16_17-21-26/@
[2019-10-16 17:21] [ALPM-SCRIPTLET] # Found snapshot: 2019-10-14 20:28:39 | timeshift-btrfs/snapshots/2019-10-14_20-28-39/@
[2019-10-16 17:21] [ALPM-SCRIPTLET] # Found snapshot: 2019-10-14 20:12:30 | timeshift-btrfs/snapshots/2019-10-14_20-12-30/@
[2019-10-16 17:21] [ALPM-SCRIPTLET] # Found 3 snapshot(s)
[2019-10-16 17:21] [ALPM-SCRIPTLET] ###### - Grub-btrfs: Snapshot detection ended   - ######
[2019-10-16 17:21] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2019-10-16 17:21] [ALPM-SCRIPTLET] done
[2019-10-16 17:21] [ALPM] transaction started
[2019-10-16 17:21] [ALPM] upgraded sudo (1.8.27-1 -> 1.8.28-0)
[2019-10-16 17:21] [ALPM] transaction completed
[2019-10-16 17:21] [ALPM] running 'systemd-tmpfiles.hook'...
[2019-10-16 17:21] [ALPM] running 'systemd-update.hook'...
[2019-10-16 17:28] [PACMAN] Running 'pacman -Syyuu'
[2019-10-16 17:28] [PACMAN] synchronizing package lists
[2019-10-16 17:29] [PACMAN] starting full system upgrade
I'm going to wait a wee while before I run another update :crossed_fingers::crossed_fingers:
Update- latest update didn't work. Looking at the logs it would appear that the problem is related to the sddm process.
remove sddm-theme-sugar-candy-git.
then update.
Hi Librewish, thanks for your help
I tried removing sddm-theme-sugar-candy-git. as you suggested but I get the following error
checking dependencies...
:: manjarowish-lxqt-kwin-dark-coreapps-settings: removing sddm-theme-sugar-candy-git breaks dependency 'sddm-theme-sugar-candy-git'
try removing it using
sudo pacman -Rdd sddm-theme-sugar-candy-git
Unfortunately I'm still struggling with this one. Removing sddm-theme didn't help. I have reviewed the logs and its a mass of red referencing an ongoing issue with sddm :frowning_face:
