Naturally.
My Brave installation is the flatpak version.
This choice was made to avoid having to redo settings, extensions etc. since there apparently is no way to transfer from flatpak to the repository version without breaking Brave.
Here is the inxi output.
Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=3b202b9f-a011-44d2-b439-6ba15f18943f rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
wm: kwin_x11 with: kdocker,krunner vt: 2 dm: SDDM Distro: Manjaro
base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7C56 v: 6.0
serial: <superuser required> Chassis: type: 3 v: 6.0
Mobo: Micro-Star model: B550-A PRO (MS-7C56) v: 2.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: A.J1 date: 08/27/2024
System RAM: total: 32 GiB available: 31.27 GiB used: 11.66 GiB (37.3%)
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 16 GiB speed: 3600 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: A-DATA Technology part-no: AX4U360016G18I-DTBKD
serial: <filter>
Device-3: Channel-B DIMM 0 type: no module installed
serial: <filter>
Info: model: AMD Ryzen 5 5600 bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3588 min/max: 550/4468 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3588 2: 3588 3: 3588
4: 3588 5: 3588 6: 3588 7: 3588 8: 3588 9: 3588 10: 3588 11: 3588 12: 3588
bogomips: 84029
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT / 7800
XT] vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1,DP-3,HDMI-A-1 empty: DP-2,Writeback-1 bus-ID: 2d:00.0
chip-ID: 1002:747e class-ID: 0300
Device-2: EMEET HD Webcam C960 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:6 chip-ID: 328f:003f
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1524x285mm (60.00x11.22")
s-diag: 1550mm (61.04")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: right model: Kamvas Pro 13
built: 2020 res: 1920x1080 hz: 60 dpi: 166 gamma: 1.2 chroma: red: x: 0.639
y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white: x: 0.314
y: 0.329 size: 294x165mm (11.57x6.5") diag: 337mm (13.3") ratio: 16:9
modes: 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900, 1360x850,
1280x800, 1280x720, 1024x768, 800x600, 640x480, 720x400
Monitor-2: DP-3 mapped: DisplayPort-2 pos: center model: BenQ GL2460
serial: <filter> built: 2014 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2 chroma:
red: x: 0.643 y: 0.333 green: x: 0.333 y: 0.624 blue: x: 0.153 y: 0.047
white: x: 0.314 y: 0.329 size: 531x299mm (20.91x11.77") diag: 609mm (24")
ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900,
1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600, 640x480, 720x400
Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left model: PMOS240-IFC-1
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 133 gamma: 1.2
chroma: red: x: 0.639 y: 0.329 green: x: 0.302 y: 0.627 blue: x: 0.153
y: 0.071 white: x: 0.314 y: 0.329 size: 368x207mm (14.49x8.15")
diag: 604mm (23.8") ratio: 16:9 modes: 1920x1080, 1600x1200, 1680x1050,
1600x900, 1280x1024, 1440x900, 1280x960, 1366x768, 1280x800, 1152x864,
1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480, 640x480, 720x400
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7700 XT (radeonsi
navi32 LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO) device-ID: 1002:747e
memory: 11.72 GiB unified: no
API: Vulkan v: 1.4.303 layers: 4 device: 0 type: discrete-gpu name: AMD
Radeon RX 7700 XT (RADV NAVI32) driver: N/A device-ID: 1002:747e
surfaces: xcb,xlib
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
bus-ID: 2d:00.1 chip-ID: 1002:ab30 class-ID: 0403
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media Anua Mic 900 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3
chip-ID: 0d8c:0134 class-ID: 0300
Device-4: EMEET HD Webcam C960 driver: snd-usb-audio,uvcvideo type: USB
Device-5: Logitech G430 Surround Sound Gaming Headset
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 5-4:5 chip-ID: 046d:0a4d class-ID: 0300
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 2a:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp42s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10.3:8 chip-ID: 0b95:1790
class-ID: 0a00 serial: <filter>
IF: enp2s0f0u10u3c2 state: down mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3.2:6
chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 4.25 TiB used: 1.9 TiB (44.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: LEGEND 850
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: X0124A0 temp: 35.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM001-1CH164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC27 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT500MX500SSD1
tech: SSD serial: <filter> fw-rev: 023 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Fanxiang model: S101 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3A0 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Generic model: N/A size: 116.1 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.11 scheme: MBR
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%) used: 31.16 GiB (3.3%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 3b202b9f-a011-44d2-b439-6ba15f18943f
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 38F6-56E2
ID-3: /mnt/Beth raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 1.36 TiB (74.6%) fs: ntfs dev: /dev/sda1 maj-min: 8:1 label: Beth
uuid: 0EB4E51CB4E50755
ID-4: /mnt/Morty raw-size: 953.87 GiB size: 937.82 GiB (98.32%)
used: 520.3 GiB (55.5%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: Morty
uuid: 54a25dea-7674-41fc-a841-342fcda53b84
ID-1: swap-1 type: file size: 512 MiB used: 1024 KiB (0.2%) priority: -2
file: /swapfile
ID-1: /dev/sdd1 maj-min: 8:49 size: 116.06 GiB fs: exfat label: Ventoy
uuid: 8A35-5765
ID-2: /dev/sdd2 maj-min: 8:50 size: 32 MiB fs: vfat label: VTOYEFI
uuid: 223C-F3F8
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-5:3 info: C-Media Anua Mic 900 type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
Device-2: 1-6:4 info: Logitech G502 SE HERO Gaming Mouse type: mouse,HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c08b class-ID: 0300
serial: <filter>
Device-3: 1-7:5 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c56 class-ID: 0300
serial: <filter>
Device-4: 1-9:6 info: EMEET HD Webcam C960 type: video,audio
chip-ID: 328f:003f class-ID: 0102 serial: <filter>
Hub-3: 1-10:7 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
Device-1: 1-10.3:8 info: ASIX AX88179 Gigabit Ethernet
type: communication,CDC-data driver: cdc_ncm interfaces: 2 rev: 2.1
chip-ID: 0b95:1790 class-ID: 0a00 serial: <filter>
Device-2: 1-10.5:9 info: VIA Labs USB Billboard Device type: billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 100mA chip-ID: 2109:8817 class-ID: 1100 serial: <filter>
Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Valve Wireless Steam Controller type: keyboard,HID
driver: hid-steam,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 28de:1142 class-ID: 0300
Device-2: 3-2:13 info: SCUF Gaming PC Controller Dongle type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 2e95:5046 class-ID: 0300
serial: <filter>
Hub-6: 3-3:4 info: VIA Labs VL812 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2812
Device-1: 3-3.2:6 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-7: 3-3.3:7 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 3-3.3.3:8 info: Elgato Systems GmbH Stream Deck original V2
type: HID driver: usbfs interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0fd9:006d class-ID: 0300
serial: <filter>
Device-2: 3-3.3.4:9 info: GEMBIRD MicroSD Card Reader/Writer
type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 150mA
chip-ID: 1908:0226 class-ID: 0806
Device-3: 3-4:5 info: Tablet Monitor type: mouse driver: uclogic,usbhid
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 256c:006d class-ID: 0301
Hub-8: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
Hub-9: 4-3:2 info: VIA Labs VL812 Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0812
Hub-10: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: Licensed by Sony Entertainment America Guitar Hero
type: HID driver: sony,usbhid interfaces: 1 rev: 1.0
chip-ID: 12ba:074b class-ID: 0301 serial: <filter>
Device-2: 5-2:3 info: Keychron K10 Pro type: keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 3434:02a1 class-ID: 0300
Device-3: 5-3:4 info: Acer & Multimedia USB Composite Device type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1189:8840 class-ID: 0300
serial: <filter>
Device-4: 5-4:5 info: Logitech G430 Surround Sound Gaming Headset
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Hub-11: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 44.5 C mobo: N/A gpu: amdgpu temp: 57.0 C
mem: 62.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 51
Packages: 1298 pm: pacman pkgs: 1290 libs: 379 tools: pamac pm: flatpak
pkgs: 8
Active pacman repo servers in: /etc/pacman.conf
1: https://download.sublimetext.com/arch/stable/x86_64
1: https://mirror.easyname.at/manjaro/stable/$repo/$arch
2: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
3: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 419
1: cpu: 25.4% command: brave pid: 221472 mem: 589.0 MiB (1.8%)
2: cpu: 14.4% command: StreamController pid: 1395 mem: 509.9 MiB (1.5%)
3: cpu: 11.1% command: kwin_x11 pid: 968 mem: 311.9 MiB (0.9%)
4: cpu: 10.0% command: brave pid: 220397 mem: 364.8 MiB (1.1%)
5: cpu: 7.5% command: Xorg pid: 750 mem: 272.8 MiB (0.8%)
Memory top: 5 of 419
1: mem: 1625.5 MiB (5.0%) command: dolphin pid: 16592 cpu: 2.5%
2: mem: 1439.9 MiB (4.4%) command: pamac-manager pid: 123616 cpu: 0.5%
3: mem: 684.1 MiB (2.1%) command: plasmashell pid: 133677 cpu: 0.7%
4: mem: 589.8 MiB (1.8%) command: brave pid: 220330 cpu: 5.4%
5: mem: 589.0 MiB (1.8%) command: brave pid: 221472 cpu: 25.4%
Processes: 419 Power: uptime: 2h 39m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: guake inxi: 3.3.36
