I installed csgo clicked the play button which started it in opengl I am able to interact with the game i can hear the sound when i click any button in the game but nothing is visible its black screen at first with sound when I switch between application the application is there but i can still interact with the game any solution to this?
Thank you in advance!
I’ve seen this issue mentioned multiple times in both /r/linux_gaming and Steam discussions.
One solution I heard someone did was to just use the flatpak version of Steam to play CSGO, don’t know if it worked for everyone though.
Another solution was to use the -nojoy
launch option.
how do I do this?
Right click the game in Steam Library, and put -nojoy
in Launch Options
okay thanx i tried running it in flatpak but it’s crashing on the loading screen so i’ll try this one too.
I tried that the logo appeared nothing after that, tried the flatpak version it did start the game but when i tried playing a match it crashed all the times, the match didn’t start it was stuck on the loading screen.
