Cs go gec yuklenme ve oyun ici donma sorunu
Merhaba! Manjaro yu oyun bilgisayarima yukleyeli neredeyse 1 ay oldu, kullanisli buldum daha akici geldi bana. Windows 10 dan döndum full sistem silip manjaro yukledim. Yukledikten hemen sonra guncellemeleri yaptiktan sonra steam, lutris gibi programlari yukleyip cs go yu steam dan indirdim. Oyun akici calisiyor birkac sey disinda. cs go acilmasi windows 10 a göre cok daha yavas geldi. Oyun ici bazen birkac saniyelik donma oluyor ama hemen geciyor. Oyun icinde rekabetci olsun ölum oyunu olsun, oyunlara girdigimde haritalarin yuklenmesi uzun suruyor.
[kudret@kudret-zbek ~]$ inxi -Fxxxza --no-host
System: Kernel: 5.4.35-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0
root=UUID=2fcaf76a-130a-4297-8cd2-cb6d3dc43645 rw quiet apparmor=1 security=apparmor
resume=UUID=b22d97b6-48a5-4738-97ec-398aab2af596 udev.log_priority=3
Desktop: KDE Plasma 5.18.4 tk: Qt 5.14.2 wm: kwin_x11 dm: LightDM 1.30.0, SDDM
Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASRock model: H81M-VG4 R3.0 serial:
UEFI: American Megatrends v: P1.30 date: 03/12/2018
CPU: Topology: Quad Core model: Intel Core i5-4460 bits: 64 type: MCP arch: Haswell family: 6
model-id: 3C (60) stepping: 3 microcode: 27 L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 25602
Speed: 880 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 964 2: 984 3: 1011 4: 989
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP:
disabled, RSB filling
Graphics: Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK driver: nvidia v: 440.82
bus ID: 01:00.0 chip ID: 10de:1c82
Display: x11 server: X.Org 1.20.8 driver: nvidia compositor: kwin_x11
resolution: 1680x1050~60Hz, 1280x1024~60Hz
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 440.82 direct render: Yes
Audio: Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
Device-2: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
Device-3: Corsair Corsair Gaming H1500 Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 2-6:4 chip ID: 1b1c:1b1d
Sound Server: ALSA v: k5.4.35-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock
driver: r8169 v: kernel port: d000 bus ID: 03:00.0 chip ID: 10ec:8168
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac:
IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac:
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac:
Drives: Local Storage: total: 2.39 TiB used: 987.32 GiB (40.3%)
ID-1: /dev/sda vendor: Samsung model: MZ7TE128HMGR-000L1 size: 119.24 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: rev: 6L0Q scheme: GPT
ID-2: /dev/sdb vendor: Seagate model: ST1000DX001-1CM162 size: 931.51 GiB block size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial:
rev: CC43 scheme: MBR
ID-3: /dev/sdc vendor: Western Digital model: WD5000LPCX-24C6HT0 size: 465.76 GiB
block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm
serial: rev: 1A02 scheme: GPT
ID-4: /dev/sdd vendor: Western Digital model: WD5000LPCX-24C6HT0 size: 465.76 GiB
ID-5: /dev/sde type: USB vendor: Western Digital model: WD5000LPCX-24C6HT0
size: 465.76 GiB block size: physical: 512 B logical: 512 B rotation: 5400 rpm
serial: rev: 0107 scheme: MBR
Partition: ID-1: / raw size: 110.15 GiB size: 107.92 GiB (97.98%) used: 74.07 GiB (68.6%) fs: ext4
dev: /dev/sda2
ID-2: swap-1 size: 8.80 GiB used: 2.0 MiB (0.0%) fs: swap swappiness: 60 (default)
cache pressure: 100 (default) dev: /dev/sda3
Sensors: System Temperatures: cpu: 37.0 C mobo: 36.0 C gpu: nvidia temp: 53 C
Fan Speeds (RPM): fan-1: 1721 fan-2: 1844 fan-3: 0 fan-4: 0 fan-5: 0 gpu: nvidia fan: 0%
Voltages: 12v: N/A 5v: N/A 3.3v: 3.38 vbat: 3.33
Info: Processes: 263 Uptime: 14h 06m Memory: 15.58 GiB used: 3.90 GiB (25.0%) Init: systemd
v: 244 Compilers: gcc: 9.3.0 clang: 10.0.0 Shell: bash v: 5.0.16 running in: konsole
inxi: 3.0.37
