Kernel: 5.16.20-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=946d67f7-e2d1-44f8-96b2-4bf678b3bde9 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: H110M-S2H v: N/A
serial: <superuser required>
Mobo: Gigabyte model: H110M-S2H-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F22 date: 06/12/2017
Info: model: Intel Core i7-7700 bits: 64 type: MT MCP arch: Kaby Lake
family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 801 4: 800
5: 800 6: 800 7: 800 8: 800 bogomips: 57616
Type: l1tf
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ZOTAC driver: nvidia
v: 510.68.02 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Pascal pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1b81 class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.1
compositor: kwin_x11 driver: N/A note: X driver n/a display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: DP-2 res: 2560x1440 dpi: 109 size: 598x336mm (23.54x13.23")
diag: 686mm (27.01") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
v: 4.6.0 NVIDIA 510.68.02 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: ZOTAC
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Sound Server-1: ALSA v: k5.16.20-2-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: no
Sound Server-3: PipeWire v: 0.3.51 running: yes
lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Local Storage: total: 931.51 GiB used: 836.24 GiB (89.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DX002-2DV162
type: HDD rpm: 7200 serial: <filter> rev: CC41 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.6 GiB (98.32%)
used: 836.24 GiB (91.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 300 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 53 C
Processes: 265 Uptime: 3m wakeups: 0 Memory: 15.58 GiB
used: 2.17 GiB (14.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1808 pacman: 1795 lib: 472 flatpak: 0
snap: 13 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.16
when rebooting after update my pc gets stuck on the motherboard gigabyte screen that you see when the machine first boots up. Been like that for 20 minutes so I did a timeshift to previous save point.
